RTEMS 6.2
Files | Functions | Variables
Motorola 68340 Board Support Package. More...
file  bsp.h
 Global BSP definitions.
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
int dbug_in_char (int minor)
void dbug_out_char (int minor, int ch)
int dbug_char_present (int minor)
void _dbug_dumpanic (void)
void _Init68340 (void)
rtems_isr_entry M68Kvec []
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
