RTEMS 6.2
This group contains the API Mutex Handler implementation. More...
Modules | |
| RTEMS Allocator Mutex | |
| Protection for all memory allocations and deallocations in RTEMS. | |
Files | |
| file | apimutex.h |
| This header file provides the interfaces of the API Mutex Handler. | |
| file | allocatormutex.c |
| This source file contains the implementation of _RTEMS_Lock_allocator(), _RTEMS_Unlock_allocator(), and _RTEMS_Allocator_is_owner(). | |
| file | apimutexisowner.c |
| This source file contains the implementation of _API_Mutex_Is_owner(). | |
| file | apimutexlock.c |
| This source file contains the implementation of _API_Mutex_Lock(). | |
| file | apimutexunlock.c |
| This source file contains the implementation of _API_Mutex_Unlock(). | |
| struct | API_Mutex_Control |
| Control block used to manage each API mutex. More... | |
| #define | API_MUTEX_INITIALIZER(name) { _MUTEX_RECURSIVE_NAMED_INITIALIZER( name ), 0 } |
| Statically initialize an API mutex. | |
| void | _API_Mutex_Lock (API_Mutex_Control *mutex) |
| Acquires the specified API mutex. | |
| void | _API_Mutex_Unlock (API_Mutex_Control *mutex) |
| Releases the specified API mutex. | |
| bool | _API_Mutex_Is_owner (const API_Mutex_Control *mutex) |
| Checks if the specified API mutex is owned by the executing thread. | |
This handler provides routines to ensure mutual exclusion in a thread context at the API level.
| bool _API_Mutex_Is_owner | ( | const API_Mutex_Control * | mutex | ) |
| [in] | mutex | The API mutex to check the owner from. |
| void _API_Mutex_Lock | ( | API_Mutex_Control * | mutex | ) |
| [in,out] | mutex | The API mutex to acquire. |
| void _API_Mutex_Unlock | ( | API_Mutex_Control * | mutex | ) |
| [in,out] | mutex | The API mutex to release. |
