RTEMS 6.2
utility.h File Reference
This header file provides utility macros for BSPs. More...
#include <stdint.h>
#define BSP_BIT8(bit)    ((uint8_t) (((unsigned int) 1) << (bit)))
#define BSP_MSK8(first_bit, last_bit)    ((uint8_t) ((BSP_BIT8((last_bit) - (first_bit) + 1) - 1) << (first_bit)))
#define BSP_FLD8(val, first_bit, last_bit)
#define BSP_FLD8GET(reg, first_bit, last_bit)    ((uint8_t) (((reg) & BSP_MSK8(first_bit, last_bit)) >> (first_bit)))
#define BSP_FLD8SET(reg, val, first_bit, last_bit)
#define BSP_BIT16(bit)    ((uint16_t) (((unsigned int) 1) << (bit)))
#define BSP_MSK16(first_bit, last_bit)    ((uint16_t) ((BSP_BIT16((last_bit) - (first_bit) + 1) - 1) << (first_bit)))
#define BSP_FLD16(val, first_bit, last_bit)
#define BSP_FLD16GET(reg, first_bit, last_bit)    ((uint16_t) (((reg) & BSP_MSK16(first_bit, last_bit)) >> (first_bit)))
#define BSP_FLD16SET(reg, val, first_bit, last_bit)
#define BSP_BIT32(bit)    ((uint32_t) (((uint32_t) 1) << (bit)))
#define BSP_MSK32(first_bit, last_bit)    ((uint32_t) ((BSP_BIT32((last_bit) - (first_bit) + 1) - 1) << (first_bit)))
#define BSP_FLD32(val, first_bit, last_bit)
#define BSP_FLD32GET(reg, first_bit, last_bit)    ((uint32_t) (((reg) & BSP_MSK32(first_bit, last_bit)) >> (first_bit)))
#define BSP_FLD32SET(reg, val, first_bit, last_bit)
#define BSP_BIT64(bit)    ((uint64_t) (((uint64_t) 1) << (bit)))
#define BSP_MSK64(first_bit, last_bit)    ((uint64_t) ((BSP_BIT64((last_bit) - (first_bit) + 1) - 1) << (first_bit)))
#define BSP_FLD64(val, first_bit, last_bit)
#define BSP_FLD64GET(reg, first_bit, last_bit)    ((uint64_t) (((reg) & BSP_MSK64(first_bit, last_bit)) >> (first_bit)))
#define BSP_FLD64SET(reg, val, first_bit, last_bit)
#define BSP_BBIT8(bit)    BSP_BIT8(7 - (bit))
#define BSP_BMSK8(first_bit, last_bit)    BSP_MSK8(7 - (last_bit), 7 - (first_bit))
#define BSP_BFLD8(val, first_bit, last_bit)    BSP_FLD8(val, 7 - (last_bit), 7 - (first_bit))
#define BSP_BFLD8GET(reg, first_bit, last_bit)    BSP_FLD8GET(reg, 7 - (last_bit), 7 - (first_bit))
#define BSP_BFLD8SET(reg, val, first_bit, last_bit)    BSP_FLD8SET(reg, val, 7 - (last_bit), 7 - (first_bit))
#define BSP_BBIT16(bit)    BSP_BIT16(15 - (bit))
#define BSP_BMSK16(first_bit, last_bit)    BSP_MSK16(15 - (last_bit), 15 - (first_bit))
#define BSP_BFLD16(val, first_bit, last_bit)    BSP_FLD16(val, 15 - (last_bit), 15 - (first_bit))
#define BSP_BFLD16GET(reg, first_bit, last_bit)    BSP_FLD16GET(reg, 15 - (last_bit), 15 - (first_bit))
#define BSP_BFLD16SET(reg, val, first_bit, last_bit)    BSP_FLD16SET(reg, val, 15 - (last_bit), 15 - (first_bit))
#define BSP_BBIT32(bit)    BSP_BIT32(31 - (bit))
#define BSP_BMSK32(first_bit, last_bit)    BSP_MSK32(31 - (last_bit), 31 - (first_bit))
#define BSP_BFLD32(val, first_bit, last_bit)    BSP_FLD32(val, 31 - (last_bit), 31 - (first_bit))
#define BSP_BFLD32GET(reg, first_bit, last_bit)    BSP_FLD32GET(reg, 31 - (last_bit), 31 - (first_bit))
#define BSP_BFLD32SET(reg, val, first_bit, last_bit)    BSP_FLD32SET(reg, val, 31 - (last_bit), 31 - (first_bit))
#define BSP_BBIT64(bit)    BSP_BIT64(63 - (bit))
#define BSP_BMSK64(first_bit, last_bit)    BSP_MSK64(63 - (last_bit), 63 - (first_bit))
#define BSP_BFLD64(val, first_bit, last_bit)    BSP_FLD64(val, 63 - (last_bit), 63 - (first_bit))
#define BSP_BFLD64GET(reg, first_bit, last_bit)    BSP_FLD64GET(reg, 63 - (last_bit), 63 - (first_bit))
#define BSP_BFLD64SET(reg, val, first_bit, last_bit)    BSP_FLD64SET(reg, val, 63 - (last_bit), 63 - (first_bit))
◆ BSP_FLD16
#define BSP_FLD16 (   val,
  first_bit,
  last_bit
Value:
((uint16_t) \
((((unsigned int) (val)) << (first_bit)) & BSP_MSK16(first_bit, last_bit)))
◆ BSP_FLD16SET
#define BSP_FLD16SET (   reg,
  val,
  first_bit,
  last_bit
Value:
((uint16_t) (((reg) & ~BSP_MSK16(first_bit, last_bit)) \
| BSP_FLD16(val, first_bit, last_bit)))
◆ BSP_FLD32
#define BSP_FLD32 (   val,
  first_bit,
  last_bit
Value:
((uint32_t) \
((((uint32_t) (val)) << (first_bit)) & BSP_MSK32(first_bit, last_bit)))
◆ BSP_FLD32SET
#define BSP_FLD32SET (   reg,
  val,
  first_bit,
  last_bit
Value:
((uint32_t) (((reg) & ~BSP_MSK32(first_bit, last_bit)) \
| BSP_FLD32(val, first_bit, last_bit)))
◆ BSP_FLD64
#define BSP_FLD64 (   val,
  first_bit,
  last_bit
Value:
((uint64_t) \
((((uint64_t) (val)) << (first_bit)) & BSP_MSK64(first_bit, last_bit)))
◆ BSP_FLD64SET
#define BSP_FLD64SET (   reg,
  val,
  first_bit,
  last_bit
Value:
((uint64_t) (((reg) & ~BSP_MSK64(first_bit, last_bit)) \
| BSP_FLD64(val, first_bit, last_bit)))
◆ BSP_FLD8
#define BSP_FLD8 (   val,
  first_bit,
  last_bit
Value:
((uint8_t) \
((((unsigned int) (val)) << (first_bit)) & BSP_MSK8(first_bit, last_bit)))
◆ BSP_FLD8SET
#define BSP_FLD8SET (   reg,
  val,
  first_bit,
  last_bit
Value:
((uint8_t) (((reg) & ~BSP_MSK8(first_bit, last_bit)) \
| BSP_FLD8(val, first_bit, last_bit)))
