RTEMS 6.2
Tests a fatal error. More...
Files | |
| file | tr-fatal-scheduler-requires-exactly-one-processor.c |
| file | tr-fatal-scheduler-requires-exactly-one-processor.h |
| struct | ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Context |
| Test context for spec:/score/smp/val/fatal-scheduler-requires-exactly-one-processor test case. More... | |
| void | ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void ScoreSmpValFatalSchedulerRequiresExactlyOneProcessor_Run | ( | rtems_fatal_source | source, |
| rtems_fatal_code | code | ||
| source | is fatal source. |
| code | is fatal code. |
