RTEMS 6.2
PPC_AUTHEN_CTRL - PPC Authentication Control | |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_USER_MASK (0x1U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_USER_SHIFT (0U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_USER(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_USER_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_USER_MASK) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_MASK (0x2U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_SHIFT (1U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_MASK) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING_MASK (0x10U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING_SHIFT (4U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING_MASK) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST_MASK (0xF00U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST_SHIFT (8U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST_MASK) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST_MASK (0x1000U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST_SHIFT (12U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST_MASK) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG_MASK (0x100000U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG_SHIFT (20U) |
| #define | PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG_MASK) |
PPC_MODE - PPC Mode | |
| #define | PGMC_PPC_PPC_MODE_CTRL_MODE_MASK (0x3U) |
| #define | PGMC_PPC_PPC_MODE_CTRL_MODE_SHIFT (0U) |
| #define | PGMC_PPC_PPC_MODE_CTRL_MODE(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_MODE_CTRL_MODE_SHIFT)) & PGMC_PPC_PPC_MODE_CTRL_MODE_MASK) |
| #define | PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN_MASK (0x30U) |
| #define | PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN_SHIFT (4U) |
| #define | PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN_SHIFT)) & PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN_MASK) |
PPC_STBY_CM_CTRL - PPC standby CPU mode control | |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT_MASK (0x2U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT_SHIFT (1U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT_MASK) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP_MASK (0x4U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP_SHIFT (2U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP_MASK) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND_MASK (0x8U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND_SHIFT (3U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND_MASK) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT_MASK (0x100U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT_SHIFT (8U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT_MASK) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT_MASK (0x200U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT_SHIFT (9U) |
| #define | PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT_MASK) |
PPC_STBY_SP_CTRL - PPC standby Setpoint control | |
| #define | PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE_MASK (0xFFFFU) |
| #define | PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE_SHIFT (0U) |
| #define | PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE_SHIFT)) & PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE_MASK) |
| #define | PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP_MASK (0xFFFF0000U) |
| #define | PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP_SHIFT (16U) |
| #define | PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP(x) (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP_SHIFT)) & PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP_MASK) |
| #define PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_CFG_MASK) |
LOCK_CFG - Configuration lock
| #define PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_LIST_MASK) |
LOCK_LIST - White list lock
| #define PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_LOCK_SETTING_MASK) |
LOCK_SETTING - Lock NONSECURE and USER
| #define PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_NONSECURE_MASK) |
NONSECURE - Allow non-secure mode access
| #define PGMC_PPC_PPC_AUTHEN_CTRL_USER | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_USER_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_USER_MASK) |
USER - Allow user mode access
| #define PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST_SHIFT)) & PGMC_PPC_PPC_AUTHEN_CTRL_WHITE_LIST_MASK) |
WHITE_LIST - Domain ID white list
| #define PGMC_PPC_PPC_MODE_CTRL_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_MODE_CTRL_MODE_SHIFT)) & PGMC_PPC_PPC_MODE_CTRL_MODE_MASK) |
CTRL_MODE - Control mode. This field is locked by AUTHEN_CTRL[LOCK_CFG] field. 0b00..Not affected by any low power mode 0b01..Controlled by CPU power mode of the domain 0b10..Controlled by Setpoint and system standby 0b11..Reserved
| #define PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN_SHIFT)) & PGMC_PPC_PPC_MODE_DOMAIN_ASSIGN_MASK) |
DOMAIN_ASSIGN - Domain assignment of the BPC 0b00..Domain 0 0b01..Domain 1 0b10..Domain 2 0b11..Domain 3
| #define PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_OFF_SOFT_MASK) |
STBY_OFF_SOFT - Software PMIC standby off trigger
| #define PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_STOP_MASK) |
STBY_ON_AT_STOP - PMIC Standby on when domain enters STOP mode. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
| #define PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_SUSPEND_MASK) |
STBY_ON_AT_SUSPEND - PMIC Standby on when domain enters SUSPEND mode. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
| #define PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_AT_WAIT_MASK) |
STBY_ON_AT_WAIT - PMIC Standby on when domain enters WAIT mode. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
| #define PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT_SHIFT)) & PGMC_PPC_PPC_STBY_CM_CTRL_STBY_ON_SOFT_MASK) |
STBY_ON_SOFT - Software PMIC standby on trigger
| #define PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE_SHIFT)) & PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_ACTIVE_MASK) |
STBY_ON_AT_SP_ACTIVE - PMIC standby on when system enters Setpoint number. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
| #define PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP_SHIFT)) & PGMC_PPC_PPC_STBY_SP_CTRL_STBY_ON_AT_SP_SLEEP_MASK) |
STBY_ON_AT_SP_SLEEP - PMIC standby on when system enters Setpoint number and system is in standby mode. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
