RTEMS 6.2
CTRL0 - Temperature Sensor Control Register 0
#define TMPSNS_CTRL0_SLOPE_CAL_MASK   (0x3FU)
#define TMPSNS_CTRL0_SLOPE_CAL_SHIFT   (0U)
#define TMPSNS_CTRL0_SLOPE_CAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_SLOPE_CAL_MASK)
#define TMPSNS_CTRL0_V_SEL_MASK   (0x300U)
#define TMPSNS_CTRL0_V_SEL_SHIFT   (8U)
#define TMPSNS_CTRL0_V_SEL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_V_SEL_SHIFT)) & TMPSNS_CTRL0_V_SEL_MASK)
#define TMPSNS_CTRL0_IBIAS_TRIM_MASK   (0xF000U)
#define TMPSNS_CTRL0_IBIAS_TRIM_SHIFT   (12U)
#define TMPSNS_CTRL0_IBIAS_TRIM(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_IBIAS_TRIM_MASK)
CTRL0_SET - Temperature Sensor Control Register 0
#define TMPSNS_CTRL0_SET_SLOPE_CAL_MASK   (0x3FU)
#define TMPSNS_CTRL0_SET_SLOPE_CAL_SHIFT   (0U)
#define TMPSNS_CTRL0_SET_SLOPE_CAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SET_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_SET_SLOPE_CAL_MASK)
#define TMPSNS_CTRL0_SET_V_SEL_MASK   (0x300U)
#define TMPSNS_CTRL0_SET_V_SEL_SHIFT   (8U)
#define TMPSNS_CTRL0_SET_V_SEL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SET_V_SEL_SHIFT)) & TMPSNS_CTRL0_SET_V_SEL_MASK)
#define TMPSNS_CTRL0_SET_IBIAS_TRIM_MASK   (0xF000U)
#define TMPSNS_CTRL0_SET_IBIAS_TRIM_SHIFT   (12U)
#define TMPSNS_CTRL0_SET_IBIAS_TRIM(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SET_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_SET_IBIAS_TRIM_MASK)
CTRL0_CLR - Temperature Sensor Control Register 0
#define TMPSNS_CTRL0_CLR_SLOPE_CAL_MASK   (0x3FU)
#define TMPSNS_CTRL0_CLR_SLOPE_CAL_SHIFT   (0U)
#define TMPSNS_CTRL0_CLR_SLOPE_CAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_CLR_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_CLR_SLOPE_CAL_MASK)
#define TMPSNS_CTRL0_CLR_V_SEL_MASK   (0x300U)
#define TMPSNS_CTRL0_CLR_V_SEL_SHIFT   (8U)
#define TMPSNS_CTRL0_CLR_V_SEL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_CLR_V_SEL_SHIFT)) & TMPSNS_CTRL0_CLR_V_SEL_MASK)
#define TMPSNS_CTRL0_CLR_IBIAS_TRIM_MASK   (0xF000U)
#define TMPSNS_CTRL0_CLR_IBIAS_TRIM_SHIFT   (12U)
#define TMPSNS_CTRL0_CLR_IBIAS_TRIM(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_CLR_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_CLR_IBIAS_TRIM_MASK)
CTRL0_TOG - Temperature Sensor Control Register 0
#define TMPSNS_CTRL0_TOG_SLOPE_CAL_MASK   (0x3FU)
#define TMPSNS_CTRL0_TOG_SLOPE_CAL_SHIFT   (0U)
#define TMPSNS_CTRL0_TOG_SLOPE_CAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_TOG_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_TOG_SLOPE_CAL_MASK)
#define TMPSNS_CTRL0_TOG_V_SEL_MASK   (0x300U)
#define TMPSNS_CTRL0_TOG_V_SEL_SHIFT   (8U)
#define TMPSNS_CTRL0_TOG_V_SEL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_TOG_V_SEL_SHIFT)) & TMPSNS_CTRL0_TOG_V_SEL_MASK)
#define TMPSNS_CTRL0_TOG_IBIAS_TRIM_MASK   (0xF000U)
#define TMPSNS_CTRL0_TOG_IBIAS_TRIM_SHIFT   (12U)
#define TMPSNS_CTRL0_TOG_IBIAS_TRIM(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_TOG_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_TOG_IBIAS_TRIM_MASK)
CTRL1 - Temperature Sensor Control Register 1
#define TMPSNS_CTRL1_FREQ_MASK   (0xFFFFU)
#define TMPSNS_CTRL1_FREQ_SHIFT   (0U)
#define TMPSNS_CTRL1_FREQ(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_FREQ_SHIFT)) & TMPSNS_CTRL1_FREQ_MASK)
#define TMPSNS_CTRL1_FINISH_IE_MASK   (0x10000U)
#define TMPSNS_CTRL1_FINISH_IE_SHIFT   (16U)
#define TMPSNS_CTRL1_FINISH_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_FINISH_IE_MASK)
#define TMPSNS_CTRL1_LOW_TEMP_IE_MASK   (0x20000U)
#define TMPSNS_CTRL1_LOW_TEMP_IE_SHIFT   (17U)
#define TMPSNS_CTRL1_LOW_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_LOW_TEMP_IE_MASK)
#define TMPSNS_CTRL1_HIGH_TEMP_IE_MASK   (0x40000U)
#define TMPSNS_CTRL1_HIGH_TEMP_IE_SHIFT   (18U)
#define TMPSNS_CTRL1_HIGH_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_HIGH_TEMP_IE_MASK)
#define TMPSNS_CTRL1_PANIC_TEMP_IE_MASK   (0x80000U)
#define TMPSNS_CTRL1_PANIC_TEMP_IE_SHIFT   (19U)
#define TMPSNS_CTRL1_PANIC_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_PANIC_TEMP_IE_MASK)
#define TMPSNS_CTRL1_START_MASK   (0x400000U)
#define TMPSNS_CTRL1_START_SHIFT   (22U)
#define TMPSNS_CTRL1_START(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_START_SHIFT)) & TMPSNS_CTRL1_START_MASK)
#define TMPSNS_CTRL1_PWD_MASK   (0x800000U)
#define TMPSNS_CTRL1_PWD_SHIFT   (23U)
#define TMPSNS_CTRL1_PWD(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_PWD_SHIFT)) & TMPSNS_CTRL1_PWD_MASK)
#define TMPSNS_CTRL1_RFU_MASK   (0x7F000000U)
#define TMPSNS_CTRL1_RFU_SHIFT   (24U)
#define TMPSNS_CTRL1_RFU(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_RFU_SHIFT)) & TMPSNS_CTRL1_RFU_MASK)
#define TMPSNS_CTRL1_PWD_FULL_MASK   (0x80000000U)
#define TMPSNS_CTRL1_PWD_FULL_SHIFT   (31U)
#define TMPSNS_CTRL1_PWD_FULL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_PWD_FULL_MASK)
CTRL1_SET - Temperature Sensor Control Register 1
#define TMPSNS_CTRL1_SET_FREQ_MASK   (0xFFFFU)
#define TMPSNS_CTRL1_SET_FREQ_SHIFT   (0U)
#define TMPSNS_CTRL1_SET_FREQ(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_FREQ_SHIFT)) & TMPSNS_CTRL1_SET_FREQ_MASK)
#define TMPSNS_CTRL1_SET_FINISH_IE_MASK   (0x10000U)
#define TMPSNS_CTRL1_SET_FINISH_IE_SHIFT   (16U)
#define TMPSNS_CTRL1_SET_FINISH_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_SET_FINISH_IE_MASK)
#define TMPSNS_CTRL1_SET_LOW_TEMP_IE_MASK   (0x20000U)
#define TMPSNS_CTRL1_SET_LOW_TEMP_IE_SHIFT   (17U)
#define TMPSNS_CTRL1_SET_LOW_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_SET_LOW_TEMP_IE_MASK)
#define TMPSNS_CTRL1_SET_HIGH_TEMP_IE_MASK   (0x40000U)
#define TMPSNS_CTRL1_SET_HIGH_TEMP_IE_SHIFT   (18U)
#define TMPSNS_CTRL1_SET_HIGH_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_SET_HIGH_TEMP_IE_MASK)
#define TMPSNS_CTRL1_SET_PANIC_TEMP_IE_MASK   (0x80000U)
#define TMPSNS_CTRL1_SET_PANIC_TEMP_IE_SHIFT   (19U)
#define TMPSNS_CTRL1_SET_PANIC_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_SET_PANIC_TEMP_IE_MASK)
#define TMPSNS_CTRL1_SET_START_MASK   (0x400000U)
#define TMPSNS_CTRL1_SET_START_SHIFT   (22U)
#define TMPSNS_CTRL1_SET_START(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_START_SHIFT)) & TMPSNS_CTRL1_SET_START_MASK)
#define TMPSNS_CTRL1_SET_PWD_MASK   (0x800000U)
#define TMPSNS_CTRL1_SET_PWD_SHIFT   (23U)
#define TMPSNS_CTRL1_SET_PWD(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_PWD_SHIFT)) & TMPSNS_CTRL1_SET_PWD_MASK)
#define TMPSNS_CTRL1_SET_RFU_MASK   (0x7F000000U)
#define TMPSNS_CTRL1_SET_RFU_SHIFT   (24U)
#define TMPSNS_CTRL1_SET_RFU(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_RFU_SHIFT)) & TMPSNS_CTRL1_SET_RFU_MASK)
#define TMPSNS_CTRL1_SET_PWD_FULL_MASK   (0x80000000U)
#define TMPSNS_CTRL1_SET_PWD_FULL_SHIFT   (31U)
#define TMPSNS_CTRL1_SET_PWD_FULL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_SET_PWD_FULL_MASK)
CTRL1_CLR - Temperature Sensor Control Register 1
#define TMPSNS_CTRL1_CLR_FREQ_MASK   (0xFFFFU)
#define TMPSNS_CTRL1_CLR_FREQ_SHIFT   (0U)
#define TMPSNS_CTRL1_CLR_FREQ(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_FREQ_SHIFT)) & TMPSNS_CTRL1_CLR_FREQ_MASK)
#define TMPSNS_CTRL1_CLR_FINISH_IE_MASK   (0x10000U)
#define TMPSNS_CTRL1_CLR_FINISH_IE_SHIFT   (16U)
#define TMPSNS_CTRL1_CLR_FINISH_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_CLR_FINISH_IE_MASK)
#define TMPSNS_CTRL1_CLR_LOW_TEMP_IE_MASK   (0x20000U)
#define TMPSNS_CTRL1_CLR_LOW_TEMP_IE_SHIFT   (17U)
#define TMPSNS_CTRL1_CLR_LOW_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_CLR_LOW_TEMP_IE_MASK)
#define TMPSNS_CTRL1_CLR_HIGH_TEMP_IE_MASK   (0x40000U)
#define TMPSNS_CTRL1_CLR_HIGH_TEMP_IE_SHIFT   (18U)
#define TMPSNS_CTRL1_CLR_HIGH_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_CLR_HIGH_TEMP_IE_MASK)
#define TMPSNS_CTRL1_CLR_PANIC_TEMP_IE_MASK   (0x80000U)
#define TMPSNS_CTRL1_CLR_PANIC_TEMP_IE_SHIFT   (19U)
#define TMPSNS_CTRL1_CLR_PANIC_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_CLR_PANIC_TEMP_IE_MASK)
#define TMPSNS_CTRL1_CLR_START_MASK   (0x400000U)
#define TMPSNS_CTRL1_CLR_START_SHIFT   (22U)
#define TMPSNS_CTRL1_CLR_START(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_START_SHIFT)) & TMPSNS_CTRL1_CLR_START_MASK)
#define TMPSNS_CTRL1_CLR_PWD_MASK   (0x800000U)
#define TMPSNS_CTRL1_CLR_PWD_SHIFT   (23U)
#define TMPSNS_CTRL1_CLR_PWD(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_PWD_SHIFT)) & TMPSNS_CTRL1_CLR_PWD_MASK)
#define TMPSNS_CTRL1_CLR_RFU_MASK   (0x7F000000U)
#define TMPSNS_CTRL1_CLR_RFU_SHIFT   (24U)
#define TMPSNS_CTRL1_CLR_RFU(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_RFU_SHIFT)) & TMPSNS_CTRL1_CLR_RFU_MASK)
#define TMPSNS_CTRL1_CLR_PWD_FULL_MASK   (0x80000000U)
#define TMPSNS_CTRL1_CLR_PWD_FULL_SHIFT   (31U)
#define TMPSNS_CTRL1_CLR_PWD_FULL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_CLR_PWD_FULL_MASK)
CTRL1_TOG - Temperature Sensor Control Register 1
#define TMPSNS_CTRL1_TOG_FREQ_MASK   (0xFFFFU)
#define TMPSNS_CTRL1_TOG_FREQ_SHIFT   (0U)
#define TMPSNS_CTRL1_TOG_FREQ(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_FREQ_SHIFT)) & TMPSNS_CTRL1_TOG_FREQ_MASK)
#define TMPSNS_CTRL1_TOG_FINISH_IE_MASK   (0x10000U)
#define TMPSNS_CTRL1_TOG_FINISH_IE_SHIFT   (16U)
#define TMPSNS_CTRL1_TOG_FINISH_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_TOG_FINISH_IE_MASK)
#define TMPSNS_CTRL1_TOG_LOW_TEMP_IE_MASK   (0x20000U)
#define TMPSNS_CTRL1_TOG_LOW_TEMP_IE_SHIFT   (17U)
#define TMPSNS_CTRL1_TOG_LOW_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_TOG_LOW_TEMP_IE_MASK)
#define TMPSNS_CTRL1_TOG_HIGH_TEMP_IE_MASK   (0x40000U)
#define TMPSNS_CTRL1_TOG_HIGH_TEMP_IE_SHIFT   (18U)
#define TMPSNS_CTRL1_TOG_HIGH_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_TOG_HIGH_TEMP_IE_MASK)
#define TMPSNS_CTRL1_TOG_PANIC_TEMP_IE_MASK   (0x80000U)
#define TMPSNS_CTRL1_TOG_PANIC_TEMP_IE_SHIFT   (19U)
#define TMPSNS_CTRL1_TOG_PANIC_TEMP_IE(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_TOG_PANIC_TEMP_IE_MASK)
#define TMPSNS_CTRL1_TOG_START_MASK   (0x400000U)
#define TMPSNS_CTRL1_TOG_START_SHIFT   (22U)
#define TMPSNS_CTRL1_TOG_START(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_START_SHIFT)) & TMPSNS_CTRL1_TOG_START_MASK)
#define TMPSNS_CTRL1_TOG_PWD_MASK   (0x800000U)
#define TMPSNS_CTRL1_TOG_PWD_SHIFT   (23U)
#define TMPSNS_CTRL1_TOG_PWD(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_PWD_SHIFT)) & TMPSNS_CTRL1_TOG_PWD_MASK)
#define TMPSNS_CTRL1_TOG_RFU_MASK   (0x7F000000U)
#define TMPSNS_CTRL1_TOG_RFU_SHIFT   (24U)
#define TMPSNS_CTRL1_TOG_RFU(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_RFU_SHIFT)) & TMPSNS_CTRL1_TOG_RFU_MASK)
#define TMPSNS_CTRL1_TOG_PWD_FULL_MASK   (0x80000000U)
#define TMPSNS_CTRL1_TOG_PWD_FULL_SHIFT   (31U)
#define TMPSNS_CTRL1_TOG_PWD_FULL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_TOG_PWD_FULL_MASK)
RANGE0 - Temperature Sensor Range Register 0
#define TMPSNS_RANGE0_LOW_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE0_LOW_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE0_LOW_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_LOW_TEMP_VAL_MASK)
#define TMPSNS_RANGE0_HIGH_TEMP_VAL_MASK   (0xFFF0000U)
#define TMPSNS_RANGE0_HIGH_TEMP_VAL_SHIFT   (16U)
#define TMPSNS_RANGE0_HIGH_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_HIGH_TEMP_VAL_MASK)
RANGE0_SET - Temperature Sensor Range Register 0
#define TMPSNS_RANGE0_SET_LOW_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE0_SET_LOW_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE0_SET_LOW_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_SET_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_SET_LOW_TEMP_VAL_MASK)
#define TMPSNS_RANGE0_SET_HIGH_TEMP_VAL_MASK   (0xFFF0000U)
#define TMPSNS_RANGE0_SET_HIGH_TEMP_VAL_SHIFT   (16U)
#define TMPSNS_RANGE0_SET_HIGH_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_SET_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_SET_HIGH_TEMP_VAL_MASK)
RANGE0_CLR - Temperature Sensor Range Register 0
#define TMPSNS_RANGE0_CLR_LOW_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE0_CLR_LOW_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE0_CLR_LOW_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_CLR_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_CLR_LOW_TEMP_VAL_MASK)
#define TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL_MASK   (0xFFF0000U)
#define TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL_SHIFT   (16U)
#define TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL_MASK)
RANGE0_TOG - Temperature Sensor Range Register 0
#define TMPSNS_RANGE0_TOG_LOW_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE0_TOG_LOW_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE0_TOG_LOW_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_TOG_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_TOG_LOW_TEMP_VAL_MASK)
#define TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL_MASK   (0xFFF0000U)
#define TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL_SHIFT   (16U)
#define TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL_MASK)
RANGE1 - Temperature Sensor Range Register 1
#define TMPSNS_RANGE1_PANIC_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE1_PANIC_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE1_PANIC_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_PANIC_TEMP_VAL_MASK)
RANGE1_SET - Temperature Sensor Range Register 1
#define TMPSNS_RANGE1_SET_PANIC_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE1_SET_PANIC_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE1_SET_PANIC_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_SET_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_SET_PANIC_TEMP_VAL_MASK)
RANGE1_CLR - Temperature Sensor Range Register 1
#define TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL_MASK)
RANGE1_TOG - Temperature Sensor Range Register 1
#define TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL_MASK)
STATUS0 - Temperature Sensor Status Register 0
#define TMPSNS_STATUS0_TEMP_VAL_MASK   (0xFFFU)
#define TMPSNS_STATUS0_TEMP_VAL_SHIFT   (0U)
#define TMPSNS_STATUS0_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_TEMP_VAL_SHIFT)) & TMPSNS_STATUS0_TEMP_VAL_MASK)
#define TMPSNS_STATUS0_FINISH_MASK   (0x10000U)
#define TMPSNS_STATUS0_FINISH_SHIFT   (16U)
#define TMPSNS_STATUS0_FINISH(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_FINISH_SHIFT)) & TMPSNS_STATUS0_FINISH_MASK)
#define TMPSNS_STATUS0_LOW_TEMP_MASK   (0x20000U)
#define TMPSNS_STATUS0_LOW_TEMP_SHIFT   (17U)
#define TMPSNS_STATUS0_LOW_TEMP(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_LOW_TEMP_SHIFT)) & TMPSNS_STATUS0_LOW_TEMP_MASK)
#define TMPSNS_STATUS0_HIGH_TEMP_MASK   (0x40000U)
#define TMPSNS_STATUS0_HIGH_TEMP_SHIFT   (18U)
#define TMPSNS_STATUS0_HIGH_TEMP(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_HIGH_TEMP_SHIFT)) & TMPSNS_STATUS0_HIGH_TEMP_MASK)
#define TMPSNS_STATUS0_PANIC_TEMP_MASK   (0x80000U)
#define TMPSNS_STATUS0_PANIC_TEMP_SHIFT   (19U)
#define TMPSNS_STATUS0_PANIC_TEMP(x)   (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_PANIC_TEMP_SHIFT)) & TMPSNS_STATUS0_PANIC_TEMP_MASK)
◆ TMPSNS_CTRL0_CLR_IBIAS_TRIM [1/2]
#define TMPSNS_CTRL0_CLR_IBIAS_TRIM (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_CLR_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_CLR_IBIAS_TRIM_MASK)
IBIAS_TRIM - Current bias trim value
◆ TMPSNS_CTRL0_CLR_IBIAS_TRIM [2/2]
◆ TMPSNS_CTRL0_CLR_SLOPE_CAL [1/2]
#define TMPSNS_CTRL0_CLR_SLOPE_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_CLR_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_CLR_SLOPE_CAL_MASK)
SLOPE_CAL - Ramp slope calibration control
◆ TMPSNS_CTRL0_CLR_SLOPE_CAL [2/2]
◆ TMPSNS_CTRL0_CLR_V_SEL [1/2]
#define TMPSNS_CTRL0_CLR_V_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_CLR_V_SEL_SHIFT)) & TMPSNS_CTRL0_CLR_V_SEL_MASK)
V_SEL - Voltage Select
◆ TMPSNS_CTRL0_CLR_V_SEL [2/2]
◆ TMPSNS_CTRL0_IBIAS_TRIM [1/2]
#define TMPSNS_CTRL0_IBIAS_TRIM (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_IBIAS_TRIM_MASK)
◆ TMPSNS_CTRL0_IBIAS_TRIM [2/2]
◆ TMPSNS_CTRL0_SET_IBIAS_TRIM [1/2]
#define TMPSNS_CTRL0_SET_IBIAS_TRIM (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SET_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_SET_IBIAS_TRIM_MASK)
◆ TMPSNS_CTRL0_SET_IBIAS_TRIM [2/2]
◆ TMPSNS_CTRL0_SET_SLOPE_CAL [1/2]
#define TMPSNS_CTRL0_SET_SLOPE_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SET_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_SET_SLOPE_CAL_MASK)
◆ TMPSNS_CTRL0_SET_SLOPE_CAL [2/2]
◆ TMPSNS_CTRL0_SET_V_SEL [1/2]
#define TMPSNS_CTRL0_SET_V_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SET_V_SEL_SHIFT)) & TMPSNS_CTRL0_SET_V_SEL_MASK)
◆ TMPSNS_CTRL0_SET_V_SEL [2/2]
◆ TMPSNS_CTRL0_SLOPE_CAL [1/2]
#define TMPSNS_CTRL0_SLOPE_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_SLOPE_CAL_MASK)
◆ TMPSNS_CTRL0_SLOPE_CAL [2/2]
◆ TMPSNS_CTRL0_TOG_IBIAS_TRIM [1/2]
#define TMPSNS_CTRL0_TOG_IBIAS_TRIM (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_TOG_IBIAS_TRIM_SHIFT)) & TMPSNS_CTRL0_TOG_IBIAS_TRIM_MASK)
◆ TMPSNS_CTRL0_TOG_IBIAS_TRIM [2/2]
◆ TMPSNS_CTRL0_TOG_SLOPE_CAL [1/2]
#define TMPSNS_CTRL0_TOG_SLOPE_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_TOG_SLOPE_CAL_SHIFT)) & TMPSNS_CTRL0_TOG_SLOPE_CAL_MASK)
◆ TMPSNS_CTRL0_TOG_SLOPE_CAL [2/2]
◆ TMPSNS_CTRL0_TOG_V_SEL [1/2]
#define TMPSNS_CTRL0_TOG_V_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_TOG_V_SEL_SHIFT)) & TMPSNS_CTRL0_TOG_V_SEL_MASK)
◆ TMPSNS_CTRL0_TOG_V_SEL [2/2]
◆ TMPSNS_CTRL0_V_SEL [1/2]
#define TMPSNS_CTRL0_V_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL0_V_SEL_SHIFT)) & TMPSNS_CTRL0_V_SEL_MASK)
V_SEL - Voltage Select 0b00..Normal temperature measuring mode 0b01-0b10..Reserved
◆ TMPSNS_CTRL0_V_SEL [2/2]
◆ TMPSNS_CTRL1_CLR_FINISH_IE [1/2]
#define TMPSNS_CTRL1_CLR_FINISH_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_CLR_FINISH_IE_MASK)
FINISH_IE - Measurement finished interrupt enable
◆ TMPSNS_CTRL1_CLR_FINISH_IE [2/2]
◆ TMPSNS_CTRL1_CLR_FREQ [1/2]
#define TMPSNS_CTRL1_CLR_FREQ (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_FREQ_SHIFT)) & TMPSNS_CTRL1_CLR_FREQ_MASK)
FREQ - Temperature Measurement Frequency
◆ TMPSNS_CTRL1_CLR_FREQ [2/2]
◆ TMPSNS_CTRL1_CLR_HIGH_TEMP_IE [1/2]
#define TMPSNS_CTRL1_CLR_HIGH_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_CLR_HIGH_TEMP_IE_MASK)
HIGH_TEMP_IE - High temperature interrupt enable
◆ TMPSNS_CTRL1_CLR_HIGH_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_CLR_LOW_TEMP_IE [1/2]
#define TMPSNS_CTRL1_CLR_LOW_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_CLR_LOW_TEMP_IE_MASK)
LOW_TEMP_IE - Low temperature interrupt enable
◆ TMPSNS_CTRL1_CLR_LOW_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_CLR_PANIC_TEMP_IE [1/2]
#define TMPSNS_CTRL1_CLR_PANIC_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_CLR_PANIC_TEMP_IE_MASK)
PANIC_TEMP_IE - Panic temperature interrupt enable
◆ TMPSNS_CTRL1_CLR_PANIC_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_CLR_PWD [1/2]
#define TMPSNS_CTRL1_CLR_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_PWD_SHIFT)) & TMPSNS_CTRL1_CLR_PWD_MASK)
PWD - Temperature Sensor Power Down
◆ TMPSNS_CTRL1_CLR_PWD [2/2]
◆ TMPSNS_CTRL1_CLR_PWD_FULL [1/2]
#define TMPSNS_CTRL1_CLR_PWD_FULL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_CLR_PWD_FULL_MASK)
PWD_FULL - Temperature Sensor Full Power Down
◆ TMPSNS_CTRL1_CLR_PWD_FULL [2/2]
◆ TMPSNS_CTRL1_CLR_RFU [1/2]
#define TMPSNS_CTRL1_CLR_RFU (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_RFU_SHIFT)) & TMPSNS_CTRL1_CLR_RFU_MASK)
RFU - Read/Writeable field. Reserved for future use
◆ TMPSNS_CTRL1_CLR_RFU [2/2]
◆ TMPSNS_CTRL1_CLR_START [1/2]
#define TMPSNS_CTRL1_CLR_START (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_CLR_START_SHIFT)) & TMPSNS_CTRL1_CLR_START_MASK)
START - Start Temperature Measurement
◆ TMPSNS_CTRL1_CLR_START [2/2]
◆ TMPSNS_CTRL1_FINISH_IE [1/2]
#define TMPSNS_CTRL1_FINISH_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_FINISH_IE_MASK)
FINISH_IE - Measurement finished interrupt enable 0b0..Interrupt is disabled 0b1..Interrupt is enabled
◆ TMPSNS_CTRL1_FINISH_IE [2/2]
◆ TMPSNS_CTRL1_FREQ [1/2]
#define TMPSNS_CTRL1_FREQ (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_FREQ_SHIFT)) & TMPSNS_CTRL1_FREQ_MASK)
FREQ - Temperature Measurement Frequency 0b0000000000000000..Single Reading Mode. New reading available every time CTRL1[START] bit is set to 1 from 0. 0b0000000000000001-0b1111111111111111..Continuous Reading Mode. Next temperature reading taken after programmed number of cycles after current reading is complete.
◆ TMPSNS_CTRL1_FREQ [2/2]
◆ TMPSNS_CTRL1_HIGH_TEMP_IE [1/2]
#define TMPSNS_CTRL1_HIGH_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_HIGH_TEMP_IE_MASK)
HIGH_TEMP_IE - High temperature interrupt enable 0b0..Interrupt is disabled 0b1..Interrupt is enabled
◆ TMPSNS_CTRL1_HIGH_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_LOW_TEMP_IE [1/2]
#define TMPSNS_CTRL1_LOW_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_LOW_TEMP_IE_MASK)
LOW_TEMP_IE - Low temperature interrupt enable 0b0..Interrupt is disabled 0b1..Interrupt is enabled
◆ TMPSNS_CTRL1_LOW_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_PANIC_TEMP_IE [1/2]
#define TMPSNS_CTRL1_PANIC_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_PANIC_TEMP_IE_MASK)
PANIC_TEMP_IE - Panic temperature interrupt enable 0b0..Interrupt is disabled 0b1..Interrupt is enabled
◆ TMPSNS_CTRL1_PANIC_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_PWD [1/2]
#define TMPSNS_CTRL1_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_PWD_SHIFT)) & TMPSNS_CTRL1_PWD_MASK)
PWD - Temperature Sensor Power Down 0b0..Sensor is active 0b1..Sensor is powered down
◆ TMPSNS_CTRL1_PWD [2/2]
◆ TMPSNS_CTRL1_PWD_FULL [1/2]
#define TMPSNS_CTRL1_PWD_FULL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_PWD_FULL_MASK)
PWD_FULL - Temperature Sensor Full Power Down 0b0..Sensor is active 0b1..Sensor is powered down
◆ TMPSNS_CTRL1_PWD_FULL [2/2]
◆ TMPSNS_CTRL1_RFU [1/2]
#define TMPSNS_CTRL1_RFU (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_RFU_SHIFT)) & TMPSNS_CTRL1_RFU_MASK)
◆ TMPSNS_CTRL1_RFU [2/2]
◆ TMPSNS_CTRL1_SET_FINISH_IE [1/2]
#define TMPSNS_CTRL1_SET_FINISH_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_SET_FINISH_IE_MASK)
◆ TMPSNS_CTRL1_SET_FINISH_IE [2/2]
◆ TMPSNS_CTRL1_SET_FREQ [1/2]
#define TMPSNS_CTRL1_SET_FREQ (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_FREQ_SHIFT)) & TMPSNS_CTRL1_SET_FREQ_MASK)
◆ TMPSNS_CTRL1_SET_FREQ [2/2]
◆ TMPSNS_CTRL1_SET_HIGH_TEMP_IE [1/2]
#define TMPSNS_CTRL1_SET_HIGH_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_SET_HIGH_TEMP_IE_MASK)
◆ TMPSNS_CTRL1_SET_HIGH_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_SET_LOW_TEMP_IE [1/2]
#define TMPSNS_CTRL1_SET_LOW_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_SET_LOW_TEMP_IE_MASK)
◆ TMPSNS_CTRL1_SET_LOW_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_SET_PANIC_TEMP_IE [1/2]
#define TMPSNS_CTRL1_SET_PANIC_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_SET_PANIC_TEMP_IE_MASK)
◆ TMPSNS_CTRL1_SET_PANIC_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_SET_PWD [1/2]
#define TMPSNS_CTRL1_SET_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_PWD_SHIFT)) & TMPSNS_CTRL1_SET_PWD_MASK)
◆ TMPSNS_CTRL1_SET_PWD [2/2]
◆ TMPSNS_CTRL1_SET_PWD_FULL [1/2]
#define TMPSNS_CTRL1_SET_PWD_FULL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_SET_PWD_FULL_MASK)
◆ TMPSNS_CTRL1_SET_PWD_FULL [2/2]
◆ TMPSNS_CTRL1_SET_RFU [1/2]
#define TMPSNS_CTRL1_SET_RFU (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_RFU_SHIFT)) & TMPSNS_CTRL1_SET_RFU_MASK)
◆ TMPSNS_CTRL1_SET_RFU [2/2]
◆ TMPSNS_CTRL1_SET_START [1/2]
#define TMPSNS_CTRL1_SET_START (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_SET_START_SHIFT)) & TMPSNS_CTRL1_SET_START_MASK)
◆ TMPSNS_CTRL1_SET_START [2/2]
◆ TMPSNS_CTRL1_START [1/2]
#define TMPSNS_CTRL1_START (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_START_SHIFT)) & TMPSNS_CTRL1_START_MASK)
START - Start Temperature Measurement 0b0..No new temperature reading taken 0b1..Initiate a new temperature reading
◆ TMPSNS_CTRL1_START [2/2]
◆ TMPSNS_CTRL1_TOG_FINISH_IE [1/2]
#define TMPSNS_CTRL1_TOG_FINISH_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_FINISH_IE_SHIFT)) & TMPSNS_CTRL1_TOG_FINISH_IE_MASK)
◆ TMPSNS_CTRL1_TOG_FINISH_IE [2/2]
◆ TMPSNS_CTRL1_TOG_FREQ [1/2]
#define TMPSNS_CTRL1_TOG_FREQ (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_FREQ_SHIFT)) & TMPSNS_CTRL1_TOG_FREQ_MASK)
◆ TMPSNS_CTRL1_TOG_FREQ [2/2]
◆ TMPSNS_CTRL1_TOG_HIGH_TEMP_IE [1/2]
#define TMPSNS_CTRL1_TOG_HIGH_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_HIGH_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_TOG_HIGH_TEMP_IE_MASK)
◆ TMPSNS_CTRL1_TOG_HIGH_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_TOG_LOW_TEMP_IE [1/2]
#define TMPSNS_CTRL1_TOG_LOW_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_LOW_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_TOG_LOW_TEMP_IE_MASK)
◆ TMPSNS_CTRL1_TOG_LOW_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_TOG_PANIC_TEMP_IE [1/2]
#define TMPSNS_CTRL1_TOG_PANIC_TEMP_IE (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_PANIC_TEMP_IE_SHIFT)) & TMPSNS_CTRL1_TOG_PANIC_TEMP_IE_MASK)
◆ TMPSNS_CTRL1_TOG_PANIC_TEMP_IE [2/2]
◆ TMPSNS_CTRL1_TOG_PWD [1/2]
#define TMPSNS_CTRL1_TOG_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_PWD_SHIFT)) & TMPSNS_CTRL1_TOG_PWD_MASK)
◆ TMPSNS_CTRL1_TOG_PWD [2/2]
◆ TMPSNS_CTRL1_TOG_PWD_FULL [1/2]
#define TMPSNS_CTRL1_TOG_PWD_FULL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_PWD_FULL_SHIFT)) & TMPSNS_CTRL1_TOG_PWD_FULL_MASK)
◆ TMPSNS_CTRL1_TOG_PWD_FULL [2/2]
◆ TMPSNS_CTRL1_TOG_RFU [1/2]
#define TMPSNS_CTRL1_TOG_RFU (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_RFU_SHIFT)) & TMPSNS_CTRL1_TOG_RFU_MASK)
◆ TMPSNS_CTRL1_TOG_RFU [2/2]
◆ TMPSNS_CTRL1_TOG_START [1/2]
#define TMPSNS_CTRL1_TOG_START (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_CTRL1_TOG_START_SHIFT)) & TMPSNS_CTRL1_TOG_START_MASK)
◆ TMPSNS_CTRL1_TOG_START [2/2]
◆ TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL_MASK)
HIGH_TEMP_VAL - High temperature threshold value
◆ TMPSNS_RANGE0_CLR_HIGH_TEMP_VAL [2/2]
◆ TMPSNS_RANGE0_CLR_LOW_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_CLR_LOW_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_CLR_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_CLR_LOW_TEMP_VAL_MASK)
LOW_TEMP_VAL - Low temperature threshold value
◆ TMPSNS_RANGE0_CLR_LOW_TEMP_VAL [2/2]
◆ TMPSNS_RANGE0_HIGH_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_HIGH_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_HIGH_TEMP_VAL_MASK)
◆ TMPSNS_RANGE0_HIGH_TEMP_VAL [2/2]
◆ TMPSNS_RANGE0_LOW_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_LOW_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_LOW_TEMP_VAL_MASK)
◆ TMPSNS_RANGE0_LOW_TEMP_VAL [2/2]
◆ TMPSNS_RANGE0_SET_HIGH_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_SET_HIGH_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_SET_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_SET_HIGH_TEMP_VAL_MASK)
◆ TMPSNS_RANGE0_SET_HIGH_TEMP_VAL [2/2]
◆ TMPSNS_RANGE0_SET_LOW_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_SET_LOW_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_SET_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_SET_LOW_TEMP_VAL_MASK)
◆ TMPSNS_RANGE0_SET_LOW_TEMP_VAL [2/2]
◆ TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL_MASK)
◆ TMPSNS_RANGE0_TOG_HIGH_TEMP_VAL [2/2]
◆ TMPSNS_RANGE0_TOG_LOW_TEMP_VAL [1/2]
#define TMPSNS_RANGE0_TOG_LOW_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE0_TOG_LOW_TEMP_VAL_SHIFT)) & TMPSNS_RANGE0_TOG_LOW_TEMP_VAL_MASK)
◆ TMPSNS_RANGE0_TOG_LOW_TEMP_VAL [2/2]
◆ TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL [1/2]
#define TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL_MASK)
PANIC_TEMP_VAL - Panic temperature threshold value
◆ TMPSNS_RANGE1_CLR_PANIC_TEMP_VAL [2/2]
◆ TMPSNS_RANGE1_PANIC_TEMP_VAL [1/2]
#define TMPSNS_RANGE1_PANIC_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_PANIC_TEMP_VAL_MASK)
◆ TMPSNS_RANGE1_PANIC_TEMP_VAL [2/2]
◆ TMPSNS_RANGE1_SET_PANIC_TEMP_VAL [1/2]
#define TMPSNS_RANGE1_SET_PANIC_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_SET_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_SET_PANIC_TEMP_VAL_MASK)
◆ TMPSNS_RANGE1_SET_PANIC_TEMP_VAL [2/2]
◆ TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL [1/2]
#define TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL_SHIFT)) & TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL_MASK)
◆ TMPSNS_RANGE1_TOG_PANIC_TEMP_VAL [2/2]
◆ TMPSNS_STATUS0_FINISH [1/2]
#define TMPSNS_STATUS0_FINISH (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_FINISH_SHIFT)) & TMPSNS_STATUS0_FINISH_MASK)
FINISH - Temperature measurement complete 0b0..Temperature sensor is busy (if CTRL1[START] = 1)or no new reading has been initiated (if CTRL1[START] = 0) 0b1..Temperature reading is complete and new temperature value available for reading
◆ TMPSNS_STATUS0_FINISH [2/2]
◆ TMPSNS_STATUS0_HIGH_TEMP [1/2]
#define TMPSNS_STATUS0_HIGH_TEMP (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_HIGH_TEMP_SHIFT)) & TMPSNS_STATUS0_HIGH_TEMP_MASK)
HIGH_TEMP - High temperature alarm bit 0b0..No High temperature alert 0b1..High temperature alert
◆ TMPSNS_STATUS0_HIGH_TEMP [2/2]
◆ TMPSNS_STATUS0_LOW_TEMP [1/2]
#define TMPSNS_STATUS0_LOW_TEMP (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_LOW_TEMP_SHIFT)) & TMPSNS_STATUS0_LOW_TEMP_MASK)
LOW_TEMP - Low temperature alarm bit 0b0..No Low temperature alert 0b1..Low temperature alert
◆ TMPSNS_STATUS0_LOW_TEMP [2/2]
◆ TMPSNS_STATUS0_PANIC_TEMP [1/2]
#define TMPSNS_STATUS0_PANIC_TEMP (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_PANIC_TEMP_SHIFT)) & TMPSNS_STATUS0_PANIC_TEMP_MASK)
PANIC_TEMP - Panic temperature alarm bit 0b0..No Panic temperature alert 0b1..Panic temperature alert
◆ TMPSNS_STATUS0_PANIC_TEMP [2/2]
◆ TMPSNS_STATUS0_TEMP_VAL [1/2]
#define TMPSNS_STATUS0_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << TMPSNS_STATUS0_TEMP_VAL_SHIFT)) & TMPSNS_STATUS0_TEMP_VAL_MASK)
TEMP_VAL - Measured temperature value
◆ TMPSNS_STATUS0_TEMP_VAL [2/2]
