RTEMS 6.2
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXBF (SWPMI_TypeDef *SWPMIx) |
| Check if the last word of the frame under reception has arrived in SWPMI_RDR. @rmtoll ISR RXBFF LL_SWPMI_IsActiveFlag_RXBF. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TXBE (SWPMI_TypeDef *SWPMIx) |
| Check if Frame transmission buffer has been emptied @rmtoll ISR TXBEF LL_SWPMI_IsActiveFlag_TXBE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXBER (SWPMI_TypeDef *SWPMIx) |
| Check if CRC error in reception has been detected @rmtoll ISR RXBERF LL_SWPMI_IsActiveFlag_RXBER. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Check if Overrun in reception has been detected @rmtoll ISR RXOVRF LL_SWPMI_IsActiveFlag_RXOVR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Check if underrun error in transmission has been detected @rmtoll ISR TXUNRF LL_SWPMI_IsActiveFlag_TXUNR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXNE (SWPMI_TypeDef *SWPMIx) |
| Check if Receive data register not empty (it means that Received data is ready to be read in the SWPMI_RDR register) @rmtoll ISR RXNE LL_SWPMI_IsActiveFlag_RXNE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TXE (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit data register is empty (it means that Data written in transmit data register SWPMI_TDR has been transmitted and SWPMI_TDR can be written to again) @rmtoll ISR TXE LL_SWPMI_IsActiveFlag_TXE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TC (SWPMI_TypeDef *SWPMIx) |
| Check if Both transmission and reception are completed and SWP is switched to the SUSPENDED state @rmtoll ISR TCF LL_SWPMI_IsActiveFlag_TC. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_SR (SWPMI_TypeDef *SWPMIx) |
| Check if a Resume by slave state has been detected during the SWP bus SUSPENDED state @rmtoll ISR SRF LL_SWPMI_IsActiveFlag_SR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_SUSP (SWPMI_TypeDef *SWPMIx) |
| Check if SWP bus is in SUSPENDED or DEACTIVATED state @rmtoll ISR SUSP LL_SWPMI_IsActiveFlag_SUSP. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_DEACT (SWPMI_TypeDef *SWPMIx) |
| Check if SWP bus is in DEACTIVATED state @rmtoll ISR DEACTF LL_SWPMI_IsActiveFlag_DEACT. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RDYF (SWPMI_TypeDef *SWPMIx) |
| Check if SWPMI transceiver is ready @rmtoll ISR RDYF LL_SWPMI_IsActiveFlag_RDYF. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RXBF (SWPMI_TypeDef *SWPMIx) |
| Clear receive buffer full flag @rmtoll ICR CRXBFF LL_SWPMI_ClearFlag_RXBF. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_TXBE (SWPMI_TypeDef *SWPMIx) |
| Clear transmit buffer empty flag @rmtoll ICR CTXBEF LL_SWPMI_ClearFlag_TXBE. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RXBER (SWPMI_TypeDef *SWPMIx) |
| Clear receive CRC error flag @rmtoll ICR CRXBERF LL_SWPMI_ClearFlag_RXBER. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Clear receive overrun error flag @rmtoll ICR CRXOVRF LL_SWPMI_ClearFlag_RXOVR. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Clear transmit underrun error flag @rmtoll ICR CTXUNRF LL_SWPMI_ClearFlag_TXUNR. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_TC (SWPMI_TypeDef *SWPMIx) |
| Clear transfer complete flag @rmtoll ICR CTCF LL_SWPMI_ClearFlag_TC. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_SR (SWPMI_TypeDef *SWPMIx) |
| Clear slave resume flag @rmtoll ICR CSRF LL_SWPMI_ClearFlag_SR. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RDY (SWPMI_TypeDef *SWPMIx) |
| Clear SWPMI transceiver ready flag @rmtoll ISR CRDYF LL_SWPMI_ClearFlag_RDY. | |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_RDY | ( | SWPMI_TypeDef * | SWPMIx | ) |
| SWPMIx | SWPMI Instance |
| None |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_RXBER | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_RXBF | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_RXOVR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_SR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_TC | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_TXBE | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_ClearFlag_TXUNR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_DEACT | ( | SWPMI_TypeDef * | SWPMIx | ) |
| State | of bit (1 or 0). |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RDYF | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBER | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBF | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXNE | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXOVR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SR | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SUSP | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TC | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXBE | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXE | ( | SWPMI_TypeDef * | SWPMIx | ) |
| __STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXUNR | ( | SWPMI_TypeDef * | SWPMIx | ) |
