RTEMS 6.2
AHB Failing Address Register (AHBFAR)
This group contains register bit definitions. More...
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_SHIFT   0
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_MASK   0xffffffffU
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_GET(_reg)
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_SET(_reg, _val)
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS(_val)
◆ MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS (   _val)
Value:
( ( ( _val ) << MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_SHIFT ) & \
MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_MASK )
◆ MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_GET
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_GET (   _reg)
Value:
( ( ( _reg ) & MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_MASK ) >> \
◆ MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_SET
#define MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_MASK ) | \
MEMSCRUB_AHBFAR_AHB_FAILING_ADDRESS_MASK ) )
