RTEMS 6.2
| __STATIC_INLINE void | LL_SWPMI_EnableDMAReq_RX (SWPMI_TypeDef *SWPMIx) |
| Enable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_EnableDMAReq_RX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableDMAReq_RX (SWPMI_TypeDef *SWPMIx) |
| Disable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_DisableDMAReq_RX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledDMAReq_RX (SWPMI_TypeDef *SWPMIx) |
| Check if DMA mode for reception is enabled @rmtoll CR RXDMA LL_SWPMI_IsEnabledDMAReq_RX. | |
| __STATIC_INLINE void | LL_SWPMI_EnableDMAReq_TX (SWPMI_TypeDef *SWPMIx) |
| Enable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_EnableDMAReq_TX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableDMAReq_TX (SWPMI_TypeDef *SWPMIx) |
| Disable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_DisableDMAReq_TX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledDMAReq_TX (SWPMI_TypeDef *SWPMIx) |
| Check if DMA mode for transmission is enabled @rmtoll CR TXDMA LL_SWPMI_IsEnabledDMAReq_TX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_DMA_GetRegAddr (SWPMI_TypeDef *SWPMIx, uint32_t Direction) |
| Get the data register address used for DMA transfer @rmtoll TDR TD LL_SWPMI_DMA_GetRegAddr RDR RD LL_SWPMI_DMA_GetRegAddr. | |
| __STATIC_INLINE void LL_SWPMI_DisableDMAReq_RX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| SWPMIx | SWPMI Instance |
| None |
| __STATIC_INLINE void LL_SWPMI_DisableDMAReq_TX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE uint32_t LL_SWPMI_DMA_GetRegAddr | ( | SWPMI_TypeDef * | SWPMIx, |
| uint32_t | Direction | ||
| Direction | This parameter can be one of the following values: |
| Address | of data register |
| __STATIC_INLINE void LL_SWPMI_EnableDMAReq_RX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE void LL_SWPMI_EnableDMAReq_TX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| None |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_RX | ( | SWPMI_TypeDef * | SWPMIx | ) |
| State | of bit (1 or 0). |
| __STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_TX | ( | SWPMI_TypeDef * | SWPMIx | ) |
