RTEMS 6.2
Files | Data Structures | Macros | Functions
Xilinx Triple Timer Counter (TTC) Clock Driver
This group contains the Xilinx Triple Timer Counter (TTC) Clock Driver implementation. More...
file  xttcps_hw.h
file  xil-ttc.c
 This source file contains a Clock Driver implementation using the Xilinx Triple Timer Counter (TTC).
struct  xil_ttc_timecounter
#define XTTCPS_HW_H   /* by using protection macros */
#define ARMA9
#define Clock_driver_support_at_tick(arg)    xil_ttc_clock_driver_support_at_tick(arg)
#define Clock_driver_support_initialize_hardware    xil_ttc_clock_driver_support_initialize_hardware
#define Clock_driver_support_install_isr(isr)    xil_ttc_clock_driver_support_install_isr(isr)
uint32_t _CPU_Counter_frequency (void)
 Gets the current CPU counter frequency in Hz.
CPU_Counter_ticks _CPU_Counter_read (void)
 Gets the current CPU counter value.
 RTEMS_SYSINIT_ITEM (xil_ttc_initialize, RTEMS_SYSINIT_CPU_COUNTER, RTEMS_SYSINIT_ORDER_MIDDLE)
Register Map
Register offsets from the base address of the device.
#define XTTCPS_CLK_CNTRL_OFFSET   0x00000000U
#define XTTCPS_CNT_CNTRL_OFFSET   0x0000000CU
#define XTTCPS_COUNT_VALUE_OFFSET   0x00000018U
#define XTTCPS_INTERVAL_VAL_OFFSET   0x00000024U
#define XTTCPS_MATCH_0_OFFSET   0x00000030U
#define XTTCPS_MATCH_1_OFFSET   0x0000003CU
#define XTTCPS_MATCH_2_OFFSET   0x00000048U
#define XTTCPS_ISR_OFFSET   0x00000054U
#define XTTCPS_IER_OFFSET   0x00000060U
Clock Control Register
Clock Control Register definitions
#define XTTCPS_CLK_CNTRL_PS_EN_MASK   0x00000001U
#define XTTCPS_CLK_CNTRL_PS_VAL_MASK   0x0000001EU
#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT   1U
#define XTTCPS_CLK_CNTRL_PS_DISABLE   16U
#define XTTCPS_CLK_CNTRL_SRC_MASK   0x00000020U
#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK   0x00000040U
Counter Control Register
Counter Control Register definitions
#define XTTCPS_CNT_CNTRL_DIS_MASK   0x00000001U
#define XTTCPS_CNT_CNTRL_INT_MASK   0x00000002U
#define XTTCPS_CNT_CNTRL_DECR_MASK   0x00000004U
#define XTTCPS_CNT_CNTRL_MATCH_MASK   0x00000008U
#define XTTCPS_CNT_CNTRL_RST_MASK   0x00000010U
#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK   0x00000020U
#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK   0x00000040U
#define XTTCPS_CNT_CNTRL_RESET_VALUE   0x00000021U
Current Counter Value Register
Current Counter Value Register definitions
#define XTTCPS_COUNT_VALUE_MASK   0x0000FFFFU
Interval Value Register
Interval Value Register is the maximum value the counter will count up or down to.
#define XTTCPS_INTERVAL_VAL_MASK   0x0000FFFFU
Match Registers
Definitions for Match registers, each timer counter has three match registers.
#define XTTCPS_MATCH_MASK   0x0000FFFFU
#define XTTCPS_NUM_MATCH_REG   3U
Interrupt Registers
Following register bit mask is for all interrupt registers.
#define XTTCPS_IXR_INTERVAL_MASK   0x00000001U
#define XTTCPS_IXR_MATCH_0_MASK   0x00000002U
#define XTTCPS_IXR_MATCH_1_MASK   0x00000004U
#define XTTCPS_IXR_MATCH_2_MASK   0x00000008U
#define XTTCPS_IXR_CNT_OVR_MASK   0x00000010U
#define XTTCPS_IXR_ALL_MASK   0x0000001FU
#define XTtcPs_ReadReg(BaseAddress, RegOffset)    (Xil_In32((BaseAddress) + (u32)(RegOffset)))
#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data)    (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
#define XTtcPs_Match_N_Offset(MatchIndex)    ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
◆ XTTCPS_CLK_CNTRL_EXT_EDGE_MASK
External Clock edge
◆ XTTCPS_CLK_CNTRL_OFFSET
◆ XTTCPS_CLK_CNTRL_PS_DISABLE
Prescale disable
◆ XTTCPS_CLK_CNTRL_PS_EN_MASK
Prescale enable
◆ XTTCPS_CLK_CNTRL_PS_VAL_MASK
Prescale value
◆ XTTCPS_CLK_CNTRL_PS_VAL_SHIFT
Prescale shift
◆ XTTCPS_CLK_CNTRL_SRC_MASK
Clock source
◆ XTTCPS_CNT_CNTRL_DECR_MASK
Decrement mode
◆ XTTCPS_CNT_CNTRL_DIS_MASK
Disable the counter
◆ XTTCPS_CNT_CNTRL_EN_WAVE_MASK
Enable waveform
◆ XTTCPS_CNT_CNTRL_INT_MASK
Interval mode
◆ XTTCPS_CNT_CNTRL_MATCH_MASK
Match mode
◆ XTTCPS_CNT_CNTRL_OFFSET
◆ XTTCPS_CNT_CNTRL_POL_WAVE_MASK
Waveform polarity
◆ XTTCPS_CNT_CNTRL_RESET_VALUE
Reset value
◆ XTTCPS_CNT_CNTRL_RST_MASK
Reset counter
◆ XTTCPS_COUNT_VALUE_MASK
16-bit counter value
◆ XTTCPS_COUNT_VALUE_OFFSET
◆ XTTCPS_IER_OFFSET
Interrupt Enable Register
◆ XTTCPS_INTERVAL_VAL_MASK
16-bit Interval value
◆ XTTCPS_INTERVAL_VAL_OFFSET
Interval Count Value
◆ XTTCPS_ISR_OFFSET
Interrupt Status Register
◆ XTTCPS_IXR_ALL_MASK
All valid Interrupts
◆ XTTCPS_IXR_CNT_OVR_MASK
Counter Overflow
◆ XTTCPS_IXR_INTERVAL_MASK
Interval Interrupt
◆ XTTCPS_IXR_MATCH_0_MASK
Match 1 Interrupt
◆ XTTCPS_IXR_MATCH_1_MASK
Match 2 Interrupt
◆ XTTCPS_IXR_MATCH_2_MASK
Match 3 Interrupt
◆ XTTCPS_MATCH_0_OFFSET
Match 1 value
◆ XTTCPS_MATCH_1_OFFSET
Match 2 value
◆ XTTCPS_MATCH_2_OFFSET
Match 3 value
◆ XTTCPS_MATCH_MASK
16-bit Match value
◆ XTtcPs_Match_N_Offset
#define XTtcPs_Match_N_Offset (   MatchIndex)     ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
Calculate a match register offset using the Match Register index.
Parameters
MatchIndexis the 0-2 value of the match register
Returns
MATCH_N_OFFSET.
Note
C-style signature: u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
◆ XTTCPS_NUM_MATCH_REG
Num of Match reg
◆ XTtcPs_ReadReg
#define XTtcPs_ReadReg (   BaseAddress,
  RegOffset
Read the given Timer Counter register.
Parameters
BaseAddressis the base address of the timer counter device.
RegOffsetis the register offset to be read
Returns
The 32-bit value of the register
Note
C-style signature: u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
◆ XTtcPs_WriteReg
#define XTtcPs_WriteReg (   BaseAddress,
  RegOffset,
  Data
Write the given Timer Counter register.
Parameters
RegOffsetis the register offset to be written
Datais the 32-bit value to write to the register
Returns
None.
Note
C-style signature: void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset, u32 Data)
◆ _CPU_Counter_frequency()
uint32_t _CPU_Counter_frequency ( void  )
Returns
Returns the current CPU counter frequency in Hz.
◆ _CPU_Counter_read()
CPU_Counter_ticks _CPU_Counter_read ( void  )
A CPU counter should be some monotonically increasing free-running counter. It ticks usually with a frequency close to the CPU or system bus clock. The counter should not be affected by power saving states so that it can be used for timestamps. The CPU counter should be initialized at the RTEMS_SYSINIT_CPU_COUNTER initialization step if necessary. If RTEMS_PROFILING is enabled, the CPU counter may have to work very early in the system initialization to avoid invalid profiling statistics.
Returns
Returns the current CPU counter value.
