RTEMS 6.2
| #define | OPAMP_PGA_CONNECT_INVERTINGINPUT_NO 0x00000000U |
| #define | OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0 OPAMP_CSR_PGGAIN_2 |
| #define | OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS OPAMP_CSR_PGGAIN_3 |
| #define | OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS (OPAMP_CSR_PGGAIN_2 | OPAMP_CSR_PGGAIN_3) |
| #define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0 OPAMP_CSR_PGGAIN_2 |
In PGA mode, the inverting input is connected to VINM0
| #define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS OPAMP_CSR_PGGAIN_3 |
In PGA mode, the inverting input is connected to VINM0 or bias
| #define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS (OPAMP_CSR_PGGAIN_2 | OPAMP_CSR_PGGAIN_3) |
In PGA mode, the inverting input is connected to VINM0 or bias , VINM1 connected for filtering
| #define OPAMP_PGA_CONNECT_INVERTINGINPUT_NO 0x00000000U |
In PGA mode, the inverting input is not connected
