RTEMS 6.2
Files | Macros | Functions | Variables
CSB3602 Board Support Package. More...
file  bsp.h
 Global BSP definitions.
#define BSP_MEM_ADDR_SRAM   0x20000000
#define BSP_MEM_SIZE_SRAM   4096
#define BSP_MEM_ADDR_SDRAM   0x00000000
#define BSP_MEM_MASK_SDRAM   0x01ffffff
#define BSP_MEM_SIZE_SDRAM   (32 * 1024 * 1024)
#define BSP_MBAR   0x10000000
#define BSP_RAMBAR   BSP_MEM_ADDR_SRAM
#define BSP_INTVEC_INT1   65
#define BSP_INTVEC_INT2   66
#define BSP_INTVEC_INT3   67
#define BSP_INTVEC_INT4   68
#define BSP_INTVEC_TMR0   69
#define BSP_INTVEC_TMR1   70
#define BSP_INTVEC_TMR2   71
#define BSP_INTVEC_TMR3   72
#define BSP_INTVEC_UART1   73
#define BSP_INTVEC_UART2   74
#define BSP_INTVEC_PLIP   75
#define BSP_INTVEC_PLIA   76
#define BSP_INTVEC_USB0   77
#define BSP_INTVEC_USB1   78
#define BSP_INTVEC_USB2   79
#define BSP_INTVEC_USB3   80
#define BSP_INTVEC_USB4   81
#define BSP_INTVEC_USB5   82
#define BSP_INTVEC_USB6   83
#define BSP_INTVEC_USB7   84
#define BSP_INTVEC_DMA   85
#define BSP_INTVEC_ERX   86
#define BSP_INTVEC_ETX   87
#define BSP_INTVEC_ENTC   88
#define BSP_INTVEC_QSPI   89
#define BSP_INTVEC_INT5   90
#define BSP_INTVEC_INT6   91
#define BSP_INTVEC_SWTO   92
#define BSP_INTLVL_INT1   1
#define BSP_INTLVL_INT2   1
#define BSP_INTLVL_INT3   1
#define BSP_INTLVL_INT4   1
#define BSP_INTLVL_TMR0   1
#define BSP_INTLVL_TMR1   1
#define BSP_INTLVL_TMR2   1
#define BSP_INTLVL_TMR3   1
#define BSP_INTLVL_UART1   1
#define BSP_INTLVL_UART2   1
#define BSP_INTLVL_PLIP   1
#define BSP_INTLVL_PLIA   1
#define BSP_INTLVL_USB0   1
#define BSP_INTLVL_USB1   1
#define BSP_INTLVL_USB2   1
#define BSP_INTLVL_USB3   1
#define BSP_INTLVL_USB4   1
#define BSP_INTLVL_USB5   1
#define BSP_INTLVL_USB6   1
#define BSP_INTLVL_USB7   1
#define BSP_INTLVL_DMA   1
#define BSP_INTLVL_ERX   1
#define BSP_INTLVL_ETX   1
#define BSP_INTLVL_ENTC   1
#define BSP_INTLVL_QSPI   1
#define BSP_INTLVL_INT5   1
#define BSP_INTLVL_INT6   1
#define BSP_INTLVL_SWTO   1
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth0"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_enet_driver_attach
#define BSP_SYSTEM_FREQUENCY   (66 * 1000 * 1000)
#define rtems_bsp_delay(microseconds)
#define RTC_DRIVER_TABLE_ENTRY    { rtc_initialize, NULL, NULL, NULL, NULL, NULL }
int rtems_enet_driver_attach (struct rtems_bsdnet_ifconfig *config)
rtems_device_driver rtc_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
void init5272 (void)
rtems_isr_entry M68Kvec []
rtems_isr(* rtems_clock_hook )(rtems_vector_number)
◆ rtems_bsp_delay
#define rtems_bsp_delay (   microseconds)
Value:
{ register uint32_t _delay=(microseconds); \
register uint32_t _tmp=123; \
__asm__ volatile( "0: \ nbcd %0 ; \ nbcd %0 ; \ dbf %1,0b" \
: "=d" (_tmp), "=d" (_delay) \
: "0" (_tmp), "1" (_delay) ); \
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
