RTEMS 6.2
SEL0 - Crossbar A Select Register 0
#define XBARA_SEL0_SEL0_MASK   (0x7FU)
#define XBARA_SEL0_SEL0_SHIFT   (0U)
#define XBARA_SEL0_SEL0(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL0_SEL0_SHIFT)) & XBARA_SEL0_SEL0_MASK)
#define XBARA_SEL0_SEL1_MASK   (0x7F00U)
#define XBARA_SEL0_SEL1_SHIFT   (8U)
#define XBARA_SEL0_SEL1(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL0_SEL1_SHIFT)) & XBARA_SEL0_SEL1_MASK)
SEL1 - Crossbar A Select Register 1
#define XBARA_SEL1_SEL2_MASK   (0x7FU)
#define XBARA_SEL1_SEL2_SHIFT   (0U)
#define XBARA_SEL1_SEL2(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL1_SEL2_SHIFT)) & XBARA_SEL1_SEL2_MASK)
#define XBARA_SEL1_SEL3_MASK   (0x7F00U)
#define XBARA_SEL1_SEL3_SHIFT   (8U)
#define XBARA_SEL1_SEL3(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL1_SEL3_SHIFT)) & XBARA_SEL1_SEL3_MASK)
SEL2 - Crossbar A Select Register 2
#define XBARA_SEL2_SEL4_MASK   (0x7FU)
#define XBARA_SEL2_SEL4_SHIFT   (0U)
#define XBARA_SEL2_SEL4(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL2_SEL4_SHIFT)) & XBARA_SEL2_SEL4_MASK)
#define XBARA_SEL2_SEL5_MASK   (0x7F00U)
#define XBARA_SEL2_SEL5_SHIFT   (8U)
#define XBARA_SEL2_SEL5(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL2_SEL5_SHIFT)) & XBARA_SEL2_SEL5_MASK)
SEL3 - Crossbar A Select Register 3
#define XBARA_SEL3_SEL6_MASK   (0x7FU)
#define XBARA_SEL3_SEL6_SHIFT   (0U)
#define XBARA_SEL3_SEL6(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL3_SEL6_SHIFT)) & XBARA_SEL3_SEL6_MASK)
#define XBARA_SEL3_SEL7_MASK   (0x7F00U)
#define XBARA_SEL3_SEL7_SHIFT   (8U)
#define XBARA_SEL3_SEL7(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL3_SEL7_SHIFT)) & XBARA_SEL3_SEL7_MASK)
SEL4 - Crossbar A Select Register 4
#define XBARA_SEL4_SEL8_MASK   (0x7FU)
#define XBARA_SEL4_SEL8_SHIFT   (0U)
#define XBARA_SEL4_SEL8(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL4_SEL8_SHIFT)) & XBARA_SEL4_SEL8_MASK)
#define XBARA_SEL4_SEL9_MASK   (0x7F00U)
#define XBARA_SEL4_SEL9_SHIFT   (8U)
#define XBARA_SEL4_SEL9(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL4_SEL9_SHIFT)) & XBARA_SEL4_SEL9_MASK)
SEL5 - Crossbar A Select Register 5
#define XBARA_SEL5_SEL10_MASK   (0x7FU)
#define XBARA_SEL5_SEL10_SHIFT   (0U)
#define XBARA_SEL5_SEL10(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL5_SEL10_SHIFT)) & XBARA_SEL5_SEL10_MASK)
#define XBARA_SEL5_SEL11_MASK   (0x7F00U)
#define XBARA_SEL5_SEL11_SHIFT   (8U)
#define XBARA_SEL5_SEL11(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL5_SEL11_SHIFT)) & XBARA_SEL5_SEL11_MASK)
SEL6 - Crossbar A Select Register 6
#define XBARA_SEL6_SEL12_MASK   (0x7FU)
#define XBARA_SEL6_SEL12_SHIFT   (0U)
#define XBARA_SEL6_SEL12(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL6_SEL12_SHIFT)) & XBARA_SEL6_SEL12_MASK)
#define XBARA_SEL6_SEL13_MASK   (0x7F00U)
#define XBARA_SEL6_SEL13_SHIFT   (8U)
#define XBARA_SEL6_SEL13(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL6_SEL13_SHIFT)) & XBARA_SEL6_SEL13_MASK)
SEL7 - Crossbar A Select Register 7
#define XBARA_SEL7_SEL14_MASK   (0x7FU)
#define XBARA_SEL7_SEL14_SHIFT   (0U)
#define XBARA_SEL7_SEL14(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL7_SEL14_SHIFT)) & XBARA_SEL7_SEL14_MASK)
#define XBARA_SEL7_SEL15_MASK   (0x7F00U)
#define XBARA_SEL7_SEL15_SHIFT   (8U)
#define XBARA_SEL7_SEL15(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL7_SEL15_SHIFT)) & XBARA_SEL7_SEL15_MASK)
SEL8 - Crossbar A Select Register 8
#define XBARA_SEL8_SEL16_MASK   (0x7FU)
#define XBARA_SEL8_SEL16_SHIFT   (0U)
#define XBARA_SEL8_SEL16(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL8_SEL16_SHIFT)) & XBARA_SEL8_SEL16_MASK)
#define XBARA_SEL8_SEL17_MASK   (0x7F00U)
#define XBARA_SEL8_SEL17_SHIFT   (8U)
#define XBARA_SEL8_SEL17(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL8_SEL17_SHIFT)) & XBARA_SEL8_SEL17_MASK)
SEL9 - Crossbar A Select Register 9
#define XBARA_SEL9_SEL18_MASK   (0x7FU)
#define XBARA_SEL9_SEL18_SHIFT   (0U)
#define XBARA_SEL9_SEL18(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL9_SEL18_SHIFT)) & XBARA_SEL9_SEL18_MASK)
#define XBARA_SEL9_SEL19_MASK   (0x7F00U)
#define XBARA_SEL9_SEL19_SHIFT   (8U)
#define XBARA_SEL9_SEL19(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL9_SEL19_SHIFT)) & XBARA_SEL9_SEL19_MASK)
SEL10 - Crossbar A Select Register 10
#define XBARA_SEL10_SEL20_MASK   (0x7FU)
#define XBARA_SEL10_SEL20_SHIFT   (0U)
#define XBARA_SEL10_SEL20(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL10_SEL20_SHIFT)) & XBARA_SEL10_SEL20_MASK)
#define XBARA_SEL10_SEL21_MASK   (0x7F00U)
#define XBARA_SEL10_SEL21_SHIFT   (8U)
#define XBARA_SEL10_SEL21(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL10_SEL21_SHIFT)) & XBARA_SEL10_SEL21_MASK)
SEL11 - Crossbar A Select Register 11
#define XBARA_SEL11_SEL22_MASK   (0x7FU)
#define XBARA_SEL11_SEL22_SHIFT   (0U)
#define XBARA_SEL11_SEL22(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL11_SEL22_SHIFT)) & XBARA_SEL11_SEL22_MASK)
#define XBARA_SEL11_SEL23_MASK   (0x7F00U)
#define XBARA_SEL11_SEL23_SHIFT   (8U)
#define XBARA_SEL11_SEL23(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL11_SEL23_SHIFT)) & XBARA_SEL11_SEL23_MASK)
SEL12 - Crossbar A Select Register 12
#define XBARA_SEL12_SEL24_MASK   (0x7FU)
#define XBARA_SEL12_SEL24_SHIFT   (0U)
#define XBARA_SEL12_SEL24(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL12_SEL24_SHIFT)) & XBARA_SEL12_SEL24_MASK)
#define XBARA_SEL12_SEL25_MASK   (0x7F00U)
#define XBARA_SEL12_SEL25_SHIFT   (8U)
#define XBARA_SEL12_SEL25(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL12_SEL25_SHIFT)) & XBARA_SEL12_SEL25_MASK)
SEL13 - Crossbar A Select Register 13
#define XBARA_SEL13_SEL26_MASK   (0x7FU)
#define XBARA_SEL13_SEL26_SHIFT   (0U)
#define XBARA_SEL13_SEL26(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL13_SEL26_SHIFT)) & XBARA_SEL13_SEL26_MASK)
#define XBARA_SEL13_SEL27_MASK   (0x7F00U)
#define XBARA_SEL13_SEL27_SHIFT   (8U)
#define XBARA_SEL13_SEL27(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL13_SEL27_SHIFT)) & XBARA_SEL13_SEL27_MASK)
SEL14 - Crossbar A Select Register 14
#define XBARA_SEL14_SEL28_MASK   (0x7FU)
#define XBARA_SEL14_SEL28_SHIFT   (0U)
#define XBARA_SEL14_SEL28(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL14_SEL28_SHIFT)) & XBARA_SEL14_SEL28_MASK)
#define XBARA_SEL14_SEL29_MASK   (0x7F00U)
#define XBARA_SEL14_SEL29_SHIFT   (8U)
#define XBARA_SEL14_SEL29(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL14_SEL29_SHIFT)) & XBARA_SEL14_SEL29_MASK)
SEL15 - Crossbar A Select Register 15
#define XBARA_SEL15_SEL30_MASK   (0x7FU)
#define XBARA_SEL15_SEL30_SHIFT   (0U)
#define XBARA_SEL15_SEL30(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL15_SEL30_SHIFT)) & XBARA_SEL15_SEL30_MASK)
#define XBARA_SEL15_SEL31_MASK   (0x7F00U)
#define XBARA_SEL15_SEL31_SHIFT   (8U)
#define XBARA_SEL15_SEL31(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL15_SEL31_SHIFT)) & XBARA_SEL15_SEL31_MASK)
SEL16 - Crossbar A Select Register 16
#define XBARA_SEL16_SEL32_MASK   (0x7FU)
#define XBARA_SEL16_SEL32_SHIFT   (0U)
#define XBARA_SEL16_SEL32(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL16_SEL32_SHIFT)) & XBARA_SEL16_SEL32_MASK)
#define XBARA_SEL16_SEL33_MASK   (0x7F00U)
#define XBARA_SEL16_SEL33_SHIFT   (8U)
#define XBARA_SEL16_SEL33(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL16_SEL33_SHIFT)) & XBARA_SEL16_SEL33_MASK)
SEL17 - Crossbar A Select Register 17
#define XBARA_SEL17_SEL34_MASK   (0x7FU)
#define XBARA_SEL17_SEL34_SHIFT   (0U)
#define XBARA_SEL17_SEL34(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL17_SEL34_SHIFT)) & XBARA_SEL17_SEL34_MASK)
#define XBARA_SEL17_SEL35_MASK   (0x7F00U)
#define XBARA_SEL17_SEL35_SHIFT   (8U)
#define XBARA_SEL17_SEL35(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL17_SEL35_SHIFT)) & XBARA_SEL17_SEL35_MASK)
SEL18 - Crossbar A Select Register 18
#define XBARA_SEL18_SEL36_MASK   (0x7FU)
#define XBARA_SEL18_SEL36_SHIFT   (0U)
#define XBARA_SEL18_SEL36(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL18_SEL36_SHIFT)) & XBARA_SEL18_SEL36_MASK)
#define XBARA_SEL18_SEL37_MASK   (0x7F00U)
#define XBARA_SEL18_SEL37_SHIFT   (8U)
#define XBARA_SEL18_SEL37(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL18_SEL37_SHIFT)) & XBARA_SEL18_SEL37_MASK)
SEL19 - Crossbar A Select Register 19
#define XBARA_SEL19_SEL38_MASK   (0x7FU)
#define XBARA_SEL19_SEL38_SHIFT   (0U)
#define XBARA_SEL19_SEL38(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL19_SEL38_SHIFT)) & XBARA_SEL19_SEL38_MASK)
#define XBARA_SEL19_SEL39_MASK   (0x7F00U)
#define XBARA_SEL19_SEL39_SHIFT   (8U)
#define XBARA_SEL19_SEL39(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL19_SEL39_SHIFT)) & XBARA_SEL19_SEL39_MASK)
SEL20 - Crossbar A Select Register 20
#define XBARA_SEL20_SEL40_MASK   (0x7FU)
#define XBARA_SEL20_SEL40_SHIFT   (0U)
#define XBARA_SEL20_SEL40(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL20_SEL40_SHIFT)) & XBARA_SEL20_SEL40_MASK)
#define XBARA_SEL20_SEL41_MASK   (0x7F00U)
#define XBARA_SEL20_SEL41_SHIFT   (8U)
#define XBARA_SEL20_SEL41(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL20_SEL41_SHIFT)) & XBARA_SEL20_SEL41_MASK)
SEL21 - Crossbar A Select Register 21
#define XBARA_SEL21_SEL42_MASK   (0x7FU)
#define XBARA_SEL21_SEL42_SHIFT   (0U)
#define XBARA_SEL21_SEL42(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL21_SEL42_SHIFT)) & XBARA_SEL21_SEL42_MASK)
#define XBARA_SEL21_SEL43_MASK   (0x7F00U)
#define XBARA_SEL21_SEL43_SHIFT   (8U)
#define XBARA_SEL21_SEL43(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL21_SEL43_SHIFT)) & XBARA_SEL21_SEL43_MASK)
SEL22 - Crossbar A Select Register 22
#define XBARA_SEL22_SEL44_MASK   (0x7FU)
#define XBARA_SEL22_SEL44_SHIFT   (0U)
#define XBARA_SEL22_SEL44(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL22_SEL44_SHIFT)) & XBARA_SEL22_SEL44_MASK)
#define XBARA_SEL22_SEL45_MASK   (0x7F00U)
#define XBARA_SEL22_SEL45_SHIFT   (8U)
#define XBARA_SEL22_SEL45(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL22_SEL45_SHIFT)) & XBARA_SEL22_SEL45_MASK)
SEL23 - Crossbar A Select Register 23
#define XBARA_SEL23_SEL46_MASK   (0x7FU)
#define XBARA_SEL23_SEL46_SHIFT   (0U)
#define XBARA_SEL23_SEL46(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL23_SEL46_SHIFT)) & XBARA_SEL23_SEL46_MASK)
#define XBARA_SEL23_SEL47_MASK   (0x7F00U)
#define XBARA_SEL23_SEL47_SHIFT   (8U)
#define XBARA_SEL23_SEL47(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL23_SEL47_SHIFT)) & XBARA_SEL23_SEL47_MASK)
SEL24 - Crossbar A Select Register 24
#define XBARA_SEL24_SEL48_MASK   (0x7FU)
#define XBARA_SEL24_SEL48_SHIFT   (0U)
#define XBARA_SEL24_SEL48(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL24_SEL48_SHIFT)) & XBARA_SEL24_SEL48_MASK)
#define XBARA_SEL24_SEL49_MASK   (0x7F00U)
#define XBARA_SEL24_SEL49_SHIFT   (8U)
#define XBARA_SEL24_SEL49(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL24_SEL49_SHIFT)) & XBARA_SEL24_SEL49_MASK)
SEL25 - Crossbar A Select Register 25
#define XBARA_SEL25_SEL50_MASK   (0x7FU)
#define XBARA_SEL25_SEL50_SHIFT   (0U)
#define XBARA_SEL25_SEL50(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL25_SEL50_SHIFT)) & XBARA_SEL25_SEL50_MASK)
#define XBARA_SEL25_SEL51_MASK   (0x7F00U)
#define XBARA_SEL25_SEL51_SHIFT   (8U)
#define XBARA_SEL25_SEL51(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL25_SEL51_SHIFT)) & XBARA_SEL25_SEL51_MASK)
SEL26 - Crossbar A Select Register 26
#define XBARA_SEL26_SEL52_MASK   (0x7FU)
#define XBARA_SEL26_SEL52_SHIFT   (0U)
#define XBARA_SEL26_SEL52(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL26_SEL52_SHIFT)) & XBARA_SEL26_SEL52_MASK)
#define XBARA_SEL26_SEL53_MASK   (0x7F00U)
#define XBARA_SEL26_SEL53_SHIFT   (8U)
#define XBARA_SEL26_SEL53(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL26_SEL53_SHIFT)) & XBARA_SEL26_SEL53_MASK)
SEL27 - Crossbar A Select Register 27
#define XBARA_SEL27_SEL54_MASK   (0x7FU)
#define XBARA_SEL27_SEL54_SHIFT   (0U)
#define XBARA_SEL27_SEL54(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL27_SEL54_SHIFT)) & XBARA_SEL27_SEL54_MASK)
#define XBARA_SEL27_SEL55_MASK   (0x7F00U)
#define XBARA_SEL27_SEL55_SHIFT   (8U)
#define XBARA_SEL27_SEL55(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL27_SEL55_SHIFT)) & XBARA_SEL27_SEL55_MASK)
SEL28 - Crossbar A Select Register 28
#define XBARA_SEL28_SEL56_MASK   (0x7FU)
#define XBARA_SEL28_SEL56_SHIFT   (0U)
#define XBARA_SEL28_SEL56(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL28_SEL56_SHIFT)) & XBARA_SEL28_SEL56_MASK)
#define XBARA_SEL28_SEL57_MASK   (0x7F00U)
#define XBARA_SEL28_SEL57_SHIFT   (8U)
#define XBARA_SEL28_SEL57(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL28_SEL57_SHIFT)) & XBARA_SEL28_SEL57_MASK)
SEL29 - Crossbar A Select Register 29
#define XBARA_SEL29_SEL58_MASK   (0x7FU)
#define XBARA_SEL29_SEL58_SHIFT   (0U)
#define XBARA_SEL29_SEL58(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL29_SEL58_SHIFT)) & XBARA_SEL29_SEL58_MASK)
#define XBARA_SEL29_SEL59_MASK   (0x7F00U)
#define XBARA_SEL29_SEL59_SHIFT   (8U)
#define XBARA_SEL29_SEL59(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL29_SEL59_SHIFT)) & XBARA_SEL29_SEL59_MASK)
SEL30 - Crossbar A Select Register 30
#define XBARA_SEL30_SEL60_MASK   (0x7FU)
#define XBARA_SEL30_SEL60_SHIFT   (0U)
#define XBARA_SEL30_SEL60(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL30_SEL60_SHIFT)) & XBARA_SEL30_SEL60_MASK)
#define XBARA_SEL30_SEL61_MASK   (0x7F00U)
#define XBARA_SEL30_SEL61_SHIFT   (8U)
#define XBARA_SEL30_SEL61(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL30_SEL61_SHIFT)) & XBARA_SEL30_SEL61_MASK)
SEL31 - Crossbar A Select Register 31
#define XBARA_SEL31_SEL62_MASK   (0x7FU)
#define XBARA_SEL31_SEL62_SHIFT   (0U)
#define XBARA_SEL31_SEL62(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL31_SEL62_SHIFT)) & XBARA_SEL31_SEL62_MASK)
#define XBARA_SEL31_SEL63_MASK   (0x7F00U)
#define XBARA_SEL31_SEL63_SHIFT   (8U)
#define XBARA_SEL31_SEL63(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL31_SEL63_SHIFT)) & XBARA_SEL31_SEL63_MASK)
SEL32 - Crossbar A Select Register 32
#define XBARA_SEL32_SEL64_MASK   (0x7FU)
#define XBARA_SEL32_SEL64_SHIFT   (0U)
#define XBARA_SEL32_SEL64(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL32_SEL64_SHIFT)) & XBARA_SEL32_SEL64_MASK)
#define XBARA_SEL32_SEL65_MASK   (0x7F00U)
#define XBARA_SEL32_SEL65_SHIFT   (8U)
#define XBARA_SEL32_SEL65(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL32_SEL65_SHIFT)) & XBARA_SEL32_SEL65_MASK)
SEL33 - Crossbar A Select Register 33
#define XBARA_SEL33_SEL66_MASK   (0x7FU)
#define XBARA_SEL33_SEL66_SHIFT   (0U)
#define XBARA_SEL33_SEL66(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL33_SEL66_SHIFT)) & XBARA_SEL33_SEL66_MASK)
#define XBARA_SEL33_SEL67_MASK   (0x7F00U)
#define XBARA_SEL33_SEL67_SHIFT   (8U)
#define XBARA_SEL33_SEL67(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL33_SEL67_SHIFT)) & XBARA_SEL33_SEL67_MASK)
SEL34 - Crossbar A Select Register 34
#define XBARA_SEL34_SEL68_MASK   (0x7FU)
#define XBARA_SEL34_SEL68_SHIFT   (0U)
#define XBARA_SEL34_SEL68(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL34_SEL68_SHIFT)) & XBARA_SEL34_SEL68_MASK)
#define XBARA_SEL34_SEL69_MASK   (0x7F00U)
#define XBARA_SEL34_SEL69_SHIFT   (8U)
#define XBARA_SEL34_SEL69(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL34_SEL69_SHIFT)) & XBARA_SEL34_SEL69_MASK)
SEL35 - Crossbar A Select Register 35
#define XBARA_SEL35_SEL70_MASK   (0x7FU)
#define XBARA_SEL35_SEL70_SHIFT   (0U)
#define XBARA_SEL35_SEL70(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL35_SEL70_SHIFT)) & XBARA_SEL35_SEL70_MASK)
#define XBARA_SEL35_SEL71_MASK   (0x7F00U)
#define XBARA_SEL35_SEL71_SHIFT   (8U)
#define XBARA_SEL35_SEL71(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL35_SEL71_SHIFT)) & XBARA_SEL35_SEL71_MASK)
SEL36 - Crossbar A Select Register 36
#define XBARA_SEL36_SEL72_MASK   (0x7FU)
#define XBARA_SEL36_SEL72_SHIFT   (0U)
#define XBARA_SEL36_SEL72(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL36_SEL72_SHIFT)) & XBARA_SEL36_SEL72_MASK)
#define XBARA_SEL36_SEL73_MASK   (0x7F00U)
#define XBARA_SEL36_SEL73_SHIFT   (8U)
#define XBARA_SEL36_SEL73(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL36_SEL73_SHIFT)) & XBARA_SEL36_SEL73_MASK)
SEL37 - Crossbar A Select Register 37
#define XBARA_SEL37_SEL74_MASK   (0x7FU)
#define XBARA_SEL37_SEL74_SHIFT   (0U)
#define XBARA_SEL37_SEL74(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL37_SEL74_SHIFT)) & XBARA_SEL37_SEL74_MASK)
#define XBARA_SEL37_SEL75_MASK   (0x7F00U)
#define XBARA_SEL37_SEL75_SHIFT   (8U)
#define XBARA_SEL37_SEL75(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL37_SEL75_SHIFT)) & XBARA_SEL37_SEL75_MASK)
SEL38 - Crossbar A Select Register 38
#define XBARA_SEL38_SEL76_MASK   (0x7FU)
#define XBARA_SEL38_SEL76_SHIFT   (0U)
#define XBARA_SEL38_SEL76(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL38_SEL76_SHIFT)) & XBARA_SEL38_SEL76_MASK)
#define XBARA_SEL38_SEL77_MASK   (0x7F00U)
#define XBARA_SEL38_SEL77_SHIFT   (8U)
#define XBARA_SEL38_SEL77(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL38_SEL77_SHIFT)) & XBARA_SEL38_SEL77_MASK)
SEL39 - Crossbar A Select Register 39
#define XBARA_SEL39_SEL78_MASK   (0x7FU)
#define XBARA_SEL39_SEL78_SHIFT   (0U)
#define XBARA_SEL39_SEL78(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL39_SEL78_SHIFT)) & XBARA_SEL39_SEL78_MASK)
#define XBARA_SEL39_SEL79_MASK   (0x7F00U)
#define XBARA_SEL39_SEL79_SHIFT   (8U)
#define XBARA_SEL39_SEL79(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL39_SEL79_SHIFT)) & XBARA_SEL39_SEL79_MASK)
SEL40 - Crossbar A Select Register 40
#define XBARA_SEL40_SEL80_MASK   (0x7FU)
#define XBARA_SEL40_SEL80_SHIFT   (0U)
#define XBARA_SEL40_SEL80(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL40_SEL80_SHIFT)) & XBARA_SEL40_SEL80_MASK)
#define XBARA_SEL40_SEL81_MASK   (0x7F00U)
#define XBARA_SEL40_SEL81_SHIFT   (8U)
#define XBARA_SEL40_SEL81(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL40_SEL81_SHIFT)) & XBARA_SEL40_SEL81_MASK)
SEL41 - Crossbar A Select Register 41
#define XBARA_SEL41_SEL82_MASK   (0x7FU)
#define XBARA_SEL41_SEL82_SHIFT   (0U)
#define XBARA_SEL41_SEL82(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL41_SEL82_SHIFT)) & XBARA_SEL41_SEL82_MASK)
#define XBARA_SEL41_SEL83_MASK   (0x7F00U)
#define XBARA_SEL41_SEL83_SHIFT   (8U)
#define XBARA_SEL41_SEL83(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL41_SEL83_SHIFT)) & XBARA_SEL41_SEL83_MASK)
SEL42 - Crossbar A Select Register 42
#define XBARA_SEL42_SEL84_MASK   (0x7FU)
#define XBARA_SEL42_SEL84_SHIFT   (0U)
#define XBARA_SEL42_SEL84(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL42_SEL84_SHIFT)) & XBARA_SEL42_SEL84_MASK)
#define XBARA_SEL42_SEL85_MASK   (0x7F00U)
#define XBARA_SEL42_SEL85_SHIFT   (8U)
#define XBARA_SEL42_SEL85(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL42_SEL85_SHIFT)) & XBARA_SEL42_SEL85_MASK)
SEL43 - Crossbar A Select Register 43
#define XBARA_SEL43_SEL86_MASK   (0x7FU)
#define XBARA_SEL43_SEL86_SHIFT   (0U)
#define XBARA_SEL43_SEL86(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL43_SEL86_SHIFT)) & XBARA_SEL43_SEL86_MASK)
#define XBARA_SEL43_SEL87_MASK   (0x7F00U)
#define XBARA_SEL43_SEL87_SHIFT   (8U)
#define XBARA_SEL43_SEL87(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL43_SEL87_SHIFT)) & XBARA_SEL43_SEL87_MASK)
SEL44 - Crossbar A Select Register 44
#define XBARA_SEL44_SEL88_MASK   (0x7FU)
#define XBARA_SEL44_SEL88_SHIFT   (0U)
#define XBARA_SEL44_SEL88(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL44_SEL88_SHIFT)) & XBARA_SEL44_SEL88_MASK)
#define XBARA_SEL44_SEL89_MASK   (0x7F00U)
#define XBARA_SEL44_SEL89_SHIFT   (8U)
#define XBARA_SEL44_SEL89(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL44_SEL89_SHIFT)) & XBARA_SEL44_SEL89_MASK)
SEL45 - Crossbar A Select Register 45
#define XBARA_SEL45_SEL90_MASK   (0x7FU)
#define XBARA_SEL45_SEL90_SHIFT   (0U)
#define XBARA_SEL45_SEL90(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL45_SEL90_SHIFT)) & XBARA_SEL45_SEL90_MASK)
#define XBARA_SEL45_SEL91_MASK   (0x7F00U)
#define XBARA_SEL45_SEL91_SHIFT   (8U)
#define XBARA_SEL45_SEL91(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL45_SEL91_SHIFT)) & XBARA_SEL45_SEL91_MASK)
SEL46 - Crossbar A Select Register 46
#define XBARA_SEL46_SEL92_MASK   (0x7FU)
#define XBARA_SEL46_SEL92_SHIFT   (0U)
#define XBARA_SEL46_SEL92(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL46_SEL92_SHIFT)) & XBARA_SEL46_SEL92_MASK)
#define XBARA_SEL46_SEL93_MASK   (0x7F00U)
#define XBARA_SEL46_SEL93_SHIFT   (8U)
#define XBARA_SEL46_SEL93(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL46_SEL93_SHIFT)) & XBARA_SEL46_SEL93_MASK)
SEL47 - Crossbar A Select Register 47
#define XBARA_SEL47_SEL94_MASK   (0x7FU)
#define XBARA_SEL47_SEL94_SHIFT   (0U)
#define XBARA_SEL47_SEL94(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL47_SEL94_SHIFT)) & XBARA_SEL47_SEL94_MASK)
#define XBARA_SEL47_SEL95_MASK   (0x7F00U)
#define XBARA_SEL47_SEL95_SHIFT   (8U)
#define XBARA_SEL47_SEL95(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL47_SEL95_SHIFT)) & XBARA_SEL47_SEL95_MASK)
SEL48 - Crossbar A Select Register 48
#define XBARA_SEL48_SEL96_MASK   (0x7FU)
#define XBARA_SEL48_SEL96_SHIFT   (0U)
#define XBARA_SEL48_SEL96(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL48_SEL96_SHIFT)) & XBARA_SEL48_SEL96_MASK)
#define XBARA_SEL48_SEL97_MASK   (0x7F00U)
#define XBARA_SEL48_SEL97_SHIFT   (8U)
#define XBARA_SEL48_SEL97(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL48_SEL97_SHIFT)) & XBARA_SEL48_SEL97_MASK)
SEL49 - Crossbar A Select Register 49
#define XBARA_SEL49_SEL98_MASK   (0x7FU)
#define XBARA_SEL49_SEL98_SHIFT   (0U)
#define XBARA_SEL49_SEL98(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL49_SEL98_SHIFT)) & XBARA_SEL49_SEL98_MASK)
#define XBARA_SEL49_SEL99_MASK   (0x7F00U)
#define XBARA_SEL49_SEL99_SHIFT   (8U)
#define XBARA_SEL49_SEL99(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL49_SEL99_SHIFT)) & XBARA_SEL49_SEL99_MASK)
SEL50 - Crossbar A Select Register 50
#define XBARA_SEL50_SEL100_MASK   (0x7FU)
#define XBARA_SEL50_SEL100_SHIFT   (0U)
#define XBARA_SEL50_SEL100(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL50_SEL100_SHIFT)) & XBARA_SEL50_SEL100_MASK)
#define XBARA_SEL50_SEL101_MASK   (0x7F00U)
#define XBARA_SEL50_SEL101_SHIFT   (8U)
#define XBARA_SEL50_SEL101(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL50_SEL101_SHIFT)) & XBARA_SEL50_SEL101_MASK)
SEL51 - Crossbar A Select Register 51
#define XBARA_SEL51_SEL102_MASK   (0x7FU)
#define XBARA_SEL51_SEL102_SHIFT   (0U)
#define XBARA_SEL51_SEL102(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL51_SEL102_SHIFT)) & XBARA_SEL51_SEL102_MASK)
#define XBARA_SEL51_SEL103_MASK   (0x7F00U)
#define XBARA_SEL51_SEL103_SHIFT   (8U)
#define XBARA_SEL51_SEL103(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL51_SEL103_SHIFT)) & XBARA_SEL51_SEL103_MASK)
SEL52 - Crossbar A Select Register 52
#define XBARA_SEL52_SEL104_MASK   (0x7FU)
#define XBARA_SEL52_SEL104_SHIFT   (0U)
#define XBARA_SEL52_SEL104(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL52_SEL104_SHIFT)) & XBARA_SEL52_SEL104_MASK)
#define XBARA_SEL52_SEL105_MASK   (0x7F00U)
#define XBARA_SEL52_SEL105_SHIFT   (8U)
#define XBARA_SEL52_SEL105(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL52_SEL105_SHIFT)) & XBARA_SEL52_SEL105_MASK)
SEL53 - Crossbar A Select Register 53
#define XBARA_SEL53_SEL106_MASK   (0x7FU)
#define XBARA_SEL53_SEL106_SHIFT   (0U)
#define XBARA_SEL53_SEL106(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL53_SEL106_SHIFT)) & XBARA_SEL53_SEL106_MASK)
#define XBARA_SEL53_SEL107_MASK   (0x7F00U)
#define XBARA_SEL53_SEL107_SHIFT   (8U)
#define XBARA_SEL53_SEL107(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL53_SEL107_SHIFT)) & XBARA_SEL53_SEL107_MASK)
SEL54 - Crossbar A Select Register 54
#define XBARA_SEL54_SEL108_MASK   (0x7FU)
#define XBARA_SEL54_SEL108_SHIFT   (0U)
#define XBARA_SEL54_SEL108(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL54_SEL108_SHIFT)) & XBARA_SEL54_SEL108_MASK)
#define XBARA_SEL54_SEL109_MASK   (0x7F00U)
#define XBARA_SEL54_SEL109_SHIFT   (8U)
#define XBARA_SEL54_SEL109(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL54_SEL109_SHIFT)) & XBARA_SEL54_SEL109_MASK)
SEL55 - Crossbar A Select Register 55
#define XBARA_SEL55_SEL110_MASK   (0x7FU)
#define XBARA_SEL55_SEL110_SHIFT   (0U)
#define XBARA_SEL55_SEL110(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL55_SEL110_SHIFT)) & XBARA_SEL55_SEL110_MASK)
#define XBARA_SEL55_SEL111_MASK   (0x7F00U)
#define XBARA_SEL55_SEL111_SHIFT   (8U)
#define XBARA_SEL55_SEL111(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL55_SEL111_SHIFT)) & XBARA_SEL55_SEL111_MASK)
SEL56 - Crossbar A Select Register 56
#define XBARA_SEL56_SEL112_MASK   (0x7FU)
#define XBARA_SEL56_SEL112_SHIFT   (0U)
#define XBARA_SEL56_SEL112(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL56_SEL112_SHIFT)) & XBARA_SEL56_SEL112_MASK)
#define XBARA_SEL56_SEL113_MASK   (0x7F00U)
#define XBARA_SEL56_SEL113_SHIFT   (8U)
#define XBARA_SEL56_SEL113(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL56_SEL113_SHIFT)) & XBARA_SEL56_SEL113_MASK)
SEL57 - Crossbar A Select Register 57
#define XBARA_SEL57_SEL114_MASK   (0x7FU)
#define XBARA_SEL57_SEL114_SHIFT   (0U)
#define XBARA_SEL57_SEL114(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL57_SEL114_SHIFT)) & XBARA_SEL57_SEL114_MASK)
#define XBARA_SEL57_SEL115_MASK   (0x7F00U)
#define XBARA_SEL57_SEL115_SHIFT   (8U)
#define XBARA_SEL57_SEL115(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL57_SEL115_SHIFT)) & XBARA_SEL57_SEL115_MASK)
SEL58 - Crossbar A Select Register 58
#define XBARA_SEL58_SEL116_MASK   (0x7FU)
#define XBARA_SEL58_SEL116_SHIFT   (0U)
#define XBARA_SEL58_SEL116(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL58_SEL116_SHIFT)) & XBARA_SEL58_SEL116_MASK)
#define XBARA_SEL58_SEL117_MASK   (0x7F00U)
#define XBARA_SEL58_SEL117_SHIFT   (8U)
#define XBARA_SEL58_SEL117(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL58_SEL117_SHIFT)) & XBARA_SEL58_SEL117_MASK)
SEL59 - Crossbar A Select Register 59
#define XBARA_SEL59_SEL118_MASK   (0x7FU)
#define XBARA_SEL59_SEL118_SHIFT   (0U)
#define XBARA_SEL59_SEL118(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL59_SEL118_SHIFT)) & XBARA_SEL59_SEL118_MASK)
#define XBARA_SEL59_SEL119_MASK   (0x7F00U)
#define XBARA_SEL59_SEL119_SHIFT   (8U)
#define XBARA_SEL59_SEL119(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL59_SEL119_SHIFT)) & XBARA_SEL59_SEL119_MASK)
SEL60 - Crossbar A Select Register 60
#define XBARA_SEL60_SEL120_MASK   (0x7FU)
#define XBARA_SEL60_SEL120_SHIFT   (0U)
#define XBARA_SEL60_SEL120(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL60_SEL120_SHIFT)) & XBARA_SEL60_SEL120_MASK)
#define XBARA_SEL60_SEL121_MASK   (0x7F00U)
#define XBARA_SEL60_SEL121_SHIFT   (8U)
#define XBARA_SEL60_SEL121(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL60_SEL121_SHIFT)) & XBARA_SEL60_SEL121_MASK)
SEL61 - Crossbar A Select Register 61
#define XBARA_SEL61_SEL122_MASK   (0x7FU)
#define XBARA_SEL61_SEL122_SHIFT   (0U)
#define XBARA_SEL61_SEL122(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL61_SEL122_SHIFT)) & XBARA_SEL61_SEL122_MASK)
#define XBARA_SEL61_SEL123_MASK   (0x7F00U)
#define XBARA_SEL61_SEL123_SHIFT   (8U)
#define XBARA_SEL61_SEL123(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL61_SEL123_SHIFT)) & XBARA_SEL61_SEL123_MASK)
SEL62 - Crossbar A Select Register 62
#define XBARA_SEL62_SEL124_MASK   (0x7FU)
#define XBARA_SEL62_SEL124_SHIFT   (0U)
#define XBARA_SEL62_SEL124(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL62_SEL124_SHIFT)) & XBARA_SEL62_SEL124_MASK)
#define XBARA_SEL62_SEL125_MASK   (0x7F00U)
#define XBARA_SEL62_SEL125_SHIFT   (8U)
#define XBARA_SEL62_SEL125(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL62_SEL125_SHIFT)) & XBARA_SEL62_SEL125_MASK)
SEL63 - Crossbar A Select Register 63
#define XBARA_SEL63_SEL126_MASK   (0x7FU)
#define XBARA_SEL63_SEL126_SHIFT   (0U)
#define XBARA_SEL63_SEL126(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL63_SEL126_SHIFT)) & XBARA_SEL63_SEL126_MASK)
#define XBARA_SEL63_SEL127_MASK   (0x7F00U)
#define XBARA_SEL63_SEL127_SHIFT   (8U)
#define XBARA_SEL63_SEL127(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL63_SEL127_SHIFT)) & XBARA_SEL63_SEL127_MASK)
SEL64 - Crossbar A Select Register 64
#define XBARA_SEL64_SEL128_MASK   (0x7FU)
#define XBARA_SEL64_SEL128_SHIFT   (0U)
#define XBARA_SEL64_SEL128(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL64_SEL128_SHIFT)) & XBARA_SEL64_SEL128_MASK)
#define XBARA_SEL64_SEL129_MASK   (0x7F00U)
#define XBARA_SEL64_SEL129_SHIFT   (8U)
#define XBARA_SEL64_SEL129(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL64_SEL129_SHIFT)) & XBARA_SEL64_SEL129_MASK)
SEL65 - Crossbar A Select Register 65
#define XBARA_SEL65_SEL130_MASK   (0x7FU)
#define XBARA_SEL65_SEL130_SHIFT   (0U)
#define XBARA_SEL65_SEL130(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL65_SEL130_SHIFT)) & XBARA_SEL65_SEL130_MASK)
#define XBARA_SEL65_SEL131_MASK   (0x7F00U)
#define XBARA_SEL65_SEL131_SHIFT   (8U)
#define XBARA_SEL65_SEL131(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL65_SEL131_SHIFT)) & XBARA_SEL65_SEL131_MASK)
CTRL0 - Crossbar A Control Register 0
#define XBARA_CTRL0_DEN0_MASK   (0x1U)
#define XBARA_CTRL0_DEN0_SHIFT   (0U)
#define XBARA_CTRL0_DEN0(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_DEN0_SHIFT)) & XBARA_CTRL0_DEN0_MASK)
#define XBARA_CTRL0_IEN0_MASK   (0x2U)
#define XBARA_CTRL0_IEN0_SHIFT   (1U)
#define XBARA_CTRL0_IEN0(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_IEN0_SHIFT)) & XBARA_CTRL0_IEN0_MASK)
#define XBARA_CTRL0_EDGE0_MASK   (0xCU)
#define XBARA_CTRL0_EDGE0_SHIFT   (2U)
#define XBARA_CTRL0_EDGE0(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_EDGE0_SHIFT)) & XBARA_CTRL0_EDGE0_MASK)
#define XBARA_CTRL0_STS0_MASK   (0x10U)
#define XBARA_CTRL0_STS0_SHIFT   (4U)
#define XBARA_CTRL0_STS0(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_STS0_SHIFT)) & XBARA_CTRL0_STS0_MASK)
#define XBARA_CTRL0_DEN1_MASK   (0x100U)
#define XBARA_CTRL0_DEN1_SHIFT   (8U)
#define XBARA_CTRL0_DEN1(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_DEN1_SHIFT)) & XBARA_CTRL0_DEN1_MASK)
#define XBARA_CTRL0_IEN1_MASK   (0x200U)
#define XBARA_CTRL0_IEN1_SHIFT   (9U)
#define XBARA_CTRL0_IEN1(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_IEN1_SHIFT)) & XBARA_CTRL0_IEN1_MASK)
#define XBARA_CTRL0_EDGE1_MASK   (0xC00U)
#define XBARA_CTRL0_EDGE1_SHIFT   (10U)
#define XBARA_CTRL0_EDGE1(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_EDGE1_SHIFT)) & XBARA_CTRL0_EDGE1_MASK)
#define XBARA_CTRL0_STS1_MASK   (0x1000U)
#define XBARA_CTRL0_STS1_SHIFT   (12U)
#define XBARA_CTRL0_STS1(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_STS1_SHIFT)) & XBARA_CTRL0_STS1_MASK)
CTRL1 - Crossbar A Control Register 1
#define XBARA_CTRL1_DEN2_MASK   (0x1U)
#define XBARA_CTRL1_DEN2_SHIFT   (0U)
#define XBARA_CTRL1_DEN2(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_DEN2_SHIFT)) & XBARA_CTRL1_DEN2_MASK)
#define XBARA_CTRL1_IEN2_MASK   (0x2U)
#define XBARA_CTRL1_IEN2_SHIFT   (1U)
#define XBARA_CTRL1_IEN2(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_IEN2_SHIFT)) & XBARA_CTRL1_IEN2_MASK)
#define XBARA_CTRL1_EDGE2_MASK   (0xCU)
#define XBARA_CTRL1_EDGE2_SHIFT   (2U)
#define XBARA_CTRL1_EDGE2(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_EDGE2_SHIFT)) & XBARA_CTRL1_EDGE2_MASK)
#define XBARA_CTRL1_STS2_MASK   (0x10U)
#define XBARA_CTRL1_STS2_SHIFT   (4U)
#define XBARA_CTRL1_STS2(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_STS2_SHIFT)) & XBARA_CTRL1_STS2_MASK)
#define XBARA_CTRL1_DEN3_MASK   (0x100U)
#define XBARA_CTRL1_DEN3_SHIFT   (8U)
#define XBARA_CTRL1_DEN3(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_DEN3_SHIFT)) & XBARA_CTRL1_DEN3_MASK)
#define XBARA_CTRL1_IEN3_MASK   (0x200U)
#define XBARA_CTRL1_IEN3_SHIFT   (9U)
#define XBARA_CTRL1_IEN3(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_IEN3_SHIFT)) & XBARA_CTRL1_IEN3_MASK)
#define XBARA_CTRL1_EDGE3_MASK   (0xC00U)
#define XBARA_CTRL1_EDGE3_SHIFT   (10U)
#define XBARA_CTRL1_EDGE3(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_EDGE3_SHIFT)) & XBARA_CTRL1_EDGE3_MASK)
#define XBARA_CTRL1_STS3_MASK   (0x1000U)
#define XBARA_CTRL1_STS3_SHIFT   (12U)
#define XBARA_CTRL1_STS3(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_STS3_SHIFT)) & XBARA_CTRL1_STS3_MASK)
#define XBARA_SEL0_SEL0_MASK   (0xFFU)
#define XBARA_SEL0_SEL1_MASK   (0xFF00U)
#define XBARA_SEL1_SEL2_MASK   (0xFFU)
#define XBARA_SEL1_SEL3_MASK   (0xFF00U)
#define XBARA_SEL2_SEL4_MASK   (0xFFU)
#define XBARA_SEL2_SEL5_MASK   (0xFF00U)
#define XBARA_SEL3_SEL6_MASK   (0xFFU)
#define XBARA_SEL3_SEL7_MASK   (0xFF00U)
#define XBARA_SEL4_SEL8_MASK   (0xFFU)
#define XBARA_SEL4_SEL9_MASK   (0xFF00U)
#define XBARA_SEL5_SEL10_MASK   (0xFFU)
#define XBARA_SEL5_SEL11_MASK   (0xFF00U)
#define XBARA_SEL6_SEL12_MASK   (0xFFU)
#define XBARA_SEL6_SEL13_MASK   (0xFF00U)
#define XBARA_SEL7_SEL14_MASK   (0xFFU)
#define XBARA_SEL7_SEL15_MASK   (0xFF00U)
#define XBARA_SEL8_SEL16_MASK   (0xFFU)
#define XBARA_SEL8_SEL17_MASK   (0xFF00U)
#define XBARA_SEL9_SEL18_MASK   (0xFFU)
#define XBARA_SEL9_SEL19_MASK   (0xFF00U)
#define XBARA_SEL10_SEL20_MASK   (0xFFU)
#define XBARA_SEL10_SEL21_MASK   (0xFF00U)
#define XBARA_SEL11_SEL22_MASK   (0xFFU)
#define XBARA_SEL11_SEL23_MASK   (0xFF00U)
#define XBARA_SEL12_SEL24_MASK   (0xFFU)
#define XBARA_SEL12_SEL25_MASK   (0xFF00U)
#define XBARA_SEL13_SEL26_MASK   (0xFFU)
#define XBARA_SEL13_SEL27_MASK   (0xFF00U)
#define XBARA_SEL14_SEL28_MASK   (0xFFU)
#define XBARA_SEL14_SEL29_MASK   (0xFF00U)
#define XBARA_SEL15_SEL30_MASK   (0xFFU)
#define XBARA_SEL15_SEL31_MASK   (0xFF00U)
#define XBARA_SEL16_SEL32_MASK   (0xFFU)
#define XBARA_SEL16_SEL33_MASK   (0xFF00U)
#define XBARA_SEL17_SEL34_MASK   (0xFFU)
#define XBARA_SEL17_SEL35_MASK   (0xFF00U)
#define XBARA_SEL18_SEL36_MASK   (0xFFU)
#define XBARA_SEL18_SEL37_MASK   (0xFF00U)
#define XBARA_SEL19_SEL38_MASK   (0xFFU)
#define XBARA_SEL19_SEL39_MASK   (0xFF00U)
#define XBARA_SEL20_SEL40_MASK   (0xFFU)
#define XBARA_SEL20_SEL41_MASK   (0xFF00U)
#define XBARA_SEL21_SEL42_MASK   (0xFFU)
#define XBARA_SEL21_SEL43_MASK   (0xFF00U)
#define XBARA_SEL22_SEL44_MASK   (0xFFU)
#define XBARA_SEL22_SEL45_MASK   (0xFF00U)
#define XBARA_SEL23_SEL46_MASK   (0xFFU)
#define XBARA_SEL23_SEL47_MASK   (0xFF00U)
#define XBARA_SEL24_SEL48_MASK   (0xFFU)
#define XBARA_SEL24_SEL49_MASK   (0xFF00U)
#define XBARA_SEL25_SEL50_MASK   (0xFFU)
#define XBARA_SEL25_SEL51_MASK   (0xFF00U)
#define XBARA_SEL26_SEL52_MASK   (0xFFU)
#define XBARA_SEL26_SEL53_MASK   (0xFF00U)
#define XBARA_SEL27_SEL54_MASK   (0xFFU)
#define XBARA_SEL27_SEL55_MASK   (0xFF00U)
#define XBARA_SEL28_SEL56_MASK   (0xFFU)
#define XBARA_SEL28_SEL57_MASK   (0xFF00U)
#define XBARA_SEL29_SEL58_MASK   (0xFFU)
#define XBARA_SEL29_SEL59_MASK   (0xFF00U)
#define XBARA_SEL30_SEL60_MASK   (0xFFU)
#define XBARA_SEL30_SEL61_MASK   (0xFF00U)
#define XBARA_SEL31_SEL62_MASK   (0xFFU)
#define XBARA_SEL31_SEL63_MASK   (0xFF00U)
#define XBARA_SEL32_SEL64_MASK   (0xFFU)
#define XBARA_SEL32_SEL65_MASK   (0xFF00U)
#define XBARA_SEL33_SEL66_MASK   (0xFFU)
#define XBARA_SEL33_SEL67_MASK   (0xFF00U)
#define XBARA_SEL34_SEL68_MASK   (0xFFU)
#define XBARA_SEL34_SEL69_MASK   (0xFF00U)
#define XBARA_SEL35_SEL70_MASK   (0xFFU)
#define XBARA_SEL35_SEL71_MASK   (0xFF00U)
#define XBARA_SEL36_SEL72_MASK   (0xFFU)
#define XBARA_SEL36_SEL73_MASK   (0xFF00U)
#define XBARA_SEL37_SEL74_MASK   (0xFFU)
#define XBARA_SEL37_SEL75_MASK   (0xFF00U)
#define XBARA_SEL38_SEL76_MASK   (0xFFU)
#define XBARA_SEL38_SEL77_MASK   (0xFF00U)
#define XBARA_SEL39_SEL78_MASK   (0xFFU)
#define XBARA_SEL39_SEL79_MASK   (0xFF00U)
#define XBARA_SEL40_SEL80_MASK   (0xFFU)
#define XBARA_SEL40_SEL81_MASK   (0xFF00U)
#define XBARA_SEL41_SEL82_MASK   (0xFFU)
#define XBARA_SEL41_SEL83_MASK   (0xFF00U)
#define XBARA_SEL42_SEL84_MASK   (0xFFU)
#define XBARA_SEL42_SEL85_MASK   (0xFF00U)
#define XBARA_SEL43_SEL86_MASK   (0xFFU)
#define XBARA_SEL43_SEL87_MASK   (0xFF00U)
#define XBARA_SEL44_SEL88_MASK   (0xFFU)
#define XBARA_SEL44_SEL89_MASK   (0xFF00U)
#define XBARA_SEL45_SEL90_MASK   (0xFFU)
#define XBARA_SEL45_SEL91_MASK   (0xFF00U)
#define XBARA_SEL46_SEL92_MASK   (0xFFU)
#define XBARA_SEL46_SEL93_MASK   (0xFF00U)
#define XBARA_SEL47_SEL94_MASK   (0xFFU)
#define XBARA_SEL47_SEL95_MASK   (0xFF00U)
#define XBARA_SEL48_SEL96_MASK   (0xFFU)
#define XBARA_SEL48_SEL97_MASK   (0xFF00U)
#define XBARA_SEL49_SEL98_MASK   (0xFFU)
#define XBARA_SEL49_SEL99_MASK   (0xFF00U)
#define XBARA_SEL50_SEL100_MASK   (0xFFU)
#define XBARA_SEL50_SEL101_MASK   (0xFF00U)
#define XBARA_SEL51_SEL102_MASK   (0xFFU)
#define XBARA_SEL51_SEL103_MASK   (0xFF00U)
#define XBARA_SEL52_SEL104_MASK   (0xFFU)
#define XBARA_SEL52_SEL105_MASK   (0xFF00U)
#define XBARA_SEL53_SEL106_MASK   (0xFFU)
#define XBARA_SEL53_SEL107_MASK   (0xFF00U)
#define XBARA_SEL54_SEL108_MASK   (0xFFU)
#define XBARA_SEL54_SEL109_MASK   (0xFF00U)
#define XBARA_SEL55_SEL110_MASK   (0xFFU)
#define XBARA_SEL55_SEL111_MASK   (0xFF00U)
#define XBARA_SEL56_SEL112_MASK   (0xFFU)
#define XBARA_SEL56_SEL113_MASK   (0xFF00U)
#define XBARA_SEL57_SEL114_MASK   (0xFFU)
#define XBARA_SEL57_SEL115_MASK   (0xFF00U)
#define XBARA_SEL58_SEL116_MASK   (0xFFU)
#define XBARA_SEL58_SEL117_MASK   (0xFF00U)
#define XBARA_SEL59_SEL118_MASK   (0xFFU)
#define XBARA_SEL59_SEL119_MASK   (0xFF00U)
#define XBARA_SEL60_SEL120_MASK   (0xFFU)
#define XBARA_SEL60_SEL121_MASK   (0xFF00U)
#define XBARA_SEL61_SEL122_MASK   (0xFFU)
#define XBARA_SEL61_SEL123_MASK   (0xFF00U)
#define XBARA_SEL62_SEL124_MASK   (0xFFU)
#define XBARA_SEL62_SEL125_MASK   (0xFF00U)
#define XBARA_SEL63_SEL126_MASK   (0xFFU)
#define XBARA_SEL63_SEL127_MASK   (0xFF00U)
#define XBARA_SEL64_SEL128_MASK   (0xFFU)
#define XBARA_SEL64_SEL129_MASK   (0xFF00U)
#define XBARA_SEL65_SEL130_MASK   (0xFFU)
#define XBARA_SEL65_SEL131_MASK   (0xFF00U)
SEL66 - Crossbar A Select Register 66
#define XBARA_SEL66_SEL132_MASK   (0xFFU)
#define XBARA_SEL66_SEL132_SHIFT   (0U)
#define XBARA_SEL66_SEL132(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL66_SEL132_SHIFT)) & XBARA_SEL66_SEL132_MASK)
#define XBARA_SEL66_SEL133_MASK   (0xFF00U)
#define XBARA_SEL66_SEL133_SHIFT   (8U)
#define XBARA_SEL66_SEL133(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL66_SEL133_SHIFT)) & XBARA_SEL66_SEL133_MASK)
SEL67 - Crossbar A Select Register 67
#define XBARA_SEL67_SEL134_MASK   (0xFFU)
#define XBARA_SEL67_SEL134_SHIFT   (0U)
#define XBARA_SEL67_SEL134(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL67_SEL134_SHIFT)) & XBARA_SEL67_SEL134_MASK)
#define XBARA_SEL67_SEL135_MASK   (0xFF00U)
#define XBARA_SEL67_SEL135_SHIFT   (8U)
#define XBARA_SEL67_SEL135(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL67_SEL135_SHIFT)) & XBARA_SEL67_SEL135_MASK)
SEL68 - Crossbar A Select Register 68
#define XBARA_SEL68_SEL136_MASK   (0xFFU)
#define XBARA_SEL68_SEL136_SHIFT   (0U)
#define XBARA_SEL68_SEL136(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL68_SEL136_SHIFT)) & XBARA_SEL68_SEL136_MASK)
#define XBARA_SEL68_SEL137_MASK   (0xFF00U)
#define XBARA_SEL68_SEL137_SHIFT   (8U)
#define XBARA_SEL68_SEL137(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL68_SEL137_SHIFT)) & XBARA_SEL68_SEL137_MASK)
SEL69 - Crossbar A Select Register 69
#define XBARA_SEL69_SEL138_MASK   (0xFFU)
#define XBARA_SEL69_SEL138_SHIFT   (0U)
#define XBARA_SEL69_SEL138(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL69_SEL138_SHIFT)) & XBARA_SEL69_SEL138_MASK)
#define XBARA_SEL69_SEL139_MASK   (0xFF00U)
#define XBARA_SEL69_SEL139_SHIFT   (8U)
#define XBARA_SEL69_SEL139(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL69_SEL139_SHIFT)) & XBARA_SEL69_SEL139_MASK)
SEL70 - Crossbar A Select Register 70
#define XBARA_SEL70_SEL140_MASK   (0xFFU)
#define XBARA_SEL70_SEL140_SHIFT   (0U)
#define XBARA_SEL70_SEL140(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL70_SEL140_SHIFT)) & XBARA_SEL70_SEL140_MASK)
#define XBARA_SEL70_SEL141_MASK   (0xFF00U)
#define XBARA_SEL70_SEL141_SHIFT   (8U)
#define XBARA_SEL70_SEL141(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL70_SEL141_SHIFT)) & XBARA_SEL70_SEL141_MASK)
SEL71 - Crossbar A Select Register 71
#define XBARA_SEL71_SEL142_MASK   (0xFFU)
#define XBARA_SEL71_SEL142_SHIFT   (0U)
#define XBARA_SEL71_SEL142(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL71_SEL142_SHIFT)) & XBARA_SEL71_SEL142_MASK)
#define XBARA_SEL71_SEL143_MASK   (0xFF00U)
#define XBARA_SEL71_SEL143_SHIFT   (8U)
#define XBARA_SEL71_SEL143(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL71_SEL143_SHIFT)) & XBARA_SEL71_SEL143_MASK)
SEL72 - Crossbar A Select Register 72
#define XBARA_SEL72_SEL144_MASK   (0xFFU)
#define XBARA_SEL72_SEL144_SHIFT   (0U)
#define XBARA_SEL72_SEL144(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL72_SEL144_SHIFT)) & XBARA_SEL72_SEL144_MASK)
#define XBARA_SEL72_SEL145_MASK   (0xFF00U)
#define XBARA_SEL72_SEL145_SHIFT   (8U)
#define XBARA_SEL72_SEL145(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL72_SEL145_SHIFT)) & XBARA_SEL72_SEL145_MASK)
SEL73 - Crossbar A Select Register 73
#define XBARA_SEL73_SEL146_MASK   (0xFFU)
#define XBARA_SEL73_SEL146_SHIFT   (0U)
#define XBARA_SEL73_SEL146(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL73_SEL146_SHIFT)) & XBARA_SEL73_SEL146_MASK)
#define XBARA_SEL73_SEL147_MASK   (0xFF00U)
#define XBARA_SEL73_SEL147_SHIFT   (8U)
#define XBARA_SEL73_SEL147(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL73_SEL147_SHIFT)) & XBARA_SEL73_SEL147_MASK)
SEL74 - Crossbar A Select Register 74
#define XBARA_SEL74_SEL148_MASK   (0xFFU)
#define XBARA_SEL74_SEL148_SHIFT   (0U)
#define XBARA_SEL74_SEL148(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL74_SEL148_SHIFT)) & XBARA_SEL74_SEL148_MASK)
#define XBARA_SEL74_SEL149_MASK   (0xFF00U)
#define XBARA_SEL74_SEL149_SHIFT   (8U)
#define XBARA_SEL74_SEL149(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL74_SEL149_SHIFT)) & XBARA_SEL74_SEL149_MASK)
SEL75 - Crossbar A Select Register 75
#define XBARA_SEL75_SEL150_MASK   (0xFFU)
#define XBARA_SEL75_SEL150_SHIFT   (0U)
#define XBARA_SEL75_SEL150(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL75_SEL150_SHIFT)) & XBARA_SEL75_SEL150_MASK)
#define XBARA_SEL75_SEL151_MASK   (0xFF00U)
#define XBARA_SEL75_SEL151_SHIFT   (8U)
#define XBARA_SEL75_SEL151(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL75_SEL151_SHIFT)) & XBARA_SEL75_SEL151_MASK)
SEL76 - Crossbar A Select Register 76
#define XBARA_SEL76_SEL152_MASK   (0xFFU)
#define XBARA_SEL76_SEL152_SHIFT   (0U)
#define XBARA_SEL76_SEL152(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL76_SEL152_SHIFT)) & XBARA_SEL76_SEL152_MASK)
#define XBARA_SEL76_SEL153_MASK   (0xFF00U)
#define XBARA_SEL76_SEL153_SHIFT   (8U)
#define XBARA_SEL76_SEL153(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL76_SEL153_SHIFT)) & XBARA_SEL76_SEL153_MASK)
SEL77 - Crossbar A Select Register 77
#define XBARA_SEL77_SEL154_MASK   (0xFFU)
#define XBARA_SEL77_SEL154_SHIFT   (0U)
#define XBARA_SEL77_SEL154(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL77_SEL154_SHIFT)) & XBARA_SEL77_SEL154_MASK)
#define XBARA_SEL77_SEL155_MASK   (0xFF00U)
#define XBARA_SEL77_SEL155_SHIFT   (8U)
#define XBARA_SEL77_SEL155(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL77_SEL155_SHIFT)) & XBARA_SEL77_SEL155_MASK)
SEL78 - Crossbar A Select Register 78
#define XBARA_SEL78_SEL156_MASK   (0xFFU)
#define XBARA_SEL78_SEL156_SHIFT   (0U)
#define XBARA_SEL78_SEL156(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL78_SEL156_SHIFT)) & XBARA_SEL78_SEL156_MASK)
#define XBARA_SEL78_SEL157_MASK   (0xFF00U)
#define XBARA_SEL78_SEL157_SHIFT   (8U)
#define XBARA_SEL78_SEL157(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL78_SEL157_SHIFT)) & XBARA_SEL78_SEL157_MASK)
SEL79 - Crossbar A Select Register 79
#define XBARA_SEL79_SEL158_MASK   (0xFFU)
#define XBARA_SEL79_SEL158_SHIFT   (0U)
#define XBARA_SEL79_SEL158(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL79_SEL158_SHIFT)) & XBARA_SEL79_SEL158_MASK)
#define XBARA_SEL79_SEL159_MASK   (0xFF00U)
#define XBARA_SEL79_SEL159_SHIFT   (8U)
#define XBARA_SEL79_SEL159(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL79_SEL159_SHIFT)) & XBARA_SEL79_SEL159_MASK)
SEL80 - Crossbar A Select Register 80
#define XBARA_SEL80_SEL160_MASK   (0xFFU)
#define XBARA_SEL80_SEL160_SHIFT   (0U)
#define XBARA_SEL80_SEL160(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL80_SEL160_SHIFT)) & XBARA_SEL80_SEL160_MASK)
#define XBARA_SEL80_SEL161_MASK   (0xFF00U)
#define XBARA_SEL80_SEL161_SHIFT   (8U)
#define XBARA_SEL80_SEL161(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL80_SEL161_SHIFT)) & XBARA_SEL80_SEL161_MASK)
SEL81 - Crossbar A Select Register 81
#define XBARA_SEL81_SEL162_MASK   (0xFFU)
#define XBARA_SEL81_SEL162_SHIFT   (0U)
#define XBARA_SEL81_SEL162(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL81_SEL162_SHIFT)) & XBARA_SEL81_SEL162_MASK)
#define XBARA_SEL81_SEL163_MASK   (0xFF00U)
#define XBARA_SEL81_SEL163_SHIFT   (8U)
#define XBARA_SEL81_SEL163(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL81_SEL163_SHIFT)) & XBARA_SEL81_SEL163_MASK)
SEL82 - Crossbar A Select Register 82
#define XBARA_SEL82_SEL164_MASK   (0xFFU)
#define XBARA_SEL82_SEL164_SHIFT   (0U)
#define XBARA_SEL82_SEL164(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL82_SEL164_SHIFT)) & XBARA_SEL82_SEL164_MASK)
#define XBARA_SEL82_SEL165_MASK   (0xFF00U)
#define XBARA_SEL82_SEL165_SHIFT   (8U)
#define XBARA_SEL82_SEL165(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL82_SEL165_SHIFT)) & XBARA_SEL82_SEL165_MASK)
SEL83 - Crossbar A Select Register 83
#define XBARA_SEL83_SEL166_MASK   (0xFFU)
#define XBARA_SEL83_SEL166_SHIFT   (0U)
#define XBARA_SEL83_SEL166(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL83_SEL166_SHIFT)) & XBARA_SEL83_SEL166_MASK)
#define XBARA_SEL83_SEL167_MASK   (0xFF00U)
#define XBARA_SEL83_SEL167_SHIFT   (8U)
#define XBARA_SEL83_SEL167(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL83_SEL167_SHIFT)) & XBARA_SEL83_SEL167_MASK)
SEL84 - Crossbar A Select Register 84
#define XBARA_SEL84_SEL168_MASK   (0xFFU)
#define XBARA_SEL84_SEL168_SHIFT   (0U)
#define XBARA_SEL84_SEL168(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL84_SEL168_SHIFT)) & XBARA_SEL84_SEL168_MASK)
#define XBARA_SEL84_SEL169_MASK   (0xFF00U)
#define XBARA_SEL84_SEL169_SHIFT   (8U)
#define XBARA_SEL84_SEL169(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL84_SEL169_SHIFT)) & XBARA_SEL84_SEL169_MASK)
SEL85 - Crossbar A Select Register 85
#define XBARA_SEL85_SEL170_MASK   (0xFFU)
#define XBARA_SEL85_SEL170_SHIFT   (0U)
#define XBARA_SEL85_SEL170(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL85_SEL170_SHIFT)) & XBARA_SEL85_SEL170_MASK)
#define XBARA_SEL85_SEL171_MASK   (0xFF00U)
#define XBARA_SEL85_SEL171_SHIFT   (8U)
#define XBARA_SEL85_SEL171(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL85_SEL171_SHIFT)) & XBARA_SEL85_SEL171_MASK)
SEL86 - Crossbar A Select Register 86
#define XBARA_SEL86_SEL172_MASK   (0xFFU)
#define XBARA_SEL86_SEL172_SHIFT   (0U)
#define XBARA_SEL86_SEL172(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL86_SEL172_SHIFT)) & XBARA_SEL86_SEL172_MASK)
#define XBARA_SEL86_SEL173_MASK   (0xFF00U)
#define XBARA_SEL86_SEL173_SHIFT   (8U)
#define XBARA_SEL86_SEL173(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL86_SEL173_SHIFT)) & XBARA_SEL86_SEL173_MASK)
SEL87 - Crossbar A Select Register 87
#define XBARA_SEL87_SEL174_MASK   (0xFFU)
#define XBARA_SEL87_SEL174_SHIFT   (0U)
#define XBARA_SEL87_SEL174(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL87_SEL174_SHIFT)) & XBARA_SEL87_SEL174_MASK)
#define XBARA_SEL87_SEL175_MASK   (0xFF00U)
#define XBARA_SEL87_SEL175_SHIFT   (8U)
#define XBARA_SEL87_SEL175(x)   (((uint16_t)(((uint16_t)(x)) << XBARA_SEL87_SEL175_SHIFT)) & XBARA_SEL87_SEL175_MASK)
◆ XBARA_CTRL0_DEN0 [1/3]
#define XBARA_CTRL0_DEN0 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_DEN0_SHIFT)) & XBARA_CTRL0_DEN0_MASK)
DEN0 - DMA Enable for XBAR_OUT0 0b0..DMA disabled 0b1..DMA enabled
◆ XBARA_CTRL0_DEN0 [2/3]
◆ XBARA_CTRL0_DEN0 [3/3]
◆ XBARA_CTRL0_DEN1 [1/3]
#define XBARA_CTRL0_DEN1 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_DEN1_SHIFT)) & XBARA_CTRL0_DEN1_MASK)
DEN1 - DMA Enable for XBAR_OUT1 0b0..DMA disabled 0b1..DMA enabled
◆ XBARA_CTRL0_DEN1 [2/3]
◆ XBARA_CTRL0_DEN1 [3/3]
◆ XBARA_CTRL0_EDGE0 [1/3]
#define XBARA_CTRL0_EDGE0 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_EDGE0_SHIFT)) & XBARA_CTRL0_EDGE0_MASK)
EDGE0 - Active edge for edge detection on XBAR_OUT0 0b00..STS0 never asserts 0b01..STS0 asserts on rising edges of XBAR_OUT0 0b10..STS0 asserts on falling edges of XBAR_OUT0 0b11..STS0 asserts on rising and falling edges of XBAR_OUT0
◆ XBARA_CTRL0_EDGE0 [2/3]
◆ XBARA_CTRL0_EDGE0 [3/3]
◆ XBARA_CTRL0_EDGE1 [1/3]
#define XBARA_CTRL0_EDGE1 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_EDGE1_SHIFT)) & XBARA_CTRL0_EDGE1_MASK)
EDGE1 - Active edge for edge detection on XBAR_OUT1 0b00..STS1 never asserts 0b01..STS1 asserts on rising edges of XBAR_OUT1 0b10..STS1 asserts on falling edges of XBAR_OUT1 0b11..STS1 asserts on rising and falling edges of XBAR_OUT1
◆ XBARA_CTRL0_EDGE1 [2/3]
◆ XBARA_CTRL0_EDGE1 [3/3]
◆ XBARA_CTRL0_IEN0 [1/3]
#define XBARA_CTRL0_IEN0 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_IEN0_SHIFT)) & XBARA_CTRL0_IEN0_MASK)
IEN0 - Interrupt Enable for XBAR_OUT0 0b0..Interrupt disabled 0b1..Interrupt enabled
◆ XBARA_CTRL0_IEN0 [2/3]
◆ XBARA_CTRL0_IEN0 [3/3]
◆ XBARA_CTRL0_IEN1 [1/3]
#define XBARA_CTRL0_IEN1 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_IEN1_SHIFT)) & XBARA_CTRL0_IEN1_MASK)
IEN1 - Interrupt Enable for XBAR_OUT1 0b0..Interrupt disabled 0b1..Interrupt enabled
◆ XBARA_CTRL0_IEN1 [2/3]
◆ XBARA_CTRL0_IEN1 [3/3]
◆ XBARA_CTRL0_STS0 [1/3]
#define XBARA_CTRL0_STS0 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_STS0_SHIFT)) & XBARA_CTRL0_STS0_MASK)
STS0 - Edge detection status for XBAR_OUT0 0b0..Active edge not yet detected on XBAR_OUT0 0b1..Active edge detected on XBAR_OUT0
◆ XBARA_CTRL0_STS0 [2/3]
◆ XBARA_CTRL0_STS0 [3/3]
◆ XBARA_CTRL0_STS1 [1/3]
#define XBARA_CTRL0_STS1 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL0_STS1_SHIFT)) & XBARA_CTRL0_STS1_MASK)
STS1 - Edge detection status for XBAR_OUT1 0b0..Active edge not yet detected on XBAR_OUT1 0b1..Active edge detected on XBAR_OUT1
◆ XBARA_CTRL0_STS1 [2/3]
◆ XBARA_CTRL0_STS1 [3/3]
◆ XBARA_CTRL1_DEN2 [1/3]
#define XBARA_CTRL1_DEN2 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_DEN2_SHIFT)) & XBARA_CTRL1_DEN2_MASK)
DEN2 - DMA Enable for XBAR_OUT2 0b0..DMA disabled 0b1..DMA enabled
◆ XBARA_CTRL1_DEN2 [2/3]
◆ XBARA_CTRL1_DEN2 [3/3]
◆ XBARA_CTRL1_DEN3 [1/3]
#define XBARA_CTRL1_DEN3 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_DEN3_SHIFT)) & XBARA_CTRL1_DEN3_MASK)
DEN3 - DMA Enable for XBAR_OUT3 0b0..DMA disabled 0b1..DMA enabled
◆ XBARA_CTRL1_DEN3 [2/3]
◆ XBARA_CTRL1_DEN3 [3/3]
◆ XBARA_CTRL1_EDGE2 [1/3]
#define XBARA_CTRL1_EDGE2 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_EDGE2_SHIFT)) & XBARA_CTRL1_EDGE2_MASK)
EDGE2 - Active edge for edge detection on XBAR_OUT2 0b00..STS2 never asserts 0b01..STS2 asserts on rising edges of XBAR_OUT2 0b10..STS2 asserts on falling edges of XBAR_OUT2 0b11..STS2 asserts on rising and falling edges of XBAR_OUT2
◆ XBARA_CTRL1_EDGE2 [2/3]
◆ XBARA_CTRL1_EDGE2 [3/3]
◆ XBARA_CTRL1_EDGE3 [1/3]
#define XBARA_CTRL1_EDGE3 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_EDGE3_SHIFT)) & XBARA_CTRL1_EDGE3_MASK)
EDGE3 - Active edge for edge detection on XBAR_OUT3 0b00..STS3 never asserts 0b01..STS3 asserts on rising edges of XBAR_OUT3 0b10..STS3 asserts on falling edges of XBAR_OUT3 0b11..STS3 asserts on rising and falling edges of XBAR_OUT3
◆ XBARA_CTRL1_EDGE3 [2/3]
◆ XBARA_CTRL1_EDGE3 [3/3]
◆ XBARA_CTRL1_IEN2 [1/3]
#define XBARA_CTRL1_IEN2 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_IEN2_SHIFT)) & XBARA_CTRL1_IEN2_MASK)
IEN2 - Interrupt Enable for XBAR_OUT2 0b0..Interrupt disabled 0b1..Interrupt enabled
◆ XBARA_CTRL1_IEN2 [2/3]
◆ XBARA_CTRL1_IEN2 [3/3]
◆ XBARA_CTRL1_IEN3 [1/3]
#define XBARA_CTRL1_IEN3 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_IEN3_SHIFT)) & XBARA_CTRL1_IEN3_MASK)
IEN3 - Interrupt Enable for XBAR_OUT3 0b0..Interrupt disabled 0b1..Interrupt enabled
◆ XBARA_CTRL1_IEN3 [2/3]
◆ XBARA_CTRL1_IEN3 [3/3]
◆ XBARA_CTRL1_STS2 [1/3]
#define XBARA_CTRL1_STS2 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_STS2_SHIFT)) & XBARA_CTRL1_STS2_MASK)
STS2 - Edge detection status for XBAR_OUT2 0b0..Active edge not yet detected on XBAR_OUT2 0b1..Active edge detected on XBAR_OUT2
◆ XBARA_CTRL1_STS2 [2/3]
◆ XBARA_CTRL1_STS2 [3/3]
◆ XBARA_CTRL1_STS3 [1/3]
#define XBARA_CTRL1_STS3 (   x)    (((uint16_t)(((uint16_t)(x)) << XBARA_CTRL1_STS3_SHIFT)) & XBARA_CTRL1_STS3_MASK)
STS3 - Edge detection status for XBAR_OUT3 0b0..Active edge not yet detected on XBAR_OUT3 0b1..Active edge detected on XBAR_OUT3
◆ XBARA_CTRL1_STS3 [2/3]
◆ XBARA_CTRL1_STS3 [3/3]
