RTEMS 6.2
This validation test suite contains a test case for the system termination procedure. More...
Modules | |
| spec:/score/interr/val/terminate | |
| Tests system termination procedure. | |
Files | |
| file | ts-terminate.c |
| #define | CONFIGURE_MAXIMUM_PROCESSORS 2 |
| #define | CONFIGURE_INITIAL_EXTENSIONS |
| #define | CONFIGURE_DISABLE_BSP_SETTINGS |
| const char | rtems_test_name [] = "TestsuitesTerminate" |
| Each test must define a test name string. | |
| #define CONFIGURE_INITIAL_EXTENSIONS |
