RTEMS 6.2
| #define | CONFIGURE_INIT_TASK_ARGUMENTS |
| This configuration option is an integer define. | |
| #define | CONFIGURE_INIT_TASK_ATTRIBUTES |
| #define | CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE |
| #define | CONFIGURE_INIT_TASK_ENTRY_POINT |
| This configuration option is an initializer define. | |
| #define | CONFIGURE_INIT_TASK_INITIAL_MODES |
| #define | CONFIGURE_INIT_TASK_NAME |
| #define | CONFIGURE_INIT_TASK_PRIORITY |
| #define | CONFIGURE_INIT_TASK_STACK_SIZE |
| #define | CONFIGURE_RTEMS_INIT_TASKS_TABLE |
| This configuration option is a boolean feature define. | |
This section describes configuration options related to the Classic API initialization task.
| #define CONFIGURE_INIT_TASK_ARGUMENTS |
The value of this configuration option defines task argument of the Classic API initialization task.
| #define CONFIGURE_INIT_TASK_ATTRIBUTES |
The value of this configuration option defines the task attributes of the Classic API initialization task.
| #define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE |
The value of this configuration option defines the task storage size of the Classic API initialization task.
The following constraints apply to this configuration option:
If this configuration option is specified, then
<rtems/confdefs.h> for the Classic API initialization task,The
CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZEconfiguration options are mutually exclusive.
| #define CONFIGURE_INIT_TASK_ENTRY_POINT |
The value of this configuration option initializes the entry point of the Classic API initialization task.
Init.void ( *entry_point )( rtems_task_argument ).| #define CONFIGURE_INIT_TASK_INITIAL_MODES |
The value of this configuration option defines the initial execution mode of the Classic API initialization task.
| #define CONFIGURE_INIT_TASK_NAME |
The value of this configuration option defines the name of the Classic API initialization task.
| #define CONFIGURE_INIT_TASK_PRIORITY |
The value of this configuration option defines the initial priority of the Classic API initialization task.
| #define CONFIGURE_INIT_TASK_STACK_SIZE |
The value of this configuration option defines the task stack size of the Classic API initialization task.
<rtems/confdefs.h> does not overflow an integer of type uintptr_t. The
CONFIGURE_INIT_TASK_STACK_SIZE andconfiguration options are mutually exclusive.
| #define CONFIGURE_RTEMS_INIT_TASKS_TABLE |
In case this configuration option is defined, then exactly one Classic API initialization task is configured.
The application shall define at least one of the following configuration options
CONFIGURE_RTEMS_INIT_TASKS_TABLE,otherwise a compile time error in the configuration file will occur.
The Classic API initialization task performs the Global Construction.
