RTEMS 6.2
HAL_StatusTypeDef HAL_RTCEx_SetWakeUpTimer (RTC_HandleTypeDef *hrtc, uint32_t WakeUpCounter, uint32_t WakeUpClock)
HAL_StatusTypeDef HAL_RTCEx_SetWakeUpTimer_IT (RTC_HandleTypeDef *hrtc, uint32_t WakeUpCounter, uint32_t WakeUpClock)
HAL_StatusTypeDef HAL_RTCEx_DeactivateWakeUpTimer (RTC_HandleTypeDef *hrtc)
uint32_t HAL_RTCEx_GetWakeUpTimer (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_WakeUpTimerIRQHandler (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_WakeUpTimerEventCallback (RTC_HandleTypeDef *hrtc)
 Wake Up Timer Event Callback in non blocking mode.
HAL_StatusTypeDef HAL_RTCEx_PollForWakeUpTimerEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
◆ HAL_RTCEx_WakeUpTimerEventCallback()
void HAL_RTCEx_WakeUpTimerEventCallback ( RTC_HandleTypeDef hrtc)
Note
This function is called when RTC_WKUP interrupt took place, inside RTC_WKUP_IRQHandler(). It makes a direct call to HAL_IncTick() to increment a global variable "uwTick" used as application time base.
Parameters
hrtcRTC handle
Return values
None
