RTEMS 6.2
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RDY (SWPMI_TypeDef *SWPMIx) |
| Enable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_EnableIT_RDY. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_SR (SWPMI_TypeDef *SWPMIx) |
| Enable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_EnableIT_SR. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TC (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_EnableIT_TC. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TX (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit interrupt @rmtoll IER TIE LL_SWPMI_EnableIT_TX. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RX (SWPMI_TypeDef *SWPMIx) |
| Enable Receive interrupt @rmtoll IER RIE LL_SWPMI_EnableIT_RX. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_EnableIT_TXUNR. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Enable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_EnableIT_RXOVR. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RXBER (SWPMI_TypeDef *SWPMIx) |
| Enable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_EnableIT_RXBER. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TXBE (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_EnableIT_TXBE. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RXBF (SWPMI_TypeDef *SWPMIx) |
| Enable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_EnableIT_RXBF. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RDY (SWPMI_TypeDef *SWPMIx) |
| Disable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_DisableIT_RDY. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_SR (SWPMI_TypeDef *SWPMIx) |
| Disable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_DisableIT_SR. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TC (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_DisableIT_TC. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TX (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit interrupt @rmtoll IER TIE LL_SWPMI_DisableIT_TX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RX (SWPMI_TypeDef *SWPMIx) |
| Disable Receive interrupt @rmtoll IER RIE LL_SWPMI_DisableIT_RX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_DisableIT_TXUNR. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Disable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_DisableIT_RXOVR. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RXBER (SWPMI_TypeDef *SWPMIx) |
| Disable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_DisableIT_RXBER. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TXBE (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_DisableIT_TXBE. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RXBF (SWPMI_TypeDef *SWPMIx) |
| Disable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_DisableIT_RXBF. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RDY (SWPMI_TypeDef *SWPMIx) |
| Check if SWPMI transceiver ready interrupt is enabled @rmtoll IER RDYIE LL_SWPMI_IsEnabledIT_RDY. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_SR (SWPMI_TypeDef *SWPMIx) |
| Check if Slave resume interrupt is enabled @rmtoll IER SRIE LL_SWPMI_IsEnabledIT_SR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TC (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit complete interrupt is enabled @rmtoll IER TCIE LL_SWPMI_IsEnabledIT_TC. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TX (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit interrupt is enabled @rmtoll IER TIE LL_SWPMI_IsEnabledIT_TX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RX (SWPMI_TypeDef *SWPMIx) |
| Check if Receive interrupt is enabled @rmtoll IER RIE LL_SWPMI_IsEnabledIT_RX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit underrun error interrupt is enabled @rmtoll IER TXUNRIE LL_SWPMI_IsEnabledIT_TXUNR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Check if Receive overrun error interrupt is enabled @rmtoll IER RXOVRIE LL_SWPMI_IsEnabledIT_RXOVR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RXBER (SWPMI_TypeDef *SWPMIx) |
| Check if Receive CRC error interrupt is enabled @rmtoll IER RXBERIE LL_SWPMI_IsEnabledIT_RXBER. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TXBE (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit buffer empty interrupt is enabled @rmtoll IER TXBEIE LL_SWPMI_IsEnabledIT_TXBE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RXBF (SWPMI_TypeDef *SWPMIx) |
| Check if Receive buffer full interrupt is enabled @rmtoll IER RXBFIE LL_SWPMI_IsEnabledIT_RXBF. | |
| __STATIC_INLINE void LL_SWPMI_DisableIT_RDY | ( | SWPMI_TypeDef * | SWPMIx | ) |
| SWPMIx | SWPMI Instance |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_RX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_RXBER | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_RXBF | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_RXOVR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_SR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_TC | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_TX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_TXBE | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableIT_TXUNR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_RDY | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_RX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_RXBER | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_RXBF | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_RXOVR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_SR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_TC | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_TX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_TXBE | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableIT_TXUNR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RDY | ( | SWPMI_TypeDef * | SWPMIx | ) |
| State | of bit (1 or 0). |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBER | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBF | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXOVR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_SR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TC | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXBE | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXUNR | ( | SWPMI_TypeDef * | SWPMIx | ) |
