RTEMS 6.2
| #define | __HAL_RCC_CRS_FREQ_ERROR_COUNTER_ENABLE() SET_BIT(CRS->CR, CRS_CR_CEN) |
| Enable the oscillator clock for frequency error counter. | |
| #define | __HAL_RCC_CRS_FREQ_ERROR_COUNTER_DISABLE() CLEAR_BIT(CRS->CR, CRS_CR_CEN) |
| Disable the oscillator clock for frequency error counter. | |
| #define | __HAL_RCC_CRS_AUTOMATIC_CALIB_ENABLE() SET_BIT(CRS->CR, CRS_CR_AUTOTRIMEN) |
| Enable the automatic hardware adjustment of TRIM bits. | |
| #define | __HAL_RCC_CRS_AUTOMATIC_CALIB_DISABLE() CLEAR_BIT(CRS->CR, CRS_CR_AUTOTRIMEN) |
| Enable or disable the automatic hardware adjustment of TRIM bits. | |
| #define | __HAL_RCC_CRS_RELOADVALUE_CALCULATE(__FTARGET__, __FSYNC__) (((__FTARGET__) / (__FSYNC__)) - 1U) |
| Macro to calculate reload value to be set in CRS register according to target and sync frequencies. | |
| #define __HAL_RCC_CRS_AUTOMATIC_CALIB_DISABLE | ( | ) | CLEAR_BIT(CRS->CR, CRS_CR_AUTOTRIMEN) |
| None |
| #define __HAL_RCC_CRS_AUTOMATIC_CALIB_ENABLE | ( | ) | SET_BIT(CRS->CR, CRS_CR_AUTOTRIMEN) |
| None |
| #define __HAL_RCC_CRS_FREQ_ERROR_COUNTER_DISABLE | ( | ) | CLEAR_BIT(CRS->CR, CRS_CR_CEN) |
| None |
| #define __HAL_RCC_CRS_FREQ_ERROR_COUNTER_ENABLE | ( | ) | SET_BIT(CRS->CR, CRS_CR_CEN) |
| None |
| #define __HAL_RCC_CRS_RELOADVALUE_CALCULATE | ( | __FTARGET__, | |
| __FSYNC__ | |||
| ) | (((__FTARGET__) / (__FSYNC__)) - 1U) |
| __FTARGET__ | Target frequency (value in Hz) |
| __FSYNC__ | Synchronization signal frequency (value in Hz) |
| None |
