RTEMS 6.2
Macros | Typedefs | Functions
Red-Black Trees
The red-black tree container provides data structures and directives to manage user-defined data structures in red-black trees. More...
#define RTEMS_RBTREE_INITIALIZER_EMPTY(name)    RBTREE_INITIALIZER_EMPTY(name)
 RBTree initializer for an empty rbtree with designator name.
#define RTEMS_RBTREE_DEFINE_EMPTY(name)    RBTREE_DEFINE_EMPTY(name)
 RBTree definition for an empty rbtree with designator name.
typedef RBTree_Node rtems_rbtree_node
typedef RBTree_Control rtems_rbtree_control
typedef long rtems_rbtree_compare_result
 Integer type for compare results.
typedef rtems_rbtree_compare_result(* rtems_rbtree_compare) (const RBTree_Node *first, const RBTree_Node *second)
 Compares two red-black tree nodes.
void rtems_rbtree_initialize (rtems_rbtree_control *the_rbtree, rtems_rbtree_compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique)
 Initialize a RBTree header.
rtems_rbtree_nodertems_rbtree_find (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Tries to find a node for the specified key in the tree.
rtems_rbtree_nodertems_rbtree_insert (RBTree_Control *the_rbtree, RBTree_Node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Inserts the node into the red-black tree.
The red-black tree container offers no internal protection against concurrent access. The user must ensure that at most one thread at once can access a red-black tree instance.
Typedef Documentation
◆ rtems_rbtree_compare
Parameters
[in]firstThe first node.
[in]secondThe second node.
Return values
positiveThe key value of the first node is greater than the one of the second node.
0The key value of the first node is equal to the one of the second node.
negativeThe key value of the first node is less than the one of the second node.
◆ rtems_rbtree_compare_result
The type is large enough to represent pointers and 32-bit signed integers.
See also
rtems_rbtree_compare.
◆ rtems_rbtree_control
The rbtree's control anchors the rbtree.
◆ rtems_rbtree_node
A node that can be manipulated in the rbtree.
◆ rtems_rbtree_find()
rtems_rbtree_node * rtems_rbtree_find ( const rtems_rbtree_control the_rbtree,
const rtems_rbtree_node the_node,
bool  is_unique
Parameters
[in]the_rbtreeThe red-black tree control.
[in]the_nodeA node specifying the key.
[in]compareThe node compare function.
[in]is_uniqueIf true, then return the first node with a key equal to the one of the node specified if it exits, else return the last node if it exists.
Return values
nodeA node corresponding to the key. If the tree is not unique and contains duplicate keys, the set of duplicate keys acts as FIFO.
NULLNo node exists in the tree for the key.
◆ rtems_rbtree_initialize()
void rtems_rbtree_initialize ( rtems_rbtree_control the_rbtree,
void *  starting_address,
size_t  node_size,
bool  is_unique
This routine initializes the_rbtree structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
Parameters
[in]the_rbtreeis the pointer to rbtree header
[in]starting_addressis the starting address of first node
[in]number_nodesis the number of nodes in rbtree
[in]node_sizeis the size of node in bytes
[in]is_uniqueIf true, then reject nodes with a duplicate key, else otherwise.
◆ rtems_rbtree_insert()
rtems_rbtree_node * rtems_rbtree_insert ( RBTree_Control *  the_rbtree,
RBTree_Node the_node,
bool  is_unique
In case the node is already a node of a tree, then this function yields unpredictable results.
Parameters
[in]the_nodeThe node to insert.
[in]is_uniqueIf true, then reject nodes with a duplicate key, else insert nodes in FIFO order in case the key value is equal to existing nodes.
Return values
NULLSuccessfully inserted.
existing_nodeThis is a unique insert and there exists a node with an equal key in the tree already.
