RTEMS 6.2
This validation test suite contains test cases which test the kernel character input/output device provided by the BSP before the system initialization is performed. More...
Modules | |
| spec:/rtems/io/val/kernel | |
| Tests the functions referenced by BSP_output_char and BSP_poll_char. | |
Files | |
| file | ts-validation-io-kernel.c |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0 |
| #define | CONFIGURE_DISABLE_NEWLIB_REENTRANCY |
| #define | CONFIGURE_APPLICATION_DISABLE_FILESYSTEM |
| #define | CONFIGURE_SCHEDULER_USER |
| #define | CONFIGURE_SCHEDULER |
| #define | CONFIGURE_SCHEDULER_TABLE_ENTRIES { } |
| #define | CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE |
| #define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
| #define | CONFIGURE_IDLE_TASK_BODY IdleBody |
| #define | CONFIGURE_INIT |
| void | boot_card (const char *cmdline) |
| Standard system initialization procedure. | |
| const char | rtems_test_name [] = "TestsuitesValidationIoKernel" |
| Each test must define a test name string. | |
| void boot_card | ( | const char * | cmdline | ) |
You may pass a command line in cmdline. It is later available via the global bsp_boot_cmdline variable.
This is the C entry point for ALL RTEMS BSPs. It is invoked from the assembly language initialization file usually called start.S which does the basic CPU setup (stack, C runtime environment, zero BSS, load other sections) and calls afterwards boot_card(). The boot card function provides the framework for the BSP initialization sequence. For the basic flow of initialization see RTEMS C User's Guide, Initialization Manager.
This style of initialization ensures that the C++ global constructors are executed after RTEMS is initialized.
