RTEMS 6.2
Files | Data Structures | Functions
spec:/score/thread/val/fatal-idle-thread-create-failed
Tests a fatal error caused by a failing task create extension. More...
file  tr-fatal-idle-thread-create-failed.c
file  tr-fatal-idle-thread-create-failed.h
struct  ScoreThreadValFatalIdleThreadCreateFailed_Context
 Test context for spec:/score/thread/val/fatal-idle-thread-create-failed test case. More...
void ScoreThreadValFatalIdleThreadCreateFailed_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case.
This test case performs the following actions:
◆ ScoreThreadValFatalIdleThreadCreateFailed_Run()
void ScoreThreadValFatalIdleThreadCreateFailed_Run ( rtems_fatal_source  source,
Parameters
sourceis the fatal source.
codeis the fatal code.
