RTEMS 6.2
Files | Macros | Functions
Aarch64 system low level start. More...
file  aarch64-mmu.h
 AArch64 MMU configuration.
file  start.h
file  mmu-setup.c
#define BSP_START_TEXT_SECTION   __attribute__((section(".bsp_start_text")))
#define BSP_START_DATA_SECTION   __attribute__((section(".bsp_start_data")))
void _start (void)
 System start entry.
void bsp_start_hook_0 (void)
 Start entry hook 0.
void bsp_start_hook_1 (void)
 Start entry hook 1.
◆ bsp_start_hook_0()
void bsp_start_hook_0 ( void  )
Start entry hook 0.
This hook will be called from the start entry code after all modes and stack pointers are initialized but before the copying of the exception vectors.
◆ bsp_start_hook_1()
void bsp_start_hook_1 ( void  )
Start entry hook 1.
This hook will be called from the start entry code after copying of the exception vectors but before the call to boot_card().
