RTEMS 6.2
CR - Control | |
| #define | DMA_CR_EDBG_MASK (0x2U) |
| #define | DMA_CR_EDBG_SHIFT (1U) |
| #define | DMA_CR_EDBG(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_EDBG_SHIFT)) & DMA_CR_EDBG_MASK) |
| #define | DMA_CR_ERCA_MASK (0x4U) |
| #define | DMA_CR_ERCA_SHIFT (2U) |
| #define | DMA_CR_ERCA(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERCA_SHIFT)) & DMA_CR_ERCA_MASK) |
| #define | DMA_CR_ERGA_MASK (0x8U) |
| #define | DMA_CR_ERGA_SHIFT (3U) |
| #define | DMA_CR_ERGA(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERGA_SHIFT)) & DMA_CR_ERGA_MASK) |
| #define | DMA_CR_HOE_MASK (0x10U) |
| #define | DMA_CR_HOE_SHIFT (4U) |
| #define | DMA_CR_HOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_HOE_SHIFT)) & DMA_CR_HOE_MASK) |
| #define | DMA_CR_HALT_MASK (0x20U) |
| #define | DMA_CR_HALT_SHIFT (5U) |
| #define | DMA_CR_HALT(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_HALT_SHIFT)) & DMA_CR_HALT_MASK) |
| #define | DMA_CR_CLM_MASK (0x40U) |
| #define | DMA_CR_CLM_SHIFT (6U) |
| #define | DMA_CR_CLM(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_CLM_SHIFT)) & DMA_CR_CLM_MASK) |
| #define | DMA_CR_EMLM_MASK (0x80U) |
| #define | DMA_CR_EMLM_SHIFT (7U) |
| #define | DMA_CR_EMLM(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_EMLM_SHIFT)) & DMA_CR_EMLM_MASK) |
| #define | DMA_CR_GRP0PRI_MASK (0x100U) |
| #define | DMA_CR_GRP0PRI_SHIFT (8U) |
| #define | DMA_CR_GRP0PRI(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP0PRI_SHIFT)) & DMA_CR_GRP0PRI_MASK) |
| #define | DMA_CR_GRP1PRI_MASK (0x400U) |
| #define | DMA_CR_GRP1PRI_SHIFT (10U) |
| #define | DMA_CR_GRP1PRI(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP1PRI_SHIFT)) & DMA_CR_GRP1PRI_MASK) |
| #define | DMA_CR_ECX_MASK (0x10000U) |
| #define | DMA_CR_ECX_SHIFT (16U) |
| #define | DMA_CR_ECX(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ECX_SHIFT)) & DMA_CR_ECX_MASK) |
| #define | DMA_CR_CX_MASK (0x20000U) |
| #define | DMA_CR_CX_SHIFT (17U) |
| #define | DMA_CR_CX(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_CX_SHIFT)) & DMA_CR_CX_MASK) |
| #define | DMA_CR_VERSION_MASK (0x7F000000U) |
| #define | DMA_CR_VERSION_SHIFT (24U) |
| #define | DMA_CR_VERSION(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_VERSION_SHIFT)) & DMA_CR_VERSION_MASK) |
| #define | DMA_CR_ACTIVE_MASK (0x80000000U) |
| #define | DMA_CR_ACTIVE_SHIFT (31U) |
| #define | DMA_CR_ACTIVE(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ACTIVE_SHIFT)) & DMA_CR_ACTIVE_MASK) |
ES - Error Status | |
| #define | DMA_ES_DBE_MASK (0x1U) |
| #define | DMA_ES_DBE_SHIFT (0U) |
| #define | DMA_ES_DBE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DBE_SHIFT)) & DMA_ES_DBE_MASK) |
| #define | DMA_ES_SBE_MASK (0x2U) |
| #define | DMA_ES_SBE_SHIFT (1U) |
| #define | DMA_ES_SBE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SBE_SHIFT)) & DMA_ES_SBE_MASK) |
| #define | DMA_ES_SGE_MASK (0x4U) |
| #define | DMA_ES_SGE_SHIFT (2U) |
| #define | DMA_ES_SGE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SGE_SHIFT)) & DMA_ES_SGE_MASK) |
| #define | DMA_ES_NCE_MASK (0x8U) |
| #define | DMA_ES_NCE_SHIFT (3U) |
| #define | DMA_ES_NCE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_NCE_SHIFT)) & DMA_ES_NCE_MASK) |
| #define | DMA_ES_DOE_MASK (0x10U) |
| #define | DMA_ES_DOE_SHIFT (4U) |
| #define | DMA_ES_DOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DOE_SHIFT)) & DMA_ES_DOE_MASK) |
| #define | DMA_ES_DAE_MASK (0x20U) |
| #define | DMA_ES_DAE_SHIFT (5U) |
| #define | DMA_ES_DAE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DAE_SHIFT)) & DMA_ES_DAE_MASK) |
| #define | DMA_ES_SOE_MASK (0x40U) |
| #define | DMA_ES_SOE_SHIFT (6U) |
| #define | DMA_ES_SOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SOE_SHIFT)) & DMA_ES_SOE_MASK) |
| #define | DMA_ES_SAE_MASK (0x80U) |
| #define | DMA_ES_SAE_SHIFT (7U) |
| #define | DMA_ES_SAE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SAE_SHIFT)) & DMA_ES_SAE_MASK) |
| #define | DMA_ES_ERRCHN_MASK (0x1F00U) |
| #define | DMA_ES_ERRCHN_SHIFT (8U) |
| #define | DMA_ES_ERRCHN(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_ERRCHN_SHIFT)) & DMA_ES_ERRCHN_MASK) |
| #define | DMA_ES_CPE_MASK (0x4000U) |
| #define | DMA_ES_CPE_SHIFT (14U) |
| #define | DMA_ES_CPE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_CPE_SHIFT)) & DMA_ES_CPE_MASK) |
| #define | DMA_ES_GPE_MASK (0x8000U) |
| #define | DMA_ES_GPE_SHIFT (15U) |
| #define | DMA_ES_GPE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_GPE_SHIFT)) & DMA_ES_GPE_MASK) |
| #define | DMA_ES_ECX_MASK (0x10000U) |
| #define | DMA_ES_ECX_SHIFT (16U) |
| #define | DMA_ES_ECX(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_ECX_SHIFT)) & DMA_ES_ECX_MASK) |
| #define | DMA_ES_VLD_MASK (0x80000000U) |
| #define | DMA_ES_VLD_SHIFT (31U) |
| #define | DMA_ES_VLD(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_VLD_SHIFT)) & DMA_ES_VLD_MASK) |
ERQ - Enable Request | |
| #define | DMA_ERQ_ERQ0_MASK (0x1U) |
| #define | DMA_ERQ_ERQ0_SHIFT (0U) |
| #define | DMA_ERQ_ERQ0(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ0_SHIFT)) & DMA_ERQ_ERQ0_MASK) |
| #define | DMA_ERQ_ERQ1_MASK (0x2U) |
| #define | DMA_ERQ_ERQ1_SHIFT (1U) |
| #define | DMA_ERQ_ERQ1(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ1_SHIFT)) & DMA_ERQ_ERQ1_MASK) |
| #define | DMA_ERQ_ERQ2_MASK (0x4U) |
| #define | DMA_ERQ_ERQ2_SHIFT (2U) |
| #define | DMA_ERQ_ERQ2(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ2_SHIFT)) & DMA_ERQ_ERQ2_MASK) |
| #define | DMA_ERQ_ERQ3_MASK (0x8U) |
| #define | DMA_ERQ_ERQ3_SHIFT (3U) |
| #define | DMA_ERQ_ERQ3(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ3_SHIFT)) & DMA_ERQ_ERQ3_MASK) |
| #define | DMA_ERQ_ERQ4_MASK (0x10U) |
| #define | DMA_ERQ_ERQ4_SHIFT (4U) |
| #define | DMA_ERQ_ERQ4(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ4_SHIFT)) & DMA_ERQ_ERQ4_MASK) |
| #define | DMA_ERQ_ERQ5_MASK (0x20U) |
| #define | DMA_ERQ_ERQ5_SHIFT (5U) |
| #define | DMA_ERQ_ERQ5(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ5_SHIFT)) & DMA_ERQ_ERQ5_MASK) |
| #define | DMA_ERQ_ERQ6_MASK (0x40U) |
| #define | DMA_ERQ_ERQ6_SHIFT (6U) |
| #define | DMA_ERQ_ERQ6(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ6_SHIFT)) & DMA_ERQ_ERQ6_MASK) |
| #define | DMA_ERQ_ERQ7_MASK (0x80U) |
| #define | DMA_ERQ_ERQ7_SHIFT (7U) |
| #define | DMA_ERQ_ERQ7(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ7_SHIFT)) & DMA_ERQ_ERQ7_MASK) |
| #define | DMA_ERQ_ERQ8_MASK (0x100U) |
| #define | DMA_ERQ_ERQ8_SHIFT (8U) |
| #define | DMA_ERQ_ERQ8(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ8_SHIFT)) & DMA_ERQ_ERQ8_MASK) |
| #define | DMA_ERQ_ERQ9_MASK (0x200U) |
| #define | DMA_ERQ_ERQ9_SHIFT (9U) |
| #define | DMA_ERQ_ERQ9(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ9_SHIFT)) & DMA_ERQ_ERQ9_MASK) |
| #define | DMA_ERQ_ERQ10_MASK (0x400U) |
| #define | DMA_ERQ_ERQ10_SHIFT (10U) |
| #define | DMA_ERQ_ERQ10(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ10_SHIFT)) & DMA_ERQ_ERQ10_MASK) |
| #define | DMA_ERQ_ERQ11_MASK (0x800U) |
| #define | DMA_ERQ_ERQ11_SHIFT (11U) |
| #define | DMA_ERQ_ERQ11(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ11_SHIFT)) & DMA_ERQ_ERQ11_MASK) |
| #define | DMA_ERQ_ERQ12_MASK (0x1000U) |
| #define | DMA_ERQ_ERQ12_SHIFT (12U) |
| #define | DMA_ERQ_ERQ12(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ12_SHIFT)) & DMA_ERQ_ERQ12_MASK) |
| #define | DMA_ERQ_ERQ13_MASK (0x2000U) |
| #define | DMA_ERQ_ERQ13_SHIFT (13U) |
| #define | DMA_ERQ_ERQ13(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ13_SHIFT)) & DMA_ERQ_ERQ13_MASK) |
| #define | DMA_ERQ_ERQ14_MASK (0x4000U) |
| #define | DMA_ERQ_ERQ14_SHIFT (14U) |
| #define | DMA_ERQ_ERQ14(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ14_SHIFT)) & DMA_ERQ_ERQ14_MASK) |
| #define | DMA_ERQ_ERQ15_MASK (0x8000U) |
| #define | DMA_ERQ_ERQ15_SHIFT (15U) |
| #define | DMA_ERQ_ERQ15(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ15_SHIFT)) & DMA_ERQ_ERQ15_MASK) |
| #define | DMA_ERQ_ERQ16_MASK (0x10000U) |
| #define | DMA_ERQ_ERQ16_SHIFT (16U) |
| #define | DMA_ERQ_ERQ16(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ16_SHIFT)) & DMA_ERQ_ERQ16_MASK) |
| #define | DMA_ERQ_ERQ17_MASK (0x20000U) |
| #define | DMA_ERQ_ERQ17_SHIFT (17U) |
| #define | DMA_ERQ_ERQ17(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ17_SHIFT)) & DMA_ERQ_ERQ17_MASK) |
| #define | DMA_ERQ_ERQ18_MASK (0x40000U) |
| #define | DMA_ERQ_ERQ18_SHIFT (18U) |
| #define | DMA_ERQ_ERQ18(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ18_SHIFT)) & DMA_ERQ_ERQ18_MASK) |
| #define | DMA_ERQ_ERQ19_MASK (0x80000U) |
| #define | DMA_ERQ_ERQ19_SHIFT (19U) |
| #define | DMA_ERQ_ERQ19(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ19_SHIFT)) & DMA_ERQ_ERQ19_MASK) |
| #define | DMA_ERQ_ERQ20_MASK (0x100000U) |
| #define | DMA_ERQ_ERQ20_SHIFT (20U) |
| #define | DMA_ERQ_ERQ20(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ20_SHIFT)) & DMA_ERQ_ERQ20_MASK) |
| #define | DMA_ERQ_ERQ21_MASK (0x200000U) |
| #define | DMA_ERQ_ERQ21_SHIFT (21U) |
| #define | DMA_ERQ_ERQ21(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ21_SHIFT)) & DMA_ERQ_ERQ21_MASK) |
| #define | DMA_ERQ_ERQ22_MASK (0x400000U) |
| #define | DMA_ERQ_ERQ22_SHIFT (22U) |
| #define | DMA_ERQ_ERQ22(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ22_SHIFT)) & DMA_ERQ_ERQ22_MASK) |
| #define | DMA_ERQ_ERQ23_MASK (0x800000U) |
| #define | DMA_ERQ_ERQ23_SHIFT (23U) |
| #define | DMA_ERQ_ERQ23(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ23_SHIFT)) & DMA_ERQ_ERQ23_MASK) |
| #define | DMA_ERQ_ERQ24_MASK (0x1000000U) |
| #define | DMA_ERQ_ERQ24_SHIFT (24U) |
| #define | DMA_ERQ_ERQ24(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ24_SHIFT)) & DMA_ERQ_ERQ24_MASK) |
| #define | DMA_ERQ_ERQ25_MASK (0x2000000U) |
| #define | DMA_ERQ_ERQ25_SHIFT (25U) |
| #define | DMA_ERQ_ERQ25(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ25_SHIFT)) & DMA_ERQ_ERQ25_MASK) |
| #define | DMA_ERQ_ERQ26_MASK (0x4000000U) |
| #define | DMA_ERQ_ERQ26_SHIFT (26U) |
| #define | DMA_ERQ_ERQ26(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ26_SHIFT)) & DMA_ERQ_ERQ26_MASK) |
| #define | DMA_ERQ_ERQ27_MASK (0x8000000U) |
| #define | DMA_ERQ_ERQ27_SHIFT (27U) |
| #define | DMA_ERQ_ERQ27(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ27_SHIFT)) & DMA_ERQ_ERQ27_MASK) |
| #define | DMA_ERQ_ERQ28_MASK (0x10000000U) |
| #define | DMA_ERQ_ERQ28_SHIFT (28U) |
| #define | DMA_ERQ_ERQ28(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ28_SHIFT)) & DMA_ERQ_ERQ28_MASK) |
| #define | DMA_ERQ_ERQ29_MASK (0x20000000U) |
| #define | DMA_ERQ_ERQ29_SHIFT (29U) |
| #define | DMA_ERQ_ERQ29(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ29_SHIFT)) & DMA_ERQ_ERQ29_MASK) |
| #define | DMA_ERQ_ERQ30_MASK (0x40000000U) |
| #define | DMA_ERQ_ERQ30_SHIFT (30U) |
| #define | DMA_ERQ_ERQ30(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ30_SHIFT)) & DMA_ERQ_ERQ30_MASK) |
| #define | DMA_ERQ_ERQ31_MASK (0x80000000U) |
| #define | DMA_ERQ_ERQ31_SHIFT (31U) |
| #define | DMA_ERQ_ERQ31(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ31_SHIFT)) & DMA_ERQ_ERQ31_MASK) |
EEI - Enable Error Interrupt | |
| #define | DMA_EEI_EEI0_MASK (0x1U) |
| #define | DMA_EEI_EEI0_SHIFT (0U) |
| #define | DMA_EEI_EEI0(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI0_SHIFT)) & DMA_EEI_EEI0_MASK) |
| #define | DMA_EEI_EEI1_MASK (0x2U) |
| #define | DMA_EEI_EEI1_SHIFT (1U) |
| #define | DMA_EEI_EEI1(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI1_SHIFT)) & DMA_EEI_EEI1_MASK) |
| #define | DMA_EEI_EEI2_MASK (0x4U) |
| #define | DMA_EEI_EEI2_SHIFT (2U) |
| #define | DMA_EEI_EEI2(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI2_SHIFT)) & DMA_EEI_EEI2_MASK) |
| #define | DMA_EEI_EEI3_MASK (0x8U) |
| #define | DMA_EEI_EEI3_SHIFT (3U) |
| #define | DMA_EEI_EEI3(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI3_SHIFT)) & DMA_EEI_EEI3_MASK) |
| #define | DMA_EEI_EEI4_MASK (0x10U) |
| #define | DMA_EEI_EEI4_SHIFT (4U) |
| #define | DMA_EEI_EEI4(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI4_SHIFT)) & DMA_EEI_EEI4_MASK) |
| #define | DMA_EEI_EEI5_MASK (0x20U) |
| #define | DMA_EEI_EEI5_SHIFT (5U) |
| #define | DMA_EEI_EEI5(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI5_SHIFT)) & DMA_EEI_EEI5_MASK) |
| #define | DMA_EEI_EEI6_MASK (0x40U) |
| #define | DMA_EEI_EEI6_SHIFT (6U) |
| #define | DMA_EEI_EEI6(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI6_SHIFT)) & DMA_EEI_EEI6_MASK) |
| #define | DMA_EEI_EEI7_MASK (0x80U) |
| #define | DMA_EEI_EEI7_SHIFT (7U) |
| #define | DMA_EEI_EEI7(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI7_SHIFT)) & DMA_EEI_EEI7_MASK) |
| #define | DMA_EEI_EEI8_MASK (0x100U) |
| #define | DMA_EEI_EEI8_SHIFT (8U) |
| #define | DMA_EEI_EEI8(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI8_SHIFT)) & DMA_EEI_EEI8_MASK) |
| #define | DMA_EEI_EEI9_MASK (0x200U) |
| #define | DMA_EEI_EEI9_SHIFT (9U) |
| #define | DMA_EEI_EEI9(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI9_SHIFT)) & DMA_EEI_EEI9_MASK) |
| #define | DMA_EEI_EEI10_MASK (0x400U) |
| #define | DMA_EEI_EEI10_SHIFT (10U) |
| #define | DMA_EEI_EEI10(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI10_SHIFT)) & DMA_EEI_EEI10_MASK) |
| #define | DMA_EEI_EEI11_MASK (0x800U) |
| #define | DMA_EEI_EEI11_SHIFT (11U) |
| #define | DMA_EEI_EEI11(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI11_SHIFT)) & DMA_EEI_EEI11_MASK) |
| #define | DMA_EEI_EEI12_MASK (0x1000U) |
| #define | DMA_EEI_EEI12_SHIFT (12U) |
| #define | DMA_EEI_EEI12(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI12_SHIFT)) & DMA_EEI_EEI12_MASK) |
| #define | DMA_EEI_EEI13_MASK (0x2000U) |
| #define | DMA_EEI_EEI13_SHIFT (13U) |
| #define | DMA_EEI_EEI13(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI13_SHIFT)) & DMA_EEI_EEI13_MASK) |
| #define | DMA_EEI_EEI14_MASK (0x4000U) |
| #define | DMA_EEI_EEI14_SHIFT (14U) |
| #define | DMA_EEI_EEI14(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI14_SHIFT)) & DMA_EEI_EEI14_MASK) |
| #define | DMA_EEI_EEI15_MASK (0x8000U) |
| #define | DMA_EEI_EEI15_SHIFT (15U) |
| #define | DMA_EEI_EEI15(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI15_SHIFT)) & DMA_EEI_EEI15_MASK) |
| #define | DMA_EEI_EEI16_MASK (0x10000U) |
| #define | DMA_EEI_EEI16_SHIFT (16U) |
| #define | DMA_EEI_EEI16(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI16_SHIFT)) & DMA_EEI_EEI16_MASK) |
| #define | DMA_EEI_EEI17_MASK (0x20000U) |
| #define | DMA_EEI_EEI17_SHIFT (17U) |
| #define | DMA_EEI_EEI17(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI17_SHIFT)) & DMA_EEI_EEI17_MASK) |
| #define | DMA_EEI_EEI18_MASK (0x40000U) |
| #define | DMA_EEI_EEI18_SHIFT (18U) |
| #define | DMA_EEI_EEI18(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI18_SHIFT)) & DMA_EEI_EEI18_MASK) |
| #define | DMA_EEI_EEI19_MASK (0x80000U) |
| #define | DMA_EEI_EEI19_SHIFT (19U) |
| #define | DMA_EEI_EEI19(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI19_SHIFT)) & DMA_EEI_EEI19_MASK) |
| #define | DMA_EEI_EEI20_MASK (0x100000U) |
| #define | DMA_EEI_EEI20_SHIFT (20U) |
| #define | DMA_EEI_EEI20(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI20_SHIFT)) & DMA_EEI_EEI20_MASK) |
| #define | DMA_EEI_EEI21_MASK (0x200000U) |
| #define | DMA_EEI_EEI21_SHIFT (21U) |
| #define | DMA_EEI_EEI21(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI21_SHIFT)) & DMA_EEI_EEI21_MASK) |
| #define | DMA_EEI_EEI22_MASK (0x400000U) |
| #define | DMA_EEI_EEI22_SHIFT (22U) |
| #define | DMA_EEI_EEI22(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI22_SHIFT)) & DMA_EEI_EEI22_MASK) |
| #define | DMA_EEI_EEI23_MASK (0x800000U) |
| #define | DMA_EEI_EEI23_SHIFT (23U) |
| #define | DMA_EEI_EEI23(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI23_SHIFT)) & DMA_EEI_EEI23_MASK) |
| #define | DMA_EEI_EEI24_MASK (0x1000000U) |
| #define | DMA_EEI_EEI24_SHIFT (24U) |
| #define | DMA_EEI_EEI24(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI24_SHIFT)) & DMA_EEI_EEI24_MASK) |
| #define | DMA_EEI_EEI25_MASK (0x2000000U) |
| #define | DMA_EEI_EEI25_SHIFT (25U) |
| #define | DMA_EEI_EEI25(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI25_SHIFT)) & DMA_EEI_EEI25_MASK) |
| #define | DMA_EEI_EEI26_MASK (0x4000000U) |
| #define | DMA_EEI_EEI26_SHIFT (26U) |
| #define | DMA_EEI_EEI26(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI26_SHIFT)) & DMA_EEI_EEI26_MASK) |
| #define | DMA_EEI_EEI27_MASK (0x8000000U) |
| #define | DMA_EEI_EEI27_SHIFT (27U) |
| #define | DMA_EEI_EEI27(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI27_SHIFT)) & DMA_EEI_EEI27_MASK) |
| #define | DMA_EEI_EEI28_MASK (0x10000000U) |
| #define | DMA_EEI_EEI28_SHIFT (28U) |
| #define | DMA_EEI_EEI28(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI28_SHIFT)) & DMA_EEI_EEI28_MASK) |
| #define | DMA_EEI_EEI29_MASK (0x20000000U) |
| #define | DMA_EEI_EEI29_SHIFT (29U) |
| #define | DMA_EEI_EEI29(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI29_SHIFT)) & DMA_EEI_EEI29_MASK) |
| #define | DMA_EEI_EEI30_MASK (0x40000000U) |
| #define | DMA_EEI_EEI30_SHIFT (30U) |
| #define | DMA_EEI_EEI30(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI30_SHIFT)) & DMA_EEI_EEI30_MASK) |
| #define | DMA_EEI_EEI31_MASK (0x80000000U) |
| #define | DMA_EEI_EEI31_SHIFT (31U) |
| #define | DMA_EEI_EEI31(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI31_SHIFT)) & DMA_EEI_EEI31_MASK) |
CEEI - Clear Enable Error Interrupt | |
| #define | DMA_CEEI_CEEI_MASK (0x1FU) |
| #define | DMA_CEEI_CEEI_SHIFT (0U) |
| #define | DMA_CEEI_CEEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CEEI_SHIFT)) & DMA_CEEI_CEEI_MASK) |
| #define | DMA_CEEI_CAEE_MASK (0x40U) |
| #define | DMA_CEEI_CAEE_SHIFT (6U) |
| #define | DMA_CEEI_CAEE(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CAEE_SHIFT)) & DMA_CEEI_CAEE_MASK) |
| #define | DMA_CEEI_NOP_MASK (0x80U) |
| #define | DMA_CEEI_NOP_SHIFT (7U) |
| #define | DMA_CEEI_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_NOP_SHIFT)) & DMA_CEEI_NOP_MASK) |
SEEI - Set Enable Error Interrupt | |
| #define | DMA_SEEI_SEEI_MASK (0x1FU) |
| #define | DMA_SEEI_SEEI_SHIFT (0U) |
| #define | DMA_SEEI_SEEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SEEI_SHIFT)) & DMA_SEEI_SEEI_MASK) |
| #define | DMA_SEEI_SAEE_MASK (0x40U) |
| #define | DMA_SEEI_SAEE_SHIFT (6U) |
| #define | DMA_SEEI_SAEE(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SAEE_SHIFT)) & DMA_SEEI_SAEE_MASK) |
| #define | DMA_SEEI_NOP_MASK (0x80U) |
| #define | DMA_SEEI_NOP_SHIFT (7U) |
| #define | DMA_SEEI_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_NOP_SHIFT)) & DMA_SEEI_NOP_MASK) |
CERQ - Clear Enable Request | |
| #define | DMA_CERQ_CERQ_MASK (0x1FU) |
| #define | DMA_CERQ_CERQ_SHIFT (0U) |
| #define | DMA_CERQ_CERQ(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CERQ_SHIFT)) & DMA_CERQ_CERQ_MASK) |
| #define | DMA_CERQ_CAER_MASK (0x40U) |
| #define | DMA_CERQ_CAER_SHIFT (6U) |
| #define | DMA_CERQ_CAER(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CAER_SHIFT)) & DMA_CERQ_CAER_MASK) |
| #define | DMA_CERQ_NOP_MASK (0x80U) |
| #define | DMA_CERQ_NOP_SHIFT (7U) |
| #define | DMA_CERQ_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_NOP_SHIFT)) & DMA_CERQ_NOP_MASK) |
SERQ - Set Enable Request | |
| #define | DMA_SERQ_SERQ_MASK (0x1FU) |
| #define | DMA_SERQ_SERQ_SHIFT (0U) |
| #define | DMA_SERQ_SERQ(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SERQ_SHIFT)) & DMA_SERQ_SERQ_MASK) |
| #define | DMA_SERQ_SAER_MASK (0x40U) |
| #define | DMA_SERQ_SAER_SHIFT (6U) |
| #define | DMA_SERQ_SAER(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SAER_SHIFT)) & DMA_SERQ_SAER_MASK) |
| #define | DMA_SERQ_NOP_MASK (0x80U) |
| #define | DMA_SERQ_NOP_SHIFT (7U) |
| #define | DMA_SERQ_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_NOP_SHIFT)) & DMA_SERQ_NOP_MASK) |
CDNE - Clear DONE Status Bit | |
| #define | DMA_CDNE_CDNE_MASK (0x1FU) |
| #define | DMA_CDNE_CDNE_SHIFT (0U) |
| #define | DMA_CDNE_CDNE(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CDNE_SHIFT)) & DMA_CDNE_CDNE_MASK) |
| #define | DMA_CDNE_CADN_MASK (0x40U) |
| #define | DMA_CDNE_CADN_SHIFT (6U) |
| #define | DMA_CDNE_CADN(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CADN_SHIFT)) & DMA_CDNE_CADN_MASK) |
| #define | DMA_CDNE_NOP_MASK (0x80U) |
| #define | DMA_CDNE_NOP_SHIFT (7U) |
| #define | DMA_CDNE_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_NOP_SHIFT)) & DMA_CDNE_NOP_MASK) |
SSRT - Set START Bit | |
| #define | DMA_SSRT_SSRT_MASK (0x1FU) |
| #define | DMA_SSRT_SSRT_SHIFT (0U) |
| #define | DMA_SSRT_SSRT(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SSRT_SHIFT)) & DMA_SSRT_SSRT_MASK) |
| #define | DMA_SSRT_SAST_MASK (0x40U) |
| #define | DMA_SSRT_SAST_SHIFT (6U) |
| #define | DMA_SSRT_SAST(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SAST_SHIFT)) & DMA_SSRT_SAST_MASK) |
| #define | DMA_SSRT_NOP_MASK (0x80U) |
| #define | DMA_SSRT_NOP_SHIFT (7U) |
| #define | DMA_SSRT_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_NOP_SHIFT)) & DMA_SSRT_NOP_MASK) |
CERR - Clear Error | |
| #define | DMA_CERR_CERR_MASK (0x1FU) |
| #define | DMA_CERR_CERR_SHIFT (0U) |
| #define | DMA_CERR_CERR(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CERR_SHIFT)) & DMA_CERR_CERR_MASK) |
| #define | DMA_CERR_CAEI_MASK (0x40U) |
| #define | DMA_CERR_CAEI_SHIFT (6U) |
| #define | DMA_CERR_CAEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CAEI_SHIFT)) & DMA_CERR_CAEI_MASK) |
| #define | DMA_CERR_NOP_MASK (0x80U) |
| #define | DMA_CERR_NOP_SHIFT (7U) |
| #define | DMA_CERR_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_NOP_SHIFT)) & DMA_CERR_NOP_MASK) |
CINT - Clear Interrupt Request | |
| #define | DMA_CINT_CINT_MASK (0x1FU) |
| #define | DMA_CINT_CINT_SHIFT (0U) |
| #define | DMA_CINT_CINT(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CINT_SHIFT)) & DMA_CINT_CINT_MASK) |
| #define | DMA_CINT_CAIR_MASK (0x40U) |
| #define | DMA_CINT_CAIR_SHIFT (6U) |
| #define | DMA_CINT_CAIR(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CAIR_SHIFT)) & DMA_CINT_CAIR_MASK) |
| #define | DMA_CINT_NOP_MASK (0x80U) |
| #define | DMA_CINT_NOP_SHIFT (7U) |
| #define | DMA_CINT_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_NOP_SHIFT)) & DMA_CINT_NOP_MASK) |
INT - Interrupt Request | |
| #define | DMA_INT_INT0_MASK (0x1U) |
| #define | DMA_INT_INT0_SHIFT (0U) |
| #define | DMA_INT_INT0(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT0_SHIFT)) & DMA_INT_INT0_MASK) |
| #define | DMA_INT_INT1_MASK (0x2U) |
| #define | DMA_INT_INT1_SHIFT (1U) |
| #define | DMA_INT_INT1(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT1_SHIFT)) & DMA_INT_INT1_MASK) |
| #define | DMA_INT_INT2_MASK (0x4U) |
| #define | DMA_INT_INT2_SHIFT (2U) |
| #define | DMA_INT_INT2(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT2_SHIFT)) & DMA_INT_INT2_MASK) |
| #define | DMA_INT_INT3_MASK (0x8U) |
| #define | DMA_INT_INT3_SHIFT (3U) |
| #define | DMA_INT_INT3(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT3_SHIFT)) & DMA_INT_INT3_MASK) |
| #define | DMA_INT_INT4_MASK (0x10U) |
| #define | DMA_INT_INT4_SHIFT (4U) |
| #define | DMA_INT_INT4(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT4_SHIFT)) & DMA_INT_INT4_MASK) |
| #define | DMA_INT_INT5_MASK (0x20U) |
| #define | DMA_INT_INT5_SHIFT (5U) |
| #define | DMA_INT_INT5(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT5_SHIFT)) & DMA_INT_INT5_MASK) |
| #define | DMA_INT_INT6_MASK (0x40U) |
| #define | DMA_INT_INT6_SHIFT (6U) |
| #define | DMA_INT_INT6(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT6_SHIFT)) & DMA_INT_INT6_MASK) |
| #define | DMA_INT_INT7_MASK (0x80U) |
| #define | DMA_INT_INT7_SHIFT (7U) |
| #define | DMA_INT_INT7(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT7_SHIFT)) & DMA_INT_INT7_MASK) |
| #define | DMA_INT_INT8_MASK (0x100U) |
| #define | DMA_INT_INT8_SHIFT (8U) |
| #define | DMA_INT_INT8(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT8_SHIFT)) & DMA_INT_INT8_MASK) |
| #define | DMA_INT_INT9_MASK (0x200U) |
| #define | DMA_INT_INT9_SHIFT (9U) |
| #define | DMA_INT_INT9(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT9_SHIFT)) & DMA_INT_INT9_MASK) |
| #define | DMA_INT_INT10_MASK (0x400U) |
| #define | DMA_INT_INT10_SHIFT (10U) |
| #define | DMA_INT_INT10(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT10_SHIFT)) & DMA_INT_INT10_MASK) |
| #define | DMA_INT_INT11_MASK (0x800U) |
| #define | DMA_INT_INT11_SHIFT (11U) |
| #define | DMA_INT_INT11(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT11_SHIFT)) & DMA_INT_INT11_MASK) |
| #define | DMA_INT_INT12_MASK (0x1000U) |
| #define | DMA_INT_INT12_SHIFT (12U) |
| #define | DMA_INT_INT12(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT12_SHIFT)) & DMA_INT_INT12_MASK) |
| #define | DMA_INT_INT13_MASK (0x2000U) |
| #define | DMA_INT_INT13_SHIFT (13U) |
| #define | DMA_INT_INT13(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT13_SHIFT)) & DMA_INT_INT13_MASK) |
| #define | DMA_INT_INT14_MASK (0x4000U) |
| #define | DMA_INT_INT14_SHIFT (14U) |
| #define | DMA_INT_INT14(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT14_SHIFT)) & DMA_INT_INT14_MASK) |
| #define | DMA_INT_INT15_MASK (0x8000U) |
| #define | DMA_INT_INT15_SHIFT (15U) |
| #define | DMA_INT_INT15(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT15_SHIFT)) & DMA_INT_INT15_MASK) |
| #define | DMA_INT_INT16_MASK (0x10000U) |
| #define | DMA_INT_INT16_SHIFT (16U) |
| #define | DMA_INT_INT16(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT16_SHIFT)) & DMA_INT_INT16_MASK) |
| #define | DMA_INT_INT17_MASK (0x20000U) |
| #define | DMA_INT_INT17_SHIFT (17U) |
| #define | DMA_INT_INT17(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT17_SHIFT)) & DMA_INT_INT17_MASK) |
| #define | DMA_INT_INT18_MASK (0x40000U) |
| #define | DMA_INT_INT18_SHIFT (18U) |
| #define | DMA_INT_INT18(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT18_SHIFT)) & DMA_INT_INT18_MASK) |
| #define | DMA_INT_INT19_MASK (0x80000U) |
| #define | DMA_INT_INT19_SHIFT (19U) |
| #define | DMA_INT_INT19(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT19_SHIFT)) & DMA_INT_INT19_MASK) |
| #define | DMA_INT_INT20_MASK (0x100000U) |
| #define | DMA_INT_INT20_SHIFT (20U) |
| #define | DMA_INT_INT20(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT20_SHIFT)) & DMA_INT_INT20_MASK) |
| #define | DMA_INT_INT21_MASK (0x200000U) |
| #define | DMA_INT_INT21_SHIFT (21U) |
| #define | DMA_INT_INT21(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT21_SHIFT)) & DMA_INT_INT21_MASK) |
| #define | DMA_INT_INT22_MASK (0x400000U) |
| #define | DMA_INT_INT22_SHIFT (22U) |
| #define | DMA_INT_INT22(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT22_SHIFT)) & DMA_INT_INT22_MASK) |
| #define | DMA_INT_INT23_MASK (0x800000U) |
| #define | DMA_INT_INT23_SHIFT (23U) |
| #define | DMA_INT_INT23(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT23_SHIFT)) & DMA_INT_INT23_MASK) |
| #define | DMA_INT_INT24_MASK (0x1000000U) |
| #define | DMA_INT_INT24_SHIFT (24U) |
| #define | DMA_INT_INT24(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT24_SHIFT)) & DMA_INT_INT24_MASK) |
| #define | DMA_INT_INT25_MASK (0x2000000U) |
| #define | DMA_INT_INT25_SHIFT (25U) |
| #define | DMA_INT_INT25(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT25_SHIFT)) & DMA_INT_INT25_MASK) |
| #define | DMA_INT_INT26_MASK (0x4000000U) |
| #define | DMA_INT_INT26_SHIFT (26U) |
| #define | DMA_INT_INT26(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT26_SHIFT)) & DMA_INT_INT26_MASK) |
| #define | DMA_INT_INT27_MASK (0x8000000U) |
| #define | DMA_INT_INT27_SHIFT (27U) |
| #define | DMA_INT_INT27(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT27_SHIFT)) & DMA_INT_INT27_MASK) |
| #define | DMA_INT_INT28_MASK (0x10000000U) |
| #define | DMA_INT_INT28_SHIFT (28U) |
| #define | DMA_INT_INT28(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT28_SHIFT)) & DMA_INT_INT28_MASK) |
| #define | DMA_INT_INT29_MASK (0x20000000U) |
| #define | DMA_INT_INT29_SHIFT (29U) |
| #define | DMA_INT_INT29(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT29_SHIFT)) & DMA_INT_INT29_MASK) |
| #define | DMA_INT_INT30_MASK (0x40000000U) |
| #define | DMA_INT_INT30_SHIFT (30U) |
| #define | DMA_INT_INT30(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT30_SHIFT)) & DMA_INT_INT30_MASK) |
| #define | DMA_INT_INT31_MASK (0x80000000U) |
| #define | DMA_INT_INT31_SHIFT (31U) |
| #define | DMA_INT_INT31(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT31_SHIFT)) & DMA_INT_INT31_MASK) |
ERR - Error | |
| #define | DMA_ERR_ERR0_MASK (0x1U) |
| #define | DMA_ERR_ERR0_SHIFT (0U) |
| #define | DMA_ERR_ERR0(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR0_SHIFT)) & DMA_ERR_ERR0_MASK) |
| #define | DMA_ERR_ERR1_MASK (0x2U) |
| #define | DMA_ERR_ERR1_SHIFT (1U) |
| #define | DMA_ERR_ERR1(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR1_SHIFT)) & DMA_ERR_ERR1_MASK) |
| #define | DMA_ERR_ERR2_MASK (0x4U) |
| #define | DMA_ERR_ERR2_SHIFT (2U) |
| #define | DMA_ERR_ERR2(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR2_SHIFT)) & DMA_ERR_ERR2_MASK) |
| #define | DMA_ERR_ERR3_MASK (0x8U) |
| #define | DMA_ERR_ERR3_SHIFT (3U) |
| #define | DMA_ERR_ERR3(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR3_SHIFT)) & DMA_ERR_ERR3_MASK) |
| #define | DMA_ERR_ERR4_MASK (0x10U) |
| #define | DMA_ERR_ERR4_SHIFT (4U) |
| #define | DMA_ERR_ERR4(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR4_SHIFT)) & DMA_ERR_ERR4_MASK) |
| #define | DMA_ERR_ERR5_MASK (0x20U) |
| #define | DMA_ERR_ERR5_SHIFT (5U) |
| #define | DMA_ERR_ERR5(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR5_SHIFT)) & DMA_ERR_ERR5_MASK) |
| #define | DMA_ERR_ERR6_MASK (0x40U) |
| #define | DMA_ERR_ERR6_SHIFT (6U) |
| #define | DMA_ERR_ERR6(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR6_SHIFT)) & DMA_ERR_ERR6_MASK) |
| #define | DMA_ERR_ERR7_MASK (0x80U) |
| #define | DMA_ERR_ERR7_SHIFT (7U) |
| #define | DMA_ERR_ERR7(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR7_SHIFT)) & DMA_ERR_ERR7_MASK) |
| #define | DMA_ERR_ERR8_MASK (0x100U) |
| #define | DMA_ERR_ERR8_SHIFT (8U) |
| #define | DMA_ERR_ERR8(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR8_SHIFT)) & DMA_ERR_ERR8_MASK) |
| #define | DMA_ERR_ERR9_MASK (0x200U) |
| #define | DMA_ERR_ERR9_SHIFT (9U) |
| #define | DMA_ERR_ERR9(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR9_SHIFT)) & DMA_ERR_ERR9_MASK) |
| #define | DMA_ERR_ERR10_MASK (0x400U) |
| #define | DMA_ERR_ERR10_SHIFT (10U) |
| #define | DMA_ERR_ERR10(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR10_SHIFT)) & DMA_ERR_ERR10_MASK) |
| #define | DMA_ERR_ERR11_MASK (0x800U) |
| #define | DMA_ERR_ERR11_SHIFT (11U) |
| #define | DMA_ERR_ERR11(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR11_SHIFT)) & DMA_ERR_ERR11_MASK) |
| #define | DMA_ERR_ERR12_MASK (0x1000U) |
| #define | DMA_ERR_ERR12_SHIFT (12U) |
| #define | DMA_ERR_ERR12(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR12_SHIFT)) & DMA_ERR_ERR12_MASK) |
| #define | DMA_ERR_ERR13_MASK (0x2000U) |
| #define | DMA_ERR_ERR13_SHIFT (13U) |
| #define | DMA_ERR_ERR13(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR13_SHIFT)) & DMA_ERR_ERR13_MASK) |
| #define | DMA_ERR_ERR14_MASK (0x4000U) |
| #define | DMA_ERR_ERR14_SHIFT (14U) |
| #define | DMA_ERR_ERR14(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR14_SHIFT)) & DMA_ERR_ERR14_MASK) |
| #define | DMA_ERR_ERR15_MASK (0x8000U) |
| #define | DMA_ERR_ERR15_SHIFT (15U) |
| #define | DMA_ERR_ERR15(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR15_SHIFT)) & DMA_ERR_ERR15_MASK) |
| #define | DMA_ERR_ERR16_MASK (0x10000U) |
| #define | DMA_ERR_ERR16_SHIFT (16U) |
| #define | DMA_ERR_ERR16(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR16_SHIFT)) & DMA_ERR_ERR16_MASK) |
| #define | DMA_ERR_ERR17_MASK (0x20000U) |
| #define | DMA_ERR_ERR17_SHIFT (17U) |
| #define | DMA_ERR_ERR17(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR17_SHIFT)) & DMA_ERR_ERR17_MASK) |
| #define | DMA_ERR_ERR18_MASK (0x40000U) |
| #define | DMA_ERR_ERR18_SHIFT (18U) |
| #define | DMA_ERR_ERR18(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR18_SHIFT)) & DMA_ERR_ERR18_MASK) |
| #define | DMA_ERR_ERR19_MASK (0x80000U) |
| #define | DMA_ERR_ERR19_SHIFT (19U) |
| #define | DMA_ERR_ERR19(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR19_SHIFT)) & DMA_ERR_ERR19_MASK) |
| #define | DMA_ERR_ERR20_MASK (0x100000U) |
| #define | DMA_ERR_ERR20_SHIFT (20U) |
| #define | DMA_ERR_ERR20(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR20_SHIFT)) & DMA_ERR_ERR20_MASK) |
| #define | DMA_ERR_ERR21_MASK (0x200000U) |
| #define | DMA_ERR_ERR21_SHIFT (21U) |
| #define | DMA_ERR_ERR21(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR21_SHIFT)) & DMA_ERR_ERR21_MASK) |
| #define | DMA_ERR_ERR22_MASK (0x400000U) |
| #define | DMA_ERR_ERR22_SHIFT (22U) |
| #define | DMA_ERR_ERR22(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR22_SHIFT)) & DMA_ERR_ERR22_MASK) |
| #define | DMA_ERR_ERR23_MASK (0x800000U) |
| #define | DMA_ERR_ERR23_SHIFT (23U) |
| #define | DMA_ERR_ERR23(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR23_SHIFT)) & DMA_ERR_ERR23_MASK) |
| #define | DMA_ERR_ERR24_MASK (0x1000000U) |
| #define | DMA_ERR_ERR24_SHIFT (24U) |
| #define | DMA_ERR_ERR24(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR24_SHIFT)) & DMA_ERR_ERR24_MASK) |
| #define | DMA_ERR_ERR25_MASK (0x2000000U) |
| #define | DMA_ERR_ERR25_SHIFT (25U) |
| #define | DMA_ERR_ERR25(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR25_SHIFT)) & DMA_ERR_ERR25_MASK) |
| #define | DMA_ERR_ERR26_MASK (0x4000000U) |
| #define | DMA_ERR_ERR26_SHIFT (26U) |
| #define | DMA_ERR_ERR26(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR26_SHIFT)) & DMA_ERR_ERR26_MASK) |
| #define | DMA_ERR_ERR27_MASK (0x8000000U) |
| #define | DMA_ERR_ERR27_SHIFT (27U) |
| #define | DMA_ERR_ERR27(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR27_SHIFT)) & DMA_ERR_ERR27_MASK) |
| #define | DMA_ERR_ERR28_MASK (0x10000000U) |
| #define | DMA_ERR_ERR28_SHIFT (28U) |
| #define | DMA_ERR_ERR28(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR28_SHIFT)) & DMA_ERR_ERR28_MASK) |
| #define | DMA_ERR_ERR29_MASK (0x20000000U) |
| #define | DMA_ERR_ERR29_SHIFT (29U) |
| #define | DMA_ERR_ERR29(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR29_SHIFT)) & DMA_ERR_ERR29_MASK) |
| #define | DMA_ERR_ERR30_MASK (0x40000000U) |
| #define | DMA_ERR_ERR30_SHIFT (30U) |
| #define | DMA_ERR_ERR30(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR30_SHIFT)) & DMA_ERR_ERR30_MASK) |
| #define | DMA_ERR_ERR31_MASK (0x80000000U) |
| #define | DMA_ERR_ERR31_SHIFT (31U) |
| #define | DMA_ERR_ERR31(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR31_SHIFT)) & DMA_ERR_ERR31_MASK) |
HRS - Hardware Request Status | |
| #define | DMA_HRS_HRS0_MASK (0x1U) |
| #define | DMA_HRS_HRS0_SHIFT (0U) |
| #define | DMA_HRS_HRS0(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS0_SHIFT)) & DMA_HRS_HRS0_MASK) |
| #define | DMA_HRS_HRS1_MASK (0x2U) |
| #define | DMA_HRS_HRS1_SHIFT (1U) |
| #define | DMA_HRS_HRS1(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS1_SHIFT)) & DMA_HRS_HRS1_MASK) |
| #define | DMA_HRS_HRS2_MASK (0x4U) |
| #define | DMA_HRS_HRS2_SHIFT (2U) |
| #define | DMA_HRS_HRS2(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS2_SHIFT)) & DMA_HRS_HRS2_MASK) |
| #define | DMA_HRS_HRS3_MASK (0x8U) |
| #define | DMA_HRS_HRS3_SHIFT (3U) |
| #define | DMA_HRS_HRS3(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS3_SHIFT)) & DMA_HRS_HRS3_MASK) |
| #define | DMA_HRS_HRS4_MASK (0x10U) |
| #define | DMA_HRS_HRS4_SHIFT (4U) |
| #define | DMA_HRS_HRS4(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS4_SHIFT)) & DMA_HRS_HRS4_MASK) |
| #define | DMA_HRS_HRS5_MASK (0x20U) |
| #define | DMA_HRS_HRS5_SHIFT (5U) |
| #define | DMA_HRS_HRS5(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS5_SHIFT)) & DMA_HRS_HRS5_MASK) |
| #define | DMA_HRS_HRS6_MASK (0x40U) |
| #define | DMA_HRS_HRS6_SHIFT (6U) |
| #define | DMA_HRS_HRS6(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS6_SHIFT)) & DMA_HRS_HRS6_MASK) |
| #define | DMA_HRS_HRS7_MASK (0x80U) |
| #define | DMA_HRS_HRS7_SHIFT (7U) |
| #define | DMA_HRS_HRS7(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS7_SHIFT)) & DMA_HRS_HRS7_MASK) |
| #define | DMA_HRS_HRS8_MASK (0x100U) |
| #define | DMA_HRS_HRS8_SHIFT (8U) |
| #define | DMA_HRS_HRS8(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS8_SHIFT)) & DMA_HRS_HRS8_MASK) |
| #define | DMA_HRS_HRS9_MASK (0x200U) |
| #define | DMA_HRS_HRS9_SHIFT (9U) |
| #define | DMA_HRS_HRS9(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS9_SHIFT)) & DMA_HRS_HRS9_MASK) |
| #define | DMA_HRS_HRS10_MASK (0x400U) |
| #define | DMA_HRS_HRS10_SHIFT (10U) |
| #define | DMA_HRS_HRS10(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS10_SHIFT)) & DMA_HRS_HRS10_MASK) |
| #define | DMA_HRS_HRS11_MASK (0x800U) |
| #define | DMA_HRS_HRS11_SHIFT (11U) |
| #define | DMA_HRS_HRS11(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS11_SHIFT)) & DMA_HRS_HRS11_MASK) |
| #define | DMA_HRS_HRS12_MASK (0x1000U) |
| #define | DMA_HRS_HRS12_SHIFT (12U) |
| #define | DMA_HRS_HRS12(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS12_SHIFT)) & DMA_HRS_HRS12_MASK) |
| #define | DMA_HRS_HRS13_MASK (0x2000U) |
| #define | DMA_HRS_HRS13_SHIFT (13U) |
| #define | DMA_HRS_HRS13(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS13_SHIFT)) & DMA_HRS_HRS13_MASK) |
| #define | DMA_HRS_HRS14_MASK (0x4000U) |
| #define | DMA_HRS_HRS14_SHIFT (14U) |
| #define | DMA_HRS_HRS14(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS14_SHIFT)) & DMA_HRS_HRS14_MASK) |
| #define | DMA_HRS_HRS15_MASK (0x8000U) |
| #define | DMA_HRS_HRS15_SHIFT (15U) |
| #define | DMA_HRS_HRS15(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS15_SHIFT)) & DMA_HRS_HRS15_MASK) |
| #define | DMA_HRS_HRS16_MASK (0x10000U) |
| #define | DMA_HRS_HRS16_SHIFT (16U) |
| #define | DMA_HRS_HRS16(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS16_SHIFT)) & DMA_HRS_HRS16_MASK) |
| #define | DMA_HRS_HRS17_MASK (0x20000U) |
| #define | DMA_HRS_HRS17_SHIFT (17U) |
| #define | DMA_HRS_HRS17(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS17_SHIFT)) & DMA_HRS_HRS17_MASK) |
| #define | DMA_HRS_HRS18_MASK (0x40000U) |
| #define | DMA_HRS_HRS18_SHIFT (18U) |
| #define | DMA_HRS_HRS18(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS18_SHIFT)) & DMA_HRS_HRS18_MASK) |
| #define | DMA_HRS_HRS19_MASK (0x80000U) |
| #define | DMA_HRS_HRS19_SHIFT (19U) |
| #define | DMA_HRS_HRS19(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS19_SHIFT)) & DMA_HRS_HRS19_MASK) |
| #define | DMA_HRS_HRS20_MASK (0x100000U) |
| #define | DMA_HRS_HRS20_SHIFT (20U) |
| #define | DMA_HRS_HRS20(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS20_SHIFT)) & DMA_HRS_HRS20_MASK) |
| #define | DMA_HRS_HRS21_MASK (0x200000U) |
| #define | DMA_HRS_HRS21_SHIFT (21U) |
| #define | DMA_HRS_HRS21(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS21_SHIFT)) & DMA_HRS_HRS21_MASK) |
| #define | DMA_HRS_HRS22_MASK (0x400000U) |
| #define | DMA_HRS_HRS22_SHIFT (22U) |
| #define | DMA_HRS_HRS22(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS22_SHIFT)) & DMA_HRS_HRS22_MASK) |
| #define | DMA_HRS_HRS23_MASK (0x800000U) |
| #define | DMA_HRS_HRS23_SHIFT (23U) |
| #define | DMA_HRS_HRS23(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS23_SHIFT)) & DMA_HRS_HRS23_MASK) |
| #define | DMA_HRS_HRS24_MASK (0x1000000U) |
| #define | DMA_HRS_HRS24_SHIFT (24U) |
| #define | DMA_HRS_HRS24(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS24_SHIFT)) & DMA_HRS_HRS24_MASK) |
| #define | DMA_HRS_HRS25_MASK (0x2000000U) |
| #define | DMA_HRS_HRS25_SHIFT (25U) |
| #define | DMA_HRS_HRS25(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS25_SHIFT)) & DMA_HRS_HRS25_MASK) |
| #define | DMA_HRS_HRS26_MASK (0x4000000U) |
| #define | DMA_HRS_HRS26_SHIFT (26U) |
| #define | DMA_HRS_HRS26(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS26_SHIFT)) & DMA_HRS_HRS26_MASK) |
| #define | DMA_HRS_HRS27_MASK (0x8000000U) |
| #define | DMA_HRS_HRS27_SHIFT (27U) |
| #define | DMA_HRS_HRS27(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS27_SHIFT)) & DMA_HRS_HRS27_MASK) |
| #define | DMA_HRS_HRS28_MASK (0x10000000U) |
| #define | DMA_HRS_HRS28_SHIFT (28U) |
| #define | DMA_HRS_HRS28(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS28_SHIFT)) & DMA_HRS_HRS28_MASK) |
| #define | DMA_HRS_HRS29_MASK (0x20000000U) |
| #define | DMA_HRS_HRS29_SHIFT (29U) |
| #define | DMA_HRS_HRS29(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS29_SHIFT)) & DMA_HRS_HRS29_MASK) |
| #define | DMA_HRS_HRS30_MASK (0x40000000U) |
| #define | DMA_HRS_HRS30_SHIFT (30U) |
| #define | DMA_HRS_HRS30(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS30_SHIFT)) & DMA_HRS_HRS30_MASK) |
| #define | DMA_HRS_HRS31_MASK (0x80000000U) |
| #define | DMA_HRS_HRS31_SHIFT (31U) |
| #define | DMA_HRS_HRS31(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS31_SHIFT)) & DMA_HRS_HRS31_MASK) |
EARS - Enable Asynchronous Request in Stop | |
| #define | DMA_EARS_EDREQ_0_MASK (0x1U) |
| #define | DMA_EARS_EDREQ_0_SHIFT (0U) |
| #define | DMA_EARS_EDREQ_0(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_0_SHIFT)) & DMA_EARS_EDREQ_0_MASK) |
| #define | DMA_EARS_EDREQ_1_MASK (0x2U) |
| #define | DMA_EARS_EDREQ_1_SHIFT (1U) |
| #define | DMA_EARS_EDREQ_1(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_1_SHIFT)) & DMA_EARS_EDREQ_1_MASK) |
| #define | DMA_EARS_EDREQ_2_MASK (0x4U) |
| #define | DMA_EARS_EDREQ_2_SHIFT (2U) |
| #define | DMA_EARS_EDREQ_2(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_2_SHIFT)) & DMA_EARS_EDREQ_2_MASK) |
| #define | DMA_EARS_EDREQ_3_MASK (0x8U) |
| #define | DMA_EARS_EDREQ_3_SHIFT (3U) |
| #define | DMA_EARS_EDREQ_3(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_3_SHIFT)) & DMA_EARS_EDREQ_3_MASK) |
| #define | DMA_EARS_EDREQ_4_MASK (0x10U) |
| #define | DMA_EARS_EDREQ_4_SHIFT (4U) |
| #define | DMA_EARS_EDREQ_4(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_4_SHIFT)) & DMA_EARS_EDREQ_4_MASK) |
| #define | DMA_EARS_EDREQ_5_MASK (0x20U) |
| #define | DMA_EARS_EDREQ_5_SHIFT (5U) |
| #define | DMA_EARS_EDREQ_5(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_5_SHIFT)) & DMA_EARS_EDREQ_5_MASK) |
| #define | DMA_EARS_EDREQ_6_MASK (0x40U) |
| #define | DMA_EARS_EDREQ_6_SHIFT (6U) |
| #define | DMA_EARS_EDREQ_6(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_6_SHIFT)) & DMA_EARS_EDREQ_6_MASK) |
| #define | DMA_EARS_EDREQ_7_MASK (0x80U) |
| #define | DMA_EARS_EDREQ_7_SHIFT (7U) |
| #define | DMA_EARS_EDREQ_7(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_7_SHIFT)) & DMA_EARS_EDREQ_7_MASK) |
| #define | DMA_EARS_EDREQ_8_MASK (0x100U) |
| #define | DMA_EARS_EDREQ_8_SHIFT (8U) |
| #define | DMA_EARS_EDREQ_8(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_8_SHIFT)) & DMA_EARS_EDREQ_8_MASK) |
| #define | DMA_EARS_EDREQ_9_MASK (0x200U) |
| #define | DMA_EARS_EDREQ_9_SHIFT (9U) |
| #define | DMA_EARS_EDREQ_9(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_9_SHIFT)) & DMA_EARS_EDREQ_9_MASK) |
| #define | DMA_EARS_EDREQ_10_MASK (0x400U) |
| #define | DMA_EARS_EDREQ_10_SHIFT (10U) |
| #define | DMA_EARS_EDREQ_10(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_10_SHIFT)) & DMA_EARS_EDREQ_10_MASK) |
| #define | DMA_EARS_EDREQ_11_MASK (0x800U) |
| #define | DMA_EARS_EDREQ_11_SHIFT (11U) |
| #define | DMA_EARS_EDREQ_11(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_11_SHIFT)) & DMA_EARS_EDREQ_11_MASK) |
| #define | DMA_EARS_EDREQ_12_MASK (0x1000U) |
| #define | DMA_EARS_EDREQ_12_SHIFT (12U) |
| #define | DMA_EARS_EDREQ_12(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_12_SHIFT)) & DMA_EARS_EDREQ_12_MASK) |
| #define | DMA_EARS_EDREQ_13_MASK (0x2000U) |
| #define | DMA_EARS_EDREQ_13_SHIFT (13U) |
| #define | DMA_EARS_EDREQ_13(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_13_SHIFT)) & DMA_EARS_EDREQ_13_MASK) |
| #define | DMA_EARS_EDREQ_14_MASK (0x4000U) |
| #define | DMA_EARS_EDREQ_14_SHIFT (14U) |
| #define | DMA_EARS_EDREQ_14(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_14_SHIFT)) & DMA_EARS_EDREQ_14_MASK) |
| #define | DMA_EARS_EDREQ_15_MASK (0x8000U) |
| #define | DMA_EARS_EDREQ_15_SHIFT (15U) |
| #define | DMA_EARS_EDREQ_15(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_15_SHIFT)) & DMA_EARS_EDREQ_15_MASK) |
| #define | DMA_EARS_EDREQ_16_MASK (0x10000U) |
| #define | DMA_EARS_EDREQ_16_SHIFT (16U) |
| #define | DMA_EARS_EDREQ_16(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_16_SHIFT)) & DMA_EARS_EDREQ_16_MASK) |
| #define | DMA_EARS_EDREQ_17_MASK (0x20000U) |
| #define | DMA_EARS_EDREQ_17_SHIFT (17U) |
| #define | DMA_EARS_EDREQ_17(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_17_SHIFT)) & DMA_EARS_EDREQ_17_MASK) |
| #define | DMA_EARS_EDREQ_18_MASK (0x40000U) |
| #define | DMA_EARS_EDREQ_18_SHIFT (18U) |
| #define | DMA_EARS_EDREQ_18(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_18_SHIFT)) & DMA_EARS_EDREQ_18_MASK) |
| #define | DMA_EARS_EDREQ_19_MASK (0x80000U) |
| #define | DMA_EARS_EDREQ_19_SHIFT (19U) |
| #define | DMA_EARS_EDREQ_19(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_19_SHIFT)) & DMA_EARS_EDREQ_19_MASK) |
| #define | DMA_EARS_EDREQ_20_MASK (0x100000U) |
| #define | DMA_EARS_EDREQ_20_SHIFT (20U) |
| #define | DMA_EARS_EDREQ_20(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_20_SHIFT)) & DMA_EARS_EDREQ_20_MASK) |
| #define | DMA_EARS_EDREQ_21_MASK (0x200000U) |
| #define | DMA_EARS_EDREQ_21_SHIFT (21U) |
| #define | DMA_EARS_EDREQ_21(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_21_SHIFT)) & DMA_EARS_EDREQ_21_MASK) |
| #define | DMA_EARS_EDREQ_22_MASK (0x400000U) |
| #define | DMA_EARS_EDREQ_22_SHIFT (22U) |
| #define | DMA_EARS_EDREQ_22(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_22_SHIFT)) & DMA_EARS_EDREQ_22_MASK) |
| #define | DMA_EARS_EDREQ_23_MASK (0x800000U) |
| #define | DMA_EARS_EDREQ_23_SHIFT (23U) |
| #define | DMA_EARS_EDREQ_23(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_23_SHIFT)) & DMA_EARS_EDREQ_23_MASK) |
| #define | DMA_EARS_EDREQ_24_MASK (0x1000000U) |
| #define | DMA_EARS_EDREQ_24_SHIFT (24U) |
| #define | DMA_EARS_EDREQ_24(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_24_SHIFT)) & DMA_EARS_EDREQ_24_MASK) |
| #define | DMA_EARS_EDREQ_25_MASK (0x2000000U) |
| #define | DMA_EARS_EDREQ_25_SHIFT (25U) |
| #define | DMA_EARS_EDREQ_25(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_25_SHIFT)) & DMA_EARS_EDREQ_25_MASK) |
| #define | DMA_EARS_EDREQ_26_MASK (0x4000000U) |
| #define | DMA_EARS_EDREQ_26_SHIFT (26U) |
| #define | DMA_EARS_EDREQ_26(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_26_SHIFT)) & DMA_EARS_EDREQ_26_MASK) |
| #define | DMA_EARS_EDREQ_27_MASK (0x8000000U) |
| #define | DMA_EARS_EDREQ_27_SHIFT (27U) |
| #define | DMA_EARS_EDREQ_27(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_27_SHIFT)) & DMA_EARS_EDREQ_27_MASK) |
| #define | DMA_EARS_EDREQ_28_MASK (0x10000000U) |
| #define | DMA_EARS_EDREQ_28_SHIFT (28U) |
| #define | DMA_EARS_EDREQ_28(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_28_SHIFT)) & DMA_EARS_EDREQ_28_MASK) |
| #define | DMA_EARS_EDREQ_29_MASK (0x20000000U) |
| #define | DMA_EARS_EDREQ_29_SHIFT (29U) |
| #define | DMA_EARS_EDREQ_29(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_29_SHIFT)) & DMA_EARS_EDREQ_29_MASK) |
| #define | DMA_EARS_EDREQ_30_MASK (0x40000000U) |
| #define | DMA_EARS_EDREQ_30_SHIFT (30U) |
| #define | DMA_EARS_EDREQ_30(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_30_SHIFT)) & DMA_EARS_EDREQ_30_MASK) |
| #define | DMA_EARS_EDREQ_31_MASK (0x80000000U) |
| #define | DMA_EARS_EDREQ_31_SHIFT (31U) |
| #define | DMA_EARS_EDREQ_31(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_31_SHIFT)) & DMA_EARS_EDREQ_31_MASK) |
DCHPRI3 - Channel Priority | |
| #define | DMA_DCHPRI3_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI3_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI3_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_CHPRI_SHIFT)) & DMA_DCHPRI3_CHPRI_MASK) |
| #define | DMA_DCHPRI3_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI3_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI3_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_GRPPRI_SHIFT)) & DMA_DCHPRI3_GRPPRI_MASK) |
| #define | DMA_DCHPRI3_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI3_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI3_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_DPA_SHIFT)) & DMA_DCHPRI3_DPA_MASK) |
| #define | DMA_DCHPRI3_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI3_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI3_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_ECP_SHIFT)) & DMA_DCHPRI3_ECP_MASK) |
DCHPRI2 - Channel Priority | |
| #define | DMA_DCHPRI2_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI2_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI2_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_CHPRI_SHIFT)) & DMA_DCHPRI2_CHPRI_MASK) |
| #define | DMA_DCHPRI2_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI2_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI2_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_GRPPRI_SHIFT)) & DMA_DCHPRI2_GRPPRI_MASK) |
| #define | DMA_DCHPRI2_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI2_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI2_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_DPA_SHIFT)) & DMA_DCHPRI2_DPA_MASK) |
| #define | DMA_DCHPRI2_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI2_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI2_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_ECP_SHIFT)) & DMA_DCHPRI2_ECP_MASK) |
DCHPRI1 - Channel Priority | |
| #define | DMA_DCHPRI1_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI1_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI1_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_CHPRI_SHIFT)) & DMA_DCHPRI1_CHPRI_MASK) |
| #define | DMA_DCHPRI1_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI1_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI1_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_GRPPRI_SHIFT)) & DMA_DCHPRI1_GRPPRI_MASK) |
| #define | DMA_DCHPRI1_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI1_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI1_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_DPA_SHIFT)) & DMA_DCHPRI1_DPA_MASK) |
| #define | DMA_DCHPRI1_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI1_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI1_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_ECP_SHIFT)) & DMA_DCHPRI1_ECP_MASK) |
DCHPRI0 - Channel Priority | |
| #define | DMA_DCHPRI0_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI0_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI0_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_CHPRI_SHIFT)) & DMA_DCHPRI0_CHPRI_MASK) |
| #define | DMA_DCHPRI0_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI0_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI0_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_GRPPRI_SHIFT)) & DMA_DCHPRI0_GRPPRI_MASK) |
| #define | DMA_DCHPRI0_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI0_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI0_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_DPA_SHIFT)) & DMA_DCHPRI0_DPA_MASK) |
| #define | DMA_DCHPRI0_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI0_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI0_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_ECP_SHIFT)) & DMA_DCHPRI0_ECP_MASK) |
DCHPRI7 - Channel Priority | |
| #define | DMA_DCHPRI7_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI7_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI7_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_CHPRI_SHIFT)) & DMA_DCHPRI7_CHPRI_MASK) |
| #define | DMA_DCHPRI7_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI7_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI7_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_GRPPRI_SHIFT)) & DMA_DCHPRI7_GRPPRI_MASK) |
| #define | DMA_DCHPRI7_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI7_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI7_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_DPA_SHIFT)) & DMA_DCHPRI7_DPA_MASK) |
| #define | DMA_DCHPRI7_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI7_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI7_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_ECP_SHIFT)) & DMA_DCHPRI7_ECP_MASK) |
DCHPRI6 - Channel Priority | |
| #define | DMA_DCHPRI6_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI6_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI6_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_CHPRI_SHIFT)) & DMA_DCHPRI6_CHPRI_MASK) |
| #define | DMA_DCHPRI6_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI6_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI6_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_GRPPRI_SHIFT)) & DMA_DCHPRI6_GRPPRI_MASK) |
| #define | DMA_DCHPRI6_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI6_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI6_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_DPA_SHIFT)) & DMA_DCHPRI6_DPA_MASK) |
| #define | DMA_DCHPRI6_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI6_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI6_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_ECP_SHIFT)) & DMA_DCHPRI6_ECP_MASK) |
DCHPRI5 - Channel Priority | |
| #define | DMA_DCHPRI5_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI5_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI5_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_CHPRI_SHIFT)) & DMA_DCHPRI5_CHPRI_MASK) |
| #define | DMA_DCHPRI5_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI5_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI5_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_GRPPRI_SHIFT)) & DMA_DCHPRI5_GRPPRI_MASK) |
| #define | DMA_DCHPRI5_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI5_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI5_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_DPA_SHIFT)) & DMA_DCHPRI5_DPA_MASK) |
| #define | DMA_DCHPRI5_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI5_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI5_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_ECP_SHIFT)) & DMA_DCHPRI5_ECP_MASK) |
DCHPRI4 - Channel Priority | |
| #define | DMA_DCHPRI4_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI4_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI4_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_CHPRI_SHIFT)) & DMA_DCHPRI4_CHPRI_MASK) |
| #define | DMA_DCHPRI4_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI4_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI4_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_GRPPRI_SHIFT)) & DMA_DCHPRI4_GRPPRI_MASK) |
| #define | DMA_DCHPRI4_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI4_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI4_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_DPA_SHIFT)) & DMA_DCHPRI4_DPA_MASK) |
| #define | DMA_DCHPRI4_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI4_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI4_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_ECP_SHIFT)) & DMA_DCHPRI4_ECP_MASK) |
DCHPRI11 - Channel Priority | |
| #define | DMA_DCHPRI11_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI11_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI11_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_CHPRI_SHIFT)) & DMA_DCHPRI11_CHPRI_MASK) |
| #define | DMA_DCHPRI11_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI11_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI11_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_GRPPRI_SHIFT)) & DMA_DCHPRI11_GRPPRI_MASK) |
| #define | DMA_DCHPRI11_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI11_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI11_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_DPA_SHIFT)) & DMA_DCHPRI11_DPA_MASK) |
| #define | DMA_DCHPRI11_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI11_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI11_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_ECP_SHIFT)) & DMA_DCHPRI11_ECP_MASK) |
DCHPRI10 - Channel Priority | |
| #define | DMA_DCHPRI10_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI10_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI10_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_CHPRI_SHIFT)) & DMA_DCHPRI10_CHPRI_MASK) |
| #define | DMA_DCHPRI10_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI10_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI10_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_GRPPRI_SHIFT)) & DMA_DCHPRI10_GRPPRI_MASK) |
| #define | DMA_DCHPRI10_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI10_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI10_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_DPA_SHIFT)) & DMA_DCHPRI10_DPA_MASK) |
| #define | DMA_DCHPRI10_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI10_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI10_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_ECP_SHIFT)) & DMA_DCHPRI10_ECP_MASK) |
DCHPRI9 - Channel Priority | |
| #define | DMA_DCHPRI9_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI9_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI9_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_CHPRI_SHIFT)) & DMA_DCHPRI9_CHPRI_MASK) |
| #define | DMA_DCHPRI9_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI9_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI9_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_GRPPRI_SHIFT)) & DMA_DCHPRI9_GRPPRI_MASK) |
| #define | DMA_DCHPRI9_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI9_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI9_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_DPA_SHIFT)) & DMA_DCHPRI9_DPA_MASK) |
| #define | DMA_DCHPRI9_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI9_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI9_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_ECP_SHIFT)) & DMA_DCHPRI9_ECP_MASK) |
DCHPRI8 - Channel Priority | |
| #define | DMA_DCHPRI8_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI8_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI8_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_CHPRI_SHIFT)) & DMA_DCHPRI8_CHPRI_MASK) |
| #define | DMA_DCHPRI8_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI8_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI8_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_GRPPRI_SHIFT)) & DMA_DCHPRI8_GRPPRI_MASK) |
| #define | DMA_DCHPRI8_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI8_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI8_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_DPA_SHIFT)) & DMA_DCHPRI8_DPA_MASK) |
| #define | DMA_DCHPRI8_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI8_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI8_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_ECP_SHIFT)) & DMA_DCHPRI8_ECP_MASK) |
DCHPRI15 - Channel Priority | |
| #define | DMA_DCHPRI15_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI15_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI15_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_CHPRI_SHIFT)) & DMA_DCHPRI15_CHPRI_MASK) |
| #define | DMA_DCHPRI15_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI15_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI15_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_GRPPRI_SHIFT)) & DMA_DCHPRI15_GRPPRI_MASK) |
| #define | DMA_DCHPRI15_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI15_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI15_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_DPA_SHIFT)) & DMA_DCHPRI15_DPA_MASK) |
| #define | DMA_DCHPRI15_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI15_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI15_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_ECP_SHIFT)) & DMA_DCHPRI15_ECP_MASK) |
DCHPRI14 - Channel Priority | |
| #define | DMA_DCHPRI14_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI14_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI14_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_CHPRI_SHIFT)) & DMA_DCHPRI14_CHPRI_MASK) |
| #define | DMA_DCHPRI14_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI14_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI14_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_GRPPRI_SHIFT)) & DMA_DCHPRI14_GRPPRI_MASK) |
| #define | DMA_DCHPRI14_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI14_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI14_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_DPA_SHIFT)) & DMA_DCHPRI14_DPA_MASK) |
| #define | DMA_DCHPRI14_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI14_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI14_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_ECP_SHIFT)) & DMA_DCHPRI14_ECP_MASK) |
DCHPRI13 - Channel Priority | |
| #define | DMA_DCHPRI13_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI13_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI13_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_CHPRI_SHIFT)) & DMA_DCHPRI13_CHPRI_MASK) |
| #define | DMA_DCHPRI13_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI13_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI13_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_GRPPRI_SHIFT)) & DMA_DCHPRI13_GRPPRI_MASK) |
| #define | DMA_DCHPRI13_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI13_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI13_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_DPA_SHIFT)) & DMA_DCHPRI13_DPA_MASK) |
| #define | DMA_DCHPRI13_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI13_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI13_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_ECP_SHIFT)) & DMA_DCHPRI13_ECP_MASK) |
DCHPRI12 - Channel Priority | |
| #define | DMA_DCHPRI12_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI12_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI12_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_CHPRI_SHIFT)) & DMA_DCHPRI12_CHPRI_MASK) |
| #define | DMA_DCHPRI12_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI12_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI12_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_GRPPRI_SHIFT)) & DMA_DCHPRI12_GRPPRI_MASK) |
| #define | DMA_DCHPRI12_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI12_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI12_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_DPA_SHIFT)) & DMA_DCHPRI12_DPA_MASK) |
| #define | DMA_DCHPRI12_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI12_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI12_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_ECP_SHIFT)) & DMA_DCHPRI12_ECP_MASK) |
DCHPRI19 - Channel Priority | |
| #define | DMA_DCHPRI19_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI19_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI19_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_CHPRI_SHIFT)) & DMA_DCHPRI19_CHPRI_MASK) |
| #define | DMA_DCHPRI19_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI19_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI19_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_GRPPRI_SHIFT)) & DMA_DCHPRI19_GRPPRI_MASK) |
| #define | DMA_DCHPRI19_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI19_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI19_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_DPA_SHIFT)) & DMA_DCHPRI19_DPA_MASK) |
| #define | DMA_DCHPRI19_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI19_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI19_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_ECP_SHIFT)) & DMA_DCHPRI19_ECP_MASK) |
DCHPRI18 - Channel Priority | |
| #define | DMA_DCHPRI18_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI18_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI18_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_CHPRI_SHIFT)) & DMA_DCHPRI18_CHPRI_MASK) |
| #define | DMA_DCHPRI18_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI18_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI18_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_GRPPRI_SHIFT)) & DMA_DCHPRI18_GRPPRI_MASK) |
| #define | DMA_DCHPRI18_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI18_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI18_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_DPA_SHIFT)) & DMA_DCHPRI18_DPA_MASK) |
| #define | DMA_DCHPRI18_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI18_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI18_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_ECP_SHIFT)) & DMA_DCHPRI18_ECP_MASK) |
DCHPRI17 - Channel Priority | |
| #define | DMA_DCHPRI17_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI17_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI17_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_CHPRI_SHIFT)) & DMA_DCHPRI17_CHPRI_MASK) |
| #define | DMA_DCHPRI17_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI17_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI17_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_GRPPRI_SHIFT)) & DMA_DCHPRI17_GRPPRI_MASK) |
| #define | DMA_DCHPRI17_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI17_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI17_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_DPA_SHIFT)) & DMA_DCHPRI17_DPA_MASK) |
| #define | DMA_DCHPRI17_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI17_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI17_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_ECP_SHIFT)) & DMA_DCHPRI17_ECP_MASK) |
DCHPRI16 - Channel Priority | |
| #define | DMA_DCHPRI16_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI16_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI16_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_CHPRI_SHIFT)) & DMA_DCHPRI16_CHPRI_MASK) |
| #define | DMA_DCHPRI16_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI16_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI16_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_GRPPRI_SHIFT)) & DMA_DCHPRI16_GRPPRI_MASK) |
| #define | DMA_DCHPRI16_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI16_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI16_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_DPA_SHIFT)) & DMA_DCHPRI16_DPA_MASK) |
| #define | DMA_DCHPRI16_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI16_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI16_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_ECP_SHIFT)) & DMA_DCHPRI16_ECP_MASK) |
DCHPRI23 - Channel Priority | |
| #define | DMA_DCHPRI23_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI23_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI23_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_CHPRI_SHIFT)) & DMA_DCHPRI23_CHPRI_MASK) |
| #define | DMA_DCHPRI23_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI23_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI23_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_GRPPRI_SHIFT)) & DMA_DCHPRI23_GRPPRI_MASK) |
| #define | DMA_DCHPRI23_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI23_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI23_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_DPA_SHIFT)) & DMA_DCHPRI23_DPA_MASK) |
| #define | DMA_DCHPRI23_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI23_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI23_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_ECP_SHIFT)) & DMA_DCHPRI23_ECP_MASK) |
DCHPRI22 - Channel Priority | |
| #define | DMA_DCHPRI22_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI22_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI22_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_CHPRI_SHIFT)) & DMA_DCHPRI22_CHPRI_MASK) |
| #define | DMA_DCHPRI22_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI22_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI22_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_GRPPRI_SHIFT)) & DMA_DCHPRI22_GRPPRI_MASK) |
| #define | DMA_DCHPRI22_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI22_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI22_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_DPA_SHIFT)) & DMA_DCHPRI22_DPA_MASK) |
| #define | DMA_DCHPRI22_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI22_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI22_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_ECP_SHIFT)) & DMA_DCHPRI22_ECP_MASK) |
DCHPRI21 - Channel Priority | |
| #define | DMA_DCHPRI21_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI21_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI21_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_CHPRI_SHIFT)) & DMA_DCHPRI21_CHPRI_MASK) |
| #define | DMA_DCHPRI21_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI21_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI21_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_GRPPRI_SHIFT)) & DMA_DCHPRI21_GRPPRI_MASK) |
| #define | DMA_DCHPRI21_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI21_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI21_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_DPA_SHIFT)) & DMA_DCHPRI21_DPA_MASK) |
| #define | DMA_DCHPRI21_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI21_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI21_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_ECP_SHIFT)) & DMA_DCHPRI21_ECP_MASK) |
DCHPRI20 - Channel Priority | |
| #define | DMA_DCHPRI20_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI20_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI20_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_CHPRI_SHIFT)) & DMA_DCHPRI20_CHPRI_MASK) |
| #define | DMA_DCHPRI20_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI20_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI20_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_GRPPRI_SHIFT)) & DMA_DCHPRI20_GRPPRI_MASK) |
| #define | DMA_DCHPRI20_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI20_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI20_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_DPA_SHIFT)) & DMA_DCHPRI20_DPA_MASK) |
| #define | DMA_DCHPRI20_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI20_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI20_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_ECP_SHIFT)) & DMA_DCHPRI20_ECP_MASK) |
DCHPRI27 - Channel Priority | |
| #define | DMA_DCHPRI27_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI27_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI27_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_CHPRI_SHIFT)) & DMA_DCHPRI27_CHPRI_MASK) |
| #define | DMA_DCHPRI27_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI27_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI27_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_GRPPRI_SHIFT)) & DMA_DCHPRI27_GRPPRI_MASK) |
| #define | DMA_DCHPRI27_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI27_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI27_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_DPA_SHIFT)) & DMA_DCHPRI27_DPA_MASK) |
| #define | DMA_DCHPRI27_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI27_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI27_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_ECP_SHIFT)) & DMA_DCHPRI27_ECP_MASK) |
DCHPRI26 - Channel Priority | |
| #define | DMA_DCHPRI26_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI26_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI26_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_CHPRI_SHIFT)) & DMA_DCHPRI26_CHPRI_MASK) |
| #define | DMA_DCHPRI26_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI26_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI26_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_GRPPRI_SHIFT)) & DMA_DCHPRI26_GRPPRI_MASK) |
| #define | DMA_DCHPRI26_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI26_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI26_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_DPA_SHIFT)) & DMA_DCHPRI26_DPA_MASK) |
| #define | DMA_DCHPRI26_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI26_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI26_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_ECP_SHIFT)) & DMA_DCHPRI26_ECP_MASK) |
DCHPRI25 - Channel Priority | |
| #define | DMA_DCHPRI25_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI25_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI25_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_CHPRI_SHIFT)) & DMA_DCHPRI25_CHPRI_MASK) |
| #define | DMA_DCHPRI25_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI25_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI25_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_GRPPRI_SHIFT)) & DMA_DCHPRI25_GRPPRI_MASK) |
| #define | DMA_DCHPRI25_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI25_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI25_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_DPA_SHIFT)) & DMA_DCHPRI25_DPA_MASK) |
| #define | DMA_DCHPRI25_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI25_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI25_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_ECP_SHIFT)) & DMA_DCHPRI25_ECP_MASK) |
DCHPRI24 - Channel Priority | |
| #define | DMA_DCHPRI24_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI24_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI24_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_CHPRI_SHIFT)) & DMA_DCHPRI24_CHPRI_MASK) |
| #define | DMA_DCHPRI24_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI24_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI24_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_GRPPRI_SHIFT)) & DMA_DCHPRI24_GRPPRI_MASK) |
| #define | DMA_DCHPRI24_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI24_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI24_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_DPA_SHIFT)) & DMA_DCHPRI24_DPA_MASK) |
| #define | DMA_DCHPRI24_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI24_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI24_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_ECP_SHIFT)) & DMA_DCHPRI24_ECP_MASK) |
DCHPRI31 - Channel Priority | |
| #define | DMA_DCHPRI31_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI31_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI31_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_CHPRI_SHIFT)) & DMA_DCHPRI31_CHPRI_MASK) |
| #define | DMA_DCHPRI31_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI31_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI31_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_GRPPRI_SHIFT)) & DMA_DCHPRI31_GRPPRI_MASK) |
| #define | DMA_DCHPRI31_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI31_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI31_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_DPA_SHIFT)) & DMA_DCHPRI31_DPA_MASK) |
| #define | DMA_DCHPRI31_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI31_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI31_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_ECP_SHIFT)) & DMA_DCHPRI31_ECP_MASK) |
DCHPRI30 - Channel Priority | |
| #define | DMA_DCHPRI30_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI30_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI30_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_CHPRI_SHIFT)) & DMA_DCHPRI30_CHPRI_MASK) |
| #define | DMA_DCHPRI30_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI30_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI30_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_GRPPRI_SHIFT)) & DMA_DCHPRI30_GRPPRI_MASK) |
| #define | DMA_DCHPRI30_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI30_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI30_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_DPA_SHIFT)) & DMA_DCHPRI30_DPA_MASK) |
| #define | DMA_DCHPRI30_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI30_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI30_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_ECP_SHIFT)) & DMA_DCHPRI30_ECP_MASK) |
DCHPRI29 - Channel Priority | |
| #define | DMA_DCHPRI29_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI29_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI29_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_CHPRI_SHIFT)) & DMA_DCHPRI29_CHPRI_MASK) |
| #define | DMA_DCHPRI29_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI29_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI29_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_GRPPRI_SHIFT)) & DMA_DCHPRI29_GRPPRI_MASK) |
| #define | DMA_DCHPRI29_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI29_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI29_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_DPA_SHIFT)) & DMA_DCHPRI29_DPA_MASK) |
| #define | DMA_DCHPRI29_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI29_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI29_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_ECP_SHIFT)) & DMA_DCHPRI29_ECP_MASK) |
DCHPRI28 - Channel Priority | |
| #define | DMA_DCHPRI28_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI28_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI28_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_CHPRI_SHIFT)) & DMA_DCHPRI28_CHPRI_MASK) |
| #define | DMA_DCHPRI28_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI28_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI28_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_GRPPRI_SHIFT)) & DMA_DCHPRI28_GRPPRI_MASK) |
| #define | DMA_DCHPRI28_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI28_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI28_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_DPA_SHIFT)) & DMA_DCHPRI28_DPA_MASK) |
| #define | DMA_DCHPRI28_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI28_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI28_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_ECP_SHIFT)) & DMA_DCHPRI28_ECP_MASK) |
SADDR - TCD Source Address | |
| #define | DMA_SADDR_SADDR_MASK (0xFFFFFFFFU) |
| #define | DMA_SADDR_SADDR_SHIFT (0U) |
| #define | DMA_SADDR_SADDR(x) (((uint32_t)(((uint32_t)(x)) << DMA_SADDR_SADDR_SHIFT)) & DMA_SADDR_SADDR_MASK) |
SOFF - TCD Signed Source Address Offset | |
| #define | DMA_SOFF_SOFF_MASK (0xFFFFU) |
| #define | DMA_SOFF_SOFF_SHIFT (0U) |
| #define | DMA_SOFF_SOFF(x) (((uint16_t)(((uint16_t)(x)) << DMA_SOFF_SOFF_SHIFT)) & DMA_SOFF_SOFF_MASK) |
ATTR - TCD Transfer Attributes | |
| #define | DMA_ATTR_DSIZE_MASK (0x7U) |
| #define | DMA_ATTR_DSIZE_SHIFT (0U) |
| #define | DMA_ATTR_DSIZE(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DSIZE_SHIFT)) & DMA_ATTR_DSIZE_MASK) |
| #define | DMA_ATTR_DMOD_MASK (0xF8U) |
| #define | DMA_ATTR_DMOD_SHIFT (3U) |
| #define | DMA_ATTR_DMOD(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DMOD_SHIFT)) & DMA_ATTR_DMOD_MASK) |
| #define | DMA_ATTR_SSIZE_MASK (0x700U) |
| #define | DMA_ATTR_SSIZE_SHIFT (8U) |
| #define | DMA_ATTR_SSIZE(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SSIZE_SHIFT)) & DMA_ATTR_SSIZE_MASK) |
| #define | DMA_ATTR_SMOD_MASK (0xF800U) |
| #define | DMA_ATTR_SMOD_SHIFT (11U) |
| #define | DMA_ATTR_SMOD(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SMOD_SHIFT)) & DMA_ATTR_SMOD_MASK) |
NBYTES_MLNO - TCD Minor Byte Count (Minor Loop Mapping Disabled) | |
| #define | DMA_NBYTES_MLNO_NBYTES_MASK (0xFFFFFFFFU) |
| #define | DMA_NBYTES_MLNO_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLNO_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLNO_NBYTES_SHIFT)) & DMA_NBYTES_MLNO_NBYTES_MASK) |
NBYTES_MLOFFNO - TCD Signed Minor Loop Offset (Minor Loop Mapping Enabled and Offset Disabled) | |
| #define | DMA_NBYTES_MLOFFNO_NBYTES_MASK (0x3FFFFFFFU) |
| #define | DMA_NBYTES_MLOFFNO_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLOFFNO_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFNO_NBYTES_MASK) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE_MASK (0x40000000U) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE_SHIFT (30U) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_DMLOE_MASK) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE_MASK (0x80000000U) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE_SHIFT (31U) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_SMLOE_MASK) |
NBYTES_MLOFFYES - TCD Signed Minor Loop Offset (Minor Loop Mapping and Offset Enabled) | |
| #define | DMA_NBYTES_MLOFFYES_NBYTES_MASK (0x3FFU) |
| #define | DMA_NBYTES_MLOFFYES_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLOFFYES_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFYES_NBYTES_MASK) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF_MASK (0x3FFFFC00U) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF_SHIFT (10U) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_MLOFF_SHIFT)) & DMA_NBYTES_MLOFFYES_MLOFF_MASK) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE_MASK (0x40000000U) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE_SHIFT (30U) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_DMLOE_MASK) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE_MASK (0x80000000U) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE_SHIFT (31U) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_SMLOE_MASK) |
SLAST - TCD Last Source Address Adjustment | |
| #define | DMA_SLAST_SLAST_MASK (0xFFFFFFFFU) |
| #define | DMA_SLAST_SLAST_SHIFT (0U) |
| #define | DMA_SLAST_SLAST(x) (((uint32_t)(((uint32_t)(x)) << DMA_SLAST_SLAST_SHIFT)) & DMA_SLAST_SLAST_MASK) |
DADDR - TCD Destination Address | |
| #define | DMA_DADDR_DADDR_MASK (0xFFFFFFFFU) |
| #define | DMA_DADDR_DADDR_SHIFT (0U) |
| #define | DMA_DADDR_DADDR(x) (((uint32_t)(((uint32_t)(x)) << DMA_DADDR_DADDR_SHIFT)) & DMA_DADDR_DADDR_MASK) |
DOFF - TCD Signed Destination Address Offset | |
| #define | DMA_DOFF_DOFF_MASK (0xFFFFU) |
| #define | DMA_DOFF_DOFF_SHIFT (0U) |
| #define | DMA_DOFF_DOFF(x) (((uint16_t)(((uint16_t)(x)) << DMA_DOFF_DOFF_SHIFT)) & DMA_DOFF_DOFF_MASK) |
CITER_ELINKNO - TCD Current Minor Loop Link, Major Loop Count (Channel Linking Disabled) | |
| #define | DMA_CITER_ELINKNO_CITER_MASK (0x7FFFU) |
| #define | DMA_CITER_ELINKNO_CITER_SHIFT (0U) |
| #define | DMA_CITER_ELINKNO_CITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_CITER_SHIFT)) & DMA_CITER_ELINKNO_CITER_MASK) |
| #define | DMA_CITER_ELINKNO_ELINK_MASK (0x8000U) |
| #define | DMA_CITER_ELINKNO_ELINK_SHIFT (15U) |
| #define | DMA_CITER_ELINKNO_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_ELINK_SHIFT)) & DMA_CITER_ELINKNO_ELINK_MASK) |
CITER_ELINKYES - TCD Current Minor Loop Link, Major Loop Count (Channel Linking Enabled) | |
| #define | DMA_CITER_ELINKYES_CITER_MASK (0x1FFU) |
| #define | DMA_CITER_ELINKYES_CITER_SHIFT (0U) |
| #define | DMA_CITER_ELINKYES_CITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_CITER_SHIFT)) & DMA_CITER_ELINKYES_CITER_MASK) |
| #define | DMA_CITER_ELINKYES_LINKCH_MASK (0x3E00U) |
| #define | DMA_CITER_ELINKYES_LINKCH_SHIFT (9U) |
| #define | DMA_CITER_ELINKYES_LINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_LINKCH_SHIFT)) & DMA_CITER_ELINKYES_LINKCH_MASK) |
| #define | DMA_CITER_ELINKYES_ELINK_MASK (0x8000U) |
| #define | DMA_CITER_ELINKYES_ELINK_SHIFT (15U) |
| #define | DMA_CITER_ELINKYES_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_ELINK_SHIFT)) & DMA_CITER_ELINKYES_ELINK_MASK) |
DLAST_SGA - TCD Last Destination Address Adjustment/Scatter Gather Address | |
| #define | DMA_DLAST_SGA_DLASTSGA_MASK (0xFFFFFFFFU) |
| #define | DMA_DLAST_SGA_DLASTSGA_SHIFT (0U) |
| #define | DMA_DLAST_SGA_DLASTSGA(x) (((uint32_t)(((uint32_t)(x)) << DMA_DLAST_SGA_DLASTSGA_SHIFT)) & DMA_DLAST_SGA_DLASTSGA_MASK) |
CSR - TCD Control and Status | |
| #define | DMA_CSR_START_MASK (0x1U) |
| #define | DMA_CSR_START_SHIFT (0U) |
| #define | DMA_CSR_START(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_START_SHIFT)) & DMA_CSR_START_MASK) |
| #define | DMA_CSR_INTMAJOR_MASK (0x2U) |
| #define | DMA_CSR_INTMAJOR_SHIFT (1U) |
| #define | DMA_CSR_INTMAJOR(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTMAJOR_SHIFT)) & DMA_CSR_INTMAJOR_MASK) |
| #define | DMA_CSR_INTHALF_MASK (0x4U) |
| #define | DMA_CSR_INTHALF_SHIFT (2U) |
| #define | DMA_CSR_INTHALF(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTHALF_SHIFT)) & DMA_CSR_INTHALF_MASK) |
| #define | DMA_CSR_DREQ_MASK (0x8U) |
| #define | DMA_CSR_DREQ_SHIFT (3U) |
| #define | DMA_CSR_DREQ(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DREQ_SHIFT)) & DMA_CSR_DREQ_MASK) |
| #define | DMA_CSR_ESG_MASK (0x10U) |
| #define | DMA_CSR_ESG_SHIFT (4U) |
| #define | DMA_CSR_ESG(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ESG_SHIFT)) & DMA_CSR_ESG_MASK) |
| #define | DMA_CSR_MAJORELINK_MASK (0x20U) |
| #define | DMA_CSR_MAJORELINK_SHIFT (5U) |
| #define | DMA_CSR_MAJORELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORELINK_SHIFT)) & DMA_CSR_MAJORELINK_MASK) |
| #define | DMA_CSR_ACTIVE_MASK (0x40U) |
| #define | DMA_CSR_ACTIVE_SHIFT (6U) |
| #define | DMA_CSR_ACTIVE(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ACTIVE_SHIFT)) & DMA_CSR_ACTIVE_MASK) |
| #define | DMA_CSR_DONE_MASK (0x80U) |
| #define | DMA_CSR_DONE_SHIFT (7U) |
| #define | DMA_CSR_DONE(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DONE_SHIFT)) & DMA_CSR_DONE_MASK) |
| #define | DMA_CSR_MAJORLINKCH_MASK (0x1F00U) |
| #define | DMA_CSR_MAJORLINKCH_SHIFT (8U) |
| #define | DMA_CSR_MAJORLINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORLINKCH_SHIFT)) & DMA_CSR_MAJORLINKCH_MASK) |
| #define | DMA_CSR_BWC_MASK (0xC000U) |
| #define | DMA_CSR_BWC_SHIFT (14U) |
| #define | DMA_CSR_BWC(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_BWC_SHIFT)) & DMA_CSR_BWC_MASK) |
BITER_ELINKNO - TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Disabled) | |
| #define | DMA_BITER_ELINKNO_BITER_MASK (0x7FFFU) |
| #define | DMA_BITER_ELINKNO_BITER_SHIFT (0U) |
| #define | DMA_BITER_ELINKNO_BITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_BITER_SHIFT)) & DMA_BITER_ELINKNO_BITER_MASK) |
| #define | DMA_BITER_ELINKNO_ELINK_MASK (0x8000U) |
| #define | DMA_BITER_ELINKNO_ELINK_SHIFT (15U) |
| #define | DMA_BITER_ELINKNO_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_ELINK_SHIFT)) & DMA_BITER_ELINKNO_ELINK_MASK) |
BITER_ELINKYES - TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Enabled) | |
| #define | DMA_BITER_ELINKYES_BITER_MASK (0x1FFU) |
| #define | DMA_BITER_ELINKYES_BITER_SHIFT (0U) |
| #define | DMA_BITER_ELINKYES_BITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_BITER_SHIFT)) & DMA_BITER_ELINKYES_BITER_MASK) |
| #define | DMA_BITER_ELINKYES_LINKCH_MASK (0x3E00U) |
| #define | DMA_BITER_ELINKYES_LINKCH_SHIFT (9U) |
| #define | DMA_BITER_ELINKYES_LINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_LINKCH_SHIFT)) & DMA_BITER_ELINKYES_LINKCH_MASK) |
| #define | DMA_BITER_ELINKYES_ELINK_MASK (0x8000U) |
| #define | DMA_BITER_ELINKYES_ELINK_SHIFT (15U) |
| #define | DMA_BITER_ELINKYES_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_ELINK_SHIFT)) & DMA_BITER_ELINKYES_ELINK_MASK) |
CR - Control | |
| #define | DMA_CR_EDBG_MASK (0x2U) |
| #define | DMA_CR_EDBG_SHIFT (1U) |
| #define | DMA_CR_EDBG(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_EDBG_SHIFT)) & DMA_CR_EDBG_MASK) |
| #define | DMA_CR_ERCA_MASK (0x4U) |
| #define | DMA_CR_ERCA_SHIFT (2U) |
| #define | DMA_CR_ERCA(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERCA_SHIFT)) & DMA_CR_ERCA_MASK) |
| #define | DMA_CR_ERGA_MASK (0x8U) |
| #define | DMA_CR_ERGA_SHIFT (3U) |
| #define | DMA_CR_ERGA(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERGA_SHIFT)) & DMA_CR_ERGA_MASK) |
| #define | DMA_CR_HOE_MASK (0x10U) |
| #define | DMA_CR_HOE_SHIFT (4U) |
| #define | DMA_CR_HOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_HOE_SHIFT)) & DMA_CR_HOE_MASK) |
| #define | DMA_CR_HALT_MASK (0x20U) |
| #define | DMA_CR_HALT_SHIFT (5U) |
| #define | DMA_CR_HALT(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_HALT_SHIFT)) & DMA_CR_HALT_MASK) |
| #define | DMA_CR_CLM_MASK (0x40U) |
| #define | DMA_CR_CLM_SHIFT (6U) |
| #define | DMA_CR_CLM(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_CLM_SHIFT)) & DMA_CR_CLM_MASK) |
| #define | DMA_CR_EMLM_MASK (0x80U) |
| #define | DMA_CR_EMLM_SHIFT (7U) |
| #define | DMA_CR_EMLM(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_EMLM_SHIFT)) & DMA_CR_EMLM_MASK) |
| #define | DMA_CR_GRP0PRI_MASK (0x100U) |
| #define | DMA_CR_GRP0PRI_SHIFT (8U) |
| #define | DMA_CR_GRP0PRI(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP0PRI_SHIFT)) & DMA_CR_GRP0PRI_MASK) |
| #define | DMA_CR_GRP1PRI_MASK (0x400U) |
| #define | DMA_CR_GRP1PRI_SHIFT (10U) |
| #define | DMA_CR_GRP1PRI(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP1PRI_SHIFT)) & DMA_CR_GRP1PRI_MASK) |
| #define | DMA_CR_ECX_MASK (0x10000U) |
| #define | DMA_CR_ECX_SHIFT (16U) |
| #define | DMA_CR_ECX(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ECX_SHIFT)) & DMA_CR_ECX_MASK) |
| #define | DMA_CR_CX_MASK (0x20000U) |
| #define | DMA_CR_CX_SHIFT (17U) |
| #define | DMA_CR_CX(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_CX_SHIFT)) & DMA_CR_CX_MASK) |
| #define | DMA_CR_VERSION_MASK (0x7F000000U) |
| #define | DMA_CR_VERSION_SHIFT (24U) |
| #define | DMA_CR_VERSION(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_VERSION_SHIFT)) & DMA_CR_VERSION_MASK) |
| #define | DMA_CR_ACTIVE_MASK (0x80000000U) |
| #define | DMA_CR_ACTIVE_SHIFT (31U) |
| #define | DMA_CR_ACTIVE(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ACTIVE_SHIFT)) & DMA_CR_ACTIVE_MASK) |
| #define | LPSPI_CR_MEN_MASK (0x1U) |
| #define | LPSPI_CR_MEN_SHIFT (0U) |
| #define | LPSPI_CR_MEN(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_MEN_SHIFT)) & LPSPI_CR_MEN_MASK) |
| #define | LPSPI_CR_RST_MASK (0x2U) |
| #define | LPSPI_CR_RST_SHIFT (1U) |
| #define | LPSPI_CR_RST(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RST_SHIFT)) & LPSPI_CR_RST_MASK) |
| #define | LPSPI_CR_DOZEN_MASK (0x4U) |
| #define | LPSPI_CR_DOZEN_SHIFT (2U) |
| #define | LPSPI_CR_DOZEN(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_DOZEN_SHIFT)) & LPSPI_CR_DOZEN_MASK) |
| #define | LPSPI_CR_DBGEN_MASK (0x8U) |
| #define | LPSPI_CR_DBGEN_SHIFT (3U) |
| #define | LPSPI_CR_DBGEN(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_DBGEN_SHIFT)) & LPSPI_CR_DBGEN_MASK) |
| #define | LPSPI_CR_RTF_MASK (0x100U) |
| #define | LPSPI_CR_RTF_SHIFT (8U) |
| #define | LPSPI_CR_RTF(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RTF_SHIFT)) & LPSPI_CR_RTF_MASK) |
| #define | LPSPI_CR_RRF_MASK (0x200U) |
| #define | LPSPI_CR_RRF_SHIFT (9U) |
| #define | LPSPI_CR_RRF(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RRF_SHIFT)) & LPSPI_CR_RRF_MASK) |
ES - Error Status | |
| #define | DMA_ES_DBE_MASK (0x1U) |
| #define | DMA_ES_DBE_SHIFT (0U) |
| #define | DMA_ES_DBE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DBE_SHIFT)) & DMA_ES_DBE_MASK) |
| #define | DMA_ES_SBE_MASK (0x2U) |
| #define | DMA_ES_SBE_SHIFT (1U) |
| #define | DMA_ES_SBE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SBE_SHIFT)) & DMA_ES_SBE_MASK) |
| #define | DMA_ES_SGE_MASK (0x4U) |
| #define | DMA_ES_SGE_SHIFT (2U) |
| #define | DMA_ES_SGE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SGE_SHIFT)) & DMA_ES_SGE_MASK) |
| #define | DMA_ES_NCE_MASK (0x8U) |
| #define | DMA_ES_NCE_SHIFT (3U) |
| #define | DMA_ES_NCE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_NCE_SHIFT)) & DMA_ES_NCE_MASK) |
| #define | DMA_ES_DOE_MASK (0x10U) |
| #define | DMA_ES_DOE_SHIFT (4U) |
| #define | DMA_ES_DOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DOE_SHIFT)) & DMA_ES_DOE_MASK) |
| #define | DMA_ES_DAE_MASK (0x20U) |
| #define | DMA_ES_DAE_SHIFT (5U) |
| #define | DMA_ES_DAE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DAE_SHIFT)) & DMA_ES_DAE_MASK) |
| #define | DMA_ES_SOE_MASK (0x40U) |
| #define | DMA_ES_SOE_SHIFT (6U) |
| #define | DMA_ES_SOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SOE_SHIFT)) & DMA_ES_SOE_MASK) |
| #define | DMA_ES_SAE_MASK (0x80U) |
| #define | DMA_ES_SAE_SHIFT (7U) |
| #define | DMA_ES_SAE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SAE_SHIFT)) & DMA_ES_SAE_MASK) |
| #define | DMA_ES_ERRCHN_MASK (0x1F00U) |
| #define | DMA_ES_ERRCHN_SHIFT (8U) |
| #define | DMA_ES_ERRCHN(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_ERRCHN_SHIFT)) & DMA_ES_ERRCHN_MASK) |
| #define | DMA_ES_CPE_MASK (0x4000U) |
| #define | DMA_ES_CPE_SHIFT (14U) |
| #define | DMA_ES_CPE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_CPE_SHIFT)) & DMA_ES_CPE_MASK) |
| #define | DMA_ES_GPE_MASK (0x8000U) |
| #define | DMA_ES_GPE_SHIFT (15U) |
| #define | DMA_ES_GPE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_GPE_SHIFT)) & DMA_ES_GPE_MASK) |
| #define | DMA_ES_ECX_MASK (0x10000U) |
| #define | DMA_ES_ECX_SHIFT (16U) |
| #define | DMA_ES_ECX(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_ECX_SHIFT)) & DMA_ES_ECX_MASK) |
| #define | DMA_ES_VLD_MASK (0x80000000U) |
| #define | DMA_ES_VLD_SHIFT (31U) |
| #define | DMA_ES_VLD(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_VLD_SHIFT)) & DMA_ES_VLD_MASK) |
ERQ - Enable Request | |
| #define | DMA_ERQ_ERQ0_MASK (0x1U) |
| #define | DMA_ERQ_ERQ0_SHIFT (0U) |
| #define | DMA_ERQ_ERQ0(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ0_SHIFT)) & DMA_ERQ_ERQ0_MASK) |
| #define | DMA_ERQ_ERQ1_MASK (0x2U) |
| #define | DMA_ERQ_ERQ1_SHIFT (1U) |
| #define | DMA_ERQ_ERQ1(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ1_SHIFT)) & DMA_ERQ_ERQ1_MASK) |
| #define | DMA_ERQ_ERQ2_MASK (0x4U) |
| #define | DMA_ERQ_ERQ2_SHIFT (2U) |
| #define | DMA_ERQ_ERQ2(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ2_SHIFT)) & DMA_ERQ_ERQ2_MASK) |
| #define | DMA_ERQ_ERQ3_MASK (0x8U) |
| #define | DMA_ERQ_ERQ3_SHIFT (3U) |
| #define | DMA_ERQ_ERQ3(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ3_SHIFT)) & DMA_ERQ_ERQ3_MASK) |
| #define | DMA_ERQ_ERQ4_MASK (0x10U) |
| #define | DMA_ERQ_ERQ4_SHIFT (4U) |
| #define | DMA_ERQ_ERQ4(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ4_SHIFT)) & DMA_ERQ_ERQ4_MASK) |
| #define | DMA_ERQ_ERQ5_MASK (0x20U) |
| #define | DMA_ERQ_ERQ5_SHIFT (5U) |
| #define | DMA_ERQ_ERQ5(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ5_SHIFT)) & DMA_ERQ_ERQ5_MASK) |
| #define | DMA_ERQ_ERQ6_MASK (0x40U) |
| #define | DMA_ERQ_ERQ6_SHIFT (6U) |
| #define | DMA_ERQ_ERQ6(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ6_SHIFT)) & DMA_ERQ_ERQ6_MASK) |
| #define | DMA_ERQ_ERQ7_MASK (0x80U) |
| #define | DMA_ERQ_ERQ7_SHIFT (7U) |
| #define | DMA_ERQ_ERQ7(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ7_SHIFT)) & DMA_ERQ_ERQ7_MASK) |
| #define | DMA_ERQ_ERQ8_MASK (0x100U) |
| #define | DMA_ERQ_ERQ8_SHIFT (8U) |
| #define | DMA_ERQ_ERQ8(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ8_SHIFT)) & DMA_ERQ_ERQ8_MASK) |
| #define | DMA_ERQ_ERQ9_MASK (0x200U) |
| #define | DMA_ERQ_ERQ9_SHIFT (9U) |
| #define | DMA_ERQ_ERQ9(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ9_SHIFT)) & DMA_ERQ_ERQ9_MASK) |
| #define | DMA_ERQ_ERQ10_MASK (0x400U) |
| #define | DMA_ERQ_ERQ10_SHIFT (10U) |
| #define | DMA_ERQ_ERQ10(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ10_SHIFT)) & DMA_ERQ_ERQ10_MASK) |
| #define | DMA_ERQ_ERQ11_MASK (0x800U) |
| #define | DMA_ERQ_ERQ11_SHIFT (11U) |
| #define | DMA_ERQ_ERQ11(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ11_SHIFT)) & DMA_ERQ_ERQ11_MASK) |
| #define | DMA_ERQ_ERQ12_MASK (0x1000U) |
| #define | DMA_ERQ_ERQ12_SHIFT (12U) |
| #define | DMA_ERQ_ERQ12(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ12_SHIFT)) & DMA_ERQ_ERQ12_MASK) |
| #define | DMA_ERQ_ERQ13_MASK (0x2000U) |
| #define | DMA_ERQ_ERQ13_SHIFT (13U) |
| #define | DMA_ERQ_ERQ13(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ13_SHIFT)) & DMA_ERQ_ERQ13_MASK) |
| #define | DMA_ERQ_ERQ14_MASK (0x4000U) |
| #define | DMA_ERQ_ERQ14_SHIFT (14U) |
| #define | DMA_ERQ_ERQ14(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ14_SHIFT)) & DMA_ERQ_ERQ14_MASK) |
| #define | DMA_ERQ_ERQ15_MASK (0x8000U) |
| #define | DMA_ERQ_ERQ15_SHIFT (15U) |
| #define | DMA_ERQ_ERQ15(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ15_SHIFT)) & DMA_ERQ_ERQ15_MASK) |
| #define | DMA_ERQ_ERQ16_MASK (0x10000U) |
| #define | DMA_ERQ_ERQ16_SHIFT (16U) |
| #define | DMA_ERQ_ERQ16(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ16_SHIFT)) & DMA_ERQ_ERQ16_MASK) |
| #define | DMA_ERQ_ERQ17_MASK (0x20000U) |
| #define | DMA_ERQ_ERQ17_SHIFT (17U) |
| #define | DMA_ERQ_ERQ17(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ17_SHIFT)) & DMA_ERQ_ERQ17_MASK) |
| #define | DMA_ERQ_ERQ18_MASK (0x40000U) |
| #define | DMA_ERQ_ERQ18_SHIFT (18U) |
| #define | DMA_ERQ_ERQ18(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ18_SHIFT)) & DMA_ERQ_ERQ18_MASK) |
| #define | DMA_ERQ_ERQ19_MASK (0x80000U) |
| #define | DMA_ERQ_ERQ19_SHIFT (19U) |
| #define | DMA_ERQ_ERQ19(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ19_SHIFT)) & DMA_ERQ_ERQ19_MASK) |
| #define | DMA_ERQ_ERQ20_MASK (0x100000U) |
| #define | DMA_ERQ_ERQ20_SHIFT (20U) |
| #define | DMA_ERQ_ERQ20(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ20_SHIFT)) & DMA_ERQ_ERQ20_MASK) |
| #define | DMA_ERQ_ERQ21_MASK (0x200000U) |
| #define | DMA_ERQ_ERQ21_SHIFT (21U) |
| #define | DMA_ERQ_ERQ21(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ21_SHIFT)) & DMA_ERQ_ERQ21_MASK) |
| #define | DMA_ERQ_ERQ22_MASK (0x400000U) |
| #define | DMA_ERQ_ERQ22_SHIFT (22U) |
| #define | DMA_ERQ_ERQ22(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ22_SHIFT)) & DMA_ERQ_ERQ22_MASK) |
| #define | DMA_ERQ_ERQ23_MASK (0x800000U) |
| #define | DMA_ERQ_ERQ23_SHIFT (23U) |
| #define | DMA_ERQ_ERQ23(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ23_SHIFT)) & DMA_ERQ_ERQ23_MASK) |
| #define | DMA_ERQ_ERQ24_MASK (0x1000000U) |
| #define | DMA_ERQ_ERQ24_SHIFT (24U) |
| #define | DMA_ERQ_ERQ24(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ24_SHIFT)) & DMA_ERQ_ERQ24_MASK) |
| #define | DMA_ERQ_ERQ25_MASK (0x2000000U) |
| #define | DMA_ERQ_ERQ25_SHIFT (25U) |
| #define | DMA_ERQ_ERQ25(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ25_SHIFT)) & DMA_ERQ_ERQ25_MASK) |
| #define | DMA_ERQ_ERQ26_MASK (0x4000000U) |
| #define | DMA_ERQ_ERQ26_SHIFT (26U) |
| #define | DMA_ERQ_ERQ26(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ26_SHIFT)) & DMA_ERQ_ERQ26_MASK) |
| #define | DMA_ERQ_ERQ27_MASK (0x8000000U) |
| #define | DMA_ERQ_ERQ27_SHIFT (27U) |
| #define | DMA_ERQ_ERQ27(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ27_SHIFT)) & DMA_ERQ_ERQ27_MASK) |
| #define | DMA_ERQ_ERQ28_MASK (0x10000000U) |
| #define | DMA_ERQ_ERQ28_SHIFT (28U) |
| #define | DMA_ERQ_ERQ28(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ28_SHIFT)) & DMA_ERQ_ERQ28_MASK) |
| #define | DMA_ERQ_ERQ29_MASK (0x20000000U) |
| #define | DMA_ERQ_ERQ29_SHIFT (29U) |
| #define | DMA_ERQ_ERQ29(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ29_SHIFT)) & DMA_ERQ_ERQ29_MASK) |
| #define | DMA_ERQ_ERQ30_MASK (0x40000000U) |
| #define | DMA_ERQ_ERQ30_SHIFT (30U) |
| #define | DMA_ERQ_ERQ30(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ30_SHIFT)) & DMA_ERQ_ERQ30_MASK) |
| #define | DMA_ERQ_ERQ31_MASK (0x80000000U) |
| #define | DMA_ERQ_ERQ31_SHIFT (31U) |
| #define | DMA_ERQ_ERQ31(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ31_SHIFT)) & DMA_ERQ_ERQ31_MASK) |
EEI - Enable Error Interrupt | |
| #define | DMA_EEI_EEI0_MASK (0x1U) |
| #define | DMA_EEI_EEI0_SHIFT (0U) |
| #define | DMA_EEI_EEI0(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI0_SHIFT)) & DMA_EEI_EEI0_MASK) |
| #define | DMA_EEI_EEI1_MASK (0x2U) |
| #define | DMA_EEI_EEI1_SHIFT (1U) |
| #define | DMA_EEI_EEI1(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI1_SHIFT)) & DMA_EEI_EEI1_MASK) |
| #define | DMA_EEI_EEI2_MASK (0x4U) |
| #define | DMA_EEI_EEI2_SHIFT (2U) |
| #define | DMA_EEI_EEI2(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI2_SHIFT)) & DMA_EEI_EEI2_MASK) |
| #define | DMA_EEI_EEI3_MASK (0x8U) |
| #define | DMA_EEI_EEI3_SHIFT (3U) |
| #define | DMA_EEI_EEI3(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI3_SHIFT)) & DMA_EEI_EEI3_MASK) |
| #define | DMA_EEI_EEI4_MASK (0x10U) |
| #define | DMA_EEI_EEI4_SHIFT (4U) |
| #define | DMA_EEI_EEI4(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI4_SHIFT)) & DMA_EEI_EEI4_MASK) |
| #define | DMA_EEI_EEI5_MASK (0x20U) |
| #define | DMA_EEI_EEI5_SHIFT (5U) |
| #define | DMA_EEI_EEI5(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI5_SHIFT)) & DMA_EEI_EEI5_MASK) |
| #define | DMA_EEI_EEI6_MASK (0x40U) |
| #define | DMA_EEI_EEI6_SHIFT (6U) |
| #define | DMA_EEI_EEI6(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI6_SHIFT)) & DMA_EEI_EEI6_MASK) |
| #define | DMA_EEI_EEI7_MASK (0x80U) |
| #define | DMA_EEI_EEI7_SHIFT (7U) |
| #define | DMA_EEI_EEI7(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI7_SHIFT)) & DMA_EEI_EEI7_MASK) |
| #define | DMA_EEI_EEI8_MASK (0x100U) |
| #define | DMA_EEI_EEI8_SHIFT (8U) |
| #define | DMA_EEI_EEI8(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI8_SHIFT)) & DMA_EEI_EEI8_MASK) |
| #define | DMA_EEI_EEI9_MASK (0x200U) |
| #define | DMA_EEI_EEI9_SHIFT (9U) |
| #define | DMA_EEI_EEI9(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI9_SHIFT)) & DMA_EEI_EEI9_MASK) |
| #define | DMA_EEI_EEI10_MASK (0x400U) |
| #define | DMA_EEI_EEI10_SHIFT (10U) |
| #define | DMA_EEI_EEI10(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI10_SHIFT)) & DMA_EEI_EEI10_MASK) |
| #define | DMA_EEI_EEI11_MASK (0x800U) |
| #define | DMA_EEI_EEI11_SHIFT (11U) |
| #define | DMA_EEI_EEI11(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI11_SHIFT)) & DMA_EEI_EEI11_MASK) |
| #define | DMA_EEI_EEI12_MASK (0x1000U) |
| #define | DMA_EEI_EEI12_SHIFT (12U) |
| #define | DMA_EEI_EEI12(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI12_SHIFT)) & DMA_EEI_EEI12_MASK) |
| #define | DMA_EEI_EEI13_MASK (0x2000U) |
| #define | DMA_EEI_EEI13_SHIFT (13U) |
| #define | DMA_EEI_EEI13(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI13_SHIFT)) & DMA_EEI_EEI13_MASK) |
| #define | DMA_EEI_EEI14_MASK (0x4000U) |
| #define | DMA_EEI_EEI14_SHIFT (14U) |
| #define | DMA_EEI_EEI14(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI14_SHIFT)) & DMA_EEI_EEI14_MASK) |
| #define | DMA_EEI_EEI15_MASK (0x8000U) |
| #define | DMA_EEI_EEI15_SHIFT (15U) |
| #define | DMA_EEI_EEI15(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI15_SHIFT)) & DMA_EEI_EEI15_MASK) |
| #define | DMA_EEI_EEI16_MASK (0x10000U) |
| #define | DMA_EEI_EEI16_SHIFT (16U) |
| #define | DMA_EEI_EEI16(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI16_SHIFT)) & DMA_EEI_EEI16_MASK) |
| #define | DMA_EEI_EEI17_MASK (0x20000U) |
| #define | DMA_EEI_EEI17_SHIFT (17U) |
| #define | DMA_EEI_EEI17(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI17_SHIFT)) & DMA_EEI_EEI17_MASK) |
| #define | DMA_EEI_EEI18_MASK (0x40000U) |
| #define | DMA_EEI_EEI18_SHIFT (18U) |
| #define | DMA_EEI_EEI18(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI18_SHIFT)) & DMA_EEI_EEI18_MASK) |
| #define | DMA_EEI_EEI19_MASK (0x80000U) |
| #define | DMA_EEI_EEI19_SHIFT (19U) |
| #define | DMA_EEI_EEI19(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI19_SHIFT)) & DMA_EEI_EEI19_MASK) |
| #define | DMA_EEI_EEI20_MASK (0x100000U) |
| #define | DMA_EEI_EEI20_SHIFT (20U) |
| #define | DMA_EEI_EEI20(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI20_SHIFT)) & DMA_EEI_EEI20_MASK) |
| #define | DMA_EEI_EEI21_MASK (0x200000U) |
| #define | DMA_EEI_EEI21_SHIFT (21U) |
| #define | DMA_EEI_EEI21(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI21_SHIFT)) & DMA_EEI_EEI21_MASK) |
| #define | DMA_EEI_EEI22_MASK (0x400000U) |
| #define | DMA_EEI_EEI22_SHIFT (22U) |
| #define | DMA_EEI_EEI22(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI22_SHIFT)) & DMA_EEI_EEI22_MASK) |
| #define | DMA_EEI_EEI23_MASK (0x800000U) |
| #define | DMA_EEI_EEI23_SHIFT (23U) |
| #define | DMA_EEI_EEI23(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI23_SHIFT)) & DMA_EEI_EEI23_MASK) |
| #define | DMA_EEI_EEI24_MASK (0x1000000U) |
| #define | DMA_EEI_EEI24_SHIFT (24U) |
| #define | DMA_EEI_EEI24(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI24_SHIFT)) & DMA_EEI_EEI24_MASK) |
| #define | DMA_EEI_EEI25_MASK (0x2000000U) |
| #define | DMA_EEI_EEI25_SHIFT (25U) |
| #define | DMA_EEI_EEI25(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI25_SHIFT)) & DMA_EEI_EEI25_MASK) |
| #define | DMA_EEI_EEI26_MASK (0x4000000U) |
| #define | DMA_EEI_EEI26_SHIFT (26U) |
| #define | DMA_EEI_EEI26(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI26_SHIFT)) & DMA_EEI_EEI26_MASK) |
| #define | DMA_EEI_EEI27_MASK (0x8000000U) |
| #define | DMA_EEI_EEI27_SHIFT (27U) |
| #define | DMA_EEI_EEI27(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI27_SHIFT)) & DMA_EEI_EEI27_MASK) |
| #define | DMA_EEI_EEI28_MASK (0x10000000U) |
| #define | DMA_EEI_EEI28_SHIFT (28U) |
| #define | DMA_EEI_EEI28(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI28_SHIFT)) & DMA_EEI_EEI28_MASK) |
| #define | DMA_EEI_EEI29_MASK (0x20000000U) |
| #define | DMA_EEI_EEI29_SHIFT (29U) |
| #define | DMA_EEI_EEI29(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI29_SHIFT)) & DMA_EEI_EEI29_MASK) |
| #define | DMA_EEI_EEI30_MASK (0x40000000U) |
| #define | DMA_EEI_EEI30_SHIFT (30U) |
| #define | DMA_EEI_EEI30(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI30_SHIFT)) & DMA_EEI_EEI30_MASK) |
| #define | DMA_EEI_EEI31_MASK (0x80000000U) |
| #define | DMA_EEI_EEI31_SHIFT (31U) |
| #define | DMA_EEI_EEI31(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI31_SHIFT)) & DMA_EEI_EEI31_MASK) |
CEEI - Clear Enable Error Interrupt | |
| #define | DMA_CEEI_CEEI_MASK (0x1FU) |
| #define | DMA_CEEI_CEEI_SHIFT (0U) |
| #define | DMA_CEEI_CEEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CEEI_SHIFT)) & DMA_CEEI_CEEI_MASK) |
| #define | DMA_CEEI_CAEE_MASK (0x40U) |
| #define | DMA_CEEI_CAEE_SHIFT (6U) |
| #define | DMA_CEEI_CAEE(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CAEE_SHIFT)) & DMA_CEEI_CAEE_MASK) |
| #define | DMA_CEEI_NOP_MASK (0x80U) |
| #define | DMA_CEEI_NOP_SHIFT (7U) |
| #define | DMA_CEEI_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_NOP_SHIFT)) & DMA_CEEI_NOP_MASK) |
SEEI - Set Enable Error Interrupt | |
| #define | DMA_SEEI_SEEI_MASK (0x1FU) |
| #define | DMA_SEEI_SEEI_SHIFT (0U) |
| #define | DMA_SEEI_SEEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SEEI_SHIFT)) & DMA_SEEI_SEEI_MASK) |
| #define | DMA_SEEI_SAEE_MASK (0x40U) |
| #define | DMA_SEEI_SAEE_SHIFT (6U) |
| #define | DMA_SEEI_SAEE(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SAEE_SHIFT)) & DMA_SEEI_SAEE_MASK) |
| #define | DMA_SEEI_NOP_MASK (0x80U) |
| #define | DMA_SEEI_NOP_SHIFT (7U) |
| #define | DMA_SEEI_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_NOP_SHIFT)) & DMA_SEEI_NOP_MASK) |
CERQ - Clear Enable Request | |
| #define | DMA_CERQ_CERQ_MASK (0x1FU) |
| #define | DMA_CERQ_CERQ_SHIFT (0U) |
| #define | DMA_CERQ_CERQ(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CERQ_SHIFT)) & DMA_CERQ_CERQ_MASK) |
| #define | DMA_CERQ_CAER_MASK (0x40U) |
| #define | DMA_CERQ_CAER_SHIFT (6U) |
| #define | DMA_CERQ_CAER(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CAER_SHIFT)) & DMA_CERQ_CAER_MASK) |
| #define | DMA_CERQ_NOP_MASK (0x80U) |
| #define | DMA_CERQ_NOP_SHIFT (7U) |
| #define | DMA_CERQ_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_NOP_SHIFT)) & DMA_CERQ_NOP_MASK) |
SERQ - Set Enable Request | |
| #define | DMA_SERQ_SERQ_MASK (0x1FU) |
| #define | DMA_SERQ_SERQ_SHIFT (0U) |
| #define | DMA_SERQ_SERQ(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SERQ_SHIFT)) & DMA_SERQ_SERQ_MASK) |
| #define | DMA_SERQ_SAER_MASK (0x40U) |
| #define | DMA_SERQ_SAER_SHIFT (6U) |
| #define | DMA_SERQ_SAER(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SAER_SHIFT)) & DMA_SERQ_SAER_MASK) |
| #define | DMA_SERQ_NOP_MASK (0x80U) |
| #define | DMA_SERQ_NOP_SHIFT (7U) |
| #define | DMA_SERQ_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_NOP_SHIFT)) & DMA_SERQ_NOP_MASK) |
CDNE - Clear DONE Status Bit | |
| #define | DMA_CDNE_CDNE_MASK (0x1FU) |
| #define | DMA_CDNE_CDNE_SHIFT (0U) |
| #define | DMA_CDNE_CDNE(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CDNE_SHIFT)) & DMA_CDNE_CDNE_MASK) |
| #define | DMA_CDNE_CADN_MASK (0x40U) |
| #define | DMA_CDNE_CADN_SHIFT (6U) |
| #define | DMA_CDNE_CADN(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CADN_SHIFT)) & DMA_CDNE_CADN_MASK) |
| #define | DMA_CDNE_NOP_MASK (0x80U) |
| #define | DMA_CDNE_NOP_SHIFT (7U) |
| #define | DMA_CDNE_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_NOP_SHIFT)) & DMA_CDNE_NOP_MASK) |
SSRT - Set START Bit | |
| #define | DMA_SSRT_SSRT_MASK (0x1FU) |
| #define | DMA_SSRT_SSRT_SHIFT (0U) |
| #define | DMA_SSRT_SSRT(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SSRT_SHIFT)) & DMA_SSRT_SSRT_MASK) |
| #define | DMA_SSRT_SAST_MASK (0x40U) |
| #define | DMA_SSRT_SAST_SHIFT (6U) |
| #define | DMA_SSRT_SAST(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SAST_SHIFT)) & DMA_SSRT_SAST_MASK) |
| #define | DMA_SSRT_NOP_MASK (0x80U) |
| #define | DMA_SSRT_NOP_SHIFT (7U) |
| #define | DMA_SSRT_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_NOP_SHIFT)) & DMA_SSRT_NOP_MASK) |
CERR - Clear Error | |
| #define | DMA_CERR_CERR_MASK (0x1FU) |
| #define | DMA_CERR_CERR_SHIFT (0U) |
| #define | DMA_CERR_CERR(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CERR_SHIFT)) & DMA_CERR_CERR_MASK) |
| #define | DMA_CERR_CAEI_MASK (0x40U) |
| #define | DMA_CERR_CAEI_SHIFT (6U) |
| #define | DMA_CERR_CAEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CAEI_SHIFT)) & DMA_CERR_CAEI_MASK) |
| #define | DMA_CERR_NOP_MASK (0x80U) |
| #define | DMA_CERR_NOP_SHIFT (7U) |
| #define | DMA_CERR_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_NOP_SHIFT)) & DMA_CERR_NOP_MASK) |
CINT - Clear Interrupt Request | |
| #define | DMA_CINT_CINT_MASK (0x1FU) |
| #define | DMA_CINT_CINT_SHIFT (0U) |
| #define | DMA_CINT_CINT(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CINT_SHIFT)) & DMA_CINT_CINT_MASK) |
| #define | DMA_CINT_CAIR_MASK (0x40U) |
| #define | DMA_CINT_CAIR_SHIFT (6U) |
| #define | DMA_CINT_CAIR(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CAIR_SHIFT)) & DMA_CINT_CAIR_MASK) |
| #define | DMA_CINT_NOP_MASK (0x80U) |
| #define | DMA_CINT_NOP_SHIFT (7U) |
| #define | DMA_CINT_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_NOP_SHIFT)) & DMA_CINT_NOP_MASK) |
INT - Interrupt Request | |
| #define | DMA_INT_INT0_MASK (0x1U) |
| #define | DMA_INT_INT0_SHIFT (0U) |
| #define | DMA_INT_INT0(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT0_SHIFT)) & DMA_INT_INT0_MASK) |
| #define | DMA_INT_INT1_MASK (0x2U) |
| #define | DMA_INT_INT1_SHIFT (1U) |
| #define | DMA_INT_INT1(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT1_SHIFT)) & DMA_INT_INT1_MASK) |
| #define | DMA_INT_INT2_MASK (0x4U) |
| #define | DMA_INT_INT2_SHIFT (2U) |
| #define | DMA_INT_INT2(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT2_SHIFT)) & DMA_INT_INT2_MASK) |
| #define | DMA_INT_INT3_MASK (0x8U) |
| #define | DMA_INT_INT3_SHIFT (3U) |
| #define | DMA_INT_INT3(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT3_SHIFT)) & DMA_INT_INT3_MASK) |
| #define | DMA_INT_INT4_MASK (0x10U) |
| #define | DMA_INT_INT4_SHIFT (4U) |
| #define | DMA_INT_INT4(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT4_SHIFT)) & DMA_INT_INT4_MASK) |
| #define | DMA_INT_INT5_MASK (0x20U) |
| #define | DMA_INT_INT5_SHIFT (5U) |
| #define | DMA_INT_INT5(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT5_SHIFT)) & DMA_INT_INT5_MASK) |
| #define | DMA_INT_INT6_MASK (0x40U) |
| #define | DMA_INT_INT6_SHIFT (6U) |
| #define | DMA_INT_INT6(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT6_SHIFT)) & DMA_INT_INT6_MASK) |
| #define | DMA_INT_INT7_MASK (0x80U) |
| #define | DMA_INT_INT7_SHIFT (7U) |
| #define | DMA_INT_INT7(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT7_SHIFT)) & DMA_INT_INT7_MASK) |
| #define | DMA_INT_INT8_MASK (0x100U) |
| #define | DMA_INT_INT8_SHIFT (8U) |
| #define | DMA_INT_INT8(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT8_SHIFT)) & DMA_INT_INT8_MASK) |
| #define | DMA_INT_INT9_MASK (0x200U) |
| #define | DMA_INT_INT9_SHIFT (9U) |
| #define | DMA_INT_INT9(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT9_SHIFT)) & DMA_INT_INT9_MASK) |
| #define | DMA_INT_INT10_MASK (0x400U) |
| #define | DMA_INT_INT10_SHIFT (10U) |
| #define | DMA_INT_INT10(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT10_SHIFT)) & DMA_INT_INT10_MASK) |
| #define | DMA_INT_INT11_MASK (0x800U) |
| #define | DMA_INT_INT11_SHIFT (11U) |
| #define | DMA_INT_INT11(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT11_SHIFT)) & DMA_INT_INT11_MASK) |
| #define | DMA_INT_INT12_MASK (0x1000U) |
| #define | DMA_INT_INT12_SHIFT (12U) |
| #define | DMA_INT_INT12(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT12_SHIFT)) & DMA_INT_INT12_MASK) |
| #define | DMA_INT_INT13_MASK (0x2000U) |
| #define | DMA_INT_INT13_SHIFT (13U) |
| #define | DMA_INT_INT13(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT13_SHIFT)) & DMA_INT_INT13_MASK) |
| #define | DMA_INT_INT14_MASK (0x4000U) |
| #define | DMA_INT_INT14_SHIFT (14U) |
| #define | DMA_INT_INT14(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT14_SHIFT)) & DMA_INT_INT14_MASK) |
| #define | DMA_INT_INT15_MASK (0x8000U) |
| #define | DMA_INT_INT15_SHIFT (15U) |
| #define | DMA_INT_INT15(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT15_SHIFT)) & DMA_INT_INT15_MASK) |
| #define | DMA_INT_INT16_MASK (0x10000U) |
| #define | DMA_INT_INT16_SHIFT (16U) |
| #define | DMA_INT_INT16(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT16_SHIFT)) & DMA_INT_INT16_MASK) |
| #define | DMA_INT_INT17_MASK (0x20000U) |
| #define | DMA_INT_INT17_SHIFT (17U) |
| #define | DMA_INT_INT17(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT17_SHIFT)) & DMA_INT_INT17_MASK) |
| #define | DMA_INT_INT18_MASK (0x40000U) |
| #define | DMA_INT_INT18_SHIFT (18U) |
| #define | DMA_INT_INT18(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT18_SHIFT)) & DMA_INT_INT18_MASK) |
| #define | DMA_INT_INT19_MASK (0x80000U) |
| #define | DMA_INT_INT19_SHIFT (19U) |
| #define | DMA_INT_INT19(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT19_SHIFT)) & DMA_INT_INT19_MASK) |
| #define | DMA_INT_INT20_MASK (0x100000U) |
| #define | DMA_INT_INT20_SHIFT (20U) |
| #define | DMA_INT_INT20(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT20_SHIFT)) & DMA_INT_INT20_MASK) |
| #define | DMA_INT_INT21_MASK (0x200000U) |
| #define | DMA_INT_INT21_SHIFT (21U) |
| #define | DMA_INT_INT21(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT21_SHIFT)) & DMA_INT_INT21_MASK) |
| #define | DMA_INT_INT22_MASK (0x400000U) |
| #define | DMA_INT_INT22_SHIFT (22U) |
| #define | DMA_INT_INT22(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT22_SHIFT)) & DMA_INT_INT22_MASK) |
| #define | DMA_INT_INT23_MASK (0x800000U) |
| #define | DMA_INT_INT23_SHIFT (23U) |
| #define | DMA_INT_INT23(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT23_SHIFT)) & DMA_INT_INT23_MASK) |
| #define | DMA_INT_INT24_MASK (0x1000000U) |
| #define | DMA_INT_INT24_SHIFT (24U) |
| #define | DMA_INT_INT24(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT24_SHIFT)) & DMA_INT_INT24_MASK) |
| #define | DMA_INT_INT25_MASK (0x2000000U) |
| #define | DMA_INT_INT25_SHIFT (25U) |
| #define | DMA_INT_INT25(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT25_SHIFT)) & DMA_INT_INT25_MASK) |
| #define | DMA_INT_INT26_MASK (0x4000000U) |
| #define | DMA_INT_INT26_SHIFT (26U) |
| #define | DMA_INT_INT26(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT26_SHIFT)) & DMA_INT_INT26_MASK) |
| #define | DMA_INT_INT27_MASK (0x8000000U) |
| #define | DMA_INT_INT27_SHIFT (27U) |
| #define | DMA_INT_INT27(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT27_SHIFT)) & DMA_INT_INT27_MASK) |
| #define | DMA_INT_INT28_MASK (0x10000000U) |
| #define | DMA_INT_INT28_SHIFT (28U) |
| #define | DMA_INT_INT28(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT28_SHIFT)) & DMA_INT_INT28_MASK) |
| #define | DMA_INT_INT29_MASK (0x20000000U) |
| #define | DMA_INT_INT29_SHIFT (29U) |
| #define | DMA_INT_INT29(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT29_SHIFT)) & DMA_INT_INT29_MASK) |
| #define | DMA_INT_INT30_MASK (0x40000000U) |
| #define | DMA_INT_INT30_SHIFT (30U) |
| #define | DMA_INT_INT30(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT30_SHIFT)) & DMA_INT_INT30_MASK) |
| #define | DMA_INT_INT31_MASK (0x80000000U) |
| #define | DMA_INT_INT31_SHIFT (31U) |
| #define | DMA_INT_INT31(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT31_SHIFT)) & DMA_INT_INT31_MASK) |
ERR - Error | |
| #define | DMA_ERR_ERR0_MASK (0x1U) |
| #define | DMA_ERR_ERR0_SHIFT (0U) |
| #define | DMA_ERR_ERR0(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR0_SHIFT)) & DMA_ERR_ERR0_MASK) |
| #define | DMA_ERR_ERR1_MASK (0x2U) |
| #define | DMA_ERR_ERR1_SHIFT (1U) |
| #define | DMA_ERR_ERR1(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR1_SHIFT)) & DMA_ERR_ERR1_MASK) |
| #define | DMA_ERR_ERR2_MASK (0x4U) |
| #define | DMA_ERR_ERR2_SHIFT (2U) |
| #define | DMA_ERR_ERR2(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR2_SHIFT)) & DMA_ERR_ERR2_MASK) |
| #define | DMA_ERR_ERR3_MASK (0x8U) |
| #define | DMA_ERR_ERR3_SHIFT (3U) |
| #define | DMA_ERR_ERR3(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR3_SHIFT)) & DMA_ERR_ERR3_MASK) |
| #define | DMA_ERR_ERR4_MASK (0x10U) |
| #define | DMA_ERR_ERR4_SHIFT (4U) |
| #define | DMA_ERR_ERR4(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR4_SHIFT)) & DMA_ERR_ERR4_MASK) |
| #define | DMA_ERR_ERR5_MASK (0x20U) |
| #define | DMA_ERR_ERR5_SHIFT (5U) |
| #define | DMA_ERR_ERR5(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR5_SHIFT)) & DMA_ERR_ERR5_MASK) |
| #define | DMA_ERR_ERR6_MASK (0x40U) |
| #define | DMA_ERR_ERR6_SHIFT (6U) |
| #define | DMA_ERR_ERR6(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR6_SHIFT)) & DMA_ERR_ERR6_MASK) |
| #define | DMA_ERR_ERR7_MASK (0x80U) |
| #define | DMA_ERR_ERR7_SHIFT (7U) |
| #define | DMA_ERR_ERR7(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR7_SHIFT)) & DMA_ERR_ERR7_MASK) |
| #define | DMA_ERR_ERR8_MASK (0x100U) |
| #define | DMA_ERR_ERR8_SHIFT (8U) |
| #define | DMA_ERR_ERR8(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR8_SHIFT)) & DMA_ERR_ERR8_MASK) |
| #define | DMA_ERR_ERR9_MASK (0x200U) |
| #define | DMA_ERR_ERR9_SHIFT (9U) |
| #define | DMA_ERR_ERR9(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR9_SHIFT)) & DMA_ERR_ERR9_MASK) |
| #define | DMA_ERR_ERR10_MASK (0x400U) |
| #define | DMA_ERR_ERR10_SHIFT (10U) |
| #define | DMA_ERR_ERR10(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR10_SHIFT)) & DMA_ERR_ERR10_MASK) |
| #define | DMA_ERR_ERR11_MASK (0x800U) |
| #define | DMA_ERR_ERR11_SHIFT (11U) |
| #define | DMA_ERR_ERR11(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR11_SHIFT)) & DMA_ERR_ERR11_MASK) |
| #define | DMA_ERR_ERR12_MASK (0x1000U) |
| #define | DMA_ERR_ERR12_SHIFT (12U) |
| #define | DMA_ERR_ERR12(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR12_SHIFT)) & DMA_ERR_ERR12_MASK) |
| #define | DMA_ERR_ERR13_MASK (0x2000U) |
| #define | DMA_ERR_ERR13_SHIFT (13U) |
| #define | DMA_ERR_ERR13(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR13_SHIFT)) & DMA_ERR_ERR13_MASK) |
| #define | DMA_ERR_ERR14_MASK (0x4000U) |
| #define | DMA_ERR_ERR14_SHIFT (14U) |
| #define | DMA_ERR_ERR14(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR14_SHIFT)) & DMA_ERR_ERR14_MASK) |
| #define | DMA_ERR_ERR15_MASK (0x8000U) |
| #define | DMA_ERR_ERR15_SHIFT (15U) |
| #define | DMA_ERR_ERR15(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR15_SHIFT)) & DMA_ERR_ERR15_MASK) |
| #define | DMA_ERR_ERR16_MASK (0x10000U) |
| #define | DMA_ERR_ERR16_SHIFT (16U) |
| #define | DMA_ERR_ERR16(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR16_SHIFT)) & DMA_ERR_ERR16_MASK) |
| #define | DMA_ERR_ERR17_MASK (0x20000U) |
| #define | DMA_ERR_ERR17_SHIFT (17U) |
| #define | DMA_ERR_ERR17(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR17_SHIFT)) & DMA_ERR_ERR17_MASK) |
| #define | DMA_ERR_ERR18_MASK (0x40000U) |
| #define | DMA_ERR_ERR18_SHIFT (18U) |
| #define | DMA_ERR_ERR18(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR18_SHIFT)) & DMA_ERR_ERR18_MASK) |
| #define | DMA_ERR_ERR19_MASK (0x80000U) |
| #define | DMA_ERR_ERR19_SHIFT (19U) |
| #define | DMA_ERR_ERR19(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR19_SHIFT)) & DMA_ERR_ERR19_MASK) |
| #define | DMA_ERR_ERR20_MASK (0x100000U) |
| #define | DMA_ERR_ERR20_SHIFT (20U) |
| #define | DMA_ERR_ERR20(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR20_SHIFT)) & DMA_ERR_ERR20_MASK) |
| #define | DMA_ERR_ERR21_MASK (0x200000U) |
| #define | DMA_ERR_ERR21_SHIFT (21U) |
| #define | DMA_ERR_ERR21(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR21_SHIFT)) & DMA_ERR_ERR21_MASK) |
| #define | DMA_ERR_ERR22_MASK (0x400000U) |
| #define | DMA_ERR_ERR22_SHIFT (22U) |
| #define | DMA_ERR_ERR22(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR22_SHIFT)) & DMA_ERR_ERR22_MASK) |
| #define | DMA_ERR_ERR23_MASK (0x800000U) |
| #define | DMA_ERR_ERR23_SHIFT (23U) |
| #define | DMA_ERR_ERR23(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR23_SHIFT)) & DMA_ERR_ERR23_MASK) |
| #define | DMA_ERR_ERR24_MASK (0x1000000U) |
| #define | DMA_ERR_ERR24_SHIFT (24U) |
| #define | DMA_ERR_ERR24(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR24_SHIFT)) & DMA_ERR_ERR24_MASK) |
| #define | DMA_ERR_ERR25_MASK (0x2000000U) |
| #define | DMA_ERR_ERR25_SHIFT (25U) |
| #define | DMA_ERR_ERR25(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR25_SHIFT)) & DMA_ERR_ERR25_MASK) |
| #define | DMA_ERR_ERR26_MASK (0x4000000U) |
| #define | DMA_ERR_ERR26_SHIFT (26U) |
| #define | DMA_ERR_ERR26(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR26_SHIFT)) & DMA_ERR_ERR26_MASK) |
| #define | DMA_ERR_ERR27_MASK (0x8000000U) |
| #define | DMA_ERR_ERR27_SHIFT (27U) |
| #define | DMA_ERR_ERR27(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR27_SHIFT)) & DMA_ERR_ERR27_MASK) |
| #define | DMA_ERR_ERR28_MASK (0x10000000U) |
| #define | DMA_ERR_ERR28_SHIFT (28U) |
| #define | DMA_ERR_ERR28(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR28_SHIFT)) & DMA_ERR_ERR28_MASK) |
| #define | DMA_ERR_ERR29_MASK (0x20000000U) |
| #define | DMA_ERR_ERR29_SHIFT (29U) |
| #define | DMA_ERR_ERR29(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR29_SHIFT)) & DMA_ERR_ERR29_MASK) |
| #define | DMA_ERR_ERR30_MASK (0x40000000U) |
| #define | DMA_ERR_ERR30_SHIFT (30U) |
| #define | DMA_ERR_ERR30(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR30_SHIFT)) & DMA_ERR_ERR30_MASK) |
| #define | DMA_ERR_ERR31_MASK (0x80000000U) |
| #define | DMA_ERR_ERR31_SHIFT (31U) |
| #define | DMA_ERR_ERR31(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR31_SHIFT)) & DMA_ERR_ERR31_MASK) |
HRS - Hardware Request Status | |
| #define | DMA_HRS_HRS0_MASK (0x1U) |
| #define | DMA_HRS_HRS0_SHIFT (0U) |
| #define | DMA_HRS_HRS0(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS0_SHIFT)) & DMA_HRS_HRS0_MASK) |
| #define | DMA_HRS_HRS1_MASK (0x2U) |
| #define | DMA_HRS_HRS1_SHIFT (1U) |
| #define | DMA_HRS_HRS1(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS1_SHIFT)) & DMA_HRS_HRS1_MASK) |
| #define | DMA_HRS_HRS2_MASK (0x4U) |
| #define | DMA_HRS_HRS2_SHIFT (2U) |
| #define | DMA_HRS_HRS2(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS2_SHIFT)) & DMA_HRS_HRS2_MASK) |
| #define | DMA_HRS_HRS3_MASK (0x8U) |
| #define | DMA_HRS_HRS3_SHIFT (3U) |
| #define | DMA_HRS_HRS3(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS3_SHIFT)) & DMA_HRS_HRS3_MASK) |
| #define | DMA_HRS_HRS4_MASK (0x10U) |
| #define | DMA_HRS_HRS4_SHIFT (4U) |
| #define | DMA_HRS_HRS4(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS4_SHIFT)) & DMA_HRS_HRS4_MASK) |
| #define | DMA_HRS_HRS5_MASK (0x20U) |
| #define | DMA_HRS_HRS5_SHIFT (5U) |
| #define | DMA_HRS_HRS5(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS5_SHIFT)) & DMA_HRS_HRS5_MASK) |
| #define | DMA_HRS_HRS6_MASK (0x40U) |
| #define | DMA_HRS_HRS6_SHIFT (6U) |
| #define | DMA_HRS_HRS6(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS6_SHIFT)) & DMA_HRS_HRS6_MASK) |
| #define | DMA_HRS_HRS7_MASK (0x80U) |
| #define | DMA_HRS_HRS7_SHIFT (7U) |
| #define | DMA_HRS_HRS7(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS7_SHIFT)) & DMA_HRS_HRS7_MASK) |
| #define | DMA_HRS_HRS8_MASK (0x100U) |
| #define | DMA_HRS_HRS8_SHIFT (8U) |
| #define | DMA_HRS_HRS8(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS8_SHIFT)) & DMA_HRS_HRS8_MASK) |
| #define | DMA_HRS_HRS9_MASK (0x200U) |
| #define | DMA_HRS_HRS9_SHIFT (9U) |
| #define | DMA_HRS_HRS9(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS9_SHIFT)) & DMA_HRS_HRS9_MASK) |
| #define | DMA_HRS_HRS10_MASK (0x400U) |
| #define | DMA_HRS_HRS10_SHIFT (10U) |
| #define | DMA_HRS_HRS10(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS10_SHIFT)) & DMA_HRS_HRS10_MASK) |
| #define | DMA_HRS_HRS11_MASK (0x800U) |
| #define | DMA_HRS_HRS11_SHIFT (11U) |
| #define | DMA_HRS_HRS11(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS11_SHIFT)) & DMA_HRS_HRS11_MASK) |
| #define | DMA_HRS_HRS12_MASK (0x1000U) |
| #define | DMA_HRS_HRS12_SHIFT (12U) |
| #define | DMA_HRS_HRS12(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS12_SHIFT)) & DMA_HRS_HRS12_MASK) |
| #define | DMA_HRS_HRS13_MASK (0x2000U) |
| #define | DMA_HRS_HRS13_SHIFT (13U) |
| #define | DMA_HRS_HRS13(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS13_SHIFT)) & DMA_HRS_HRS13_MASK) |
| #define | DMA_HRS_HRS14_MASK (0x4000U) |
| #define | DMA_HRS_HRS14_SHIFT (14U) |
| #define | DMA_HRS_HRS14(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS14_SHIFT)) & DMA_HRS_HRS14_MASK) |
| #define | DMA_HRS_HRS15_MASK (0x8000U) |
| #define | DMA_HRS_HRS15_SHIFT (15U) |
| #define | DMA_HRS_HRS15(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS15_SHIFT)) & DMA_HRS_HRS15_MASK) |
| #define | DMA_HRS_HRS16_MASK (0x10000U) |
| #define | DMA_HRS_HRS16_SHIFT (16U) |
| #define | DMA_HRS_HRS16(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS16_SHIFT)) & DMA_HRS_HRS16_MASK) |
| #define | DMA_HRS_HRS17_MASK (0x20000U) |
| #define | DMA_HRS_HRS17_SHIFT (17U) |
| #define | DMA_HRS_HRS17(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS17_SHIFT)) & DMA_HRS_HRS17_MASK) |
| #define | DMA_HRS_HRS18_MASK (0x40000U) |
| #define | DMA_HRS_HRS18_SHIFT (18U) |
| #define | DMA_HRS_HRS18(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS18_SHIFT)) & DMA_HRS_HRS18_MASK) |
| #define | DMA_HRS_HRS19_MASK (0x80000U) |
| #define | DMA_HRS_HRS19_SHIFT (19U) |
| #define | DMA_HRS_HRS19(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS19_SHIFT)) & DMA_HRS_HRS19_MASK) |
| #define | DMA_HRS_HRS20_MASK (0x100000U) |
| #define | DMA_HRS_HRS20_SHIFT (20U) |
| #define | DMA_HRS_HRS20(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS20_SHIFT)) & DMA_HRS_HRS20_MASK) |
| #define | DMA_HRS_HRS21_MASK (0x200000U) |
| #define | DMA_HRS_HRS21_SHIFT (21U) |
| #define | DMA_HRS_HRS21(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS21_SHIFT)) & DMA_HRS_HRS21_MASK) |
| #define | DMA_HRS_HRS22_MASK (0x400000U) |
| #define | DMA_HRS_HRS22_SHIFT (22U) |
| #define | DMA_HRS_HRS22(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS22_SHIFT)) & DMA_HRS_HRS22_MASK) |
| #define | DMA_HRS_HRS23_MASK (0x800000U) |
| #define | DMA_HRS_HRS23_SHIFT (23U) |
| #define | DMA_HRS_HRS23(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS23_SHIFT)) & DMA_HRS_HRS23_MASK) |
| #define | DMA_HRS_HRS24_MASK (0x1000000U) |
| #define | DMA_HRS_HRS24_SHIFT (24U) |
| #define | DMA_HRS_HRS24(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS24_SHIFT)) & DMA_HRS_HRS24_MASK) |
| #define | DMA_HRS_HRS25_MASK (0x2000000U) |
| #define | DMA_HRS_HRS25_SHIFT (25U) |
| #define | DMA_HRS_HRS25(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS25_SHIFT)) & DMA_HRS_HRS25_MASK) |
| #define | DMA_HRS_HRS26_MASK (0x4000000U) |
| #define | DMA_HRS_HRS26_SHIFT (26U) |
| #define | DMA_HRS_HRS26(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS26_SHIFT)) & DMA_HRS_HRS26_MASK) |
| #define | DMA_HRS_HRS27_MASK (0x8000000U) |
| #define | DMA_HRS_HRS27_SHIFT (27U) |
| #define | DMA_HRS_HRS27(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS27_SHIFT)) & DMA_HRS_HRS27_MASK) |
| #define | DMA_HRS_HRS28_MASK (0x10000000U) |
| #define | DMA_HRS_HRS28_SHIFT (28U) |
| #define | DMA_HRS_HRS28(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS28_SHIFT)) & DMA_HRS_HRS28_MASK) |
| #define | DMA_HRS_HRS29_MASK (0x20000000U) |
| #define | DMA_HRS_HRS29_SHIFT (29U) |
| #define | DMA_HRS_HRS29(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS29_SHIFT)) & DMA_HRS_HRS29_MASK) |
| #define | DMA_HRS_HRS30_MASK (0x40000000U) |
| #define | DMA_HRS_HRS30_SHIFT (30U) |
| #define | DMA_HRS_HRS30(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS30_SHIFT)) & DMA_HRS_HRS30_MASK) |
| #define | DMA_HRS_HRS31_MASK (0x80000000U) |
| #define | DMA_HRS_HRS31_SHIFT (31U) |
| #define | DMA_HRS_HRS31(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS31_SHIFT)) & DMA_HRS_HRS31_MASK) |
EARS - Enable Asynchronous Request in Stop | |
| #define | DMA_EARS_EDREQ_0_MASK (0x1U) |
| #define | DMA_EARS_EDREQ_0_SHIFT (0U) |
| #define | DMA_EARS_EDREQ_0(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_0_SHIFT)) & DMA_EARS_EDREQ_0_MASK) |
| #define | DMA_EARS_EDREQ_1_MASK (0x2U) |
| #define | DMA_EARS_EDREQ_1_SHIFT (1U) |
| #define | DMA_EARS_EDREQ_1(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_1_SHIFT)) & DMA_EARS_EDREQ_1_MASK) |
| #define | DMA_EARS_EDREQ_2_MASK (0x4U) |
| #define | DMA_EARS_EDREQ_2_SHIFT (2U) |
| #define | DMA_EARS_EDREQ_2(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_2_SHIFT)) & DMA_EARS_EDREQ_2_MASK) |
| #define | DMA_EARS_EDREQ_3_MASK (0x8U) |
| #define | DMA_EARS_EDREQ_3_SHIFT (3U) |
| #define | DMA_EARS_EDREQ_3(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_3_SHIFT)) & DMA_EARS_EDREQ_3_MASK) |
| #define | DMA_EARS_EDREQ_4_MASK (0x10U) |
| #define | DMA_EARS_EDREQ_4_SHIFT (4U) |
| #define | DMA_EARS_EDREQ_4(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_4_SHIFT)) & DMA_EARS_EDREQ_4_MASK) |
| #define | DMA_EARS_EDREQ_5_MASK (0x20U) |
| #define | DMA_EARS_EDREQ_5_SHIFT (5U) |
| #define | DMA_EARS_EDREQ_5(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_5_SHIFT)) & DMA_EARS_EDREQ_5_MASK) |
| #define | DMA_EARS_EDREQ_6_MASK (0x40U) |
| #define | DMA_EARS_EDREQ_6_SHIFT (6U) |
| #define | DMA_EARS_EDREQ_6(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_6_SHIFT)) & DMA_EARS_EDREQ_6_MASK) |
| #define | DMA_EARS_EDREQ_7_MASK (0x80U) |
| #define | DMA_EARS_EDREQ_7_SHIFT (7U) |
| #define | DMA_EARS_EDREQ_7(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_7_SHIFT)) & DMA_EARS_EDREQ_7_MASK) |
| #define | DMA_EARS_EDREQ_8_MASK (0x100U) |
| #define | DMA_EARS_EDREQ_8_SHIFT (8U) |
| #define | DMA_EARS_EDREQ_8(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_8_SHIFT)) & DMA_EARS_EDREQ_8_MASK) |
| #define | DMA_EARS_EDREQ_9_MASK (0x200U) |
| #define | DMA_EARS_EDREQ_9_SHIFT (9U) |
| #define | DMA_EARS_EDREQ_9(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_9_SHIFT)) & DMA_EARS_EDREQ_9_MASK) |
| #define | DMA_EARS_EDREQ_10_MASK (0x400U) |
| #define | DMA_EARS_EDREQ_10_SHIFT (10U) |
| #define | DMA_EARS_EDREQ_10(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_10_SHIFT)) & DMA_EARS_EDREQ_10_MASK) |
| #define | DMA_EARS_EDREQ_11_MASK (0x800U) |
| #define | DMA_EARS_EDREQ_11_SHIFT (11U) |
| #define | DMA_EARS_EDREQ_11(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_11_SHIFT)) & DMA_EARS_EDREQ_11_MASK) |
| #define | DMA_EARS_EDREQ_12_MASK (0x1000U) |
| #define | DMA_EARS_EDREQ_12_SHIFT (12U) |
| #define | DMA_EARS_EDREQ_12(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_12_SHIFT)) & DMA_EARS_EDREQ_12_MASK) |
| #define | DMA_EARS_EDREQ_13_MASK (0x2000U) |
| #define | DMA_EARS_EDREQ_13_SHIFT (13U) |
| #define | DMA_EARS_EDREQ_13(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_13_SHIFT)) & DMA_EARS_EDREQ_13_MASK) |
| #define | DMA_EARS_EDREQ_14_MASK (0x4000U) |
| #define | DMA_EARS_EDREQ_14_SHIFT (14U) |
| #define | DMA_EARS_EDREQ_14(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_14_SHIFT)) & DMA_EARS_EDREQ_14_MASK) |
| #define | DMA_EARS_EDREQ_15_MASK (0x8000U) |
| #define | DMA_EARS_EDREQ_15_SHIFT (15U) |
| #define | DMA_EARS_EDREQ_15(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_15_SHIFT)) & DMA_EARS_EDREQ_15_MASK) |
| #define | DMA_EARS_EDREQ_16_MASK (0x10000U) |
| #define | DMA_EARS_EDREQ_16_SHIFT (16U) |
| #define | DMA_EARS_EDREQ_16(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_16_SHIFT)) & DMA_EARS_EDREQ_16_MASK) |
| #define | DMA_EARS_EDREQ_17_MASK (0x20000U) |
| #define | DMA_EARS_EDREQ_17_SHIFT (17U) |
| #define | DMA_EARS_EDREQ_17(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_17_SHIFT)) & DMA_EARS_EDREQ_17_MASK) |
| #define | DMA_EARS_EDREQ_18_MASK (0x40000U) |
| #define | DMA_EARS_EDREQ_18_SHIFT (18U) |
| #define | DMA_EARS_EDREQ_18(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_18_SHIFT)) & DMA_EARS_EDREQ_18_MASK) |
| #define | DMA_EARS_EDREQ_19_MASK (0x80000U) |
| #define | DMA_EARS_EDREQ_19_SHIFT (19U) |
| #define | DMA_EARS_EDREQ_19(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_19_SHIFT)) & DMA_EARS_EDREQ_19_MASK) |
| #define | DMA_EARS_EDREQ_20_MASK (0x100000U) |
| #define | DMA_EARS_EDREQ_20_SHIFT (20U) |
| #define | DMA_EARS_EDREQ_20(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_20_SHIFT)) & DMA_EARS_EDREQ_20_MASK) |
| #define | DMA_EARS_EDREQ_21_MASK (0x200000U) |
| #define | DMA_EARS_EDREQ_21_SHIFT (21U) |
| #define | DMA_EARS_EDREQ_21(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_21_SHIFT)) & DMA_EARS_EDREQ_21_MASK) |
| #define | DMA_EARS_EDREQ_22_MASK (0x400000U) |
| #define | DMA_EARS_EDREQ_22_SHIFT (22U) |
| #define | DMA_EARS_EDREQ_22(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_22_SHIFT)) & DMA_EARS_EDREQ_22_MASK) |
| #define | DMA_EARS_EDREQ_23_MASK (0x800000U) |
| #define | DMA_EARS_EDREQ_23_SHIFT (23U) |
| #define | DMA_EARS_EDREQ_23(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_23_SHIFT)) & DMA_EARS_EDREQ_23_MASK) |
| #define | DMA_EARS_EDREQ_24_MASK (0x1000000U) |
| #define | DMA_EARS_EDREQ_24_SHIFT (24U) |
| #define | DMA_EARS_EDREQ_24(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_24_SHIFT)) & DMA_EARS_EDREQ_24_MASK) |
| #define | DMA_EARS_EDREQ_25_MASK (0x2000000U) |
| #define | DMA_EARS_EDREQ_25_SHIFT (25U) |
| #define | DMA_EARS_EDREQ_25(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_25_SHIFT)) & DMA_EARS_EDREQ_25_MASK) |
| #define | DMA_EARS_EDREQ_26_MASK (0x4000000U) |
| #define | DMA_EARS_EDREQ_26_SHIFT (26U) |
| #define | DMA_EARS_EDREQ_26(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_26_SHIFT)) & DMA_EARS_EDREQ_26_MASK) |
| #define | DMA_EARS_EDREQ_27_MASK (0x8000000U) |
| #define | DMA_EARS_EDREQ_27_SHIFT (27U) |
| #define | DMA_EARS_EDREQ_27(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_27_SHIFT)) & DMA_EARS_EDREQ_27_MASK) |
| #define | DMA_EARS_EDREQ_28_MASK (0x10000000U) |
| #define | DMA_EARS_EDREQ_28_SHIFT (28U) |
| #define | DMA_EARS_EDREQ_28(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_28_SHIFT)) & DMA_EARS_EDREQ_28_MASK) |
| #define | DMA_EARS_EDREQ_29_MASK (0x20000000U) |
| #define | DMA_EARS_EDREQ_29_SHIFT (29U) |
| #define | DMA_EARS_EDREQ_29(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_29_SHIFT)) & DMA_EARS_EDREQ_29_MASK) |
| #define | DMA_EARS_EDREQ_30_MASK (0x40000000U) |
| #define | DMA_EARS_EDREQ_30_SHIFT (30U) |
| #define | DMA_EARS_EDREQ_30(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_30_SHIFT)) & DMA_EARS_EDREQ_30_MASK) |
| #define | DMA_EARS_EDREQ_31_MASK (0x80000000U) |
| #define | DMA_EARS_EDREQ_31_SHIFT (31U) |
| #define | DMA_EARS_EDREQ_31(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_31_SHIFT)) & DMA_EARS_EDREQ_31_MASK) |
DCHPRI3 - Channel Priority | |
| #define | DMA_DCHPRI3_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI3_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI3_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_CHPRI_SHIFT)) & DMA_DCHPRI3_CHPRI_MASK) |
| #define | DMA_DCHPRI3_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI3_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI3_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_GRPPRI_SHIFT)) & DMA_DCHPRI3_GRPPRI_MASK) |
| #define | DMA_DCHPRI3_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI3_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI3_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_DPA_SHIFT)) & DMA_DCHPRI3_DPA_MASK) |
| #define | DMA_DCHPRI3_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI3_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI3_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_ECP_SHIFT)) & DMA_DCHPRI3_ECP_MASK) |
DCHPRI2 - Channel Priority | |
| #define | DMA_DCHPRI2_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI2_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI2_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_CHPRI_SHIFT)) & DMA_DCHPRI2_CHPRI_MASK) |
| #define | DMA_DCHPRI2_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI2_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI2_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_GRPPRI_SHIFT)) & DMA_DCHPRI2_GRPPRI_MASK) |
| #define | DMA_DCHPRI2_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI2_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI2_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_DPA_SHIFT)) & DMA_DCHPRI2_DPA_MASK) |
| #define | DMA_DCHPRI2_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI2_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI2_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_ECP_SHIFT)) & DMA_DCHPRI2_ECP_MASK) |
DCHPRI1 - Channel Priority | |
| #define | DMA_DCHPRI1_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI1_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI1_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_CHPRI_SHIFT)) & DMA_DCHPRI1_CHPRI_MASK) |
| #define | DMA_DCHPRI1_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI1_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI1_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_GRPPRI_SHIFT)) & DMA_DCHPRI1_GRPPRI_MASK) |
| #define | DMA_DCHPRI1_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI1_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI1_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_DPA_SHIFT)) & DMA_DCHPRI1_DPA_MASK) |
| #define | DMA_DCHPRI1_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI1_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI1_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_ECP_SHIFT)) & DMA_DCHPRI1_ECP_MASK) |
DCHPRI0 - Channel Priority | |
| #define | DMA_DCHPRI0_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI0_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI0_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_CHPRI_SHIFT)) & DMA_DCHPRI0_CHPRI_MASK) |
| #define | DMA_DCHPRI0_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI0_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI0_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_GRPPRI_SHIFT)) & DMA_DCHPRI0_GRPPRI_MASK) |
| #define | DMA_DCHPRI0_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI0_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI0_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_DPA_SHIFT)) & DMA_DCHPRI0_DPA_MASK) |
| #define | DMA_DCHPRI0_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI0_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI0_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_ECP_SHIFT)) & DMA_DCHPRI0_ECP_MASK) |
DCHPRI7 - Channel Priority | |
| #define | DMA_DCHPRI7_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI7_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI7_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_CHPRI_SHIFT)) & DMA_DCHPRI7_CHPRI_MASK) |
| #define | DMA_DCHPRI7_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI7_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI7_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_GRPPRI_SHIFT)) & DMA_DCHPRI7_GRPPRI_MASK) |
| #define | DMA_DCHPRI7_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI7_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI7_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_DPA_SHIFT)) & DMA_DCHPRI7_DPA_MASK) |
| #define | DMA_DCHPRI7_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI7_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI7_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_ECP_SHIFT)) & DMA_DCHPRI7_ECP_MASK) |
DCHPRI6 - Channel Priority | |
| #define | DMA_DCHPRI6_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI6_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI6_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_CHPRI_SHIFT)) & DMA_DCHPRI6_CHPRI_MASK) |
| #define | DMA_DCHPRI6_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI6_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI6_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_GRPPRI_SHIFT)) & DMA_DCHPRI6_GRPPRI_MASK) |
| #define | DMA_DCHPRI6_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI6_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI6_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_DPA_SHIFT)) & DMA_DCHPRI6_DPA_MASK) |
| #define | DMA_DCHPRI6_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI6_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI6_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_ECP_SHIFT)) & DMA_DCHPRI6_ECP_MASK) |
DCHPRI5 - Channel Priority | |
| #define | DMA_DCHPRI5_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI5_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI5_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_CHPRI_SHIFT)) & DMA_DCHPRI5_CHPRI_MASK) |
| #define | DMA_DCHPRI5_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI5_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI5_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_GRPPRI_SHIFT)) & DMA_DCHPRI5_GRPPRI_MASK) |
| #define | DMA_DCHPRI5_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI5_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI5_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_DPA_SHIFT)) & DMA_DCHPRI5_DPA_MASK) |
| #define | DMA_DCHPRI5_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI5_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI5_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_ECP_SHIFT)) & DMA_DCHPRI5_ECP_MASK) |
DCHPRI4 - Channel Priority | |
| #define | DMA_DCHPRI4_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI4_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI4_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_CHPRI_SHIFT)) & DMA_DCHPRI4_CHPRI_MASK) |
| #define | DMA_DCHPRI4_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI4_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI4_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_GRPPRI_SHIFT)) & DMA_DCHPRI4_GRPPRI_MASK) |
| #define | DMA_DCHPRI4_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI4_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI4_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_DPA_SHIFT)) & DMA_DCHPRI4_DPA_MASK) |
| #define | DMA_DCHPRI4_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI4_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI4_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_ECP_SHIFT)) & DMA_DCHPRI4_ECP_MASK) |
DCHPRI11 - Channel Priority | |
| #define | DMA_DCHPRI11_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI11_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI11_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_CHPRI_SHIFT)) & DMA_DCHPRI11_CHPRI_MASK) |
| #define | DMA_DCHPRI11_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI11_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI11_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_GRPPRI_SHIFT)) & DMA_DCHPRI11_GRPPRI_MASK) |
| #define | DMA_DCHPRI11_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI11_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI11_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_DPA_SHIFT)) & DMA_DCHPRI11_DPA_MASK) |
| #define | DMA_DCHPRI11_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI11_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI11_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_ECP_SHIFT)) & DMA_DCHPRI11_ECP_MASK) |
DCHPRI10 - Channel Priority | |
| #define | DMA_DCHPRI10_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI10_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI10_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_CHPRI_SHIFT)) & DMA_DCHPRI10_CHPRI_MASK) |
| #define | DMA_DCHPRI10_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI10_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI10_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_GRPPRI_SHIFT)) & DMA_DCHPRI10_GRPPRI_MASK) |
| #define | DMA_DCHPRI10_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI10_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI10_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_DPA_SHIFT)) & DMA_DCHPRI10_DPA_MASK) |
| #define | DMA_DCHPRI10_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI10_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI10_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_ECP_SHIFT)) & DMA_DCHPRI10_ECP_MASK) |
DCHPRI9 - Channel Priority | |
| #define | DMA_DCHPRI9_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI9_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI9_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_CHPRI_SHIFT)) & DMA_DCHPRI9_CHPRI_MASK) |
| #define | DMA_DCHPRI9_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI9_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI9_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_GRPPRI_SHIFT)) & DMA_DCHPRI9_GRPPRI_MASK) |
| #define | DMA_DCHPRI9_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI9_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI9_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_DPA_SHIFT)) & DMA_DCHPRI9_DPA_MASK) |
| #define | DMA_DCHPRI9_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI9_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI9_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_ECP_SHIFT)) & DMA_DCHPRI9_ECP_MASK) |
DCHPRI8 - Channel Priority | |
| #define | DMA_DCHPRI8_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI8_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI8_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_CHPRI_SHIFT)) & DMA_DCHPRI8_CHPRI_MASK) |
| #define | DMA_DCHPRI8_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI8_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI8_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_GRPPRI_SHIFT)) & DMA_DCHPRI8_GRPPRI_MASK) |
| #define | DMA_DCHPRI8_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI8_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI8_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_DPA_SHIFT)) & DMA_DCHPRI8_DPA_MASK) |
| #define | DMA_DCHPRI8_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI8_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI8_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_ECP_SHIFT)) & DMA_DCHPRI8_ECP_MASK) |
DCHPRI15 - Channel Priority | |
| #define | DMA_DCHPRI15_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI15_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI15_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_CHPRI_SHIFT)) & DMA_DCHPRI15_CHPRI_MASK) |
| #define | DMA_DCHPRI15_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI15_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI15_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_GRPPRI_SHIFT)) & DMA_DCHPRI15_GRPPRI_MASK) |
| #define | DMA_DCHPRI15_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI15_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI15_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_DPA_SHIFT)) & DMA_DCHPRI15_DPA_MASK) |
| #define | DMA_DCHPRI15_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI15_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI15_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_ECP_SHIFT)) & DMA_DCHPRI15_ECP_MASK) |
DCHPRI14 - Channel Priority | |
| #define | DMA_DCHPRI14_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI14_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI14_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_CHPRI_SHIFT)) & DMA_DCHPRI14_CHPRI_MASK) |
| #define | DMA_DCHPRI14_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI14_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI14_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_GRPPRI_SHIFT)) & DMA_DCHPRI14_GRPPRI_MASK) |
| #define | DMA_DCHPRI14_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI14_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI14_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_DPA_SHIFT)) & DMA_DCHPRI14_DPA_MASK) |
| #define | DMA_DCHPRI14_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI14_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI14_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_ECP_SHIFT)) & DMA_DCHPRI14_ECP_MASK) |
DCHPRI13 - Channel Priority | |
| #define | DMA_DCHPRI13_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI13_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI13_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_CHPRI_SHIFT)) & DMA_DCHPRI13_CHPRI_MASK) |
| #define | DMA_DCHPRI13_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI13_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI13_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_GRPPRI_SHIFT)) & DMA_DCHPRI13_GRPPRI_MASK) |
| #define | DMA_DCHPRI13_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI13_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI13_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_DPA_SHIFT)) & DMA_DCHPRI13_DPA_MASK) |
| #define | DMA_DCHPRI13_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI13_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI13_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_ECP_SHIFT)) & DMA_DCHPRI13_ECP_MASK) |
DCHPRI12 - Channel Priority | |
| #define | DMA_DCHPRI12_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI12_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI12_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_CHPRI_SHIFT)) & DMA_DCHPRI12_CHPRI_MASK) |
| #define | DMA_DCHPRI12_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI12_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI12_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_GRPPRI_SHIFT)) & DMA_DCHPRI12_GRPPRI_MASK) |
| #define | DMA_DCHPRI12_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI12_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI12_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_DPA_SHIFT)) & DMA_DCHPRI12_DPA_MASK) |
| #define | DMA_DCHPRI12_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI12_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI12_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_ECP_SHIFT)) & DMA_DCHPRI12_ECP_MASK) |
DCHPRI19 - Channel Priority | |
| #define | DMA_DCHPRI19_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI19_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI19_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_CHPRI_SHIFT)) & DMA_DCHPRI19_CHPRI_MASK) |
| #define | DMA_DCHPRI19_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI19_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI19_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_GRPPRI_SHIFT)) & DMA_DCHPRI19_GRPPRI_MASK) |
| #define | DMA_DCHPRI19_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI19_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI19_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_DPA_SHIFT)) & DMA_DCHPRI19_DPA_MASK) |
| #define | DMA_DCHPRI19_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI19_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI19_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_ECP_SHIFT)) & DMA_DCHPRI19_ECP_MASK) |
DCHPRI18 - Channel Priority | |
| #define | DMA_DCHPRI18_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI18_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI18_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_CHPRI_SHIFT)) & DMA_DCHPRI18_CHPRI_MASK) |
| #define | DMA_DCHPRI18_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI18_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI18_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_GRPPRI_SHIFT)) & DMA_DCHPRI18_GRPPRI_MASK) |
| #define | DMA_DCHPRI18_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI18_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI18_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_DPA_SHIFT)) & DMA_DCHPRI18_DPA_MASK) |
| #define | DMA_DCHPRI18_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI18_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI18_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_ECP_SHIFT)) & DMA_DCHPRI18_ECP_MASK) |
DCHPRI17 - Channel Priority | |
| #define | DMA_DCHPRI17_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI17_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI17_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_CHPRI_SHIFT)) & DMA_DCHPRI17_CHPRI_MASK) |
| #define | DMA_DCHPRI17_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI17_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI17_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_GRPPRI_SHIFT)) & DMA_DCHPRI17_GRPPRI_MASK) |
| #define | DMA_DCHPRI17_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI17_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI17_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_DPA_SHIFT)) & DMA_DCHPRI17_DPA_MASK) |
| #define | DMA_DCHPRI17_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI17_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI17_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_ECP_SHIFT)) & DMA_DCHPRI17_ECP_MASK) |
DCHPRI16 - Channel Priority | |
| #define | DMA_DCHPRI16_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI16_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI16_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_CHPRI_SHIFT)) & DMA_DCHPRI16_CHPRI_MASK) |
| #define | DMA_DCHPRI16_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI16_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI16_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_GRPPRI_SHIFT)) & DMA_DCHPRI16_GRPPRI_MASK) |
| #define | DMA_DCHPRI16_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI16_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI16_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_DPA_SHIFT)) & DMA_DCHPRI16_DPA_MASK) |
| #define | DMA_DCHPRI16_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI16_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI16_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_ECP_SHIFT)) & DMA_DCHPRI16_ECP_MASK) |
DCHPRI23 - Channel Priority | |
| #define | DMA_DCHPRI23_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI23_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI23_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_CHPRI_SHIFT)) & DMA_DCHPRI23_CHPRI_MASK) |
| #define | DMA_DCHPRI23_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI23_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI23_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_GRPPRI_SHIFT)) & DMA_DCHPRI23_GRPPRI_MASK) |
| #define | DMA_DCHPRI23_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI23_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI23_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_DPA_SHIFT)) & DMA_DCHPRI23_DPA_MASK) |
| #define | DMA_DCHPRI23_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI23_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI23_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_ECP_SHIFT)) & DMA_DCHPRI23_ECP_MASK) |
DCHPRI22 - Channel Priority | |
| #define | DMA_DCHPRI22_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI22_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI22_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_CHPRI_SHIFT)) & DMA_DCHPRI22_CHPRI_MASK) |
| #define | DMA_DCHPRI22_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI22_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI22_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_GRPPRI_SHIFT)) & DMA_DCHPRI22_GRPPRI_MASK) |
| #define | DMA_DCHPRI22_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI22_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI22_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_DPA_SHIFT)) & DMA_DCHPRI22_DPA_MASK) |
| #define | DMA_DCHPRI22_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI22_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI22_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_ECP_SHIFT)) & DMA_DCHPRI22_ECP_MASK) |
DCHPRI21 - Channel Priority | |
| #define | DMA_DCHPRI21_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI21_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI21_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_CHPRI_SHIFT)) & DMA_DCHPRI21_CHPRI_MASK) |
| #define | DMA_DCHPRI21_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI21_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI21_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_GRPPRI_SHIFT)) & DMA_DCHPRI21_GRPPRI_MASK) |
| #define | DMA_DCHPRI21_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI21_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI21_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_DPA_SHIFT)) & DMA_DCHPRI21_DPA_MASK) |
| #define | DMA_DCHPRI21_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI21_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI21_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_ECP_SHIFT)) & DMA_DCHPRI21_ECP_MASK) |
DCHPRI20 - Channel Priority | |
| #define | DMA_DCHPRI20_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI20_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI20_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_CHPRI_SHIFT)) & DMA_DCHPRI20_CHPRI_MASK) |
| #define | DMA_DCHPRI20_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI20_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI20_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_GRPPRI_SHIFT)) & DMA_DCHPRI20_GRPPRI_MASK) |
| #define | DMA_DCHPRI20_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI20_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI20_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_DPA_SHIFT)) & DMA_DCHPRI20_DPA_MASK) |
| #define | DMA_DCHPRI20_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI20_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI20_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_ECP_SHIFT)) & DMA_DCHPRI20_ECP_MASK) |
DCHPRI27 - Channel Priority | |
| #define | DMA_DCHPRI27_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI27_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI27_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_CHPRI_SHIFT)) & DMA_DCHPRI27_CHPRI_MASK) |
| #define | DMA_DCHPRI27_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI27_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI27_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_GRPPRI_SHIFT)) & DMA_DCHPRI27_GRPPRI_MASK) |
| #define | DMA_DCHPRI27_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI27_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI27_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_DPA_SHIFT)) & DMA_DCHPRI27_DPA_MASK) |
| #define | DMA_DCHPRI27_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI27_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI27_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_ECP_SHIFT)) & DMA_DCHPRI27_ECP_MASK) |
DCHPRI26 - Channel Priority | |
| #define | DMA_DCHPRI26_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI26_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI26_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_CHPRI_SHIFT)) & DMA_DCHPRI26_CHPRI_MASK) |
| #define | DMA_DCHPRI26_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI26_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI26_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_GRPPRI_SHIFT)) & DMA_DCHPRI26_GRPPRI_MASK) |
| #define | DMA_DCHPRI26_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI26_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI26_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_DPA_SHIFT)) & DMA_DCHPRI26_DPA_MASK) |
| #define | DMA_DCHPRI26_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI26_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI26_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_ECP_SHIFT)) & DMA_DCHPRI26_ECP_MASK) |
DCHPRI25 - Channel Priority | |
| #define | DMA_DCHPRI25_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI25_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI25_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_CHPRI_SHIFT)) & DMA_DCHPRI25_CHPRI_MASK) |
| #define | DMA_DCHPRI25_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI25_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI25_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_GRPPRI_SHIFT)) & DMA_DCHPRI25_GRPPRI_MASK) |
| #define | DMA_DCHPRI25_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI25_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI25_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_DPA_SHIFT)) & DMA_DCHPRI25_DPA_MASK) |
| #define | DMA_DCHPRI25_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI25_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI25_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_ECP_SHIFT)) & DMA_DCHPRI25_ECP_MASK) |
DCHPRI24 - Channel Priority | |
| #define | DMA_DCHPRI24_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI24_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI24_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_CHPRI_SHIFT)) & DMA_DCHPRI24_CHPRI_MASK) |
| #define | DMA_DCHPRI24_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI24_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI24_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_GRPPRI_SHIFT)) & DMA_DCHPRI24_GRPPRI_MASK) |
| #define | DMA_DCHPRI24_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI24_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI24_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_DPA_SHIFT)) & DMA_DCHPRI24_DPA_MASK) |
| #define | DMA_DCHPRI24_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI24_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI24_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_ECP_SHIFT)) & DMA_DCHPRI24_ECP_MASK) |
DCHPRI31 - Channel Priority | |
| #define | DMA_DCHPRI31_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI31_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI31_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_CHPRI_SHIFT)) & DMA_DCHPRI31_CHPRI_MASK) |
| #define | DMA_DCHPRI31_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI31_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI31_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_GRPPRI_SHIFT)) & DMA_DCHPRI31_GRPPRI_MASK) |
| #define | DMA_DCHPRI31_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI31_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI31_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_DPA_SHIFT)) & DMA_DCHPRI31_DPA_MASK) |
| #define | DMA_DCHPRI31_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI31_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI31_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_ECP_SHIFT)) & DMA_DCHPRI31_ECP_MASK) |
DCHPRI30 - Channel Priority | |
| #define | DMA_DCHPRI30_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI30_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI30_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_CHPRI_SHIFT)) & DMA_DCHPRI30_CHPRI_MASK) |
| #define | DMA_DCHPRI30_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI30_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI30_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_GRPPRI_SHIFT)) & DMA_DCHPRI30_GRPPRI_MASK) |
| #define | DMA_DCHPRI30_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI30_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI30_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_DPA_SHIFT)) & DMA_DCHPRI30_DPA_MASK) |
| #define | DMA_DCHPRI30_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI30_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI30_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_ECP_SHIFT)) & DMA_DCHPRI30_ECP_MASK) |
DCHPRI29 - Channel Priority | |
| #define | DMA_DCHPRI29_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI29_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI29_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_CHPRI_SHIFT)) & DMA_DCHPRI29_CHPRI_MASK) |
| #define | DMA_DCHPRI29_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI29_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI29_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_GRPPRI_SHIFT)) & DMA_DCHPRI29_GRPPRI_MASK) |
| #define | DMA_DCHPRI29_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI29_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI29_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_DPA_SHIFT)) & DMA_DCHPRI29_DPA_MASK) |
| #define | DMA_DCHPRI29_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI29_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI29_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_ECP_SHIFT)) & DMA_DCHPRI29_ECP_MASK) |
DCHPRI28 - Channel Priority | |
| #define | DMA_DCHPRI28_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI28_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI28_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_CHPRI_SHIFT)) & DMA_DCHPRI28_CHPRI_MASK) |
| #define | DMA_DCHPRI28_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI28_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI28_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_GRPPRI_SHIFT)) & DMA_DCHPRI28_GRPPRI_MASK) |
| #define | DMA_DCHPRI28_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI28_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI28_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_DPA_SHIFT)) & DMA_DCHPRI28_DPA_MASK) |
| #define | DMA_DCHPRI28_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI28_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI28_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_ECP_SHIFT)) & DMA_DCHPRI28_ECP_MASK) |
SADDR - TCD Source Address | |
| #define | DMA_SADDR_SADDR_MASK (0xFFFFFFFFU) |
| #define | DMA_SADDR_SADDR_SHIFT (0U) |
| #define | DMA_SADDR_SADDR(x) (((uint32_t)(((uint32_t)(x)) << DMA_SADDR_SADDR_SHIFT)) & DMA_SADDR_SADDR_MASK) |
SOFF - TCD Signed Source Address Offset | |
| #define | DMA_SOFF_SOFF_MASK (0xFFFFU) |
| #define | DMA_SOFF_SOFF_SHIFT (0U) |
| #define | DMA_SOFF_SOFF(x) (((uint16_t)(((uint16_t)(x)) << DMA_SOFF_SOFF_SHIFT)) & DMA_SOFF_SOFF_MASK) |
ATTR - TCD Transfer Attributes | |
| #define | DMA_ATTR_DSIZE_MASK (0x7U) |
| #define | DMA_ATTR_DSIZE_SHIFT (0U) |
| #define | DMA_ATTR_DSIZE(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DSIZE_SHIFT)) & DMA_ATTR_DSIZE_MASK) |
| #define | DMA_ATTR_DMOD_MASK (0xF8U) |
| #define | DMA_ATTR_DMOD_SHIFT (3U) |
| #define | DMA_ATTR_DMOD(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DMOD_SHIFT)) & DMA_ATTR_DMOD_MASK) |
| #define | DMA_ATTR_SSIZE_MASK (0x700U) |
| #define | DMA_ATTR_SSIZE_SHIFT (8U) |
| #define | DMA_ATTR_SSIZE(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SSIZE_SHIFT)) & DMA_ATTR_SSIZE_MASK) |
| #define | DMA_ATTR_SMOD_MASK (0xF800U) |
| #define | DMA_ATTR_SMOD_SHIFT (11U) |
| #define | DMA_ATTR_SMOD(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SMOD_SHIFT)) & DMA_ATTR_SMOD_MASK) |
NBYTES_MLNO - TCD Minor Byte Count (Minor Loop Mapping Disabled) | |
| #define | DMA_NBYTES_MLNO_NBYTES_MASK (0xFFFFFFFFU) |
| #define | DMA_NBYTES_MLNO_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLNO_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLNO_NBYTES_SHIFT)) & DMA_NBYTES_MLNO_NBYTES_MASK) |
NBYTES_MLOFFNO - TCD Signed Minor Loop Offset (Minor Loop Mapping Enabled and Offset Disabled) | |
| #define | DMA_NBYTES_MLOFFNO_NBYTES_MASK (0x3FFFFFFFU) |
| #define | DMA_NBYTES_MLOFFNO_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLOFFNO_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFNO_NBYTES_MASK) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE_MASK (0x40000000U) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE_SHIFT (30U) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_DMLOE_MASK) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE_MASK (0x80000000U) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE_SHIFT (31U) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_SMLOE_MASK) |
NBYTES_MLOFFYES - TCD Signed Minor Loop Offset (Minor Loop Mapping and Offset Enabled) | |
| #define | DMA_NBYTES_MLOFFYES_NBYTES_MASK (0x3FFU) |
| #define | DMA_NBYTES_MLOFFYES_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLOFFYES_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFYES_NBYTES_MASK) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF_MASK (0x3FFFFC00U) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF_SHIFT (10U) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_MLOFF_SHIFT)) & DMA_NBYTES_MLOFFYES_MLOFF_MASK) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE_MASK (0x40000000U) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE_SHIFT (30U) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_DMLOE_MASK) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE_MASK (0x80000000U) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE_SHIFT (31U) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_SMLOE_MASK) |
SLAST - TCD Last Source Address Adjustment | |
| #define | DMA_SLAST_SLAST_MASK (0xFFFFFFFFU) |
| #define | DMA_SLAST_SLAST_SHIFT (0U) |
| #define | DMA_SLAST_SLAST(x) (((uint32_t)(((uint32_t)(x)) << DMA_SLAST_SLAST_SHIFT)) & DMA_SLAST_SLAST_MASK) |
DADDR - TCD Destination Address | |
| #define | DMA_DADDR_DADDR_MASK (0xFFFFFFFFU) |
| #define | DMA_DADDR_DADDR_SHIFT (0U) |
| #define | DMA_DADDR_DADDR(x) (((uint32_t)(((uint32_t)(x)) << DMA_DADDR_DADDR_SHIFT)) & DMA_DADDR_DADDR_MASK) |
DOFF - TCD Signed Destination Address Offset | |
| #define | DMA_DOFF_DOFF_MASK (0xFFFFU) |
| #define | DMA_DOFF_DOFF_SHIFT (0U) |
| #define | DMA_DOFF_DOFF(x) (((uint16_t)(((uint16_t)(x)) << DMA_DOFF_DOFF_SHIFT)) & DMA_DOFF_DOFF_MASK) |
CITER_ELINKNO - TCD Current Minor Loop Link, Major Loop Count (Channel Linking Disabled) | |
| #define | DMA_CITER_ELINKNO_CITER_MASK (0x7FFFU) |
| #define | DMA_CITER_ELINKNO_CITER_SHIFT (0U) |
| #define | DMA_CITER_ELINKNO_CITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_CITER_SHIFT)) & DMA_CITER_ELINKNO_CITER_MASK) |
| #define | DMA_CITER_ELINKNO_ELINK_MASK (0x8000U) |
| #define | DMA_CITER_ELINKNO_ELINK_SHIFT (15U) |
| #define | DMA_CITER_ELINKNO_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_ELINK_SHIFT)) & DMA_CITER_ELINKNO_ELINK_MASK) |
CITER_ELINKYES - TCD Current Minor Loop Link, Major Loop Count (Channel Linking Enabled) | |
| #define | DMA_CITER_ELINKYES_CITER_MASK (0x1FFU) |
| #define | DMA_CITER_ELINKYES_CITER_SHIFT (0U) |
| #define | DMA_CITER_ELINKYES_CITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_CITER_SHIFT)) & DMA_CITER_ELINKYES_CITER_MASK) |
| #define | DMA_CITER_ELINKYES_LINKCH_MASK (0x3E00U) |
| #define | DMA_CITER_ELINKYES_LINKCH_SHIFT (9U) |
| #define | DMA_CITER_ELINKYES_LINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_LINKCH_SHIFT)) & DMA_CITER_ELINKYES_LINKCH_MASK) |
| #define | DMA_CITER_ELINKYES_ELINK_MASK (0x8000U) |
| #define | DMA_CITER_ELINKYES_ELINK_SHIFT (15U) |
| #define | DMA_CITER_ELINKYES_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_ELINK_SHIFT)) & DMA_CITER_ELINKYES_ELINK_MASK) |
DLAST_SGA - TCD Last Destination Address Adjustment/Scatter Gather Address | |
| #define | DMA_DLAST_SGA_DLASTSGA_MASK (0xFFFFFFFFU) |
| #define | DMA_DLAST_SGA_DLASTSGA_SHIFT (0U) |
| #define | DMA_DLAST_SGA_DLASTSGA(x) (((uint32_t)(((uint32_t)(x)) << DMA_DLAST_SGA_DLASTSGA_SHIFT)) & DMA_DLAST_SGA_DLASTSGA_MASK) |
CSR - TCD Control and Status | |
| #define | DMA_CSR_START_MASK (0x1U) |
| #define | DMA_CSR_START_SHIFT (0U) |
| #define | DMA_CSR_START(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_START_SHIFT)) & DMA_CSR_START_MASK) |
| #define | DMA_CSR_INTMAJOR_MASK (0x2U) |
| #define | DMA_CSR_INTMAJOR_SHIFT (1U) |
| #define | DMA_CSR_INTMAJOR(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTMAJOR_SHIFT)) & DMA_CSR_INTMAJOR_MASK) |
| #define | DMA_CSR_INTHALF_MASK (0x4U) |
| #define | DMA_CSR_INTHALF_SHIFT (2U) |
| #define | DMA_CSR_INTHALF(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTHALF_SHIFT)) & DMA_CSR_INTHALF_MASK) |
| #define | DMA_CSR_DREQ_MASK (0x8U) |
| #define | DMA_CSR_DREQ_SHIFT (3U) |
| #define | DMA_CSR_DREQ(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DREQ_SHIFT)) & DMA_CSR_DREQ_MASK) |
| #define | DMA_CSR_ESG_MASK (0x10U) |
| #define | DMA_CSR_ESG_SHIFT (4U) |
| #define | DMA_CSR_ESG(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ESG_SHIFT)) & DMA_CSR_ESG_MASK) |
| #define | DMA_CSR_MAJORELINK_MASK (0x20U) |
| #define | DMA_CSR_MAJORELINK_SHIFT (5U) |
| #define | DMA_CSR_MAJORELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORELINK_SHIFT)) & DMA_CSR_MAJORELINK_MASK) |
| #define | DMA_CSR_ACTIVE_MASK (0x40U) |
| #define | DMA_CSR_ACTIVE_SHIFT (6U) |
| #define | DMA_CSR_ACTIVE(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ACTIVE_SHIFT)) & DMA_CSR_ACTIVE_MASK) |
| #define | DMA_CSR_DONE_MASK (0x80U) |
| #define | DMA_CSR_DONE_SHIFT (7U) |
| #define | DMA_CSR_DONE(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DONE_SHIFT)) & DMA_CSR_DONE_MASK) |
| #define | DMA_CSR_MAJORLINKCH_MASK (0x1F00U) |
| #define | DMA_CSR_MAJORLINKCH_SHIFT (8U) |
| #define | DMA_CSR_MAJORLINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORLINKCH_SHIFT)) & DMA_CSR_MAJORLINKCH_MASK) |
| #define | DMA_CSR_BWC_MASK (0xC000U) |
| #define | DMA_CSR_BWC_SHIFT (14U) |
| #define | DMA_CSR_BWC(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_BWC_SHIFT)) & DMA_CSR_BWC_MASK) |
BITER_ELINKNO - TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Disabled) | |
| #define | DMA_BITER_ELINKNO_BITER_MASK (0x7FFFU) |
| #define | DMA_BITER_ELINKNO_BITER_SHIFT (0U) |
| #define | DMA_BITER_ELINKNO_BITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_BITER_SHIFT)) & DMA_BITER_ELINKNO_BITER_MASK) |
| #define | DMA_BITER_ELINKNO_ELINK_MASK (0x8000U) |
| #define | DMA_BITER_ELINKNO_ELINK_SHIFT (15U) |
| #define | DMA_BITER_ELINKNO_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_ELINK_SHIFT)) & DMA_BITER_ELINKNO_ELINK_MASK) |
BITER_ELINKYES - TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Enabled) | |
| #define | DMA_BITER_ELINKYES_BITER_MASK (0x1FFU) |
| #define | DMA_BITER_ELINKYES_BITER_SHIFT (0U) |
| #define | DMA_BITER_ELINKYES_BITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_BITER_SHIFT)) & DMA_BITER_ELINKYES_BITER_MASK) |
| #define | DMA_BITER_ELINKYES_LINKCH_MASK (0x3E00U) |
| #define | DMA_BITER_ELINKYES_LINKCH_SHIFT (9U) |
| #define | DMA_BITER_ELINKYES_LINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_LINKCH_SHIFT)) & DMA_BITER_ELINKYES_LINKCH_MASK) |
| #define | DMA_BITER_ELINKYES_ELINK_MASK (0x8000U) |
| #define | DMA_BITER_ELINKYES_ELINK_SHIFT (15U) |
| #define | DMA_BITER_ELINKYES_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_ELINK_SHIFT)) & DMA_BITER_ELINKYES_ELINK_MASK) |
CR - Control | |
| #define | DMA_CR_EDBG_MASK (0x2U) |
| #define | DMA_CR_EDBG_SHIFT (1U) |
| #define | DMA_CR_EDBG(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_EDBG_SHIFT)) & DMA_CR_EDBG_MASK) |
| #define | DMA_CR_ERCA_MASK (0x4U) |
| #define | DMA_CR_ERCA_SHIFT (2U) |
| #define | DMA_CR_ERCA(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERCA_SHIFT)) & DMA_CR_ERCA_MASK) |
| #define | DMA_CR_ERGA_MASK (0x8U) |
| #define | DMA_CR_ERGA_SHIFT (3U) |
| #define | DMA_CR_ERGA(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERGA_SHIFT)) & DMA_CR_ERGA_MASK) |
| #define | DMA_CR_HOE_MASK (0x10U) |
| #define | DMA_CR_HOE_SHIFT (4U) |
| #define | DMA_CR_HOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_HOE_SHIFT)) & DMA_CR_HOE_MASK) |
| #define | DMA_CR_HALT_MASK (0x20U) |
| #define | DMA_CR_HALT_SHIFT (5U) |
| #define | DMA_CR_HALT(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_HALT_SHIFT)) & DMA_CR_HALT_MASK) |
| #define | DMA_CR_CLM_MASK (0x40U) |
| #define | DMA_CR_CLM_SHIFT (6U) |
| #define | DMA_CR_CLM(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_CLM_SHIFT)) & DMA_CR_CLM_MASK) |
| #define | DMA_CR_EMLM_MASK (0x80U) |
| #define | DMA_CR_EMLM_SHIFT (7U) |
| #define | DMA_CR_EMLM(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_EMLM_SHIFT)) & DMA_CR_EMLM_MASK) |
| #define | DMA_CR_GRP0PRI_MASK (0x100U) |
| #define | DMA_CR_GRP0PRI_SHIFT (8U) |
| #define | DMA_CR_GRP0PRI(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP0PRI_SHIFT)) & DMA_CR_GRP0PRI_MASK) |
| #define | DMA_CR_GRP1PRI_MASK (0x400U) |
| #define | DMA_CR_GRP1PRI_SHIFT (10U) |
| #define | DMA_CR_GRP1PRI(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP1PRI_SHIFT)) & DMA_CR_GRP1PRI_MASK) |
| #define | DMA_CR_ECX_MASK (0x10000U) |
| #define | DMA_CR_ECX_SHIFT (16U) |
| #define | DMA_CR_ECX(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ECX_SHIFT)) & DMA_CR_ECX_MASK) |
| #define | DMA_CR_CX_MASK (0x20000U) |
| #define | DMA_CR_CX_SHIFT (17U) |
| #define | DMA_CR_CX(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_CX_SHIFT)) & DMA_CR_CX_MASK) |
| #define | DMA_CR_VERSION_MASK (0x7F000000U) |
| #define | DMA_CR_VERSION_SHIFT (24U) |
| #define | DMA_CR_VERSION(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_VERSION_SHIFT)) & DMA_CR_VERSION_MASK) |
| #define | DMA_CR_ACTIVE_MASK (0x80000000U) |
| #define | DMA_CR_ACTIVE_SHIFT (31U) |
| #define | DMA_CR_ACTIVE(x) (((uint32_t)(((uint32_t)(x)) << DMA_CR_ACTIVE_SHIFT)) & DMA_CR_ACTIVE_MASK) |
| #define | LPSPI_CR_MEN_MASK (0x1U) |
| #define | LPSPI_CR_MEN_SHIFT (0U) |
| #define | LPSPI_CR_MEN(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_MEN_SHIFT)) & LPSPI_CR_MEN_MASK) |
| #define | LPSPI_CR_RST_MASK (0x2U) |
| #define | LPSPI_CR_RST_SHIFT (1U) |
| #define | LPSPI_CR_RST(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RST_SHIFT)) & LPSPI_CR_RST_MASK) |
| #define | LPSPI_CR_DOZEN_MASK (0x4U) |
| #define | LPSPI_CR_DOZEN_SHIFT (2U) |
| #define | LPSPI_CR_DOZEN(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_DOZEN_SHIFT)) & LPSPI_CR_DOZEN_MASK) |
| #define | LPSPI_CR_DBGEN_MASK (0x8U) |
| #define | LPSPI_CR_DBGEN_SHIFT (3U) |
| #define | LPSPI_CR_DBGEN(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_DBGEN_SHIFT)) & LPSPI_CR_DBGEN_MASK) |
| #define | LPSPI_CR_RTF_MASK (0x100U) |
| #define | LPSPI_CR_RTF_SHIFT (8U) |
| #define | LPSPI_CR_RTF(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RTF_SHIFT)) & LPSPI_CR_RTF_MASK) |
| #define | LPSPI_CR_RRF_MASK (0x200U) |
| #define | LPSPI_CR_RRF_SHIFT (9U) |
| #define | LPSPI_CR_RRF(x) (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RRF_SHIFT)) & LPSPI_CR_RRF_MASK) |
ES - Error Status | |
| #define | DMA_ES_DBE_MASK (0x1U) |
| #define | DMA_ES_DBE_SHIFT (0U) |
| #define | DMA_ES_DBE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DBE_SHIFT)) & DMA_ES_DBE_MASK) |
| #define | DMA_ES_SBE_MASK (0x2U) |
| #define | DMA_ES_SBE_SHIFT (1U) |
| #define | DMA_ES_SBE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SBE_SHIFT)) & DMA_ES_SBE_MASK) |
| #define | DMA_ES_SGE_MASK (0x4U) |
| #define | DMA_ES_SGE_SHIFT (2U) |
| #define | DMA_ES_SGE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SGE_SHIFT)) & DMA_ES_SGE_MASK) |
| #define | DMA_ES_NCE_MASK (0x8U) |
| #define | DMA_ES_NCE_SHIFT (3U) |
| #define | DMA_ES_NCE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_NCE_SHIFT)) & DMA_ES_NCE_MASK) |
| #define | DMA_ES_DOE_MASK (0x10U) |
| #define | DMA_ES_DOE_SHIFT (4U) |
| #define | DMA_ES_DOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DOE_SHIFT)) & DMA_ES_DOE_MASK) |
| #define | DMA_ES_DAE_MASK (0x20U) |
| #define | DMA_ES_DAE_SHIFT (5U) |
| #define | DMA_ES_DAE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_DAE_SHIFT)) & DMA_ES_DAE_MASK) |
| #define | DMA_ES_SOE_MASK (0x40U) |
| #define | DMA_ES_SOE_SHIFT (6U) |
| #define | DMA_ES_SOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SOE_SHIFT)) & DMA_ES_SOE_MASK) |
| #define | DMA_ES_SAE_MASK (0x80U) |
| #define | DMA_ES_SAE_SHIFT (7U) |
| #define | DMA_ES_SAE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_SAE_SHIFT)) & DMA_ES_SAE_MASK) |
| #define | DMA_ES_ERRCHN_MASK (0x1F00U) |
| #define | DMA_ES_ERRCHN_SHIFT (8U) |
| #define | DMA_ES_ERRCHN(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_ERRCHN_SHIFT)) & DMA_ES_ERRCHN_MASK) |
| #define | DMA_ES_CPE_MASK (0x4000U) |
| #define | DMA_ES_CPE_SHIFT (14U) |
| #define | DMA_ES_CPE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_CPE_SHIFT)) & DMA_ES_CPE_MASK) |
| #define | DMA_ES_GPE_MASK (0x8000U) |
| #define | DMA_ES_GPE_SHIFT (15U) |
| #define | DMA_ES_GPE(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_GPE_SHIFT)) & DMA_ES_GPE_MASK) |
| #define | DMA_ES_ECX_MASK (0x10000U) |
| #define | DMA_ES_ECX_SHIFT (16U) |
| #define | DMA_ES_ECX(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_ECX_SHIFT)) & DMA_ES_ECX_MASK) |
| #define | DMA_ES_VLD_MASK (0x80000000U) |
| #define | DMA_ES_VLD_SHIFT (31U) |
| #define | DMA_ES_VLD(x) (((uint32_t)(((uint32_t)(x)) << DMA_ES_VLD_SHIFT)) & DMA_ES_VLD_MASK) |
ERQ - Enable Request | |
| #define | DMA_ERQ_ERQ0_MASK (0x1U) |
| #define | DMA_ERQ_ERQ0_SHIFT (0U) |
| #define | DMA_ERQ_ERQ0(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ0_SHIFT)) & DMA_ERQ_ERQ0_MASK) |
| #define | DMA_ERQ_ERQ1_MASK (0x2U) |
| #define | DMA_ERQ_ERQ1_SHIFT (1U) |
| #define | DMA_ERQ_ERQ1(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ1_SHIFT)) & DMA_ERQ_ERQ1_MASK) |
| #define | DMA_ERQ_ERQ2_MASK (0x4U) |
| #define | DMA_ERQ_ERQ2_SHIFT (2U) |
| #define | DMA_ERQ_ERQ2(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ2_SHIFT)) & DMA_ERQ_ERQ2_MASK) |
| #define | DMA_ERQ_ERQ3_MASK (0x8U) |
| #define | DMA_ERQ_ERQ3_SHIFT (3U) |
| #define | DMA_ERQ_ERQ3(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ3_SHIFT)) & DMA_ERQ_ERQ3_MASK) |
| #define | DMA_ERQ_ERQ4_MASK (0x10U) |
| #define | DMA_ERQ_ERQ4_SHIFT (4U) |
| #define | DMA_ERQ_ERQ4(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ4_SHIFT)) & DMA_ERQ_ERQ4_MASK) |
| #define | DMA_ERQ_ERQ5_MASK (0x20U) |
| #define | DMA_ERQ_ERQ5_SHIFT (5U) |
| #define | DMA_ERQ_ERQ5(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ5_SHIFT)) & DMA_ERQ_ERQ5_MASK) |
| #define | DMA_ERQ_ERQ6_MASK (0x40U) |
| #define | DMA_ERQ_ERQ6_SHIFT (6U) |
| #define | DMA_ERQ_ERQ6(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ6_SHIFT)) & DMA_ERQ_ERQ6_MASK) |
| #define | DMA_ERQ_ERQ7_MASK (0x80U) |
| #define | DMA_ERQ_ERQ7_SHIFT (7U) |
| #define | DMA_ERQ_ERQ7(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ7_SHIFT)) & DMA_ERQ_ERQ7_MASK) |
| #define | DMA_ERQ_ERQ8_MASK (0x100U) |
| #define | DMA_ERQ_ERQ8_SHIFT (8U) |
| #define | DMA_ERQ_ERQ8(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ8_SHIFT)) & DMA_ERQ_ERQ8_MASK) |
| #define | DMA_ERQ_ERQ9_MASK (0x200U) |
| #define | DMA_ERQ_ERQ9_SHIFT (9U) |
| #define | DMA_ERQ_ERQ9(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ9_SHIFT)) & DMA_ERQ_ERQ9_MASK) |
| #define | DMA_ERQ_ERQ10_MASK (0x400U) |
| #define | DMA_ERQ_ERQ10_SHIFT (10U) |
| #define | DMA_ERQ_ERQ10(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ10_SHIFT)) & DMA_ERQ_ERQ10_MASK) |
| #define | DMA_ERQ_ERQ11_MASK (0x800U) |
| #define | DMA_ERQ_ERQ11_SHIFT (11U) |
| #define | DMA_ERQ_ERQ11(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ11_SHIFT)) & DMA_ERQ_ERQ11_MASK) |
| #define | DMA_ERQ_ERQ12_MASK (0x1000U) |
| #define | DMA_ERQ_ERQ12_SHIFT (12U) |
| #define | DMA_ERQ_ERQ12(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ12_SHIFT)) & DMA_ERQ_ERQ12_MASK) |
| #define | DMA_ERQ_ERQ13_MASK (0x2000U) |
| #define | DMA_ERQ_ERQ13_SHIFT (13U) |
| #define | DMA_ERQ_ERQ13(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ13_SHIFT)) & DMA_ERQ_ERQ13_MASK) |
| #define | DMA_ERQ_ERQ14_MASK (0x4000U) |
| #define | DMA_ERQ_ERQ14_SHIFT (14U) |
| #define | DMA_ERQ_ERQ14(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ14_SHIFT)) & DMA_ERQ_ERQ14_MASK) |
| #define | DMA_ERQ_ERQ15_MASK (0x8000U) |
| #define | DMA_ERQ_ERQ15_SHIFT (15U) |
| #define | DMA_ERQ_ERQ15(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ15_SHIFT)) & DMA_ERQ_ERQ15_MASK) |
| #define | DMA_ERQ_ERQ16_MASK (0x10000U) |
| #define | DMA_ERQ_ERQ16_SHIFT (16U) |
| #define | DMA_ERQ_ERQ16(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ16_SHIFT)) & DMA_ERQ_ERQ16_MASK) |
| #define | DMA_ERQ_ERQ17_MASK (0x20000U) |
| #define | DMA_ERQ_ERQ17_SHIFT (17U) |
| #define | DMA_ERQ_ERQ17(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ17_SHIFT)) & DMA_ERQ_ERQ17_MASK) |
| #define | DMA_ERQ_ERQ18_MASK (0x40000U) |
| #define | DMA_ERQ_ERQ18_SHIFT (18U) |
| #define | DMA_ERQ_ERQ18(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ18_SHIFT)) & DMA_ERQ_ERQ18_MASK) |
| #define | DMA_ERQ_ERQ19_MASK (0x80000U) |
| #define | DMA_ERQ_ERQ19_SHIFT (19U) |
| #define | DMA_ERQ_ERQ19(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ19_SHIFT)) & DMA_ERQ_ERQ19_MASK) |
| #define | DMA_ERQ_ERQ20_MASK (0x100000U) |
| #define | DMA_ERQ_ERQ20_SHIFT (20U) |
| #define | DMA_ERQ_ERQ20(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ20_SHIFT)) & DMA_ERQ_ERQ20_MASK) |
| #define | DMA_ERQ_ERQ21_MASK (0x200000U) |
| #define | DMA_ERQ_ERQ21_SHIFT (21U) |
| #define | DMA_ERQ_ERQ21(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ21_SHIFT)) & DMA_ERQ_ERQ21_MASK) |
| #define | DMA_ERQ_ERQ22_MASK (0x400000U) |
| #define | DMA_ERQ_ERQ22_SHIFT (22U) |
| #define | DMA_ERQ_ERQ22(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ22_SHIFT)) & DMA_ERQ_ERQ22_MASK) |
| #define | DMA_ERQ_ERQ23_MASK (0x800000U) |
| #define | DMA_ERQ_ERQ23_SHIFT (23U) |
| #define | DMA_ERQ_ERQ23(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ23_SHIFT)) & DMA_ERQ_ERQ23_MASK) |
| #define | DMA_ERQ_ERQ24_MASK (0x1000000U) |
| #define | DMA_ERQ_ERQ24_SHIFT (24U) |
| #define | DMA_ERQ_ERQ24(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ24_SHIFT)) & DMA_ERQ_ERQ24_MASK) |
| #define | DMA_ERQ_ERQ25_MASK (0x2000000U) |
| #define | DMA_ERQ_ERQ25_SHIFT (25U) |
| #define | DMA_ERQ_ERQ25(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ25_SHIFT)) & DMA_ERQ_ERQ25_MASK) |
| #define | DMA_ERQ_ERQ26_MASK (0x4000000U) |
| #define | DMA_ERQ_ERQ26_SHIFT (26U) |
| #define | DMA_ERQ_ERQ26(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ26_SHIFT)) & DMA_ERQ_ERQ26_MASK) |
| #define | DMA_ERQ_ERQ27_MASK (0x8000000U) |
| #define | DMA_ERQ_ERQ27_SHIFT (27U) |
| #define | DMA_ERQ_ERQ27(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ27_SHIFT)) & DMA_ERQ_ERQ27_MASK) |
| #define | DMA_ERQ_ERQ28_MASK (0x10000000U) |
| #define | DMA_ERQ_ERQ28_SHIFT (28U) |
| #define | DMA_ERQ_ERQ28(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ28_SHIFT)) & DMA_ERQ_ERQ28_MASK) |
| #define | DMA_ERQ_ERQ29_MASK (0x20000000U) |
| #define | DMA_ERQ_ERQ29_SHIFT (29U) |
| #define | DMA_ERQ_ERQ29(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ29_SHIFT)) & DMA_ERQ_ERQ29_MASK) |
| #define | DMA_ERQ_ERQ30_MASK (0x40000000U) |
| #define | DMA_ERQ_ERQ30_SHIFT (30U) |
| #define | DMA_ERQ_ERQ30(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ30_SHIFT)) & DMA_ERQ_ERQ30_MASK) |
| #define | DMA_ERQ_ERQ31_MASK (0x80000000U) |
| #define | DMA_ERQ_ERQ31_SHIFT (31U) |
| #define | DMA_ERQ_ERQ31(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ31_SHIFT)) & DMA_ERQ_ERQ31_MASK) |
EEI - Enable Error Interrupt | |
| #define | DMA_EEI_EEI0_MASK (0x1U) |
| #define | DMA_EEI_EEI0_SHIFT (0U) |
| #define | DMA_EEI_EEI0(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI0_SHIFT)) & DMA_EEI_EEI0_MASK) |
| #define | DMA_EEI_EEI1_MASK (0x2U) |
| #define | DMA_EEI_EEI1_SHIFT (1U) |
| #define | DMA_EEI_EEI1(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI1_SHIFT)) & DMA_EEI_EEI1_MASK) |
| #define | DMA_EEI_EEI2_MASK (0x4U) |
| #define | DMA_EEI_EEI2_SHIFT (2U) |
| #define | DMA_EEI_EEI2(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI2_SHIFT)) & DMA_EEI_EEI2_MASK) |
| #define | DMA_EEI_EEI3_MASK (0x8U) |
| #define | DMA_EEI_EEI3_SHIFT (3U) |
| #define | DMA_EEI_EEI3(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI3_SHIFT)) & DMA_EEI_EEI3_MASK) |
| #define | DMA_EEI_EEI4_MASK (0x10U) |
| #define | DMA_EEI_EEI4_SHIFT (4U) |
| #define | DMA_EEI_EEI4(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI4_SHIFT)) & DMA_EEI_EEI4_MASK) |
| #define | DMA_EEI_EEI5_MASK (0x20U) |
| #define | DMA_EEI_EEI5_SHIFT (5U) |
| #define | DMA_EEI_EEI5(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI5_SHIFT)) & DMA_EEI_EEI5_MASK) |
| #define | DMA_EEI_EEI6_MASK (0x40U) |
| #define | DMA_EEI_EEI6_SHIFT (6U) |
| #define | DMA_EEI_EEI6(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI6_SHIFT)) & DMA_EEI_EEI6_MASK) |
| #define | DMA_EEI_EEI7_MASK (0x80U) |
| #define | DMA_EEI_EEI7_SHIFT (7U) |
| #define | DMA_EEI_EEI7(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI7_SHIFT)) & DMA_EEI_EEI7_MASK) |
| #define | DMA_EEI_EEI8_MASK (0x100U) |
| #define | DMA_EEI_EEI8_SHIFT (8U) |
| #define | DMA_EEI_EEI8(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI8_SHIFT)) & DMA_EEI_EEI8_MASK) |
| #define | DMA_EEI_EEI9_MASK (0x200U) |
| #define | DMA_EEI_EEI9_SHIFT (9U) |
| #define | DMA_EEI_EEI9(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI9_SHIFT)) & DMA_EEI_EEI9_MASK) |
| #define | DMA_EEI_EEI10_MASK (0x400U) |
| #define | DMA_EEI_EEI10_SHIFT (10U) |
| #define | DMA_EEI_EEI10(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI10_SHIFT)) & DMA_EEI_EEI10_MASK) |
| #define | DMA_EEI_EEI11_MASK (0x800U) |
| #define | DMA_EEI_EEI11_SHIFT (11U) |
| #define | DMA_EEI_EEI11(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI11_SHIFT)) & DMA_EEI_EEI11_MASK) |
| #define | DMA_EEI_EEI12_MASK (0x1000U) |
| #define | DMA_EEI_EEI12_SHIFT (12U) |
| #define | DMA_EEI_EEI12(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI12_SHIFT)) & DMA_EEI_EEI12_MASK) |
| #define | DMA_EEI_EEI13_MASK (0x2000U) |
| #define | DMA_EEI_EEI13_SHIFT (13U) |
| #define | DMA_EEI_EEI13(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI13_SHIFT)) & DMA_EEI_EEI13_MASK) |
| #define | DMA_EEI_EEI14_MASK (0x4000U) |
| #define | DMA_EEI_EEI14_SHIFT (14U) |
| #define | DMA_EEI_EEI14(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI14_SHIFT)) & DMA_EEI_EEI14_MASK) |
| #define | DMA_EEI_EEI15_MASK (0x8000U) |
| #define | DMA_EEI_EEI15_SHIFT (15U) |
| #define | DMA_EEI_EEI15(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI15_SHIFT)) & DMA_EEI_EEI15_MASK) |
| #define | DMA_EEI_EEI16_MASK (0x10000U) |
| #define | DMA_EEI_EEI16_SHIFT (16U) |
| #define | DMA_EEI_EEI16(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI16_SHIFT)) & DMA_EEI_EEI16_MASK) |
| #define | DMA_EEI_EEI17_MASK (0x20000U) |
| #define | DMA_EEI_EEI17_SHIFT (17U) |
| #define | DMA_EEI_EEI17(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI17_SHIFT)) & DMA_EEI_EEI17_MASK) |
| #define | DMA_EEI_EEI18_MASK (0x40000U) |
| #define | DMA_EEI_EEI18_SHIFT (18U) |
| #define | DMA_EEI_EEI18(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI18_SHIFT)) & DMA_EEI_EEI18_MASK) |
| #define | DMA_EEI_EEI19_MASK (0x80000U) |
| #define | DMA_EEI_EEI19_SHIFT (19U) |
| #define | DMA_EEI_EEI19(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI19_SHIFT)) & DMA_EEI_EEI19_MASK) |
| #define | DMA_EEI_EEI20_MASK (0x100000U) |
| #define | DMA_EEI_EEI20_SHIFT (20U) |
| #define | DMA_EEI_EEI20(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI20_SHIFT)) & DMA_EEI_EEI20_MASK) |
| #define | DMA_EEI_EEI21_MASK (0x200000U) |
| #define | DMA_EEI_EEI21_SHIFT (21U) |
| #define | DMA_EEI_EEI21(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI21_SHIFT)) & DMA_EEI_EEI21_MASK) |
| #define | DMA_EEI_EEI22_MASK (0x400000U) |
| #define | DMA_EEI_EEI22_SHIFT (22U) |
| #define | DMA_EEI_EEI22(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI22_SHIFT)) & DMA_EEI_EEI22_MASK) |
| #define | DMA_EEI_EEI23_MASK (0x800000U) |
| #define | DMA_EEI_EEI23_SHIFT (23U) |
| #define | DMA_EEI_EEI23(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI23_SHIFT)) & DMA_EEI_EEI23_MASK) |
| #define | DMA_EEI_EEI24_MASK (0x1000000U) |
| #define | DMA_EEI_EEI24_SHIFT (24U) |
| #define | DMA_EEI_EEI24(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI24_SHIFT)) & DMA_EEI_EEI24_MASK) |
| #define | DMA_EEI_EEI25_MASK (0x2000000U) |
| #define | DMA_EEI_EEI25_SHIFT (25U) |
| #define | DMA_EEI_EEI25(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI25_SHIFT)) & DMA_EEI_EEI25_MASK) |
| #define | DMA_EEI_EEI26_MASK (0x4000000U) |
| #define | DMA_EEI_EEI26_SHIFT (26U) |
| #define | DMA_EEI_EEI26(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI26_SHIFT)) & DMA_EEI_EEI26_MASK) |
| #define | DMA_EEI_EEI27_MASK (0x8000000U) |
| #define | DMA_EEI_EEI27_SHIFT (27U) |
| #define | DMA_EEI_EEI27(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI27_SHIFT)) & DMA_EEI_EEI27_MASK) |
| #define | DMA_EEI_EEI28_MASK (0x10000000U) |
| #define | DMA_EEI_EEI28_SHIFT (28U) |
| #define | DMA_EEI_EEI28(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI28_SHIFT)) & DMA_EEI_EEI28_MASK) |
| #define | DMA_EEI_EEI29_MASK (0x20000000U) |
| #define | DMA_EEI_EEI29_SHIFT (29U) |
| #define | DMA_EEI_EEI29(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI29_SHIFT)) & DMA_EEI_EEI29_MASK) |
| #define | DMA_EEI_EEI30_MASK (0x40000000U) |
| #define | DMA_EEI_EEI30_SHIFT (30U) |
| #define | DMA_EEI_EEI30(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI30_SHIFT)) & DMA_EEI_EEI30_MASK) |
| #define | DMA_EEI_EEI31_MASK (0x80000000U) |
| #define | DMA_EEI_EEI31_SHIFT (31U) |
| #define | DMA_EEI_EEI31(x) (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI31_SHIFT)) & DMA_EEI_EEI31_MASK) |
CEEI - Clear Enable Error Interrupt | |
| #define | DMA_CEEI_CEEI_MASK (0x1FU) |
| #define | DMA_CEEI_CEEI_SHIFT (0U) |
| #define | DMA_CEEI_CEEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CEEI_SHIFT)) & DMA_CEEI_CEEI_MASK) |
| #define | DMA_CEEI_CAEE_MASK (0x40U) |
| #define | DMA_CEEI_CAEE_SHIFT (6U) |
| #define | DMA_CEEI_CAEE(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CAEE_SHIFT)) & DMA_CEEI_CAEE_MASK) |
| #define | DMA_CEEI_NOP_MASK (0x80U) |
| #define | DMA_CEEI_NOP_SHIFT (7U) |
| #define | DMA_CEEI_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_NOP_SHIFT)) & DMA_CEEI_NOP_MASK) |
SEEI - Set Enable Error Interrupt | |
| #define | DMA_SEEI_SEEI_MASK (0x1FU) |
| #define | DMA_SEEI_SEEI_SHIFT (0U) |
| #define | DMA_SEEI_SEEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SEEI_SHIFT)) & DMA_SEEI_SEEI_MASK) |
| #define | DMA_SEEI_SAEE_MASK (0x40U) |
| #define | DMA_SEEI_SAEE_SHIFT (6U) |
| #define | DMA_SEEI_SAEE(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SAEE_SHIFT)) & DMA_SEEI_SAEE_MASK) |
| #define | DMA_SEEI_NOP_MASK (0x80U) |
| #define | DMA_SEEI_NOP_SHIFT (7U) |
| #define | DMA_SEEI_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_NOP_SHIFT)) & DMA_SEEI_NOP_MASK) |
CERQ - Clear Enable Request | |
| #define | DMA_CERQ_CERQ_MASK (0x1FU) |
| #define | DMA_CERQ_CERQ_SHIFT (0U) |
| #define | DMA_CERQ_CERQ(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CERQ_SHIFT)) & DMA_CERQ_CERQ_MASK) |
| #define | DMA_CERQ_CAER_MASK (0x40U) |
| #define | DMA_CERQ_CAER_SHIFT (6U) |
| #define | DMA_CERQ_CAER(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CAER_SHIFT)) & DMA_CERQ_CAER_MASK) |
| #define | DMA_CERQ_NOP_MASK (0x80U) |
| #define | DMA_CERQ_NOP_SHIFT (7U) |
| #define | DMA_CERQ_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_NOP_SHIFT)) & DMA_CERQ_NOP_MASK) |
SERQ - Set Enable Request | |
| #define | DMA_SERQ_SERQ_MASK (0x1FU) |
| #define | DMA_SERQ_SERQ_SHIFT (0U) |
| #define | DMA_SERQ_SERQ(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SERQ_SHIFT)) & DMA_SERQ_SERQ_MASK) |
| #define | DMA_SERQ_SAER_MASK (0x40U) |
| #define | DMA_SERQ_SAER_SHIFT (6U) |
| #define | DMA_SERQ_SAER(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SAER_SHIFT)) & DMA_SERQ_SAER_MASK) |
| #define | DMA_SERQ_NOP_MASK (0x80U) |
| #define | DMA_SERQ_NOP_SHIFT (7U) |
| #define | DMA_SERQ_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_NOP_SHIFT)) & DMA_SERQ_NOP_MASK) |
CDNE - Clear DONE Status Bit | |
| #define | DMA_CDNE_CDNE_MASK (0x1FU) |
| #define | DMA_CDNE_CDNE_SHIFT (0U) |
| #define | DMA_CDNE_CDNE(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CDNE_SHIFT)) & DMA_CDNE_CDNE_MASK) |
| #define | DMA_CDNE_CADN_MASK (0x40U) |
| #define | DMA_CDNE_CADN_SHIFT (6U) |
| #define | DMA_CDNE_CADN(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CADN_SHIFT)) & DMA_CDNE_CADN_MASK) |
| #define | DMA_CDNE_NOP_MASK (0x80U) |
| #define | DMA_CDNE_NOP_SHIFT (7U) |
| #define | DMA_CDNE_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_NOP_SHIFT)) & DMA_CDNE_NOP_MASK) |
SSRT - Set START Bit | |
| #define | DMA_SSRT_SSRT_MASK (0x1FU) |
| #define | DMA_SSRT_SSRT_SHIFT (0U) |
| #define | DMA_SSRT_SSRT(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SSRT_SHIFT)) & DMA_SSRT_SSRT_MASK) |
| #define | DMA_SSRT_SAST_MASK (0x40U) |
| #define | DMA_SSRT_SAST_SHIFT (6U) |
| #define | DMA_SSRT_SAST(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SAST_SHIFT)) & DMA_SSRT_SAST_MASK) |
| #define | DMA_SSRT_NOP_MASK (0x80U) |
| #define | DMA_SSRT_NOP_SHIFT (7U) |
| #define | DMA_SSRT_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_NOP_SHIFT)) & DMA_SSRT_NOP_MASK) |
CERR - Clear Error | |
| #define | DMA_CERR_CERR_MASK (0x1FU) |
| #define | DMA_CERR_CERR_SHIFT (0U) |
| #define | DMA_CERR_CERR(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CERR_SHIFT)) & DMA_CERR_CERR_MASK) |
| #define | DMA_CERR_CAEI_MASK (0x40U) |
| #define | DMA_CERR_CAEI_SHIFT (6U) |
| #define | DMA_CERR_CAEI(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CAEI_SHIFT)) & DMA_CERR_CAEI_MASK) |
| #define | DMA_CERR_NOP_MASK (0x80U) |
| #define | DMA_CERR_NOP_SHIFT (7U) |
| #define | DMA_CERR_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CERR_NOP_SHIFT)) & DMA_CERR_NOP_MASK) |
CINT - Clear Interrupt Request | |
| #define | DMA_CINT_CINT_MASK (0x1FU) |
| #define | DMA_CINT_CINT_SHIFT (0U) |
| #define | DMA_CINT_CINT(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CINT_SHIFT)) & DMA_CINT_CINT_MASK) |
| #define | DMA_CINT_CAIR_MASK (0x40U) |
| #define | DMA_CINT_CAIR_SHIFT (6U) |
| #define | DMA_CINT_CAIR(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CAIR_SHIFT)) & DMA_CINT_CAIR_MASK) |
| #define | DMA_CINT_NOP_MASK (0x80U) |
| #define | DMA_CINT_NOP_SHIFT (7U) |
| #define | DMA_CINT_NOP(x) (((uint8_t)(((uint8_t)(x)) << DMA_CINT_NOP_SHIFT)) & DMA_CINT_NOP_MASK) |
INT - Interrupt Request | |
| #define | DMA_INT_INT0_MASK (0x1U) |
| #define | DMA_INT_INT0_SHIFT (0U) |
| #define | DMA_INT_INT0(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT0_SHIFT)) & DMA_INT_INT0_MASK) |
| #define | DMA_INT_INT1_MASK (0x2U) |
| #define | DMA_INT_INT1_SHIFT (1U) |
| #define | DMA_INT_INT1(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT1_SHIFT)) & DMA_INT_INT1_MASK) |
| #define | DMA_INT_INT2_MASK (0x4U) |
| #define | DMA_INT_INT2_SHIFT (2U) |
| #define | DMA_INT_INT2(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT2_SHIFT)) & DMA_INT_INT2_MASK) |
| #define | DMA_INT_INT3_MASK (0x8U) |
| #define | DMA_INT_INT3_SHIFT (3U) |
| #define | DMA_INT_INT3(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT3_SHIFT)) & DMA_INT_INT3_MASK) |
| #define | DMA_INT_INT4_MASK (0x10U) |
| #define | DMA_INT_INT4_SHIFT (4U) |
| #define | DMA_INT_INT4(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT4_SHIFT)) & DMA_INT_INT4_MASK) |
| #define | DMA_INT_INT5_MASK (0x20U) |
| #define | DMA_INT_INT5_SHIFT (5U) |
| #define | DMA_INT_INT5(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT5_SHIFT)) & DMA_INT_INT5_MASK) |
| #define | DMA_INT_INT6_MASK (0x40U) |
| #define | DMA_INT_INT6_SHIFT (6U) |
| #define | DMA_INT_INT6(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT6_SHIFT)) & DMA_INT_INT6_MASK) |
| #define | DMA_INT_INT7_MASK (0x80U) |
| #define | DMA_INT_INT7_SHIFT (7U) |
| #define | DMA_INT_INT7(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT7_SHIFT)) & DMA_INT_INT7_MASK) |
| #define | DMA_INT_INT8_MASK (0x100U) |
| #define | DMA_INT_INT8_SHIFT (8U) |
| #define | DMA_INT_INT8(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT8_SHIFT)) & DMA_INT_INT8_MASK) |
| #define | DMA_INT_INT9_MASK (0x200U) |
| #define | DMA_INT_INT9_SHIFT (9U) |
| #define | DMA_INT_INT9(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT9_SHIFT)) & DMA_INT_INT9_MASK) |
| #define | DMA_INT_INT10_MASK (0x400U) |
| #define | DMA_INT_INT10_SHIFT (10U) |
| #define | DMA_INT_INT10(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT10_SHIFT)) & DMA_INT_INT10_MASK) |
| #define | DMA_INT_INT11_MASK (0x800U) |
| #define | DMA_INT_INT11_SHIFT (11U) |
| #define | DMA_INT_INT11(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT11_SHIFT)) & DMA_INT_INT11_MASK) |
| #define | DMA_INT_INT12_MASK (0x1000U) |
| #define | DMA_INT_INT12_SHIFT (12U) |
| #define | DMA_INT_INT12(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT12_SHIFT)) & DMA_INT_INT12_MASK) |
| #define | DMA_INT_INT13_MASK (0x2000U) |
| #define | DMA_INT_INT13_SHIFT (13U) |
| #define | DMA_INT_INT13(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT13_SHIFT)) & DMA_INT_INT13_MASK) |
| #define | DMA_INT_INT14_MASK (0x4000U) |
| #define | DMA_INT_INT14_SHIFT (14U) |
| #define | DMA_INT_INT14(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT14_SHIFT)) & DMA_INT_INT14_MASK) |
| #define | DMA_INT_INT15_MASK (0x8000U) |
| #define | DMA_INT_INT15_SHIFT (15U) |
| #define | DMA_INT_INT15(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT15_SHIFT)) & DMA_INT_INT15_MASK) |
| #define | DMA_INT_INT16_MASK (0x10000U) |
| #define | DMA_INT_INT16_SHIFT (16U) |
| #define | DMA_INT_INT16(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT16_SHIFT)) & DMA_INT_INT16_MASK) |
| #define | DMA_INT_INT17_MASK (0x20000U) |
| #define | DMA_INT_INT17_SHIFT (17U) |
| #define | DMA_INT_INT17(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT17_SHIFT)) & DMA_INT_INT17_MASK) |
| #define | DMA_INT_INT18_MASK (0x40000U) |
| #define | DMA_INT_INT18_SHIFT (18U) |
| #define | DMA_INT_INT18(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT18_SHIFT)) & DMA_INT_INT18_MASK) |
| #define | DMA_INT_INT19_MASK (0x80000U) |
| #define | DMA_INT_INT19_SHIFT (19U) |
| #define | DMA_INT_INT19(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT19_SHIFT)) & DMA_INT_INT19_MASK) |
| #define | DMA_INT_INT20_MASK (0x100000U) |
| #define | DMA_INT_INT20_SHIFT (20U) |
| #define | DMA_INT_INT20(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT20_SHIFT)) & DMA_INT_INT20_MASK) |
| #define | DMA_INT_INT21_MASK (0x200000U) |
| #define | DMA_INT_INT21_SHIFT (21U) |
| #define | DMA_INT_INT21(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT21_SHIFT)) & DMA_INT_INT21_MASK) |
| #define | DMA_INT_INT22_MASK (0x400000U) |
| #define | DMA_INT_INT22_SHIFT (22U) |
| #define | DMA_INT_INT22(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT22_SHIFT)) & DMA_INT_INT22_MASK) |
| #define | DMA_INT_INT23_MASK (0x800000U) |
| #define | DMA_INT_INT23_SHIFT (23U) |
| #define | DMA_INT_INT23(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT23_SHIFT)) & DMA_INT_INT23_MASK) |
| #define | DMA_INT_INT24_MASK (0x1000000U) |
| #define | DMA_INT_INT24_SHIFT (24U) |
| #define | DMA_INT_INT24(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT24_SHIFT)) & DMA_INT_INT24_MASK) |
| #define | DMA_INT_INT25_MASK (0x2000000U) |
| #define | DMA_INT_INT25_SHIFT (25U) |
| #define | DMA_INT_INT25(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT25_SHIFT)) & DMA_INT_INT25_MASK) |
| #define | DMA_INT_INT26_MASK (0x4000000U) |
| #define | DMA_INT_INT26_SHIFT (26U) |
| #define | DMA_INT_INT26(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT26_SHIFT)) & DMA_INT_INT26_MASK) |
| #define | DMA_INT_INT27_MASK (0x8000000U) |
| #define | DMA_INT_INT27_SHIFT (27U) |
| #define | DMA_INT_INT27(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT27_SHIFT)) & DMA_INT_INT27_MASK) |
| #define | DMA_INT_INT28_MASK (0x10000000U) |
| #define | DMA_INT_INT28_SHIFT (28U) |
| #define | DMA_INT_INT28(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT28_SHIFT)) & DMA_INT_INT28_MASK) |
| #define | DMA_INT_INT29_MASK (0x20000000U) |
| #define | DMA_INT_INT29_SHIFT (29U) |
| #define | DMA_INT_INT29(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT29_SHIFT)) & DMA_INT_INT29_MASK) |
| #define | DMA_INT_INT30_MASK (0x40000000U) |
| #define | DMA_INT_INT30_SHIFT (30U) |
| #define | DMA_INT_INT30(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT30_SHIFT)) & DMA_INT_INT30_MASK) |
| #define | DMA_INT_INT31_MASK (0x80000000U) |
| #define | DMA_INT_INT31_SHIFT (31U) |
| #define | DMA_INT_INT31(x) (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT31_SHIFT)) & DMA_INT_INT31_MASK) |
ERR - Error | |
| #define | DMA_ERR_ERR0_MASK (0x1U) |
| #define | DMA_ERR_ERR0_SHIFT (0U) |
| #define | DMA_ERR_ERR0(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR0_SHIFT)) & DMA_ERR_ERR0_MASK) |
| #define | DMA_ERR_ERR1_MASK (0x2U) |
| #define | DMA_ERR_ERR1_SHIFT (1U) |
| #define | DMA_ERR_ERR1(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR1_SHIFT)) & DMA_ERR_ERR1_MASK) |
| #define | DMA_ERR_ERR2_MASK (0x4U) |
| #define | DMA_ERR_ERR2_SHIFT (2U) |
| #define | DMA_ERR_ERR2(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR2_SHIFT)) & DMA_ERR_ERR2_MASK) |
| #define | DMA_ERR_ERR3_MASK (0x8U) |
| #define | DMA_ERR_ERR3_SHIFT (3U) |
| #define | DMA_ERR_ERR3(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR3_SHIFT)) & DMA_ERR_ERR3_MASK) |
| #define | DMA_ERR_ERR4_MASK (0x10U) |
| #define | DMA_ERR_ERR4_SHIFT (4U) |
| #define | DMA_ERR_ERR4(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR4_SHIFT)) & DMA_ERR_ERR4_MASK) |
| #define | DMA_ERR_ERR5_MASK (0x20U) |
| #define | DMA_ERR_ERR5_SHIFT (5U) |
| #define | DMA_ERR_ERR5(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR5_SHIFT)) & DMA_ERR_ERR5_MASK) |
| #define | DMA_ERR_ERR6_MASK (0x40U) |
| #define | DMA_ERR_ERR6_SHIFT (6U) |
| #define | DMA_ERR_ERR6(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR6_SHIFT)) & DMA_ERR_ERR6_MASK) |
| #define | DMA_ERR_ERR7_MASK (0x80U) |
| #define | DMA_ERR_ERR7_SHIFT (7U) |
| #define | DMA_ERR_ERR7(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR7_SHIFT)) & DMA_ERR_ERR7_MASK) |
| #define | DMA_ERR_ERR8_MASK (0x100U) |
| #define | DMA_ERR_ERR8_SHIFT (8U) |
| #define | DMA_ERR_ERR8(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR8_SHIFT)) & DMA_ERR_ERR8_MASK) |
| #define | DMA_ERR_ERR9_MASK (0x200U) |
| #define | DMA_ERR_ERR9_SHIFT (9U) |
| #define | DMA_ERR_ERR9(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR9_SHIFT)) & DMA_ERR_ERR9_MASK) |
| #define | DMA_ERR_ERR10_MASK (0x400U) |
| #define | DMA_ERR_ERR10_SHIFT (10U) |
| #define | DMA_ERR_ERR10(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR10_SHIFT)) & DMA_ERR_ERR10_MASK) |
| #define | DMA_ERR_ERR11_MASK (0x800U) |
| #define | DMA_ERR_ERR11_SHIFT (11U) |
| #define | DMA_ERR_ERR11(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR11_SHIFT)) & DMA_ERR_ERR11_MASK) |
| #define | DMA_ERR_ERR12_MASK (0x1000U) |
| #define | DMA_ERR_ERR12_SHIFT (12U) |
| #define | DMA_ERR_ERR12(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR12_SHIFT)) & DMA_ERR_ERR12_MASK) |
| #define | DMA_ERR_ERR13_MASK (0x2000U) |
| #define | DMA_ERR_ERR13_SHIFT (13U) |
| #define | DMA_ERR_ERR13(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR13_SHIFT)) & DMA_ERR_ERR13_MASK) |
| #define | DMA_ERR_ERR14_MASK (0x4000U) |
| #define | DMA_ERR_ERR14_SHIFT (14U) |
| #define | DMA_ERR_ERR14(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR14_SHIFT)) & DMA_ERR_ERR14_MASK) |
| #define | DMA_ERR_ERR15_MASK (0x8000U) |
| #define | DMA_ERR_ERR15_SHIFT (15U) |
| #define | DMA_ERR_ERR15(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR15_SHIFT)) & DMA_ERR_ERR15_MASK) |
| #define | DMA_ERR_ERR16_MASK (0x10000U) |
| #define | DMA_ERR_ERR16_SHIFT (16U) |
| #define | DMA_ERR_ERR16(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR16_SHIFT)) & DMA_ERR_ERR16_MASK) |
| #define | DMA_ERR_ERR17_MASK (0x20000U) |
| #define | DMA_ERR_ERR17_SHIFT (17U) |
| #define | DMA_ERR_ERR17(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR17_SHIFT)) & DMA_ERR_ERR17_MASK) |
| #define | DMA_ERR_ERR18_MASK (0x40000U) |
| #define | DMA_ERR_ERR18_SHIFT (18U) |
| #define | DMA_ERR_ERR18(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR18_SHIFT)) & DMA_ERR_ERR18_MASK) |
| #define | DMA_ERR_ERR19_MASK (0x80000U) |
| #define | DMA_ERR_ERR19_SHIFT (19U) |
| #define | DMA_ERR_ERR19(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR19_SHIFT)) & DMA_ERR_ERR19_MASK) |
| #define | DMA_ERR_ERR20_MASK (0x100000U) |
| #define | DMA_ERR_ERR20_SHIFT (20U) |
| #define | DMA_ERR_ERR20(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR20_SHIFT)) & DMA_ERR_ERR20_MASK) |
| #define | DMA_ERR_ERR21_MASK (0x200000U) |
| #define | DMA_ERR_ERR21_SHIFT (21U) |
| #define | DMA_ERR_ERR21(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR21_SHIFT)) & DMA_ERR_ERR21_MASK) |
| #define | DMA_ERR_ERR22_MASK (0x400000U) |
| #define | DMA_ERR_ERR22_SHIFT (22U) |
| #define | DMA_ERR_ERR22(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR22_SHIFT)) & DMA_ERR_ERR22_MASK) |
| #define | DMA_ERR_ERR23_MASK (0x800000U) |
| #define | DMA_ERR_ERR23_SHIFT (23U) |
| #define | DMA_ERR_ERR23(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR23_SHIFT)) & DMA_ERR_ERR23_MASK) |
| #define | DMA_ERR_ERR24_MASK (0x1000000U) |
| #define | DMA_ERR_ERR24_SHIFT (24U) |
| #define | DMA_ERR_ERR24(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR24_SHIFT)) & DMA_ERR_ERR24_MASK) |
| #define | DMA_ERR_ERR25_MASK (0x2000000U) |
| #define | DMA_ERR_ERR25_SHIFT (25U) |
| #define | DMA_ERR_ERR25(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR25_SHIFT)) & DMA_ERR_ERR25_MASK) |
| #define | DMA_ERR_ERR26_MASK (0x4000000U) |
| #define | DMA_ERR_ERR26_SHIFT (26U) |
| #define | DMA_ERR_ERR26(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR26_SHIFT)) & DMA_ERR_ERR26_MASK) |
| #define | DMA_ERR_ERR27_MASK (0x8000000U) |
| #define | DMA_ERR_ERR27_SHIFT (27U) |
| #define | DMA_ERR_ERR27(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR27_SHIFT)) & DMA_ERR_ERR27_MASK) |
| #define | DMA_ERR_ERR28_MASK (0x10000000U) |
| #define | DMA_ERR_ERR28_SHIFT (28U) |
| #define | DMA_ERR_ERR28(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR28_SHIFT)) & DMA_ERR_ERR28_MASK) |
| #define | DMA_ERR_ERR29_MASK (0x20000000U) |
| #define | DMA_ERR_ERR29_SHIFT (29U) |
| #define | DMA_ERR_ERR29(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR29_SHIFT)) & DMA_ERR_ERR29_MASK) |
| #define | DMA_ERR_ERR30_MASK (0x40000000U) |
| #define | DMA_ERR_ERR30_SHIFT (30U) |
| #define | DMA_ERR_ERR30(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR30_SHIFT)) & DMA_ERR_ERR30_MASK) |
| #define | DMA_ERR_ERR31_MASK (0x80000000U) |
| #define | DMA_ERR_ERR31_SHIFT (31U) |
| #define | DMA_ERR_ERR31(x) (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR31_SHIFT)) & DMA_ERR_ERR31_MASK) |
HRS - Hardware Request Status | |
| #define | DMA_HRS_HRS0_MASK (0x1U) |
| #define | DMA_HRS_HRS0_SHIFT (0U) |
| #define | DMA_HRS_HRS0(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS0_SHIFT)) & DMA_HRS_HRS0_MASK) |
| #define | DMA_HRS_HRS1_MASK (0x2U) |
| #define | DMA_HRS_HRS1_SHIFT (1U) |
| #define | DMA_HRS_HRS1(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS1_SHIFT)) & DMA_HRS_HRS1_MASK) |
| #define | DMA_HRS_HRS2_MASK (0x4U) |
| #define | DMA_HRS_HRS2_SHIFT (2U) |
| #define | DMA_HRS_HRS2(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS2_SHIFT)) & DMA_HRS_HRS2_MASK) |
| #define | DMA_HRS_HRS3_MASK (0x8U) |
| #define | DMA_HRS_HRS3_SHIFT (3U) |
| #define | DMA_HRS_HRS3(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS3_SHIFT)) & DMA_HRS_HRS3_MASK) |
| #define | DMA_HRS_HRS4_MASK (0x10U) |
| #define | DMA_HRS_HRS4_SHIFT (4U) |
| #define | DMA_HRS_HRS4(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS4_SHIFT)) & DMA_HRS_HRS4_MASK) |
| #define | DMA_HRS_HRS5_MASK (0x20U) |
| #define | DMA_HRS_HRS5_SHIFT (5U) |
| #define | DMA_HRS_HRS5(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS5_SHIFT)) & DMA_HRS_HRS5_MASK) |
| #define | DMA_HRS_HRS6_MASK (0x40U) |
| #define | DMA_HRS_HRS6_SHIFT (6U) |
| #define | DMA_HRS_HRS6(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS6_SHIFT)) & DMA_HRS_HRS6_MASK) |
| #define | DMA_HRS_HRS7_MASK (0x80U) |
| #define | DMA_HRS_HRS7_SHIFT (7U) |
| #define | DMA_HRS_HRS7(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS7_SHIFT)) & DMA_HRS_HRS7_MASK) |
| #define | DMA_HRS_HRS8_MASK (0x100U) |
| #define | DMA_HRS_HRS8_SHIFT (8U) |
| #define | DMA_HRS_HRS8(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS8_SHIFT)) & DMA_HRS_HRS8_MASK) |
| #define | DMA_HRS_HRS9_MASK (0x200U) |
| #define | DMA_HRS_HRS9_SHIFT (9U) |
| #define | DMA_HRS_HRS9(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS9_SHIFT)) & DMA_HRS_HRS9_MASK) |
| #define | DMA_HRS_HRS10_MASK (0x400U) |
| #define | DMA_HRS_HRS10_SHIFT (10U) |
| #define | DMA_HRS_HRS10(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS10_SHIFT)) & DMA_HRS_HRS10_MASK) |
| #define | DMA_HRS_HRS11_MASK (0x800U) |
| #define | DMA_HRS_HRS11_SHIFT (11U) |
| #define | DMA_HRS_HRS11(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS11_SHIFT)) & DMA_HRS_HRS11_MASK) |
| #define | DMA_HRS_HRS12_MASK (0x1000U) |
| #define | DMA_HRS_HRS12_SHIFT (12U) |
| #define | DMA_HRS_HRS12(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS12_SHIFT)) & DMA_HRS_HRS12_MASK) |
| #define | DMA_HRS_HRS13_MASK (0x2000U) |
| #define | DMA_HRS_HRS13_SHIFT (13U) |
| #define | DMA_HRS_HRS13(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS13_SHIFT)) & DMA_HRS_HRS13_MASK) |
| #define | DMA_HRS_HRS14_MASK (0x4000U) |
| #define | DMA_HRS_HRS14_SHIFT (14U) |
| #define | DMA_HRS_HRS14(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS14_SHIFT)) & DMA_HRS_HRS14_MASK) |
| #define | DMA_HRS_HRS15_MASK (0x8000U) |
| #define | DMA_HRS_HRS15_SHIFT (15U) |
| #define | DMA_HRS_HRS15(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS15_SHIFT)) & DMA_HRS_HRS15_MASK) |
| #define | DMA_HRS_HRS16_MASK (0x10000U) |
| #define | DMA_HRS_HRS16_SHIFT (16U) |
| #define | DMA_HRS_HRS16(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS16_SHIFT)) & DMA_HRS_HRS16_MASK) |
| #define | DMA_HRS_HRS17_MASK (0x20000U) |
| #define | DMA_HRS_HRS17_SHIFT (17U) |
| #define | DMA_HRS_HRS17(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS17_SHIFT)) & DMA_HRS_HRS17_MASK) |
| #define | DMA_HRS_HRS18_MASK (0x40000U) |
| #define | DMA_HRS_HRS18_SHIFT (18U) |
| #define | DMA_HRS_HRS18(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS18_SHIFT)) & DMA_HRS_HRS18_MASK) |
| #define | DMA_HRS_HRS19_MASK (0x80000U) |
| #define | DMA_HRS_HRS19_SHIFT (19U) |
| #define | DMA_HRS_HRS19(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS19_SHIFT)) & DMA_HRS_HRS19_MASK) |
| #define | DMA_HRS_HRS20_MASK (0x100000U) |
| #define | DMA_HRS_HRS20_SHIFT (20U) |
| #define | DMA_HRS_HRS20(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS20_SHIFT)) & DMA_HRS_HRS20_MASK) |
| #define | DMA_HRS_HRS21_MASK (0x200000U) |
| #define | DMA_HRS_HRS21_SHIFT (21U) |
| #define | DMA_HRS_HRS21(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS21_SHIFT)) & DMA_HRS_HRS21_MASK) |
| #define | DMA_HRS_HRS22_MASK (0x400000U) |
| #define | DMA_HRS_HRS22_SHIFT (22U) |
| #define | DMA_HRS_HRS22(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS22_SHIFT)) & DMA_HRS_HRS22_MASK) |
| #define | DMA_HRS_HRS23_MASK (0x800000U) |
| #define | DMA_HRS_HRS23_SHIFT (23U) |
| #define | DMA_HRS_HRS23(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS23_SHIFT)) & DMA_HRS_HRS23_MASK) |
| #define | DMA_HRS_HRS24_MASK (0x1000000U) |
| #define | DMA_HRS_HRS24_SHIFT (24U) |
| #define | DMA_HRS_HRS24(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS24_SHIFT)) & DMA_HRS_HRS24_MASK) |
| #define | DMA_HRS_HRS25_MASK (0x2000000U) |
| #define | DMA_HRS_HRS25_SHIFT (25U) |
| #define | DMA_HRS_HRS25(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS25_SHIFT)) & DMA_HRS_HRS25_MASK) |
| #define | DMA_HRS_HRS26_MASK (0x4000000U) |
| #define | DMA_HRS_HRS26_SHIFT (26U) |
| #define | DMA_HRS_HRS26(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS26_SHIFT)) & DMA_HRS_HRS26_MASK) |
| #define | DMA_HRS_HRS27_MASK (0x8000000U) |
| #define | DMA_HRS_HRS27_SHIFT (27U) |
| #define | DMA_HRS_HRS27(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS27_SHIFT)) & DMA_HRS_HRS27_MASK) |
| #define | DMA_HRS_HRS28_MASK (0x10000000U) |
| #define | DMA_HRS_HRS28_SHIFT (28U) |
| #define | DMA_HRS_HRS28(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS28_SHIFT)) & DMA_HRS_HRS28_MASK) |
| #define | DMA_HRS_HRS29_MASK (0x20000000U) |
| #define | DMA_HRS_HRS29_SHIFT (29U) |
| #define | DMA_HRS_HRS29(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS29_SHIFT)) & DMA_HRS_HRS29_MASK) |
| #define | DMA_HRS_HRS30_MASK (0x40000000U) |
| #define | DMA_HRS_HRS30_SHIFT (30U) |
| #define | DMA_HRS_HRS30(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS30_SHIFT)) & DMA_HRS_HRS30_MASK) |
| #define | DMA_HRS_HRS31_MASK (0x80000000U) |
| #define | DMA_HRS_HRS31_SHIFT (31U) |
| #define | DMA_HRS_HRS31(x) (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS31_SHIFT)) & DMA_HRS_HRS31_MASK) |
EARS - Enable Asynchronous Request in Stop | |
| #define | DMA_EARS_EDREQ_0_MASK (0x1U) |
| #define | DMA_EARS_EDREQ_0_SHIFT (0U) |
| #define | DMA_EARS_EDREQ_0(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_0_SHIFT)) & DMA_EARS_EDREQ_0_MASK) |
| #define | DMA_EARS_EDREQ_1_MASK (0x2U) |
| #define | DMA_EARS_EDREQ_1_SHIFT (1U) |
| #define | DMA_EARS_EDREQ_1(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_1_SHIFT)) & DMA_EARS_EDREQ_1_MASK) |
| #define | DMA_EARS_EDREQ_2_MASK (0x4U) |
| #define | DMA_EARS_EDREQ_2_SHIFT (2U) |
| #define | DMA_EARS_EDREQ_2(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_2_SHIFT)) & DMA_EARS_EDREQ_2_MASK) |
| #define | DMA_EARS_EDREQ_3_MASK (0x8U) |
| #define | DMA_EARS_EDREQ_3_SHIFT (3U) |
| #define | DMA_EARS_EDREQ_3(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_3_SHIFT)) & DMA_EARS_EDREQ_3_MASK) |
| #define | DMA_EARS_EDREQ_4_MASK (0x10U) |
| #define | DMA_EARS_EDREQ_4_SHIFT (4U) |
| #define | DMA_EARS_EDREQ_4(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_4_SHIFT)) & DMA_EARS_EDREQ_4_MASK) |
| #define | DMA_EARS_EDREQ_5_MASK (0x20U) |
| #define | DMA_EARS_EDREQ_5_SHIFT (5U) |
| #define | DMA_EARS_EDREQ_5(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_5_SHIFT)) & DMA_EARS_EDREQ_5_MASK) |
| #define | DMA_EARS_EDREQ_6_MASK (0x40U) |
| #define | DMA_EARS_EDREQ_6_SHIFT (6U) |
| #define | DMA_EARS_EDREQ_6(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_6_SHIFT)) & DMA_EARS_EDREQ_6_MASK) |
| #define | DMA_EARS_EDREQ_7_MASK (0x80U) |
| #define | DMA_EARS_EDREQ_7_SHIFT (7U) |
| #define | DMA_EARS_EDREQ_7(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_7_SHIFT)) & DMA_EARS_EDREQ_7_MASK) |
| #define | DMA_EARS_EDREQ_8_MASK (0x100U) |
| #define | DMA_EARS_EDREQ_8_SHIFT (8U) |
| #define | DMA_EARS_EDREQ_8(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_8_SHIFT)) & DMA_EARS_EDREQ_8_MASK) |
| #define | DMA_EARS_EDREQ_9_MASK (0x200U) |
| #define | DMA_EARS_EDREQ_9_SHIFT (9U) |
| #define | DMA_EARS_EDREQ_9(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_9_SHIFT)) & DMA_EARS_EDREQ_9_MASK) |
| #define | DMA_EARS_EDREQ_10_MASK (0x400U) |
| #define | DMA_EARS_EDREQ_10_SHIFT (10U) |
| #define | DMA_EARS_EDREQ_10(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_10_SHIFT)) & DMA_EARS_EDREQ_10_MASK) |
| #define | DMA_EARS_EDREQ_11_MASK (0x800U) |
| #define | DMA_EARS_EDREQ_11_SHIFT (11U) |
| #define | DMA_EARS_EDREQ_11(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_11_SHIFT)) & DMA_EARS_EDREQ_11_MASK) |
| #define | DMA_EARS_EDREQ_12_MASK (0x1000U) |
| #define | DMA_EARS_EDREQ_12_SHIFT (12U) |
| #define | DMA_EARS_EDREQ_12(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_12_SHIFT)) & DMA_EARS_EDREQ_12_MASK) |
| #define | DMA_EARS_EDREQ_13_MASK (0x2000U) |
| #define | DMA_EARS_EDREQ_13_SHIFT (13U) |
| #define | DMA_EARS_EDREQ_13(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_13_SHIFT)) & DMA_EARS_EDREQ_13_MASK) |
| #define | DMA_EARS_EDREQ_14_MASK (0x4000U) |
| #define | DMA_EARS_EDREQ_14_SHIFT (14U) |
| #define | DMA_EARS_EDREQ_14(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_14_SHIFT)) & DMA_EARS_EDREQ_14_MASK) |
| #define | DMA_EARS_EDREQ_15_MASK (0x8000U) |
| #define | DMA_EARS_EDREQ_15_SHIFT (15U) |
| #define | DMA_EARS_EDREQ_15(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_15_SHIFT)) & DMA_EARS_EDREQ_15_MASK) |
| #define | DMA_EARS_EDREQ_16_MASK (0x10000U) |
| #define | DMA_EARS_EDREQ_16_SHIFT (16U) |
| #define | DMA_EARS_EDREQ_16(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_16_SHIFT)) & DMA_EARS_EDREQ_16_MASK) |
| #define | DMA_EARS_EDREQ_17_MASK (0x20000U) |
| #define | DMA_EARS_EDREQ_17_SHIFT (17U) |
| #define | DMA_EARS_EDREQ_17(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_17_SHIFT)) & DMA_EARS_EDREQ_17_MASK) |
| #define | DMA_EARS_EDREQ_18_MASK (0x40000U) |
| #define | DMA_EARS_EDREQ_18_SHIFT (18U) |
| #define | DMA_EARS_EDREQ_18(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_18_SHIFT)) & DMA_EARS_EDREQ_18_MASK) |
| #define | DMA_EARS_EDREQ_19_MASK (0x80000U) |
| #define | DMA_EARS_EDREQ_19_SHIFT (19U) |
| #define | DMA_EARS_EDREQ_19(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_19_SHIFT)) & DMA_EARS_EDREQ_19_MASK) |
| #define | DMA_EARS_EDREQ_20_MASK (0x100000U) |
| #define | DMA_EARS_EDREQ_20_SHIFT (20U) |
| #define | DMA_EARS_EDREQ_20(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_20_SHIFT)) & DMA_EARS_EDREQ_20_MASK) |
| #define | DMA_EARS_EDREQ_21_MASK (0x200000U) |
| #define | DMA_EARS_EDREQ_21_SHIFT (21U) |
| #define | DMA_EARS_EDREQ_21(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_21_SHIFT)) & DMA_EARS_EDREQ_21_MASK) |
| #define | DMA_EARS_EDREQ_22_MASK (0x400000U) |
| #define | DMA_EARS_EDREQ_22_SHIFT (22U) |
| #define | DMA_EARS_EDREQ_22(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_22_SHIFT)) & DMA_EARS_EDREQ_22_MASK) |
| #define | DMA_EARS_EDREQ_23_MASK (0x800000U) |
| #define | DMA_EARS_EDREQ_23_SHIFT (23U) |
| #define | DMA_EARS_EDREQ_23(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_23_SHIFT)) & DMA_EARS_EDREQ_23_MASK) |
| #define | DMA_EARS_EDREQ_24_MASK (0x1000000U) |
| #define | DMA_EARS_EDREQ_24_SHIFT (24U) |
| #define | DMA_EARS_EDREQ_24(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_24_SHIFT)) & DMA_EARS_EDREQ_24_MASK) |
| #define | DMA_EARS_EDREQ_25_MASK (0x2000000U) |
| #define | DMA_EARS_EDREQ_25_SHIFT (25U) |
| #define | DMA_EARS_EDREQ_25(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_25_SHIFT)) & DMA_EARS_EDREQ_25_MASK) |
| #define | DMA_EARS_EDREQ_26_MASK (0x4000000U) |
| #define | DMA_EARS_EDREQ_26_SHIFT (26U) |
| #define | DMA_EARS_EDREQ_26(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_26_SHIFT)) & DMA_EARS_EDREQ_26_MASK) |
| #define | DMA_EARS_EDREQ_27_MASK (0x8000000U) |
| #define | DMA_EARS_EDREQ_27_SHIFT (27U) |
| #define | DMA_EARS_EDREQ_27(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_27_SHIFT)) & DMA_EARS_EDREQ_27_MASK) |
| #define | DMA_EARS_EDREQ_28_MASK (0x10000000U) |
| #define | DMA_EARS_EDREQ_28_SHIFT (28U) |
| #define | DMA_EARS_EDREQ_28(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_28_SHIFT)) & DMA_EARS_EDREQ_28_MASK) |
| #define | DMA_EARS_EDREQ_29_MASK (0x20000000U) |
| #define | DMA_EARS_EDREQ_29_SHIFT (29U) |
| #define | DMA_EARS_EDREQ_29(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_29_SHIFT)) & DMA_EARS_EDREQ_29_MASK) |
| #define | DMA_EARS_EDREQ_30_MASK (0x40000000U) |
| #define | DMA_EARS_EDREQ_30_SHIFT (30U) |
| #define | DMA_EARS_EDREQ_30(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_30_SHIFT)) & DMA_EARS_EDREQ_30_MASK) |
| #define | DMA_EARS_EDREQ_31_MASK (0x80000000U) |
| #define | DMA_EARS_EDREQ_31_SHIFT (31U) |
| #define | DMA_EARS_EDREQ_31(x) (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_31_SHIFT)) & DMA_EARS_EDREQ_31_MASK) |
DCHPRI3 - Channel Priority | |
| #define | DMA_DCHPRI3_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI3_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI3_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_CHPRI_SHIFT)) & DMA_DCHPRI3_CHPRI_MASK) |
| #define | DMA_DCHPRI3_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI3_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI3_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_GRPPRI_SHIFT)) & DMA_DCHPRI3_GRPPRI_MASK) |
| #define | DMA_DCHPRI3_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI3_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI3_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_DPA_SHIFT)) & DMA_DCHPRI3_DPA_MASK) |
| #define | DMA_DCHPRI3_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI3_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI3_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_ECP_SHIFT)) & DMA_DCHPRI3_ECP_MASK) |
DCHPRI2 - Channel Priority | |
| #define | DMA_DCHPRI2_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI2_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI2_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_CHPRI_SHIFT)) & DMA_DCHPRI2_CHPRI_MASK) |
| #define | DMA_DCHPRI2_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI2_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI2_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_GRPPRI_SHIFT)) & DMA_DCHPRI2_GRPPRI_MASK) |
| #define | DMA_DCHPRI2_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI2_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI2_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_DPA_SHIFT)) & DMA_DCHPRI2_DPA_MASK) |
| #define | DMA_DCHPRI2_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI2_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI2_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_ECP_SHIFT)) & DMA_DCHPRI2_ECP_MASK) |
DCHPRI1 - Channel Priority | |
| #define | DMA_DCHPRI1_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI1_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI1_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_CHPRI_SHIFT)) & DMA_DCHPRI1_CHPRI_MASK) |
| #define | DMA_DCHPRI1_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI1_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI1_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_GRPPRI_SHIFT)) & DMA_DCHPRI1_GRPPRI_MASK) |
| #define | DMA_DCHPRI1_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI1_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI1_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_DPA_SHIFT)) & DMA_DCHPRI1_DPA_MASK) |
| #define | DMA_DCHPRI1_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI1_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI1_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_ECP_SHIFT)) & DMA_DCHPRI1_ECP_MASK) |
DCHPRI0 - Channel Priority | |
| #define | DMA_DCHPRI0_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI0_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI0_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_CHPRI_SHIFT)) & DMA_DCHPRI0_CHPRI_MASK) |
| #define | DMA_DCHPRI0_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI0_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI0_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_GRPPRI_SHIFT)) & DMA_DCHPRI0_GRPPRI_MASK) |
| #define | DMA_DCHPRI0_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI0_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI0_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_DPA_SHIFT)) & DMA_DCHPRI0_DPA_MASK) |
| #define | DMA_DCHPRI0_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI0_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI0_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_ECP_SHIFT)) & DMA_DCHPRI0_ECP_MASK) |
DCHPRI7 - Channel Priority | |
| #define | DMA_DCHPRI7_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI7_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI7_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_CHPRI_SHIFT)) & DMA_DCHPRI7_CHPRI_MASK) |
| #define | DMA_DCHPRI7_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI7_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI7_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_GRPPRI_SHIFT)) & DMA_DCHPRI7_GRPPRI_MASK) |
| #define | DMA_DCHPRI7_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI7_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI7_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_DPA_SHIFT)) & DMA_DCHPRI7_DPA_MASK) |
| #define | DMA_DCHPRI7_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI7_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI7_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_ECP_SHIFT)) & DMA_DCHPRI7_ECP_MASK) |
DCHPRI6 - Channel Priority | |
| #define | DMA_DCHPRI6_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI6_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI6_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_CHPRI_SHIFT)) & DMA_DCHPRI6_CHPRI_MASK) |
| #define | DMA_DCHPRI6_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI6_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI6_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_GRPPRI_SHIFT)) & DMA_DCHPRI6_GRPPRI_MASK) |
| #define | DMA_DCHPRI6_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI6_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI6_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_DPA_SHIFT)) & DMA_DCHPRI6_DPA_MASK) |
| #define | DMA_DCHPRI6_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI6_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI6_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_ECP_SHIFT)) & DMA_DCHPRI6_ECP_MASK) |
DCHPRI5 - Channel Priority | |
| #define | DMA_DCHPRI5_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI5_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI5_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_CHPRI_SHIFT)) & DMA_DCHPRI5_CHPRI_MASK) |
| #define | DMA_DCHPRI5_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI5_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI5_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_GRPPRI_SHIFT)) & DMA_DCHPRI5_GRPPRI_MASK) |
| #define | DMA_DCHPRI5_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI5_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI5_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_DPA_SHIFT)) & DMA_DCHPRI5_DPA_MASK) |
| #define | DMA_DCHPRI5_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI5_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI5_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_ECP_SHIFT)) & DMA_DCHPRI5_ECP_MASK) |
DCHPRI4 - Channel Priority | |
| #define | DMA_DCHPRI4_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI4_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI4_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_CHPRI_SHIFT)) & DMA_DCHPRI4_CHPRI_MASK) |
| #define | DMA_DCHPRI4_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI4_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI4_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_GRPPRI_SHIFT)) & DMA_DCHPRI4_GRPPRI_MASK) |
| #define | DMA_DCHPRI4_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI4_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI4_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_DPA_SHIFT)) & DMA_DCHPRI4_DPA_MASK) |
| #define | DMA_DCHPRI4_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI4_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI4_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_ECP_SHIFT)) & DMA_DCHPRI4_ECP_MASK) |
DCHPRI11 - Channel Priority | |
| #define | DMA_DCHPRI11_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI11_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI11_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_CHPRI_SHIFT)) & DMA_DCHPRI11_CHPRI_MASK) |
| #define | DMA_DCHPRI11_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI11_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI11_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_GRPPRI_SHIFT)) & DMA_DCHPRI11_GRPPRI_MASK) |
| #define | DMA_DCHPRI11_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI11_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI11_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_DPA_SHIFT)) & DMA_DCHPRI11_DPA_MASK) |
| #define | DMA_DCHPRI11_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI11_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI11_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_ECP_SHIFT)) & DMA_DCHPRI11_ECP_MASK) |
DCHPRI10 - Channel Priority | |
| #define | DMA_DCHPRI10_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI10_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI10_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_CHPRI_SHIFT)) & DMA_DCHPRI10_CHPRI_MASK) |
| #define | DMA_DCHPRI10_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI10_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI10_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_GRPPRI_SHIFT)) & DMA_DCHPRI10_GRPPRI_MASK) |
| #define | DMA_DCHPRI10_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI10_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI10_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_DPA_SHIFT)) & DMA_DCHPRI10_DPA_MASK) |
| #define | DMA_DCHPRI10_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI10_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI10_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_ECP_SHIFT)) & DMA_DCHPRI10_ECP_MASK) |
DCHPRI9 - Channel Priority | |
| #define | DMA_DCHPRI9_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI9_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI9_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_CHPRI_SHIFT)) & DMA_DCHPRI9_CHPRI_MASK) |
| #define | DMA_DCHPRI9_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI9_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI9_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_GRPPRI_SHIFT)) & DMA_DCHPRI9_GRPPRI_MASK) |
| #define | DMA_DCHPRI9_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI9_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI9_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_DPA_SHIFT)) & DMA_DCHPRI9_DPA_MASK) |
| #define | DMA_DCHPRI9_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI9_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI9_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_ECP_SHIFT)) & DMA_DCHPRI9_ECP_MASK) |
DCHPRI8 - Channel Priority | |
| #define | DMA_DCHPRI8_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI8_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI8_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_CHPRI_SHIFT)) & DMA_DCHPRI8_CHPRI_MASK) |
| #define | DMA_DCHPRI8_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI8_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI8_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_GRPPRI_SHIFT)) & DMA_DCHPRI8_GRPPRI_MASK) |
| #define | DMA_DCHPRI8_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI8_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI8_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_DPA_SHIFT)) & DMA_DCHPRI8_DPA_MASK) |
| #define | DMA_DCHPRI8_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI8_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI8_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_ECP_SHIFT)) & DMA_DCHPRI8_ECP_MASK) |
DCHPRI15 - Channel Priority | |
| #define | DMA_DCHPRI15_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI15_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI15_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_CHPRI_SHIFT)) & DMA_DCHPRI15_CHPRI_MASK) |
| #define | DMA_DCHPRI15_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI15_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI15_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_GRPPRI_SHIFT)) & DMA_DCHPRI15_GRPPRI_MASK) |
| #define | DMA_DCHPRI15_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI15_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI15_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_DPA_SHIFT)) & DMA_DCHPRI15_DPA_MASK) |
| #define | DMA_DCHPRI15_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI15_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI15_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_ECP_SHIFT)) & DMA_DCHPRI15_ECP_MASK) |
DCHPRI14 - Channel Priority | |
| #define | DMA_DCHPRI14_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI14_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI14_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_CHPRI_SHIFT)) & DMA_DCHPRI14_CHPRI_MASK) |
| #define | DMA_DCHPRI14_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI14_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI14_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_GRPPRI_SHIFT)) & DMA_DCHPRI14_GRPPRI_MASK) |
| #define | DMA_DCHPRI14_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI14_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI14_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_DPA_SHIFT)) & DMA_DCHPRI14_DPA_MASK) |
| #define | DMA_DCHPRI14_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI14_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI14_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_ECP_SHIFT)) & DMA_DCHPRI14_ECP_MASK) |
DCHPRI13 - Channel Priority | |
| #define | DMA_DCHPRI13_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI13_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI13_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_CHPRI_SHIFT)) & DMA_DCHPRI13_CHPRI_MASK) |
| #define | DMA_DCHPRI13_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI13_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI13_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_GRPPRI_SHIFT)) & DMA_DCHPRI13_GRPPRI_MASK) |
| #define | DMA_DCHPRI13_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI13_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI13_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_DPA_SHIFT)) & DMA_DCHPRI13_DPA_MASK) |
| #define | DMA_DCHPRI13_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI13_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI13_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_ECP_SHIFT)) & DMA_DCHPRI13_ECP_MASK) |
DCHPRI12 - Channel Priority | |
| #define | DMA_DCHPRI12_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI12_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI12_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_CHPRI_SHIFT)) & DMA_DCHPRI12_CHPRI_MASK) |
| #define | DMA_DCHPRI12_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI12_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI12_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_GRPPRI_SHIFT)) & DMA_DCHPRI12_GRPPRI_MASK) |
| #define | DMA_DCHPRI12_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI12_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI12_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_DPA_SHIFT)) & DMA_DCHPRI12_DPA_MASK) |
| #define | DMA_DCHPRI12_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI12_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI12_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_ECP_SHIFT)) & DMA_DCHPRI12_ECP_MASK) |
DCHPRI19 - Channel Priority | |
| #define | DMA_DCHPRI19_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI19_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI19_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_CHPRI_SHIFT)) & DMA_DCHPRI19_CHPRI_MASK) |
| #define | DMA_DCHPRI19_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI19_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI19_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_GRPPRI_SHIFT)) & DMA_DCHPRI19_GRPPRI_MASK) |
| #define | DMA_DCHPRI19_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI19_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI19_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_DPA_SHIFT)) & DMA_DCHPRI19_DPA_MASK) |
| #define | DMA_DCHPRI19_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI19_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI19_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_ECP_SHIFT)) & DMA_DCHPRI19_ECP_MASK) |
DCHPRI18 - Channel Priority | |
| #define | DMA_DCHPRI18_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI18_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI18_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_CHPRI_SHIFT)) & DMA_DCHPRI18_CHPRI_MASK) |
| #define | DMA_DCHPRI18_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI18_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI18_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_GRPPRI_SHIFT)) & DMA_DCHPRI18_GRPPRI_MASK) |
| #define | DMA_DCHPRI18_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI18_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI18_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_DPA_SHIFT)) & DMA_DCHPRI18_DPA_MASK) |
| #define | DMA_DCHPRI18_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI18_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI18_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_ECP_SHIFT)) & DMA_DCHPRI18_ECP_MASK) |
DCHPRI17 - Channel Priority | |
| #define | DMA_DCHPRI17_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI17_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI17_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_CHPRI_SHIFT)) & DMA_DCHPRI17_CHPRI_MASK) |
| #define | DMA_DCHPRI17_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI17_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI17_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_GRPPRI_SHIFT)) & DMA_DCHPRI17_GRPPRI_MASK) |
| #define | DMA_DCHPRI17_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI17_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI17_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_DPA_SHIFT)) & DMA_DCHPRI17_DPA_MASK) |
| #define | DMA_DCHPRI17_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI17_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI17_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_ECP_SHIFT)) & DMA_DCHPRI17_ECP_MASK) |
DCHPRI16 - Channel Priority | |
| #define | DMA_DCHPRI16_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI16_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI16_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_CHPRI_SHIFT)) & DMA_DCHPRI16_CHPRI_MASK) |
| #define | DMA_DCHPRI16_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI16_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI16_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_GRPPRI_SHIFT)) & DMA_DCHPRI16_GRPPRI_MASK) |
| #define | DMA_DCHPRI16_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI16_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI16_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_DPA_SHIFT)) & DMA_DCHPRI16_DPA_MASK) |
| #define | DMA_DCHPRI16_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI16_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI16_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_ECP_SHIFT)) & DMA_DCHPRI16_ECP_MASK) |
DCHPRI23 - Channel Priority | |
| #define | DMA_DCHPRI23_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI23_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI23_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_CHPRI_SHIFT)) & DMA_DCHPRI23_CHPRI_MASK) |
| #define | DMA_DCHPRI23_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI23_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI23_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_GRPPRI_SHIFT)) & DMA_DCHPRI23_GRPPRI_MASK) |
| #define | DMA_DCHPRI23_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI23_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI23_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_DPA_SHIFT)) & DMA_DCHPRI23_DPA_MASK) |
| #define | DMA_DCHPRI23_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI23_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI23_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_ECP_SHIFT)) & DMA_DCHPRI23_ECP_MASK) |
DCHPRI22 - Channel Priority | |
| #define | DMA_DCHPRI22_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI22_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI22_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_CHPRI_SHIFT)) & DMA_DCHPRI22_CHPRI_MASK) |
| #define | DMA_DCHPRI22_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI22_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI22_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_GRPPRI_SHIFT)) & DMA_DCHPRI22_GRPPRI_MASK) |
| #define | DMA_DCHPRI22_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI22_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI22_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_DPA_SHIFT)) & DMA_DCHPRI22_DPA_MASK) |
| #define | DMA_DCHPRI22_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI22_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI22_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_ECP_SHIFT)) & DMA_DCHPRI22_ECP_MASK) |
DCHPRI21 - Channel Priority | |
| #define | DMA_DCHPRI21_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI21_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI21_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_CHPRI_SHIFT)) & DMA_DCHPRI21_CHPRI_MASK) |
| #define | DMA_DCHPRI21_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI21_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI21_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_GRPPRI_SHIFT)) & DMA_DCHPRI21_GRPPRI_MASK) |
| #define | DMA_DCHPRI21_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI21_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI21_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_DPA_SHIFT)) & DMA_DCHPRI21_DPA_MASK) |
| #define | DMA_DCHPRI21_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI21_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI21_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_ECP_SHIFT)) & DMA_DCHPRI21_ECP_MASK) |
DCHPRI20 - Channel Priority | |
| #define | DMA_DCHPRI20_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI20_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI20_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_CHPRI_SHIFT)) & DMA_DCHPRI20_CHPRI_MASK) |
| #define | DMA_DCHPRI20_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI20_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI20_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_GRPPRI_SHIFT)) & DMA_DCHPRI20_GRPPRI_MASK) |
| #define | DMA_DCHPRI20_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI20_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI20_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_DPA_SHIFT)) & DMA_DCHPRI20_DPA_MASK) |
| #define | DMA_DCHPRI20_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI20_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI20_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_ECP_SHIFT)) & DMA_DCHPRI20_ECP_MASK) |
DCHPRI27 - Channel Priority | |
| #define | DMA_DCHPRI27_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI27_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI27_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_CHPRI_SHIFT)) & DMA_DCHPRI27_CHPRI_MASK) |
| #define | DMA_DCHPRI27_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI27_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI27_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_GRPPRI_SHIFT)) & DMA_DCHPRI27_GRPPRI_MASK) |
| #define | DMA_DCHPRI27_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI27_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI27_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_DPA_SHIFT)) & DMA_DCHPRI27_DPA_MASK) |
| #define | DMA_DCHPRI27_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI27_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI27_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_ECP_SHIFT)) & DMA_DCHPRI27_ECP_MASK) |
DCHPRI26 - Channel Priority | |
| #define | DMA_DCHPRI26_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI26_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI26_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_CHPRI_SHIFT)) & DMA_DCHPRI26_CHPRI_MASK) |
| #define | DMA_DCHPRI26_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI26_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI26_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_GRPPRI_SHIFT)) & DMA_DCHPRI26_GRPPRI_MASK) |
| #define | DMA_DCHPRI26_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI26_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI26_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_DPA_SHIFT)) & DMA_DCHPRI26_DPA_MASK) |
| #define | DMA_DCHPRI26_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI26_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI26_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_ECP_SHIFT)) & DMA_DCHPRI26_ECP_MASK) |
DCHPRI25 - Channel Priority | |
| #define | DMA_DCHPRI25_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI25_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI25_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_CHPRI_SHIFT)) & DMA_DCHPRI25_CHPRI_MASK) |
| #define | DMA_DCHPRI25_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI25_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI25_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_GRPPRI_SHIFT)) & DMA_DCHPRI25_GRPPRI_MASK) |
| #define | DMA_DCHPRI25_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI25_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI25_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_DPA_SHIFT)) & DMA_DCHPRI25_DPA_MASK) |
| #define | DMA_DCHPRI25_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI25_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI25_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_ECP_SHIFT)) & DMA_DCHPRI25_ECP_MASK) |
DCHPRI24 - Channel Priority | |
| #define | DMA_DCHPRI24_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI24_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI24_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_CHPRI_SHIFT)) & DMA_DCHPRI24_CHPRI_MASK) |
| #define | DMA_DCHPRI24_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI24_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI24_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_GRPPRI_SHIFT)) & DMA_DCHPRI24_GRPPRI_MASK) |
| #define | DMA_DCHPRI24_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI24_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI24_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_DPA_SHIFT)) & DMA_DCHPRI24_DPA_MASK) |
| #define | DMA_DCHPRI24_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI24_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI24_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_ECP_SHIFT)) & DMA_DCHPRI24_ECP_MASK) |
DCHPRI31 - Channel Priority | |
| #define | DMA_DCHPRI31_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI31_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI31_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_CHPRI_SHIFT)) & DMA_DCHPRI31_CHPRI_MASK) |
| #define | DMA_DCHPRI31_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI31_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI31_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_GRPPRI_SHIFT)) & DMA_DCHPRI31_GRPPRI_MASK) |
| #define | DMA_DCHPRI31_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI31_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI31_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_DPA_SHIFT)) & DMA_DCHPRI31_DPA_MASK) |
| #define | DMA_DCHPRI31_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI31_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI31_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_ECP_SHIFT)) & DMA_DCHPRI31_ECP_MASK) |
DCHPRI30 - Channel Priority | |
| #define | DMA_DCHPRI30_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI30_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI30_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_CHPRI_SHIFT)) & DMA_DCHPRI30_CHPRI_MASK) |
| #define | DMA_DCHPRI30_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI30_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI30_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_GRPPRI_SHIFT)) & DMA_DCHPRI30_GRPPRI_MASK) |
| #define | DMA_DCHPRI30_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI30_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI30_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_DPA_SHIFT)) & DMA_DCHPRI30_DPA_MASK) |
| #define | DMA_DCHPRI30_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI30_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI30_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_ECP_SHIFT)) & DMA_DCHPRI30_ECP_MASK) |
DCHPRI29 - Channel Priority | |
| #define | DMA_DCHPRI29_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI29_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI29_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_CHPRI_SHIFT)) & DMA_DCHPRI29_CHPRI_MASK) |
| #define | DMA_DCHPRI29_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI29_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI29_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_GRPPRI_SHIFT)) & DMA_DCHPRI29_GRPPRI_MASK) |
| #define | DMA_DCHPRI29_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI29_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI29_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_DPA_SHIFT)) & DMA_DCHPRI29_DPA_MASK) |
| #define | DMA_DCHPRI29_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI29_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI29_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_ECP_SHIFT)) & DMA_DCHPRI29_ECP_MASK) |
DCHPRI28 - Channel Priority | |
| #define | DMA_DCHPRI28_CHPRI_MASK (0xFU) |
| #define | DMA_DCHPRI28_CHPRI_SHIFT (0U) |
| #define | DMA_DCHPRI28_CHPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_CHPRI_SHIFT)) & DMA_DCHPRI28_CHPRI_MASK) |
| #define | DMA_DCHPRI28_GRPPRI_MASK (0x30U) |
| #define | DMA_DCHPRI28_GRPPRI_SHIFT (4U) |
| #define | DMA_DCHPRI28_GRPPRI(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_GRPPRI_SHIFT)) & DMA_DCHPRI28_GRPPRI_MASK) |
| #define | DMA_DCHPRI28_DPA_MASK (0x40U) |
| #define | DMA_DCHPRI28_DPA_SHIFT (6U) |
| #define | DMA_DCHPRI28_DPA(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_DPA_SHIFT)) & DMA_DCHPRI28_DPA_MASK) |
| #define | DMA_DCHPRI28_ECP_MASK (0x80U) |
| #define | DMA_DCHPRI28_ECP_SHIFT (7U) |
| #define | DMA_DCHPRI28_ECP(x) (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_ECP_SHIFT)) & DMA_DCHPRI28_ECP_MASK) |
SADDR - TCD Source Address | |
| #define | DMA_SADDR_SADDR_MASK (0xFFFFFFFFU) |
| #define | DMA_SADDR_SADDR_SHIFT (0U) |
| #define | DMA_SADDR_SADDR(x) (((uint32_t)(((uint32_t)(x)) << DMA_SADDR_SADDR_SHIFT)) & DMA_SADDR_SADDR_MASK) |
SOFF - TCD Signed Source Address Offset | |
| #define | DMA_SOFF_SOFF_MASK (0xFFFFU) |
| #define | DMA_SOFF_SOFF_SHIFT (0U) |
| #define | DMA_SOFF_SOFF(x) (((uint16_t)(((uint16_t)(x)) << DMA_SOFF_SOFF_SHIFT)) & DMA_SOFF_SOFF_MASK) |
ATTR - TCD Transfer Attributes | |
| #define | DMA_ATTR_DSIZE_MASK (0x7U) |
| #define | DMA_ATTR_DSIZE_SHIFT (0U) |
| #define | DMA_ATTR_DSIZE(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DSIZE_SHIFT)) & DMA_ATTR_DSIZE_MASK) |
| #define | DMA_ATTR_DMOD_MASK (0xF8U) |
| #define | DMA_ATTR_DMOD_SHIFT (3U) |
| #define | DMA_ATTR_DMOD(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DMOD_SHIFT)) & DMA_ATTR_DMOD_MASK) |
| #define | DMA_ATTR_SSIZE_MASK (0x700U) |
| #define | DMA_ATTR_SSIZE_SHIFT (8U) |
| #define | DMA_ATTR_SSIZE(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SSIZE_SHIFT)) & DMA_ATTR_SSIZE_MASK) |
| #define | DMA_ATTR_SMOD_MASK (0xF800U) |
| #define | DMA_ATTR_SMOD_SHIFT (11U) |
| #define | DMA_ATTR_SMOD(x) (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SMOD_SHIFT)) & DMA_ATTR_SMOD_MASK) |
NBYTES_MLNO - TCD Minor Byte Count (Minor Loop Mapping Disabled) | |
| #define | DMA_NBYTES_MLNO_NBYTES_MASK (0xFFFFFFFFU) |
| #define | DMA_NBYTES_MLNO_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLNO_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLNO_NBYTES_SHIFT)) & DMA_NBYTES_MLNO_NBYTES_MASK) |
NBYTES_MLOFFNO - TCD Signed Minor Loop Offset (Minor Loop Mapping Enabled and Offset Disabled) | |
| #define | DMA_NBYTES_MLOFFNO_NBYTES_MASK (0x3FFFFFFFU) |
| #define | DMA_NBYTES_MLOFFNO_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLOFFNO_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFNO_NBYTES_MASK) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE_MASK (0x40000000U) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE_SHIFT (30U) |
| #define | DMA_NBYTES_MLOFFNO_DMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_DMLOE_MASK) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE_MASK (0x80000000U) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE_SHIFT (31U) |
| #define | DMA_NBYTES_MLOFFNO_SMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_SMLOE_MASK) |
NBYTES_MLOFFYES - TCD Signed Minor Loop Offset (Minor Loop Mapping and Offset Enabled) | |
| #define | DMA_NBYTES_MLOFFYES_NBYTES_MASK (0x3FFU) |
| #define | DMA_NBYTES_MLOFFYES_NBYTES_SHIFT (0U) |
| #define | DMA_NBYTES_MLOFFYES_NBYTES(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFYES_NBYTES_MASK) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF_MASK (0x3FFFFC00U) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF_SHIFT (10U) |
| #define | DMA_NBYTES_MLOFFYES_MLOFF(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_MLOFF_SHIFT)) & DMA_NBYTES_MLOFFYES_MLOFF_MASK) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE_MASK (0x40000000U) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE_SHIFT (30U) |
| #define | DMA_NBYTES_MLOFFYES_DMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_DMLOE_MASK) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE_MASK (0x80000000U) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE_SHIFT (31U) |
| #define | DMA_NBYTES_MLOFFYES_SMLOE(x) (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_SMLOE_MASK) |
SLAST - TCD Last Source Address Adjustment | |
| #define | DMA_SLAST_SLAST_MASK (0xFFFFFFFFU) |
| #define | DMA_SLAST_SLAST_SHIFT (0U) |
| #define | DMA_SLAST_SLAST(x) (((uint32_t)(((uint32_t)(x)) << DMA_SLAST_SLAST_SHIFT)) & DMA_SLAST_SLAST_MASK) |
DADDR - TCD Destination Address | |
| #define | DMA_DADDR_DADDR_MASK (0xFFFFFFFFU) |
| #define | DMA_DADDR_DADDR_SHIFT (0U) |
| #define | DMA_DADDR_DADDR(x) (((uint32_t)(((uint32_t)(x)) << DMA_DADDR_DADDR_SHIFT)) & DMA_DADDR_DADDR_MASK) |
DOFF - TCD Signed Destination Address Offset | |
| #define | DMA_DOFF_DOFF_MASK (0xFFFFU) |
| #define | DMA_DOFF_DOFF_SHIFT (0U) |
| #define | DMA_DOFF_DOFF(x) (((uint16_t)(((uint16_t)(x)) << DMA_DOFF_DOFF_SHIFT)) & DMA_DOFF_DOFF_MASK) |
CITER_ELINKNO - TCD Current Minor Loop Link, Major Loop Count (Channel Linking Disabled) | |
| #define | DMA_CITER_ELINKNO_CITER_MASK (0x7FFFU) |
| #define | DMA_CITER_ELINKNO_CITER_SHIFT (0U) |
| #define | DMA_CITER_ELINKNO_CITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_CITER_SHIFT)) & DMA_CITER_ELINKNO_CITER_MASK) |
| #define | DMA_CITER_ELINKNO_ELINK_MASK (0x8000U) |
| #define | DMA_CITER_ELINKNO_ELINK_SHIFT (15U) |
| #define | DMA_CITER_ELINKNO_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_ELINK_SHIFT)) & DMA_CITER_ELINKNO_ELINK_MASK) |
CITER_ELINKYES - TCD Current Minor Loop Link, Major Loop Count (Channel Linking Enabled) | |
| #define | DMA_CITER_ELINKYES_CITER_MASK (0x1FFU) |
| #define | DMA_CITER_ELINKYES_CITER_SHIFT (0U) |
| #define | DMA_CITER_ELINKYES_CITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_CITER_SHIFT)) & DMA_CITER_ELINKYES_CITER_MASK) |
| #define | DMA_CITER_ELINKYES_LINKCH_MASK (0x3E00U) |
| #define | DMA_CITER_ELINKYES_LINKCH_SHIFT (9U) |
| #define | DMA_CITER_ELINKYES_LINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_LINKCH_SHIFT)) & DMA_CITER_ELINKYES_LINKCH_MASK) |
| #define | DMA_CITER_ELINKYES_ELINK_MASK (0x8000U) |
| #define | DMA_CITER_ELINKYES_ELINK_SHIFT (15U) |
| #define | DMA_CITER_ELINKYES_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_ELINK_SHIFT)) & DMA_CITER_ELINKYES_ELINK_MASK) |
DLAST_SGA - TCD Last Destination Address Adjustment/Scatter Gather Address | |
| #define | DMA_DLAST_SGA_DLASTSGA_MASK (0xFFFFFFFFU) |
| #define | DMA_DLAST_SGA_DLASTSGA_SHIFT (0U) |
| #define | DMA_DLAST_SGA_DLASTSGA(x) (((uint32_t)(((uint32_t)(x)) << DMA_DLAST_SGA_DLASTSGA_SHIFT)) & DMA_DLAST_SGA_DLASTSGA_MASK) |
CSR - TCD Control and Status | |
| #define | DMA_CSR_START_MASK (0x1U) |
| #define | DMA_CSR_START_SHIFT (0U) |
| #define | DMA_CSR_START(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_START_SHIFT)) & DMA_CSR_START_MASK) |
| #define | DMA_CSR_INTMAJOR_MASK (0x2U) |
| #define | DMA_CSR_INTMAJOR_SHIFT (1U) |
| #define | DMA_CSR_INTMAJOR(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTMAJOR_SHIFT)) & DMA_CSR_INTMAJOR_MASK) |
| #define | DMA_CSR_INTHALF_MASK (0x4U) |
| #define | DMA_CSR_INTHALF_SHIFT (2U) |
| #define | DMA_CSR_INTHALF(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTHALF_SHIFT)) & DMA_CSR_INTHALF_MASK) |
| #define | DMA_CSR_DREQ_MASK (0x8U) |
| #define | DMA_CSR_DREQ_SHIFT (3U) |
| #define | DMA_CSR_DREQ(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DREQ_SHIFT)) & DMA_CSR_DREQ_MASK) |
| #define | DMA_CSR_ESG_MASK (0x10U) |
| #define | DMA_CSR_ESG_SHIFT (4U) |
| #define | DMA_CSR_ESG(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ESG_SHIFT)) & DMA_CSR_ESG_MASK) |
| #define | DMA_CSR_MAJORELINK_MASK (0x20U) |
| #define | DMA_CSR_MAJORELINK_SHIFT (5U) |
| #define | DMA_CSR_MAJORELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORELINK_SHIFT)) & DMA_CSR_MAJORELINK_MASK) |
| #define | DMA_CSR_ACTIVE_MASK (0x40U) |
| #define | DMA_CSR_ACTIVE_SHIFT (6U) |
| #define | DMA_CSR_ACTIVE(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ACTIVE_SHIFT)) & DMA_CSR_ACTIVE_MASK) |
| #define | DMA_CSR_DONE_MASK (0x80U) |
| #define | DMA_CSR_DONE_SHIFT (7U) |
| #define | DMA_CSR_DONE(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DONE_SHIFT)) & DMA_CSR_DONE_MASK) |
| #define | DMA_CSR_MAJORLINKCH_MASK (0x1F00U) |
| #define | DMA_CSR_MAJORLINKCH_SHIFT (8U) |
| #define | DMA_CSR_MAJORLINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORLINKCH_SHIFT)) & DMA_CSR_MAJORLINKCH_MASK) |
| #define | DMA_CSR_BWC_MASK (0xC000U) |
| #define | DMA_CSR_BWC_SHIFT (14U) |
| #define | DMA_CSR_BWC(x) (((uint16_t)(((uint16_t)(x)) << DMA_CSR_BWC_SHIFT)) & DMA_CSR_BWC_MASK) |
BITER_ELINKNO - TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Disabled) | |
| #define | DMA_BITER_ELINKNO_BITER_MASK (0x7FFFU) |
| #define | DMA_BITER_ELINKNO_BITER_SHIFT (0U) |
| #define | DMA_BITER_ELINKNO_BITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_BITER_SHIFT)) & DMA_BITER_ELINKNO_BITER_MASK) |
| #define | DMA_BITER_ELINKNO_ELINK_MASK (0x8000U) |
| #define | DMA_BITER_ELINKNO_ELINK_SHIFT (15U) |
| #define | DMA_BITER_ELINKNO_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_ELINK_SHIFT)) & DMA_BITER_ELINKNO_ELINK_MASK) |
BITER_ELINKYES - TCD Beginning Minor Loop Link, Major Loop Count (Channel Linking Enabled) | |
| #define | DMA_BITER_ELINKYES_BITER_MASK (0x1FFU) |
| #define | DMA_BITER_ELINKYES_BITER_SHIFT (0U) |
| #define | DMA_BITER_ELINKYES_BITER(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_BITER_SHIFT)) & DMA_BITER_ELINKYES_BITER_MASK) |
| #define | DMA_BITER_ELINKYES_LINKCH_MASK (0x3E00U) |
| #define | DMA_BITER_ELINKYES_LINKCH_SHIFT (9U) |
| #define | DMA_BITER_ELINKYES_LINKCH(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_LINKCH_SHIFT)) & DMA_BITER_ELINKYES_LINKCH_MASK) |
| #define | DMA_BITER_ELINKYES_ELINK_MASK (0x8000U) |
| #define | DMA_BITER_ELINKYES_ELINK_SHIFT (15U) |
| #define | DMA_BITER_ELINKYES_ELINK(x) (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_ELINK_SHIFT)) & DMA_BITER_ELINKYES_ELINK_MASK) |
| #define DMA_ATTR_DMOD | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DMOD_SHIFT)) & DMA_ATTR_DMOD_MASK) |
DMOD - Destination Address Modulo
| #define DMA_ATTR_DSIZE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_DSIZE_SHIFT)) & DMA_ATTR_DSIZE_MASK) |
DSIZE - Destination data transfer size
| #define DMA_ATTR_SMOD | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SMOD_SHIFT)) & DMA_ATTR_SMOD_MASK) |
SMOD - Source Address Modulo 0b00000..Source address modulo feature is disabled 0b00001-0b11111..Value defines address range used to set up circular data queue
| #define DMA_ATTR_SSIZE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_ATTR_SSIZE_SHIFT)) & DMA_ATTR_SSIZE_MASK) |
SSIZE - Source data transfer size 0b000..8-bit 0b001..16-bit 0b010..32-bit 0b011..64-bit 0b100..Reserved 0b101..32-byte burst (4 beats of 64 bits) 0b110..Reserved 0b111..Reserved
| #define DMA_BITER_ELINKNO_BITER | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_BITER_SHIFT)) & DMA_BITER_ELINKNO_BITER_MASK) |
BITER - Starting Major Iteration Count
| #define DMA_BITER_ELINKNO_ELINK | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKNO_ELINK_SHIFT)) & DMA_BITER_ELINKNO_ELINK_MASK) |
ELINK - Enables channel-to-channel linking on minor loop complete 0b0..Channel-to-channel linking is disabled 0b1..Channel-to-channel linking is enabled
| #define DMA_BITER_ELINKYES_BITER | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_BITER_SHIFT)) & DMA_BITER_ELINKYES_BITER_MASK) |
BITER - Starting major iteration count
| #define DMA_BITER_ELINKYES_ELINK | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_ELINK_SHIFT)) & DMA_BITER_ELINKYES_ELINK_MASK) |
| #define DMA_BITER_ELINKYES_LINKCH | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_BITER_ELINKYES_LINKCH_SHIFT)) & DMA_BITER_ELINKYES_LINKCH_MASK) |
LINKCH - Link Channel Number
| #define DMA_CDNE_CADN | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CADN_SHIFT)) & DMA_CDNE_CADN_MASK) |
CADN - Clears All DONE fields 0b0..Writes 0 to only the TCDn_CSR[DONE] field specified in the CDNE field 0b1..Writes 0 to all bits in TCDn_CSR[DONE]
| #define DMA_CDNE_CDNE | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_CDNE_SHIFT)) & DMA_CDNE_CDNE_MASK) |
CDNE - Clear DONE field
| #define DMA_CDNE_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CDNE_NOP_SHIFT)) & DMA_CDNE_NOP_MASK) |
NOP - No Op Enable 0b0..Normal operation 0b1..No operation; all other fields in this register are ignored.
| #define DMA_CEEI_CAEE | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CAEE_SHIFT)) & DMA_CEEI_CAEE_MASK) |
CAEE - Clear All Enable Error Interrupts 0b0..Write 0 only to the EEI field specified in the CEEI field 0b1..Write 0 to all fields in EEI
| #define DMA_CEEI_CEEI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_CEEI_SHIFT)) & DMA_CEEI_CEEI_MASK) |
CEEI - Clear Enable Error Interrupt
| #define DMA_CEEI_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CEEI_NOP_SHIFT)) & DMA_CEEI_NOP_MASK) |
NOP - No Op Enable 0b0..Normal operation 0b1..No operation, ignore the other fields in this register
| #define DMA_CERQ_CAER | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CAER_SHIFT)) & DMA_CERQ_CAER_MASK) |
CAER - Clear All Enable Requests 0b0..Write 0 to only the ERQ field specified in the CERQ field 0b1..Write 0 to all fields in ERQ
| #define DMA_CERQ_CERQ | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_CERQ_SHIFT)) & DMA_CERQ_CERQ_MASK) |
CERQ - Clear Enable Request
| #define DMA_CERQ_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CERQ_NOP_SHIFT)) & DMA_CERQ_NOP_MASK) |
| #define DMA_CERR_CAEI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CAEI_SHIFT)) & DMA_CERR_CAEI_MASK) |
CAEI - Clear All Error Indicators 0b0..Write 0 to only the ERR field specified in the CERR field 0b1..Write 0 to all fields in ERR
| #define DMA_CERR_CERR | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CERR_CERR_SHIFT)) & DMA_CERR_CERR_MASK) |
CERR - Clear Error Indicator
| #define DMA_CERR_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CERR_NOP_SHIFT)) & DMA_CERR_NOP_MASK) |
| #define DMA_CINT_CAIR | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CAIR_SHIFT)) & DMA_CINT_CAIR_MASK) |
CAIR - Clear All Interrupt Requests 0b0..Clear only the INT field specified in the CINT field 0b1..Clear all bits in INT
| #define DMA_CINT_CINT | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CINT_CINT_SHIFT)) & DMA_CINT_CINT_MASK) |
CINT - Clear Interrupt Request
| #define DMA_CINT_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_CINT_NOP_SHIFT)) & DMA_CINT_NOP_MASK) |
| #define DMA_CITER_ELINKNO_CITER | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_CITER_SHIFT)) & DMA_CITER_ELINKNO_CITER_MASK) |
CITER - Current Major Iteration Count
| #define DMA_CITER_ELINKNO_ELINK | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKNO_ELINK_SHIFT)) & DMA_CITER_ELINKNO_ELINK_MASK) |
ELINK - Enable channel-to-channel linking on minor-loop complete 0b0..Channel-to-channel linking is disabled 0b1..Channel-to-channel linking is enabled
| #define DMA_CITER_ELINKYES_CITER | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_CITER_SHIFT)) & DMA_CITER_ELINKYES_CITER_MASK) |
| #define DMA_CITER_ELINKYES_ELINK | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_ELINK_SHIFT)) & DMA_CITER_ELINKYES_ELINK_MASK) |
| #define DMA_CITER_ELINKYES_LINKCH | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CITER_ELINKYES_LINKCH_SHIFT)) & DMA_CITER_ELINKYES_LINKCH_MASK) |
LINKCH - Minor Loop Link Channel Number
| #define DMA_CR_ACTIVE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_ACTIVE_SHIFT)) & DMA_CR_ACTIVE_MASK) |
ACTIVE - eDMA Active Status 0b0..eDMA is idle 0b1..eDMA is executing a channel
| #define DMA_CR_CLM | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_CLM_SHIFT)) & DMA_CR_CLM_MASK) |
CLM - Continuous Link Mode 0b0..Continuous link mode is off 0b1..Continuous link mode is on
| #define DMA_CR_CX | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_CX_SHIFT)) & DMA_CR_CX_MASK) |
CX - Cancel Transfer 0b0..Normal operation 0b1..Cancel the remaining data transfer
| #define DMA_CR_ECX | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_ECX_SHIFT)) & DMA_CR_ECX_MASK) |
ECX - Error Cancel Transfer 0b0..Normal operation 0b1..Cancel the remaining data transfer
| #define DMA_CR_EDBG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_EDBG_SHIFT)) & DMA_CR_EDBG_MASK) |
EDBG - Enable Debug 0b0..When the chip is in Debug mode, the eDMA continues to operate. 0b1..Entry of the chip into Debug mode is effective
EDBG - Enable Debug 0b0..When the chip is in Debug mode, the eDMA continues to operate. 0b1..When the chip is in debug mode, the DMA stalls the start of a new channel. Executing channels are allowed to complete.
| #define DMA_CR_EMLM | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_EMLM_SHIFT)) & DMA_CR_EMLM_MASK) |
EMLM - Enable Minor Loop Mapping 0b0..Disabled 0b1..Enabled
| #define DMA_CR_ERCA | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERCA_SHIFT)) & DMA_CR_ERCA_MASK) |
ERCA - Enable Round Robin Channel Arbitration 0b0..Fixed priority arbitration within each group 0b1..Round robin arbitration within each group
| #define DMA_CR_ERGA | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_ERGA_SHIFT)) & DMA_CR_ERGA_MASK) |
ERGA - Enable Round Robin Group Arbitration 0b0..Fixed priority arbitration 0b1..Round robin arbitration
| #define DMA_CR_GRP0PRI | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP0PRI_SHIFT)) & DMA_CR_GRP0PRI_MASK) |
GRP0PRI - Channel Group 0 Priority
| #define DMA_CR_GRP1PRI | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_GRP1PRI_SHIFT)) & DMA_CR_GRP1PRI_MASK) |
GRP1PRI - Channel Group 1 Priority
| #define DMA_CR_HALT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_HALT_SHIFT)) & DMA_CR_HALT_MASK) |
HALT - Halt eDMA Operations 0b0..Normal operation 0b1..eDMA operations halted
| #define DMA_CR_HOE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_HOE_SHIFT)) & DMA_CR_HOE_MASK) |
HOE - Halt On Error 0b0..Normal operation 0b1..Error causes HALT field to be automatically set to 1
| #define DMA_CR_VERSION | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_CR_VERSION_SHIFT)) & DMA_CR_VERSION_MASK) |
VERSION - eDMA version number
| #define DMA_CSR_ACTIVE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ACTIVE_SHIFT)) & DMA_CSR_ACTIVE_MASK) |
ACTIVE - Channel Active
| #define DMA_CSR_BWC | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_BWC_SHIFT)) & DMA_CSR_BWC_MASK) |
BWC - Bandwidth Control 0b00..No eDMA engine stalls 0b01..Reserved 0b10..eDMA engine stalls for 4 cycles after each R/W 0b11..eDMA engine stalls for 8 cycles after each R/W
| #define DMA_CSR_DONE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DONE_SHIFT)) & DMA_CSR_DONE_MASK) |
DONE - Channel Done
DONE - Channel Done
DONE - Channel Done
| #define DMA_CSR_DREQ | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_DREQ_SHIFT)) & DMA_CSR_DREQ_MASK) |
DREQ - Disable Request 0b0..The channel's ERQ field is not affected 0b1..The channel's ERQ field value changes to 0 when the major loop is complete
| #define DMA_CSR_ESG | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_ESG_SHIFT)) & DMA_CSR_ESG_MASK) |
ESG - Enable Scatter/Gather Processing 0b0..The current channel's TCD is normal format 0b1..The current channel's TCD specifies a scatter gather format
| #define DMA_CSR_INTHALF | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTHALF_SHIFT)) & DMA_CSR_INTHALF_MASK) |
INTHALF - Enable an interrupt when major counter is half complete. 0b0..Half-point interrupt is disabled 0b1..Half-point interrupt is enabled
| #define DMA_CSR_INTMAJOR | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_INTMAJOR_SHIFT)) & DMA_CSR_INTMAJOR_MASK) |
INTMAJOR - Enable an interrupt when major iteration count completes. 0b0..End of major loop interrupt is disabled 0b1..End of major loop interrupt is enabled
| #define DMA_CSR_MAJORELINK | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORELINK_SHIFT)) & DMA_CSR_MAJORELINK_MASK) |
MAJORELINK - Enable channel-to-channel linking on major loop complete 0b0..Channel-to-channel linking is disabled 0b1..Channel-to-channel linking is enabled
| #define DMA_CSR_MAJORLINKCH | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_MAJORLINKCH_SHIFT)) & DMA_CSR_MAJORLINKCH_MASK) |
MAJORLINKCH - Major Loop Link Channel Number
| #define DMA_CSR_START | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_CSR_START_SHIFT)) & DMA_CSR_START_MASK) |
START - Channel Start 0b0..Channel is not explicitly started 0b1..Channel is explicitly started via a software initiated service request
| #define DMA_DADDR_DADDR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_DADDR_DADDR_SHIFT)) & DMA_DADDR_DADDR_MASK) |
DADDR - Destination Address
| #define DMA_DCHPRI0_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_CHPRI_SHIFT)) & DMA_DCHPRI0_CHPRI_MASK) |
CHPRI - Channel n Arbitration Priority
| #define DMA_DCHPRI0_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_DPA_SHIFT)) & DMA_DCHPRI0_DPA_MASK) |
DPA - Disable Preempt Ability. This field resets to 0. 0b0..Channel n can suspend a lower priority channel 0b1..Channel n cannot suspend any channel, regardless of channel priority
| #define DMA_DCHPRI0_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_ECP_SHIFT)) & DMA_DCHPRI0_ECP_MASK) |
ECP - Enable Channel Preemption. This field resets to 0. 0b0..Channel n cannot be suspended by a higher priority channel's service request 0b1..Channel n can be temporarily suspended by the service request of a higher priority channel
| #define DMA_DCHPRI0_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI0_GRPPRI_SHIFT)) & DMA_DCHPRI0_GRPPRI_MASK) |
GRPPRI - Channel n Current Group Priority
| #define DMA_DCHPRI10_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_CHPRI_SHIFT)) & DMA_DCHPRI10_CHPRI_MASK) |
| #define DMA_DCHPRI10_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_DPA_SHIFT)) & DMA_DCHPRI10_DPA_MASK) |
| #define DMA_DCHPRI10_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_ECP_SHIFT)) & DMA_DCHPRI10_ECP_MASK) |
| #define DMA_DCHPRI10_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI10_GRPPRI_SHIFT)) & DMA_DCHPRI10_GRPPRI_MASK) |
| #define DMA_DCHPRI11_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_CHPRI_SHIFT)) & DMA_DCHPRI11_CHPRI_MASK) |
| #define DMA_DCHPRI11_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_DPA_SHIFT)) & DMA_DCHPRI11_DPA_MASK) |
| #define DMA_DCHPRI11_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_ECP_SHIFT)) & DMA_DCHPRI11_ECP_MASK) |
| #define DMA_DCHPRI11_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI11_GRPPRI_SHIFT)) & DMA_DCHPRI11_GRPPRI_MASK) |
| #define DMA_DCHPRI12_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_CHPRI_SHIFT)) & DMA_DCHPRI12_CHPRI_MASK) |
| #define DMA_DCHPRI12_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_DPA_SHIFT)) & DMA_DCHPRI12_DPA_MASK) |
| #define DMA_DCHPRI12_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_ECP_SHIFT)) & DMA_DCHPRI12_ECP_MASK) |
| #define DMA_DCHPRI12_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI12_GRPPRI_SHIFT)) & DMA_DCHPRI12_GRPPRI_MASK) |
| #define DMA_DCHPRI13_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_CHPRI_SHIFT)) & DMA_DCHPRI13_CHPRI_MASK) |
| #define DMA_DCHPRI13_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_DPA_SHIFT)) & DMA_DCHPRI13_DPA_MASK) |
| #define DMA_DCHPRI13_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_ECP_SHIFT)) & DMA_DCHPRI13_ECP_MASK) |
| #define DMA_DCHPRI13_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI13_GRPPRI_SHIFT)) & DMA_DCHPRI13_GRPPRI_MASK) |
| #define DMA_DCHPRI14_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_CHPRI_SHIFT)) & DMA_DCHPRI14_CHPRI_MASK) |
| #define DMA_DCHPRI14_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_DPA_SHIFT)) & DMA_DCHPRI14_DPA_MASK) |
| #define DMA_DCHPRI14_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_ECP_SHIFT)) & DMA_DCHPRI14_ECP_MASK) |
| #define DMA_DCHPRI14_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI14_GRPPRI_SHIFT)) & DMA_DCHPRI14_GRPPRI_MASK) |
| #define DMA_DCHPRI15_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_CHPRI_SHIFT)) & DMA_DCHPRI15_CHPRI_MASK) |
| #define DMA_DCHPRI15_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_DPA_SHIFT)) & DMA_DCHPRI15_DPA_MASK) |
| #define DMA_DCHPRI15_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_ECP_SHIFT)) & DMA_DCHPRI15_ECP_MASK) |
| #define DMA_DCHPRI15_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI15_GRPPRI_SHIFT)) & DMA_DCHPRI15_GRPPRI_MASK) |
| #define DMA_DCHPRI16_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_CHPRI_SHIFT)) & DMA_DCHPRI16_CHPRI_MASK) |
| #define DMA_DCHPRI16_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_DPA_SHIFT)) & DMA_DCHPRI16_DPA_MASK) |
| #define DMA_DCHPRI16_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_ECP_SHIFT)) & DMA_DCHPRI16_ECP_MASK) |
| #define DMA_DCHPRI16_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI16_GRPPRI_SHIFT)) & DMA_DCHPRI16_GRPPRI_MASK) |
| #define DMA_DCHPRI17_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_CHPRI_SHIFT)) & DMA_DCHPRI17_CHPRI_MASK) |
| #define DMA_DCHPRI17_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_DPA_SHIFT)) & DMA_DCHPRI17_DPA_MASK) |
| #define DMA_DCHPRI17_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_ECP_SHIFT)) & DMA_DCHPRI17_ECP_MASK) |
| #define DMA_DCHPRI17_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI17_GRPPRI_SHIFT)) & DMA_DCHPRI17_GRPPRI_MASK) |
| #define DMA_DCHPRI18_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_CHPRI_SHIFT)) & DMA_DCHPRI18_CHPRI_MASK) |
| #define DMA_DCHPRI18_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_DPA_SHIFT)) & DMA_DCHPRI18_DPA_MASK) |
| #define DMA_DCHPRI18_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_ECP_SHIFT)) & DMA_DCHPRI18_ECP_MASK) |
| #define DMA_DCHPRI18_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI18_GRPPRI_SHIFT)) & DMA_DCHPRI18_GRPPRI_MASK) |
| #define DMA_DCHPRI19_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_CHPRI_SHIFT)) & DMA_DCHPRI19_CHPRI_MASK) |
| #define DMA_DCHPRI19_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_DPA_SHIFT)) & DMA_DCHPRI19_DPA_MASK) |
| #define DMA_DCHPRI19_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_ECP_SHIFT)) & DMA_DCHPRI19_ECP_MASK) |
| #define DMA_DCHPRI19_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI19_GRPPRI_SHIFT)) & DMA_DCHPRI19_GRPPRI_MASK) |
| #define DMA_DCHPRI1_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_CHPRI_SHIFT)) & DMA_DCHPRI1_CHPRI_MASK) |
| #define DMA_DCHPRI1_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_DPA_SHIFT)) & DMA_DCHPRI1_DPA_MASK) |
| #define DMA_DCHPRI1_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_ECP_SHIFT)) & DMA_DCHPRI1_ECP_MASK) |
| #define DMA_DCHPRI1_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI1_GRPPRI_SHIFT)) & DMA_DCHPRI1_GRPPRI_MASK) |
| #define DMA_DCHPRI20_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_CHPRI_SHIFT)) & DMA_DCHPRI20_CHPRI_MASK) |
| #define DMA_DCHPRI20_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_DPA_SHIFT)) & DMA_DCHPRI20_DPA_MASK) |
| #define DMA_DCHPRI20_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_ECP_SHIFT)) & DMA_DCHPRI20_ECP_MASK) |
| #define DMA_DCHPRI20_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI20_GRPPRI_SHIFT)) & DMA_DCHPRI20_GRPPRI_MASK) |
| #define DMA_DCHPRI21_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_CHPRI_SHIFT)) & DMA_DCHPRI21_CHPRI_MASK) |
| #define DMA_DCHPRI21_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_DPA_SHIFT)) & DMA_DCHPRI21_DPA_MASK) |
| #define DMA_DCHPRI21_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_ECP_SHIFT)) & DMA_DCHPRI21_ECP_MASK) |
| #define DMA_DCHPRI21_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI21_GRPPRI_SHIFT)) & DMA_DCHPRI21_GRPPRI_MASK) |
| #define DMA_DCHPRI22_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_CHPRI_SHIFT)) & DMA_DCHPRI22_CHPRI_MASK) |
| #define DMA_DCHPRI22_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_DPA_SHIFT)) & DMA_DCHPRI22_DPA_MASK) |
| #define DMA_DCHPRI22_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_ECP_SHIFT)) & DMA_DCHPRI22_ECP_MASK) |
| #define DMA_DCHPRI22_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI22_GRPPRI_SHIFT)) & DMA_DCHPRI22_GRPPRI_MASK) |
| #define DMA_DCHPRI23_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_CHPRI_SHIFT)) & DMA_DCHPRI23_CHPRI_MASK) |
| #define DMA_DCHPRI23_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_DPA_SHIFT)) & DMA_DCHPRI23_DPA_MASK) |
| #define DMA_DCHPRI23_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_ECP_SHIFT)) & DMA_DCHPRI23_ECP_MASK) |
| #define DMA_DCHPRI23_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI23_GRPPRI_SHIFT)) & DMA_DCHPRI23_GRPPRI_MASK) |
| #define DMA_DCHPRI24_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_CHPRI_SHIFT)) & DMA_DCHPRI24_CHPRI_MASK) |
| #define DMA_DCHPRI24_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_DPA_SHIFT)) & DMA_DCHPRI24_DPA_MASK) |
| #define DMA_DCHPRI24_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_ECP_SHIFT)) & DMA_DCHPRI24_ECP_MASK) |
| #define DMA_DCHPRI24_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI24_GRPPRI_SHIFT)) & DMA_DCHPRI24_GRPPRI_MASK) |
| #define DMA_DCHPRI25_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_CHPRI_SHIFT)) & DMA_DCHPRI25_CHPRI_MASK) |
| #define DMA_DCHPRI25_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_DPA_SHIFT)) & DMA_DCHPRI25_DPA_MASK) |
| #define DMA_DCHPRI25_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_ECP_SHIFT)) & DMA_DCHPRI25_ECP_MASK) |
| #define DMA_DCHPRI25_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI25_GRPPRI_SHIFT)) & DMA_DCHPRI25_GRPPRI_MASK) |
| #define DMA_DCHPRI26_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_CHPRI_SHIFT)) & DMA_DCHPRI26_CHPRI_MASK) |
| #define DMA_DCHPRI26_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_DPA_SHIFT)) & DMA_DCHPRI26_DPA_MASK) |
| #define DMA_DCHPRI26_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_ECP_SHIFT)) & DMA_DCHPRI26_ECP_MASK) |
| #define DMA_DCHPRI26_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI26_GRPPRI_SHIFT)) & DMA_DCHPRI26_GRPPRI_MASK) |
| #define DMA_DCHPRI27_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_CHPRI_SHIFT)) & DMA_DCHPRI27_CHPRI_MASK) |
| #define DMA_DCHPRI27_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_DPA_SHIFT)) & DMA_DCHPRI27_DPA_MASK) |
| #define DMA_DCHPRI27_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_ECP_SHIFT)) & DMA_DCHPRI27_ECP_MASK) |
| #define DMA_DCHPRI27_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI27_GRPPRI_SHIFT)) & DMA_DCHPRI27_GRPPRI_MASK) |
| #define DMA_DCHPRI28_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_CHPRI_SHIFT)) & DMA_DCHPRI28_CHPRI_MASK) |
| #define DMA_DCHPRI28_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_DPA_SHIFT)) & DMA_DCHPRI28_DPA_MASK) |
| #define DMA_DCHPRI28_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_ECP_SHIFT)) & DMA_DCHPRI28_ECP_MASK) |
| #define DMA_DCHPRI28_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI28_GRPPRI_SHIFT)) & DMA_DCHPRI28_GRPPRI_MASK) |
| #define DMA_DCHPRI29_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_CHPRI_SHIFT)) & DMA_DCHPRI29_CHPRI_MASK) |
| #define DMA_DCHPRI29_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_DPA_SHIFT)) & DMA_DCHPRI29_DPA_MASK) |
| #define DMA_DCHPRI29_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_ECP_SHIFT)) & DMA_DCHPRI29_ECP_MASK) |
| #define DMA_DCHPRI29_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI29_GRPPRI_SHIFT)) & DMA_DCHPRI29_GRPPRI_MASK) |
| #define DMA_DCHPRI2_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_CHPRI_SHIFT)) & DMA_DCHPRI2_CHPRI_MASK) |
| #define DMA_DCHPRI2_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_DPA_SHIFT)) & DMA_DCHPRI2_DPA_MASK) |
| #define DMA_DCHPRI2_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_ECP_SHIFT)) & DMA_DCHPRI2_ECP_MASK) |
| #define DMA_DCHPRI2_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI2_GRPPRI_SHIFT)) & DMA_DCHPRI2_GRPPRI_MASK) |
| #define DMA_DCHPRI30_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_CHPRI_SHIFT)) & DMA_DCHPRI30_CHPRI_MASK) |
| #define DMA_DCHPRI30_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_DPA_SHIFT)) & DMA_DCHPRI30_DPA_MASK) |
| #define DMA_DCHPRI30_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_ECP_SHIFT)) & DMA_DCHPRI30_ECP_MASK) |
| #define DMA_DCHPRI30_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI30_GRPPRI_SHIFT)) & DMA_DCHPRI30_GRPPRI_MASK) |
| #define DMA_DCHPRI31_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_CHPRI_SHIFT)) & DMA_DCHPRI31_CHPRI_MASK) |
| #define DMA_DCHPRI31_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_DPA_SHIFT)) & DMA_DCHPRI31_DPA_MASK) |
| #define DMA_DCHPRI31_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_ECP_SHIFT)) & DMA_DCHPRI31_ECP_MASK) |
| #define DMA_DCHPRI31_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI31_GRPPRI_SHIFT)) & DMA_DCHPRI31_GRPPRI_MASK) |
| #define DMA_DCHPRI3_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_CHPRI_SHIFT)) & DMA_DCHPRI3_CHPRI_MASK) |
| #define DMA_DCHPRI3_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_DPA_SHIFT)) & DMA_DCHPRI3_DPA_MASK) |
| #define DMA_DCHPRI3_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_ECP_SHIFT)) & DMA_DCHPRI3_ECP_MASK) |
| #define DMA_DCHPRI3_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI3_GRPPRI_SHIFT)) & DMA_DCHPRI3_GRPPRI_MASK) |
| #define DMA_DCHPRI4_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_CHPRI_SHIFT)) & DMA_DCHPRI4_CHPRI_MASK) |
| #define DMA_DCHPRI4_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_DPA_SHIFT)) & DMA_DCHPRI4_DPA_MASK) |
| #define DMA_DCHPRI4_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_ECP_SHIFT)) & DMA_DCHPRI4_ECP_MASK) |
| #define DMA_DCHPRI4_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI4_GRPPRI_SHIFT)) & DMA_DCHPRI4_GRPPRI_MASK) |
| #define DMA_DCHPRI5_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_CHPRI_SHIFT)) & DMA_DCHPRI5_CHPRI_MASK) |
| #define DMA_DCHPRI5_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_DPA_SHIFT)) & DMA_DCHPRI5_DPA_MASK) |
| #define DMA_DCHPRI5_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_ECP_SHIFT)) & DMA_DCHPRI5_ECP_MASK) |
| #define DMA_DCHPRI5_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI5_GRPPRI_SHIFT)) & DMA_DCHPRI5_GRPPRI_MASK) |
| #define DMA_DCHPRI6_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_CHPRI_SHIFT)) & DMA_DCHPRI6_CHPRI_MASK) |
| #define DMA_DCHPRI6_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_DPA_SHIFT)) & DMA_DCHPRI6_DPA_MASK) |
| #define DMA_DCHPRI6_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_ECP_SHIFT)) & DMA_DCHPRI6_ECP_MASK) |
| #define DMA_DCHPRI6_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI6_GRPPRI_SHIFT)) & DMA_DCHPRI6_GRPPRI_MASK) |
| #define DMA_DCHPRI7_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_CHPRI_SHIFT)) & DMA_DCHPRI7_CHPRI_MASK) |
| #define DMA_DCHPRI7_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_DPA_SHIFT)) & DMA_DCHPRI7_DPA_MASK) |
| #define DMA_DCHPRI7_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_ECP_SHIFT)) & DMA_DCHPRI7_ECP_MASK) |
| #define DMA_DCHPRI7_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI7_GRPPRI_SHIFT)) & DMA_DCHPRI7_GRPPRI_MASK) |
| #define DMA_DCHPRI8_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_CHPRI_SHIFT)) & DMA_DCHPRI8_CHPRI_MASK) |
| #define DMA_DCHPRI8_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_DPA_SHIFT)) & DMA_DCHPRI8_DPA_MASK) |
| #define DMA_DCHPRI8_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_ECP_SHIFT)) & DMA_DCHPRI8_ECP_MASK) |
| #define DMA_DCHPRI8_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI8_GRPPRI_SHIFT)) & DMA_DCHPRI8_GRPPRI_MASK) |
| #define DMA_DCHPRI9_CHPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_CHPRI_SHIFT)) & DMA_DCHPRI9_CHPRI_MASK) |
| #define DMA_DCHPRI9_DPA | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_DPA_SHIFT)) & DMA_DCHPRI9_DPA_MASK) |
| #define DMA_DCHPRI9_ECP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_ECP_SHIFT)) & DMA_DCHPRI9_ECP_MASK) |
| #define DMA_DCHPRI9_GRPPRI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_DCHPRI9_GRPPRI_SHIFT)) & DMA_DCHPRI9_GRPPRI_MASK) |
| #define DMA_DLAST_SGA_DLASTSGA | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_DLAST_SGA_DLASTSGA_SHIFT)) & DMA_DLAST_SGA_DLASTSGA_MASK) |
DLASTSGA - Destination last address adjustment, or next memory address TCD for channel (scatter/gather)
| #define DMA_DOFF_DOFF | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_DOFF_DOFF_SHIFT)) & DMA_DOFF_DOFF_MASK) |
DOFF - Destination Address Signed Offset
| #define DMA_EARS_EDREQ_0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_0_SHIFT)) & DMA_EARS_EDREQ_0_MASK) |
EDREQ_0 - Enable asynchronous DMA request in stop mode for channel 0. 0b0..Disable asynchronous DMA request for channel 0 0b1..Enable asynchronous DMA request for channel 0
| #define DMA_EARS_EDREQ_1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_1_SHIFT)) & DMA_EARS_EDREQ_1_MASK) |
EDREQ_1 - Enable asynchronous DMA request in stop mode for channel 1. 0b0..Disable asynchronous DMA request for channel 1 0b1..Enable asynchronous DMA request for channel 1
| #define DMA_EARS_EDREQ_10 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_10_SHIFT)) & DMA_EARS_EDREQ_10_MASK) |
EDREQ_10 - Enable asynchronous DMA request in stop mode for channel 10. 0b0..Disable asynchronous DMA request for channel 10 0b1..Enable asynchronous DMA request for channel 10
| #define DMA_EARS_EDREQ_11 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_11_SHIFT)) & DMA_EARS_EDREQ_11_MASK) |
EDREQ_11 - Enable asynchronous DMA request in stop mode for channel 11. 0b0..Disable asynchronous DMA request for channel 11 0b1..Enable asynchronous DMA request for channel 11
| #define DMA_EARS_EDREQ_12 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_12_SHIFT)) & DMA_EARS_EDREQ_12_MASK) |
EDREQ_12 - Enable asynchronous DMA request in stop mode for channel 12. 0b0..Disable asynchronous DMA request for channel 12 0b1..Enable asynchronous DMA request for channel 12
| #define DMA_EARS_EDREQ_13 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_13_SHIFT)) & DMA_EARS_EDREQ_13_MASK) |
EDREQ_13 - Enable asynchronous DMA request in stop mode for channel 13. 0b0..Disable asynchronous DMA request for channel 13 0b1..Enable asynchronous DMA request for channel 13
| #define DMA_EARS_EDREQ_14 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_14_SHIFT)) & DMA_EARS_EDREQ_14_MASK) |
EDREQ_14 - Enable asynchronous DMA request in stop mode for channel 14. 0b0..Disable asynchronous DMA request for channel 14 0b1..Enable asynchronous DMA request for channel 14
| #define DMA_EARS_EDREQ_15 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_15_SHIFT)) & DMA_EARS_EDREQ_15_MASK) |
EDREQ_15 - Enable asynchronous DMA request in stop mode for channel 15. 0b0..Disable asynchronous DMA request for channel 15 0b1..Enable asynchronous DMA request for channel 15
| #define DMA_EARS_EDREQ_16 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_16_SHIFT)) & DMA_EARS_EDREQ_16_MASK) |
EDREQ_16 - Enable asynchronous DMA request in stop mode for channel 16. 0b0..Disable asynchronous DMA request for channel 16 0b1..Enable asynchronous DMA request for channel 16
| #define DMA_EARS_EDREQ_17 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_17_SHIFT)) & DMA_EARS_EDREQ_17_MASK) |
EDREQ_17 - Enable asynchronous DMA request in stop mode for channel 17. 0b0..Disable asynchronous DMA request for channel 17 0b1..Enable asynchronous DMA request for channel 17
| #define DMA_EARS_EDREQ_18 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_18_SHIFT)) & DMA_EARS_EDREQ_18_MASK) |
EDREQ_18 - Enable asynchronous DMA request in stop mode for channel 18. 0b0..Disable asynchronous DMA request for channel 18 0b1..Enable asynchronous DMA request for channel 18
| #define DMA_EARS_EDREQ_19 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_19_SHIFT)) & DMA_EARS_EDREQ_19_MASK) |
EDREQ_19 - Enable asynchronous DMA request in stop mode for channel 19. 0b0..Disable asynchronous DMA request for channel 19 0b1..Enable asynchronous DMA request for channel 19
| #define DMA_EARS_EDREQ_2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_2_SHIFT)) & DMA_EARS_EDREQ_2_MASK) |
EDREQ_2 - Enable asynchronous DMA request in stop mode for channel 2. 0b0..Disable asynchronous DMA request for channel 2 0b1..Enable asynchronous DMA request for channel 2
| #define DMA_EARS_EDREQ_20 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_20_SHIFT)) & DMA_EARS_EDREQ_20_MASK) |
EDREQ_20 - Enable asynchronous DMA request in stop mode for channel 20. 0b0..Disable asynchronous DMA request for channel 20 0b1..Enable asynchronous DMA request for channel 20
| #define DMA_EARS_EDREQ_21 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_21_SHIFT)) & DMA_EARS_EDREQ_21_MASK) |
EDREQ_21 - Enable asynchronous DMA request in stop mode for channel 21. 0b0..Disable asynchronous DMA request for channel 21 0b1..Enable asynchronous DMA request for channel 21
| #define DMA_EARS_EDREQ_22 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_22_SHIFT)) & DMA_EARS_EDREQ_22_MASK) |
EDREQ_22 - Enable asynchronous DMA request in stop mode for channel 22. 0b0..Disable asynchronous DMA request for channel 22 0b1..Enable asynchronous DMA request for channel 22
| #define DMA_EARS_EDREQ_23 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_23_SHIFT)) & DMA_EARS_EDREQ_23_MASK) |
EDREQ_23 - Enable asynchronous DMA request in stop mode for channel 23. 0b0..Disable asynchronous DMA request for channel 23 0b1..Enable asynchronous DMA request for channel 23
| #define DMA_EARS_EDREQ_24 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_24_SHIFT)) & DMA_EARS_EDREQ_24_MASK) |
EDREQ_24 - Enable asynchronous DMA request in stop mode for channel 24. 0b0..Disable asynchronous DMA request for channel 24 0b1..Enable asynchronous DMA request for channel 24
| #define DMA_EARS_EDREQ_25 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_25_SHIFT)) & DMA_EARS_EDREQ_25_MASK) |
EDREQ_25 - Enable asynchronous DMA request in stop mode for channel 25. 0b0..Disable asynchronous DMA request for channel 25 0b1..Enable asynchronous DMA request for channel 25
| #define DMA_EARS_EDREQ_26 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_26_SHIFT)) & DMA_EARS_EDREQ_26_MASK) |
EDREQ_26 - Enable asynchronous DMA request in stop mode for channel 26. 0b0..Disable asynchronous DMA request for channel 26 0b1..Enable asynchronous DMA request for channel 26
| #define DMA_EARS_EDREQ_27 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_27_SHIFT)) & DMA_EARS_EDREQ_27_MASK) |
EDREQ_27 - Enable asynchronous DMA request in stop mode for channel 27. 0b0..Disable asynchronous DMA request for channel 27 0b1..Enable asynchronous DMA request for channel 27
| #define DMA_EARS_EDREQ_28 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_28_SHIFT)) & DMA_EARS_EDREQ_28_MASK) |
EDREQ_28 - Enable asynchronous DMA request in stop mode for channel 28. 0b0..Disable asynchronous DMA request for channel 28 0b1..Enable asynchronous DMA request for channel 28
| #define DMA_EARS_EDREQ_29 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_29_SHIFT)) & DMA_EARS_EDREQ_29_MASK) |
EDREQ_29 - Enable asynchronous DMA request in stop mode for channel 29. 0b0..Disable asynchronous DMA request for channel 29 0b1..Enable asynchronous DMA request for channel 29
| #define DMA_EARS_EDREQ_3 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_3_SHIFT)) & DMA_EARS_EDREQ_3_MASK) |
EDREQ_3 - Enable asynchronous DMA request in stop mode for channel 3. 0b0..Disable asynchronous DMA request for channel 3 0b1..Enable asynchronous DMA request for channel 3
| #define DMA_EARS_EDREQ_30 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_30_SHIFT)) & DMA_EARS_EDREQ_30_MASK) |
EDREQ_30 - Enable asynchronous DMA request in stop mode for channel 30. 0b0..Disable asynchronous DMA request for channel 30 0b1..Enable asynchronous DMA request for channel 30
| #define DMA_EARS_EDREQ_31 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_31_SHIFT)) & DMA_EARS_EDREQ_31_MASK) |
EDREQ_31 - Enable asynchronous DMA request in stop mode for channel 31. 0b0..Disable asynchronous DMA request for channel 31 0b1..Enable asynchronous DMA request for channel 31
| #define DMA_EARS_EDREQ_4 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_4_SHIFT)) & DMA_EARS_EDREQ_4_MASK) |
EDREQ_4 - Enable asynchronous DMA request in stop mode for channel 4. 0b0..Disable asynchronous DMA request for channel 4 0b1..Enable asynchronous DMA request for channel 4
| #define DMA_EARS_EDREQ_5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_5_SHIFT)) & DMA_EARS_EDREQ_5_MASK) |
EDREQ_5 - Enable asynchronous DMA request in stop mode for channel 5. 0b0..Disable asynchronous DMA request for channel 5 0b1..Enable asynchronous DMA request for channel 5
| #define DMA_EARS_EDREQ_6 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_6_SHIFT)) & DMA_EARS_EDREQ_6_MASK) |
EDREQ_6 - Enable asynchronous DMA request in stop mode for channel 6. 0b0..Disable asynchronous DMA request for channel 6 0b1..Enable asynchronous DMA request for channel 6
| #define DMA_EARS_EDREQ_7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_7_SHIFT)) & DMA_EARS_EDREQ_7_MASK) |
EDREQ_7 - Enable asynchronous DMA request in stop mode for channel 7. 0b0..Disable asynchronous DMA request for channel 7 0b1..Enable asynchronous DMA request for channel 7
| #define DMA_EARS_EDREQ_8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_8_SHIFT)) & DMA_EARS_EDREQ_8_MASK) |
EDREQ_8 - Enable asynchronous DMA request in stop mode for channel 8. 0b0..Disable asynchronous DMA request for channel 8 0b1..Enable asynchronous DMA request for channel 8
| #define DMA_EARS_EDREQ_9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EARS_EDREQ_9_SHIFT)) & DMA_EARS_EDREQ_9_MASK) |
EDREQ_9 - Enable asynchronous DMA request in stop mode for channel 9. 0b0..Disable asynchronous DMA request for channel 9 0b1..Enable asynchronous DMA request for channel 9
| #define DMA_EEI_EEI0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI0_SHIFT)) & DMA_EEI_EEI0_MASK) |
EEI0 - Enable Error Interrupt 0 0b0..An error on channel 0 does not generate an error interrupt 0b1..An error on channel 0 generates an error interrupt request
| #define DMA_EEI_EEI1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI1_SHIFT)) & DMA_EEI_EEI1_MASK) |
EEI1 - Enable Error Interrupt 1 0b0..An error on channel 1 does not generate an error interrupt 0b1..An error on channel 1 generates an error interrupt request
| #define DMA_EEI_EEI10 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI10_SHIFT)) & DMA_EEI_EEI10_MASK) |
EEI10 - Enable Error Interrupt 10 0b0..An error on channel 10 does not generate an error interrupt 0b1..An error on channel 10 generates an error interrupt request
| #define DMA_EEI_EEI11 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI11_SHIFT)) & DMA_EEI_EEI11_MASK) |
EEI11 - Enable Error Interrupt 11 0b0..An error on channel 11 does not generate an error interrupt 0b1..An error on channel 11 generates an error interrupt request
| #define DMA_EEI_EEI12 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI12_SHIFT)) & DMA_EEI_EEI12_MASK) |
EEI12 - Enable Error Interrupt 12 0b0..An error on channel 12 does not generate an error interrupt 0b1..An error on channel 12 generates an error interrupt request
| #define DMA_EEI_EEI13 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI13_SHIFT)) & DMA_EEI_EEI13_MASK) |
EEI13 - Enable Error Interrupt 13 0b0..An error on channel 13 does not generate an error interrupt 0b1..An error on channel 13 generates an error interrupt request
| #define DMA_EEI_EEI14 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI14_SHIFT)) & DMA_EEI_EEI14_MASK) |
EEI14 - Enable Error Interrupt 14 0b0..An error on channel 14 does not generate an error interrupt 0b1..An error on channel 14 generates an error interrupt request
| #define DMA_EEI_EEI15 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI15_SHIFT)) & DMA_EEI_EEI15_MASK) |
EEI15 - Enable Error Interrupt 15 0b0..An error on channel 15 does not generate an error interrupt 0b1..An error on channel 15 generates an error interrupt request
| #define DMA_EEI_EEI16 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI16_SHIFT)) & DMA_EEI_EEI16_MASK) |
EEI16 - Enable Error Interrupt 16 0b0..An error on channel 16 does not generate an error interrupt 0b1..An error on channel 16 generates an error interrupt request
| #define DMA_EEI_EEI17 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI17_SHIFT)) & DMA_EEI_EEI17_MASK) |
EEI17 - Enable Error Interrupt 17 0b0..An error on channel 17 does not generate an error interrupt 0b1..An error on channel 17 generates an error interrupt request
| #define DMA_EEI_EEI18 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI18_SHIFT)) & DMA_EEI_EEI18_MASK) |
EEI18 - Enable Error Interrupt 18 0b0..An error on channel 18 does not generate an error interrupt 0b1..An error on channel 18 generates an error interrupt request
| #define DMA_EEI_EEI19 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI19_SHIFT)) & DMA_EEI_EEI19_MASK) |
EEI19 - Enable Error Interrupt 19 0b0..An error on channel 19 does not generate an error interrupt 0b1..An error on channel 19 generates an error interrupt request
| #define DMA_EEI_EEI2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI2_SHIFT)) & DMA_EEI_EEI2_MASK) |
EEI2 - Enable Error Interrupt 2 0b0..An error on channel 2 does not generate an error interrupt 0b1..An error on channel 2 generates an error interrupt request
| #define DMA_EEI_EEI20 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI20_SHIFT)) & DMA_EEI_EEI20_MASK) |
EEI20 - Enable Error Interrupt 20 0b0..An error on channel 20 does not generate an error interrupt 0b1..An error on channel 20 generates an error interrupt request
| #define DMA_EEI_EEI21 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI21_SHIFT)) & DMA_EEI_EEI21_MASK) |
EEI21 - Enable Error Interrupt 21 0b0..An error on channel 21 does not generate an error interrupt 0b1..An error on channel 21 generates an error interrupt request
| #define DMA_EEI_EEI22 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI22_SHIFT)) & DMA_EEI_EEI22_MASK) |
EEI22 - Enable Error Interrupt 22 0b0..An error on channel 22 does not generate an error interrupt 0b1..An error on channel 22 generates an error interrupt request
| #define DMA_EEI_EEI23 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI23_SHIFT)) & DMA_EEI_EEI23_MASK) |
EEI23 - Enable Error Interrupt 23 0b0..An error on channel 23 does not generate an error interrupt 0b1..An error on channel 23 generates an error interrupt request
| #define DMA_EEI_EEI24 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI24_SHIFT)) & DMA_EEI_EEI24_MASK) |
EEI24 - Enable Error Interrupt 24 0b0..An error on channel 24 does not generate an error interrupt 0b1..An error on channel 24 generates an error interrupt request
| #define DMA_EEI_EEI25 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI25_SHIFT)) & DMA_EEI_EEI25_MASK) |
EEI25 - Enable Error Interrupt 25 0b0..An error on channel 25 does not generate an error interrupt 0b1..An error on channel 25 generates an error interrupt request
| #define DMA_EEI_EEI26 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI26_SHIFT)) & DMA_EEI_EEI26_MASK) |
EEI26 - Enable Error Interrupt 26 0b0..An error on channel 26 does not generate an error interrupt 0b1..An error on channel 26 generates an error interrupt request
| #define DMA_EEI_EEI27 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI27_SHIFT)) & DMA_EEI_EEI27_MASK) |
EEI27 - Enable Error Interrupt 27 0b0..An error on channel 27 does not generate an error interrupt 0b1..An error on channel 27 generates an error interrupt request
| #define DMA_EEI_EEI28 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI28_SHIFT)) & DMA_EEI_EEI28_MASK) |
EEI28 - Enable Error Interrupt 28 0b0..An error on channel 28 does not generate an error interrupt 0b1..An error on channel 28 generates an error interrupt request
| #define DMA_EEI_EEI29 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI29_SHIFT)) & DMA_EEI_EEI29_MASK) |
EEI29 - Enable Error Interrupt 29 0b0..An error on channel 29 does not generate an error interrupt 0b1..An error on channel 29 generates an error interrupt request
| #define DMA_EEI_EEI3 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI3_SHIFT)) & DMA_EEI_EEI3_MASK) |
EEI3 - Enable Error Interrupt 3 0b0..An error on channel 3 does not generate an error interrupt 0b1..An error on channel 3 generates an error interrupt request
| #define DMA_EEI_EEI30 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI30_SHIFT)) & DMA_EEI_EEI30_MASK) |
EEI30 - Enable Error Interrupt 30 0b0..An error on channel 30 does not generate an error interrupt 0b1..An error on channel 30 generates an error interrupt request
| #define DMA_EEI_EEI31 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI31_SHIFT)) & DMA_EEI_EEI31_MASK) |
EEI31 - Enable Error Interrupt 31 0b0..An error on channel 31 does not generate an error interrupt 0b1..An error on channel 31 generates an error interrupt request
| #define DMA_EEI_EEI4 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI4_SHIFT)) & DMA_EEI_EEI4_MASK) |
EEI4 - Enable Error Interrupt 4 0b0..An error on channel 4 does not generate an error interrupt 0b1..An error on channel 4 generates an error interrupt request
| #define DMA_EEI_EEI5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI5_SHIFT)) & DMA_EEI_EEI5_MASK) |
EEI5 - Enable Error Interrupt 5 0b0..An error on channel 5 does not generate an error interrupt 0b1..An error on channel 5 generates an error interrupt request
| #define DMA_EEI_EEI6 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI6_SHIFT)) & DMA_EEI_EEI6_MASK) |
EEI6 - Enable Error Interrupt 6 0b0..An error on channel 6 does not generate an error interrupt 0b1..An error on channel 6 generates an error interrupt request
| #define DMA_EEI_EEI7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI7_SHIFT)) & DMA_EEI_EEI7_MASK) |
EEI7 - Enable Error Interrupt 7 0b0..An error on channel 7 does not generate an error interrupt 0b1..An error on channel 7 generates an error interrupt request
| #define DMA_EEI_EEI8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI8_SHIFT)) & DMA_EEI_EEI8_MASK) |
EEI8 - Enable Error Interrupt 8 0b0..An error on channel 8 does not generate an error interrupt 0b1..An error on channel 8 generates an error interrupt request
| #define DMA_EEI_EEI9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_EEI_EEI9_SHIFT)) & DMA_EEI_EEI9_MASK) |
EEI9 - Enable Error Interrupt 9 0b0..An error on channel 9 does not generate an error interrupt 0b1..An error on channel 9 generates an error interrupt request
| #define DMA_ERQ_ERQ0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ0_SHIFT)) & DMA_ERQ_ERQ0_MASK) |
ERQ0 - Enable DMA Request 0 0b0..The DMA request signal for channel 0 is disabled 0b1..The DMA request signal for channel 0 is enabled
| #define DMA_ERQ_ERQ1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ1_SHIFT)) & DMA_ERQ_ERQ1_MASK) |
ERQ1 - Enable DMA Request 1 0b0..The DMA request signal for channel 1 is disabled 0b1..The DMA request signal for channel 1 is enabled
| #define DMA_ERQ_ERQ10 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ10_SHIFT)) & DMA_ERQ_ERQ10_MASK) |
ERQ10 - Enable DMA Request 10 0b0..The DMA request signal for channel 10 is disabled 0b1..The DMA request signal for channel 10 is enabled
| #define DMA_ERQ_ERQ11 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ11_SHIFT)) & DMA_ERQ_ERQ11_MASK) |
ERQ11 - Enable DMA Request 11 0b0..The DMA request signal for channel 11 is disabled 0b1..The DMA request signal for channel 11 is enabled
| #define DMA_ERQ_ERQ12 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ12_SHIFT)) & DMA_ERQ_ERQ12_MASK) |
ERQ12 - Enable DMA Request 12 0b0..The DMA request signal for channel 12 is disabled 0b1..The DMA request signal for channel 12 is enabled
| #define DMA_ERQ_ERQ13 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ13_SHIFT)) & DMA_ERQ_ERQ13_MASK) |
ERQ13 - Enable DMA Request 13 0b0..The DMA request signal for channel 13 is disabled 0b1..The DMA request signal for channel 13 is enabled
| #define DMA_ERQ_ERQ14 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ14_SHIFT)) & DMA_ERQ_ERQ14_MASK) |
ERQ14 - Enable DMA Request 14 0b0..The DMA request signal for channel 14 is disabled 0b1..The DMA request signal for channel 14 is enabled
| #define DMA_ERQ_ERQ15 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ15_SHIFT)) & DMA_ERQ_ERQ15_MASK) |
ERQ15 - Enable DMA Request 15 0b0..The DMA request signal for channel 15 is disabled 0b1..The DMA request signal for channel 15 is enabled
| #define DMA_ERQ_ERQ16 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ16_SHIFT)) & DMA_ERQ_ERQ16_MASK) |
ERQ16 - Enable DMA Request 16 0b0..The DMA request signal for channel 16 is disabled 0b1..The DMA request signal for channel 16 is enabled
| #define DMA_ERQ_ERQ17 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ17_SHIFT)) & DMA_ERQ_ERQ17_MASK) |
ERQ17 - Enable DMA Request 17 0b0..The DMA request signal for channel 17 is disabled 0b1..The DMA request signal for channel 17 is enabled
| #define DMA_ERQ_ERQ18 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ18_SHIFT)) & DMA_ERQ_ERQ18_MASK) |
ERQ18 - Enable DMA Request 18 0b0..The DMA request signal for channel 18 is disabled 0b1..The DMA request signal for channel 18 is enabled
| #define DMA_ERQ_ERQ19 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ19_SHIFT)) & DMA_ERQ_ERQ19_MASK) |
ERQ19 - Enable DMA Request 19 0b0..The DMA request signal for channel 19 is disabled 0b1..The DMA request signal for channel 19 is enabled
| #define DMA_ERQ_ERQ2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ2_SHIFT)) & DMA_ERQ_ERQ2_MASK) |
ERQ2 - Enable DMA Request 2 0b0..The DMA request signal for channel 2 is disabled 0b1..The DMA request signal for channel 2 is enabled
| #define DMA_ERQ_ERQ20 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ20_SHIFT)) & DMA_ERQ_ERQ20_MASK) |
ERQ20 - Enable DMA Request 20 0b0..The DMA request signal for channel 20 is disabled 0b1..The DMA request signal for channel 20 is enabled
| #define DMA_ERQ_ERQ21 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ21_SHIFT)) & DMA_ERQ_ERQ21_MASK) |
ERQ21 - Enable DMA Request 21 0b0..The DMA request signal for channel 21 is disabled 0b1..The DMA request signal for channel 21 is enabled
| #define DMA_ERQ_ERQ22 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ22_SHIFT)) & DMA_ERQ_ERQ22_MASK) |
ERQ22 - Enable DMA Request 22 0b0..The DMA request signal for channel 22 is disabled 0b1..The DMA request signal for channel 22 is enabled
| #define DMA_ERQ_ERQ23 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ23_SHIFT)) & DMA_ERQ_ERQ23_MASK) |
ERQ23 - Enable DMA Request 23 0b0..The DMA request signal for channel 23 is disabled 0b1..The DMA request signal for channel 23 is enabled
| #define DMA_ERQ_ERQ24 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ24_SHIFT)) & DMA_ERQ_ERQ24_MASK) |
ERQ24 - Enable DMA Request 24 0b0..The DMA request signal for channel 24 is disabled 0b1..The DMA request signal for channel 24 is enabled
| #define DMA_ERQ_ERQ25 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ25_SHIFT)) & DMA_ERQ_ERQ25_MASK) |
ERQ25 - Enable DMA Request 25 0b0..The DMA request signal for channel 25 is disabled 0b1..The DMA request signal for channel 25 is enabled
| #define DMA_ERQ_ERQ26 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ26_SHIFT)) & DMA_ERQ_ERQ26_MASK) |
ERQ26 - Enable DMA Request 26 0b0..The DMA request signal for channel 26 is disabled 0b1..The DMA request signal for channel 26 is enabled
| #define DMA_ERQ_ERQ27 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ27_SHIFT)) & DMA_ERQ_ERQ27_MASK) |
ERQ27 - Enable DMA Request 27 0b0..The DMA request signal for channel 27 is disabled 0b1..The DMA request signal for channel 27 is enabled
| #define DMA_ERQ_ERQ28 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ28_SHIFT)) & DMA_ERQ_ERQ28_MASK) |
ERQ28 - Enable DMA Request 28 0b0..The DMA request signal for channel 28 is disabled 0b1..The DMA request signal for channel 28 is enabled
| #define DMA_ERQ_ERQ29 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ29_SHIFT)) & DMA_ERQ_ERQ29_MASK) |
ERQ29 - Enable DMA Request 29 0b0..The DMA request signal for channel 29 is disabled 0b1..The DMA request signal for channel 29 is enabled
| #define DMA_ERQ_ERQ3 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ3_SHIFT)) & DMA_ERQ_ERQ3_MASK) |
ERQ3 - Enable DMA Request 3 0b0..The DMA request signal for channel 3 is disabled 0b1..The DMA request signal for channel 3 is enabled
| #define DMA_ERQ_ERQ30 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ30_SHIFT)) & DMA_ERQ_ERQ30_MASK) |
ERQ30 - Enable DMA Request 30 0b0..The DMA request signal for channel 30 is disabled 0b1..The DMA request signal for channel 30 is enabled
| #define DMA_ERQ_ERQ31 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ31_SHIFT)) & DMA_ERQ_ERQ31_MASK) |
ERQ31 - Enable DMA Request 31 0b0..The DMA request signal for channel 31 is disabled 0b1..The DMA request signal for channel 31 is enabled
| #define DMA_ERQ_ERQ4 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ4_SHIFT)) & DMA_ERQ_ERQ4_MASK) |
ERQ4 - Enable DMA Request 4 0b0..The DMA request signal for channel 4 is disabled 0b1..The DMA request signal for channel 4 is enabled
| #define DMA_ERQ_ERQ5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ5_SHIFT)) & DMA_ERQ_ERQ5_MASK) |
ERQ5 - Enable DMA Request 5 0b0..The DMA request signal for channel 5 is disabled 0b1..The DMA request signal for channel 5 is enabled
| #define DMA_ERQ_ERQ6 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ6_SHIFT)) & DMA_ERQ_ERQ6_MASK) |
ERQ6 - Enable DMA Request 6 0b0..The DMA request signal for channel 6 is disabled 0b1..The DMA request signal for channel 6 is enabled
| #define DMA_ERQ_ERQ7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ7_SHIFT)) & DMA_ERQ_ERQ7_MASK) |
ERQ7 - Enable DMA Request 7 0b0..The DMA request signal for channel 7 is disabled 0b1..The DMA request signal for channel 7 is enabled
| #define DMA_ERQ_ERQ8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ8_SHIFT)) & DMA_ERQ_ERQ8_MASK) |
ERQ8 - Enable DMA Request 8 0b0..The DMA request signal for channel 8 is disabled 0b1..The DMA request signal for channel 8 is enabled
| #define DMA_ERQ_ERQ9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERQ_ERQ9_SHIFT)) & DMA_ERQ_ERQ9_MASK) |
ERQ9 - Enable DMA Request 9 0b0..The DMA request signal for channel 9 is disabled 0b1..The DMA request signal for channel 9 is enabled
| #define DMA_ERR_ERR0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR0_SHIFT)) & DMA_ERR_ERR0_MASK) |
ERR0 - Error In Channel 0 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR1_SHIFT)) & DMA_ERR_ERR1_MASK) |
ERR1 - Error In Channel 1 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR10 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR10_SHIFT)) & DMA_ERR_ERR10_MASK) |
ERR10 - Error In Channel 10 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR11 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR11_SHIFT)) & DMA_ERR_ERR11_MASK) |
ERR11 - Error In Channel 11 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR12 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR12_SHIFT)) & DMA_ERR_ERR12_MASK) |
ERR12 - Error In Channel 12 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR13 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR13_SHIFT)) & DMA_ERR_ERR13_MASK) |
ERR13 - Error In Channel 13 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR14 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR14_SHIFT)) & DMA_ERR_ERR14_MASK) |
ERR14 - Error In Channel 14 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR15 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR15_SHIFT)) & DMA_ERR_ERR15_MASK) |
ERR15 - Error In Channel 15 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR16 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR16_SHIFT)) & DMA_ERR_ERR16_MASK) |
ERR16 - Error In Channel 16 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR17 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR17_SHIFT)) & DMA_ERR_ERR17_MASK) |
ERR17 - Error In Channel 17 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR18 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR18_SHIFT)) & DMA_ERR_ERR18_MASK) |
ERR18 - Error In Channel 18 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR19 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR19_SHIFT)) & DMA_ERR_ERR19_MASK) |
ERR19 - Error In Channel 19 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR2_SHIFT)) & DMA_ERR_ERR2_MASK) |
ERR2 - Error In Channel 2 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR20 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR20_SHIFT)) & DMA_ERR_ERR20_MASK) |
ERR20 - Error In Channel 20 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR21 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR21_SHIFT)) & DMA_ERR_ERR21_MASK) |
ERR21 - Error In Channel 21 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR22 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR22_SHIFT)) & DMA_ERR_ERR22_MASK) |
ERR22 - Error In Channel 22 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR23 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR23_SHIFT)) & DMA_ERR_ERR23_MASK) |
ERR23 - Error In Channel 23 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR24 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR24_SHIFT)) & DMA_ERR_ERR24_MASK) |
ERR24 - Error In Channel 24 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR25 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR25_SHIFT)) & DMA_ERR_ERR25_MASK) |
ERR25 - Error In Channel 25 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR26 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR26_SHIFT)) & DMA_ERR_ERR26_MASK) |
ERR26 - Error In Channel 26 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR27 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR27_SHIFT)) & DMA_ERR_ERR27_MASK) |
ERR27 - Error In Channel 27 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR28 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR28_SHIFT)) & DMA_ERR_ERR28_MASK) |
ERR28 - Error In Channel 28 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR29 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR29_SHIFT)) & DMA_ERR_ERR29_MASK) |
ERR29 - Error In Channel 29 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR3 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR3_SHIFT)) & DMA_ERR_ERR3_MASK) |
ERR3 - Error In Channel 3 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR30 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR30_SHIFT)) & DMA_ERR_ERR30_MASK) |
ERR30 - Error In Channel 30 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR31 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR31_SHIFT)) & DMA_ERR_ERR31_MASK) |
ERR31 - Error In Channel 31 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR4 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR4_SHIFT)) & DMA_ERR_ERR4_MASK) |
ERR4 - Error In Channel 4 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR5_SHIFT)) & DMA_ERR_ERR5_MASK) |
ERR5 - Error In Channel 5 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR6 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR6_SHIFT)) & DMA_ERR_ERR6_MASK) |
ERR6 - Error In Channel 6 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR7_SHIFT)) & DMA_ERR_ERR7_MASK) |
ERR7 - Error In Channel 7 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR8_SHIFT)) & DMA_ERR_ERR8_MASK) |
ERR8 - Error In Channel 8 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ERR_ERR9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ERR_ERR9_SHIFT)) & DMA_ERR_ERR9_MASK) |
ERR9 - Error In Channel 9 0b0..No error in this channel has occurred 0b1..An error in this channel has occurred
| #define DMA_ES_CPE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_CPE_SHIFT)) & DMA_ES_CPE_MASK) |
CPE - Channel Priority Error 0b0..No channel priority error. 0b1..The most-recently recorded error was a configuration error in the channel priorities within a group. Channel priorities within a group are not unique.
| #define DMA_ES_DAE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_DAE_SHIFT)) & DMA_ES_DAE_MASK) |
DAE - Destination Address Error 0b0..No destination address configuration error. 0b1..The most-recently recorded error was a configuration error detected in the TCDn_DADDR field. TCDn_DADDR is inconsistent with TCDn_ATTR[DSIZE].
| #define DMA_ES_DBE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_DBE_SHIFT)) & DMA_ES_DBE_MASK) |
DBE - Destination Bus Error 0b0..No destination bus error. 0b1..The most-recently recorded error was a bus error on a destination write.
| #define DMA_ES_DOE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_DOE_SHIFT)) & DMA_ES_DOE_MASK) |
DOE - Destination Offset Error 0b0..No destination offset configuration error. 0b1..The most-recently recorded error was a configuration error detected in the TCDn_DOFF field. TCDn_DOFF is inconsistent with TCDn_ATTR[DSIZE].
| #define DMA_ES_ECX | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_ECX_SHIFT)) & DMA_ES_ECX_MASK) |
ECX - Transfer Canceled 0b0..No canceled transfers 0b1..The most-recently recorded entry was a canceled transfer initiated by the error cancel transfer field
| #define DMA_ES_ERRCHN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_ERRCHN_SHIFT)) & DMA_ES_ERRCHN_MASK) |
ERRCHN - Error Channel Number or Canceled Channel Number
| #define DMA_ES_GPE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_GPE_SHIFT)) & DMA_ES_GPE_MASK) |
GPE - Group Priority Error 0b0..No group priority error. 0b1..The most-recently recorded error was a configuration error among the group priorities. All group priorities are not unique.
| #define DMA_ES_NCE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_NCE_SHIFT)) & DMA_ES_NCE_MASK) |
NCE - NBYTES/CITER Configuration Error 0b0..No NBYTES/CITER configuration error. 0b1..The most-recently recorded error was a configuration error detected in the TCDn_NBYTES or TCDn_CITER fields. TCDn_NBYTES is not a multiple of TCDn_ATTR[SSIZE] and TCDn_ATTR[DSIZE], or TCDn_CITER[CITER] = 0, or TCDn_CITER[ELINK] is not equal to TCDn_BITER[ELINK].
| #define DMA_ES_SAE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_SAE_SHIFT)) & DMA_ES_SAE_MASK) |
SAE - Source Address Error 0b0..No source address configuration error. 0b1..The most-recently recorded error was a configuration error detected in the TCDn_SADDR field. TCDn_SADDR is inconsistent with TCDn_ATTR[SSIZE].
| #define DMA_ES_SBE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_SBE_SHIFT)) & DMA_ES_SBE_MASK) |
SBE - Source Bus Error 0b0..No source bus error. 0b1..The most-recently recorded error was a bus error on a source read.
| #define DMA_ES_SGE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_SGE_SHIFT)) & DMA_ES_SGE_MASK) |
SGE - Scatter/Gather Configuration Error 0b0..No scatter/gather configuration error. 0b1..The most-recently recorded error was a configuration error detected in the TCDn_DLASTSGA field.
| #define DMA_ES_SOE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_SOE_SHIFT)) & DMA_ES_SOE_MASK) |
SOE - Source Offset Error 0b0..No source offset configuration error. 0b1..The most-recently recorded error was a configuration error detected in the TCDn_SOFF field. TCDn_SOFF is inconsistent with TCDn_ATTR[SSIZE].
| #define DMA_ES_VLD | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_ES_VLD_SHIFT)) & DMA_ES_VLD_MASK) |
VLD - Logical OR of all ERR status fields 0b0..No ERR fields are 1 0b1..At least one ERR field has a value of 1, indicating a valid error exists that has not been cleared
| #define DMA_HRS_HRS0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS0_SHIFT)) & DMA_HRS_HRS0_MASK) |
HRS0 - Hardware Request Status Channel 0 0b0..A hardware service request for channel 0 is not present 0b1..A hardware service request for channel 0 is present
| #define DMA_HRS_HRS1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS1_SHIFT)) & DMA_HRS_HRS1_MASK) |
HRS1 - Hardware Request Status Channel 1 0b0..A hardware service request for channel 1 is not present 0b1..A hardware service request for channel 1 is present
| #define DMA_HRS_HRS10 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS10_SHIFT)) & DMA_HRS_HRS10_MASK) |
HRS10 - Hardware Request Status Channel 10 0b0..A hardware service request for channel 10 is not present 0b1..A hardware service request for channel 10 is present
| #define DMA_HRS_HRS11 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS11_SHIFT)) & DMA_HRS_HRS11_MASK) |
HRS11 - Hardware Request Status Channel 11 0b0..A hardware service request for channel 11 is not present 0b1..A hardware service request for channel 11 is present
| #define DMA_HRS_HRS12 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS12_SHIFT)) & DMA_HRS_HRS12_MASK) |
HRS12 - Hardware Request Status Channel 12 0b0..A hardware service request for channel 12 is not present 0b1..A hardware service request for channel 12 is present
| #define DMA_HRS_HRS13 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS13_SHIFT)) & DMA_HRS_HRS13_MASK) |
HRS13 - Hardware Request Status Channel 13 0b0..A hardware service request for channel 13 is not present 0b1..A hardware service request for channel 13 is present
| #define DMA_HRS_HRS14 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS14_SHIFT)) & DMA_HRS_HRS14_MASK) |
HRS14 - Hardware Request Status Channel 14 0b0..A hardware service request for channel 14 is not present 0b1..A hardware service request for channel 14 is present
| #define DMA_HRS_HRS15 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS15_SHIFT)) & DMA_HRS_HRS15_MASK) |
HRS15 - Hardware Request Status Channel 15 0b0..A hardware service request for channel 15 is not present 0b1..A hardware service request for channel 15 is present
| #define DMA_HRS_HRS16 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS16_SHIFT)) & DMA_HRS_HRS16_MASK) |
HRS16 - Hardware Request Status Channel 16 0b0..A hardware service request for channel 16 is not present 0b1..A hardware service request for channel 16 is present
| #define DMA_HRS_HRS17 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS17_SHIFT)) & DMA_HRS_HRS17_MASK) |
HRS17 - Hardware Request Status Channel 17 0b0..A hardware service request for channel 17 is not present 0b1..A hardware service request for channel 17 is present
| #define DMA_HRS_HRS18 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS18_SHIFT)) & DMA_HRS_HRS18_MASK) |
HRS18 - Hardware Request Status Channel 18 0b0..A hardware service request for channel 18 is not present 0b1..A hardware service request for channel 18 is present
| #define DMA_HRS_HRS19 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS19_SHIFT)) & DMA_HRS_HRS19_MASK) |
HRS19 - Hardware Request Status Channel 19 0b0..A hardware service request for channel 19 is not present 0b1..A hardware service request for channel 19 is present
| #define DMA_HRS_HRS2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS2_SHIFT)) & DMA_HRS_HRS2_MASK) |
HRS2 - Hardware Request Status Channel 2 0b0..A hardware service request for channel 2 is not present 0b1..A hardware service request for channel 2 is present
| #define DMA_HRS_HRS20 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS20_SHIFT)) & DMA_HRS_HRS20_MASK) |
HRS20 - Hardware Request Status Channel 20 0b0..A hardware service request for channel 20 is not present 0b1..A hardware service request for channel 20 is present
| #define DMA_HRS_HRS21 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS21_SHIFT)) & DMA_HRS_HRS21_MASK) |
HRS21 - Hardware Request Status Channel 21 0b0..A hardware service request for channel 21 is not present 0b1..A hardware service request for channel 21 is present
| #define DMA_HRS_HRS22 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS22_SHIFT)) & DMA_HRS_HRS22_MASK) |
HRS22 - Hardware Request Status Channel 22 0b0..A hardware service request for channel 22 is not present 0b1..A hardware service request for channel 22 is present
| #define DMA_HRS_HRS23 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS23_SHIFT)) & DMA_HRS_HRS23_MASK) |
HRS23 - Hardware Request Status Channel 23 0b0..A hardware service request for channel 23 is not present 0b1..A hardware service request for channel 23 is present
| #define DMA_HRS_HRS24 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS24_SHIFT)) & DMA_HRS_HRS24_MASK) |
HRS24 - Hardware Request Status Channel 24 0b0..A hardware service request for channel 24 is not present 0b1..A hardware service request for channel 24 is present
| #define DMA_HRS_HRS25 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS25_SHIFT)) & DMA_HRS_HRS25_MASK) |
HRS25 - Hardware Request Status Channel 25 0b0..A hardware service request for channel 25 is not present 0b1..A hardware service request for channel 25 is present
| #define DMA_HRS_HRS26 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS26_SHIFT)) & DMA_HRS_HRS26_MASK) |
HRS26 - Hardware Request Status Channel 26 0b0..A hardware service request for channel 26 is not present 0b1..A hardware service request for channel 26 is present
| #define DMA_HRS_HRS27 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS27_SHIFT)) & DMA_HRS_HRS27_MASK) |
HRS27 - Hardware Request Status Channel 27 0b0..A hardware service request for channel 27 is not present 0b1..A hardware service request for channel 27 is present
| #define DMA_HRS_HRS28 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS28_SHIFT)) & DMA_HRS_HRS28_MASK) |
HRS28 - Hardware Request Status Channel 28 0b0..A hardware service request for channel 28 is not present 0b1..A hardware service request for channel 28 is present
| #define DMA_HRS_HRS29 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS29_SHIFT)) & DMA_HRS_HRS29_MASK) |
HRS29 - Hardware Request Status Channel 29 0b0..A hardware service request for channel 29 is not preset 0b1..A hardware service request for channel 29 is present
| #define DMA_HRS_HRS3 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS3_SHIFT)) & DMA_HRS_HRS3_MASK) |
HRS3 - Hardware Request Status Channel 3 0b0..A hardware service request for channel 3 is not present 0b1..A hardware service request for channel 3 is present
| #define DMA_HRS_HRS30 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS30_SHIFT)) & DMA_HRS_HRS30_MASK) |
HRS30 - Hardware Request Status Channel 30 0b0..A hardware service request for channel 30 is not present 0b1..A hardware service request for channel 30 is present
| #define DMA_HRS_HRS31 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS31_SHIFT)) & DMA_HRS_HRS31_MASK) |
HRS31 - Hardware Request Status Channel 31 0b0..A hardware service request for channel 31 is not present 0b1..A hardware service request for channel 31 is present
| #define DMA_HRS_HRS4 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS4_SHIFT)) & DMA_HRS_HRS4_MASK) |
HRS4 - Hardware Request Status Channel 4 0b0..A hardware service request for channel 4 is not present 0b1..A hardware service request for channel 4 is present
| #define DMA_HRS_HRS5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS5_SHIFT)) & DMA_HRS_HRS5_MASK) |
HRS5 - Hardware Request Status Channel 5 0b0..A hardware service request for channel 5 is not present 0b1..A hardware service request for channel 5 is present
| #define DMA_HRS_HRS6 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS6_SHIFT)) & DMA_HRS_HRS6_MASK) |
HRS6 - Hardware Request Status Channel 6 0b0..A hardware service request for channel 6 is not present 0b1..A hardware service request for channel 6 is present
| #define DMA_HRS_HRS7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS7_SHIFT)) & DMA_HRS_HRS7_MASK) |
HRS7 - Hardware Request Status Channel 7 0b0..A hardware service request for channel 7 is not present 0b1..A hardware service request for channel 7 is present
| #define DMA_HRS_HRS8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS8_SHIFT)) & DMA_HRS_HRS8_MASK) |
HRS8 - Hardware Request Status Channel 8 0b0..A hardware service request for channel 8 is not present 0b1..A hardware service request for channel 8 is present
| #define DMA_HRS_HRS9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_HRS_HRS9_SHIFT)) & DMA_HRS_HRS9_MASK) |
HRS9 - Hardware Request Status Channel 9 0b0..A hardware service request for channel 9 is not present 0b1..A hardware service request for channel 9 is present
| #define DMA_INT_INT0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT0_SHIFT)) & DMA_INT_INT0_MASK) |
INT0 - Interrupt Request 0 0b0..The interrupt request for channel 0 is cleared 0b1..The interrupt request for channel 0 is active
| #define DMA_INT_INT1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT1_SHIFT)) & DMA_INT_INT1_MASK) |
INT1 - Interrupt Request 1 0b0..The interrupt request for channel 1 is cleared 0b1..The interrupt request for channel 1 is active
| #define DMA_INT_INT10 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT10_SHIFT)) & DMA_INT_INT10_MASK) |
INT10 - Interrupt Request 10 0b0..The interrupt request for channel 10 is cleared 0b1..The interrupt request for channel 10 is active
| #define DMA_INT_INT11 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT11_SHIFT)) & DMA_INT_INT11_MASK) |
INT11 - Interrupt Request 11 0b0..The interrupt request for channel 11 is cleared 0b1..The interrupt request for channel 11 is active
| #define DMA_INT_INT12 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT12_SHIFT)) & DMA_INT_INT12_MASK) |
INT12 - Interrupt Request 12 0b0..The interrupt request for channel 12 is cleared 0b1..The interrupt request for channel 12 is active
| #define DMA_INT_INT13 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT13_SHIFT)) & DMA_INT_INT13_MASK) |
INT13 - Interrupt Request 13 0b0..The interrupt request for channel 13 is cleared 0b1..The interrupt request for channel 13 is active
| #define DMA_INT_INT14 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT14_SHIFT)) & DMA_INT_INT14_MASK) |
INT14 - Interrupt Request 14 0b0..The interrupt request for channel 14 is cleared 0b1..The interrupt request for channel 14 is active
| #define DMA_INT_INT15 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT15_SHIFT)) & DMA_INT_INT15_MASK) |
INT15 - Interrupt Request 15 0b0..The interrupt request for channel 15 is cleared 0b1..The interrupt request for channel 15 is active
| #define DMA_INT_INT16 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT16_SHIFT)) & DMA_INT_INT16_MASK) |
INT16 - Interrupt Request 16 0b0..The interrupt request for channel 16 is cleared 0b1..The interrupt request for channel 16 is active
| #define DMA_INT_INT17 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT17_SHIFT)) & DMA_INT_INT17_MASK) |
INT17 - Interrupt Request 17 0b0..The interrupt request for channel 17 is cleared 0b1..The interrupt request for channel 17 is active
| #define DMA_INT_INT18 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT18_SHIFT)) & DMA_INT_INT18_MASK) |
INT18 - Interrupt Request 18 0b0..The interrupt request for channel 18 is cleared 0b1..The interrupt request for channel 18 is active
| #define DMA_INT_INT19 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT19_SHIFT)) & DMA_INT_INT19_MASK) |
INT19 - Interrupt Request 19 0b0..The interrupt request for channel 19 is cleared 0b1..The interrupt request for channel 19 is active
| #define DMA_INT_INT2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT2_SHIFT)) & DMA_INT_INT2_MASK) |
INT2 - Interrupt Request 2 0b0..The interrupt request for channel 2 is cleared 0b1..The interrupt request for channel 2 is active
| #define DMA_INT_INT20 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT20_SHIFT)) & DMA_INT_INT20_MASK) |
INT20 - Interrupt Request 20 0b0..The interrupt request for channel 20 is cleared 0b1..The interrupt request for channel 20 is active
| #define DMA_INT_INT21 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT21_SHIFT)) & DMA_INT_INT21_MASK) |
INT21 - Interrupt Request 21 0b0..The interrupt request for channel 21 is cleared 0b1..The interrupt request for channel 21 is active
| #define DMA_INT_INT22 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT22_SHIFT)) & DMA_INT_INT22_MASK) |
INT22 - Interrupt Request 22 0b0..The interrupt request for channel 22 is cleared 0b1..The interrupt request for channel 22 is active
| #define DMA_INT_INT23 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT23_SHIFT)) & DMA_INT_INT23_MASK) |
INT23 - Interrupt Request 23 0b0..The interrupt request for channel 23 is cleared 0b1..The interrupt request for channel 23 is active
| #define DMA_INT_INT24 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT24_SHIFT)) & DMA_INT_INT24_MASK) |
INT24 - Interrupt Request 24 0b0..The interrupt request for channel 24 is cleared 0b1..The interrupt request for channel 24 is active
| #define DMA_INT_INT25 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT25_SHIFT)) & DMA_INT_INT25_MASK) |
INT25 - Interrupt Request 25 0b0..The interrupt request for channel 25 is cleared 0b1..The interrupt request for channel 25 is active
| #define DMA_INT_INT26 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT26_SHIFT)) & DMA_INT_INT26_MASK) |
INT26 - Interrupt Request 26 0b0..The interrupt request for channel 26 is cleared 0b1..The interrupt request for channel 26 is active
| #define DMA_INT_INT27 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT27_SHIFT)) & DMA_INT_INT27_MASK) |
INT27 - Interrupt Request 27 0b0..The interrupt request for channel 27 is cleared 0b1..The interrupt request for channel 27 is active
| #define DMA_INT_INT28 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT28_SHIFT)) & DMA_INT_INT28_MASK) |
INT28 - Interrupt Request 28 0b0..The interrupt request for channel 28 is cleared 0b1..The interrupt request for channel 28 is active
| #define DMA_INT_INT29 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT29_SHIFT)) & DMA_INT_INT29_MASK) |
INT29 - Interrupt Request 29 0b0..The interrupt request for channel 29 is cleared 0b1..The interrupt request for channel 29 is active
| #define DMA_INT_INT3 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT3_SHIFT)) & DMA_INT_INT3_MASK) |
INT3 - Interrupt Request 3 0b0..The interrupt request for channel 3 is cleared 0b1..The interrupt request for channel 3 is active
| #define DMA_INT_INT30 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT30_SHIFT)) & DMA_INT_INT30_MASK) |
INT30 - Interrupt Request 30 0b0..The interrupt request for channel 30 is cleared 0b1..The interrupt request for channel 30 is active
| #define DMA_INT_INT31 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT31_SHIFT)) & DMA_INT_INT31_MASK) |
INT31 - Interrupt Request 31 0b0..The interrupt request for channel 31 is cleared 0b1..The interrupt request for channel 31 is active
| #define DMA_INT_INT4 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT4_SHIFT)) & DMA_INT_INT4_MASK) |
INT4 - Interrupt Request 4 0b0..The interrupt request for channel 4 is cleared 0b1..The interrupt request for channel 4 is active
| #define DMA_INT_INT5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT5_SHIFT)) & DMA_INT_INT5_MASK) |
INT5 - Interrupt Request 5 0b0..The interrupt request for channel 5 is cleared 0b1..The interrupt request for channel 5 is active
| #define DMA_INT_INT6 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT6_SHIFT)) & DMA_INT_INT6_MASK) |
INT6 - Interrupt Request 6 0b0..The interrupt request for channel 6 is cleared 0b1..The interrupt request for channel 6 is active
| #define DMA_INT_INT7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT7_SHIFT)) & DMA_INT_INT7_MASK) |
INT7 - Interrupt Request 7 0b0..The interrupt request for channel 7 is cleared 0b1..The interrupt request for channel 7 is active
| #define DMA_INT_INT8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT8_SHIFT)) & DMA_INT_INT8_MASK) |
INT8 - Interrupt Request 8 0b0..The interrupt request for channel 8 is cleared 0b1..The interrupt request for channel 8 is active
| #define DMA_INT_INT9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_INT_INT9_SHIFT)) & DMA_INT_INT9_MASK) |
INT9 - Interrupt Request 9 0b0..The interrupt request for channel 9 is cleared 0b1..The interrupt request for channel 9 is active
| #define DMA_NBYTES_MLNO_NBYTES | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLNO_NBYTES_SHIFT)) & DMA_NBYTES_MLNO_NBYTES_MASK) |
NBYTES - Minor Byte Transfer Count
| #define DMA_NBYTES_MLOFFNO_DMLOE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_DMLOE_MASK) |
DMLOE - Destination Minor Loop Offset Enable 0b0..The minor loop offset is not applied to the DADDR 0b1..The minor loop offset is applied to the DADDR
| #define DMA_NBYTES_MLOFFNO_NBYTES | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFNO_NBYTES_MASK) |
| #define DMA_NBYTES_MLOFFNO_SMLOE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFNO_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFNO_SMLOE_MASK) |
SMLOE - Source Minor Loop Offset Enable 0b0..The minor loop offset is not applied to the SADDR 0b1..The minor loop offset is applied to the SADDR
| #define DMA_NBYTES_MLOFFYES_DMLOE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_DMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_DMLOE_MASK) |
| #define DMA_NBYTES_MLOFFYES_MLOFF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_MLOFF_SHIFT)) & DMA_NBYTES_MLOFFYES_MLOFF_MASK) |
MLOFF - If SMLOE = 1 or DMLOE = 1, this field represents a sign-extended offset applied to the source or destination address to form the next-state value after the minor loop completes.
| #define DMA_NBYTES_MLOFFYES_NBYTES | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_NBYTES_SHIFT)) & DMA_NBYTES_MLOFFYES_NBYTES_MASK) |
| #define DMA_NBYTES_MLOFFYES_SMLOE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_NBYTES_MLOFFYES_SMLOE_SHIFT)) & DMA_NBYTES_MLOFFYES_SMLOE_MASK) |
| #define DMA_SADDR_SADDR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_SADDR_SADDR_SHIFT)) & DMA_SADDR_SADDR_MASK) |
SADDR - Source Address
| #define DMA_SEEI_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_NOP_SHIFT)) & DMA_SEEI_NOP_MASK) |
NOP - No Op Enable 0b0..Normal operation 0b1..No operation, ignore the other fields in this register
| #define DMA_SEEI_SAEE | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SAEE_SHIFT)) & DMA_SEEI_SAEE_MASK) |
SAEE - Set All Enable Error Interrupts 0b0..Write 1 only to the EEI field specified in the SEEI field 0b1..Writes 1 to all fields in EEI
| #define DMA_SEEI_SEEI | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SEEI_SEEI_SHIFT)) & DMA_SEEI_SEEI_MASK) |
SEEI - Set Enable Error Interrupt
| #define DMA_SERQ_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_NOP_SHIFT)) & DMA_SERQ_NOP_MASK) |
| #define DMA_SERQ_SAER | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SAER_SHIFT)) & DMA_SERQ_SAER_MASK) |
SAER - Set All Enable Requests 0b0..Write 1 to only the ERQ field specified in the SERQ field 0b1..Write 1 to all fields in ERQ
| #define DMA_SERQ_SERQ | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SERQ_SERQ_SHIFT)) & DMA_SERQ_SERQ_MASK) |
SERQ - Set Enable Request
| #define DMA_SLAST_SLAST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DMA_SLAST_SLAST_SHIFT)) & DMA_SLAST_SLAST_MASK) |
SLAST - Last Source Address Adjustment
| #define DMA_SOFF_SOFF | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << DMA_SOFF_SOFF_SHIFT)) & DMA_SOFF_SOFF_MASK) |
SOFF - Source address signed offset
| #define DMA_SSRT_NOP | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_NOP_SHIFT)) & DMA_SSRT_NOP_MASK) |
NOP - No Op Enable 0b0..Normal operation 0b1..No operation; all other fields in this register are ignored.
| #define DMA_SSRT_SAST | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SAST_SHIFT)) & DMA_SSRT_SAST_MASK) |
SAST - Set All START fields (activates all channels) 0b0..Write 1 to only the TCDn_CSR[START] field specified in the SSRT field 0b1..Write 1 to all bits in TCDn_CSR[START]
| #define DMA_SSRT_SSRT | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << DMA_SSRT_SSRT_SHIFT)) & DMA_SSRT_SSRT_MASK) |
SSRT - Set START field
| #define LPSPI_CR_DBGEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_DBGEN_SHIFT)) & LPSPI_CR_DBGEN_MASK) |
DBGEN - Debug Enable 0b0..LPSPI module is disabled in debug mode 0b1..LPSPI module is enabled in debug mode
| #define LPSPI_CR_DOZEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_DOZEN_SHIFT)) & LPSPI_CR_DOZEN_MASK) |
DOZEN - Doze Mode Enable 0b0..LPSPI module is enabled in Doze mode 0b1..LPSPI module is disabled in Doze mode
| #define LPSPI_CR_MEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_MEN_SHIFT)) & LPSPI_CR_MEN_MASK) |
MEN - Module Enable 0b0..Module is disabled 0b1..Module is enabled
| #define LPSPI_CR_RRF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RRF_SHIFT)) & LPSPI_CR_RRF_MASK) |
RRF - Reset Receive FIFO 0b0..No effect 0b1..Reset the Receive FIFO. The register bit always reads zero.
| #define LPSPI_CR_RST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RST_SHIFT)) & LPSPI_CR_RST_MASK) |
RST - Software Reset 0b0..Module is not reset 0b1..Module is reset
| #define LPSPI_CR_RTF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPSPI_CR_RTF_SHIFT)) & LPSPI_CR_RTF_MASK) |
RTF - Reset Transmit FIFO 0b0..No effect 0b1..Reset the Transmit FIFO. The register bit always reads zero.
