RTEMS 6.2
macros to handle interrupts and specific configurations More...
#define __HAL_SAI_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SAI_STATE_RESET)
 Reset SAI handle state.
#define __HAL_SAI_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->IMR |= (__INTERRUPT__))
 Enable the specified SAI interrupts.
#define __HAL_SAI_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->IMR &= (~(__INTERRUPT__)))
 Disable the specified SAI interrupts.
#define __HAL_SAI_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)   ((((__HANDLE__)->Instance->IMR & (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET)
 Check whether the specified SAI interrupt source is enabled or not.
#define __HAL_SAI_GET_FLAG(__HANDLE__, __FLAG__)   ((((__HANDLE__)->Instance->SR) & (__FLAG__)) == (__FLAG__))
 Check whether the specified SAI flag is set or not.
#define __HAL_SAI_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->CLRFR = (__FLAG__))
 Clear the specified SAI pending flag.
#define __HAL_SAI_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 |= SAI_xCR1_SAIEN)
 Enable SAI.
#define __HAL_SAI_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 &= ~SAI_xCR1_SAIEN)
 Disable SAI.
◆ __HAL_SAI_CLEAR_FLAG
#define __HAL_SAI_CLEAR_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__HANDLE__specifies the SAI Handle.
__FLAG__specifies the flag to check. This parameter can be any combination of the following values:
  • SAI_FLAG_OVRUDR: Clear Overrun underrun
  • SAI_FLAG_MUTEDET: Clear Mute detection
  • SAI_FLAG_WCKCFG: Clear Wrong Clock Configuration
  • SAI_FLAG_FREQ: Clear FIFO request
  • SAI_FLAG_CNRDY: Clear Codec not ready
  • SAI_FLAG_AFSDET: Clear Anticipated frame synchronization detection
  • SAI_FLAG_LFSDET: Clear Late frame synchronization detection
Return values
None
◆ __HAL_SAI_DISABLE
#define __HAL_SAI_DISABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR1 &= ~SAI_xCR1_SAIEN)
Disable SAI.
Parameters
Return values
None
◆ __HAL_SAI_DISABLE_IT
#define __HAL_SAI_DISABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the interrupt source to enable or disable. This parameter can be one of the following values:
  • SAI_IT_OVRUDR: Overrun underrun interrupt enable
  • SAI_IT_MUTEDET: Mute detection interrupt enable
  • SAI_IT_WCKCFG: Wrong Clock Configuration interrupt enable
  • SAI_IT_FREQ: FIFO request interrupt enable
  • SAI_IT_CNRDY: Codec not ready interrupt enable
  • SAI_IT_AFSDET: Anticipated frame synchronization detection interrupt enable
  • SAI_IT_LFSDET: Late frame synchronization detection interrupt enable
Return values
None
◆ __HAL_SAI_ENABLE
#define __HAL_SAI_ENABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR1 |= SAI_xCR1_SAIEN)
Enable SAI.
Parameters
Return values
None
◆ __HAL_SAI_ENABLE_IT
#define __HAL_SAI_ENABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
Return values
None
◆ __HAL_SAI_GET_FLAG
#define __HAL_SAI_GET_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__FLAG__specifies the flag to check. This parameter can be one of the following values:
  • SAI_FLAG_OVRUDR: Overrun underrun flag.
  • SAI_FLAG_MUTEDET: Mute detection flag.
  • SAI_FLAG_WCKCFG: Wrong Clock Configuration flag.
  • SAI_FLAG_FREQ: FIFO request flag.
  • SAI_FLAG_CNRDY: Codec not ready flag.
  • SAI_FLAG_AFSDET: Anticipated frame synchronization detection flag.
  • SAI_FLAG_LFSDET: Late frame synchronization detection flag.
Return values
Thenew state of FLAG (TRUE or FALSE).
◆ __HAL_SAI_GET_IT_SOURCE
#define __HAL_SAI_GET_IT_SOURCE (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the SAI interrupt source to check. This parameter can be one of the following values:
Return values
Thenew state of INTERRUPT (TRUE or FALSE).
◆ __HAL_SAI_RESET_HANDLE_STATE
#define __HAL_SAI_RESET_HANDLE_STATE (   __HANDLE__)    ((__HANDLE__)->State = HAL_SAI_STATE_RESET)
Parameters
Return values
None
