RTEMS 6.2
macros to handle NOR device enable/disable and read/write operations More...
#define __FMC_NORSRAM_ENABLE(__INSTANCE__, __BANK__)
 Enable the NORSRAM device access.
#define __FMC_NORSRAM_DISABLE(__INSTANCE__, __BANK__)
 Disable the NORSRAM device access.
◆ __FMC_NORSRAM_DISABLE
#define __FMC_NORSRAM_DISABLE (   __INSTANCE__,
  __BANK__
Value:
((__INSTANCE__)->BTCR[(__BANK__)]\
&= ~FMC_BCRx_MBKEN)
Parameters
__INSTANCE__FMC_NORSRAM Instance
__BANK__FMC_NORSRAM Bank
Return values
None
◆ __FMC_NORSRAM_ENABLE
#define __FMC_NORSRAM_ENABLE (   __INSTANCE__,
  __BANK__
Value:
#define FMC_BCRx_MBKEN
Definition: stm32h723xx.h:11300
Parameters
Return values
None
