RTEMS 6.2
DMAEx MUX SyncSignalID selection. More...
| #define | HAL_DMAMUX1_SYNC_DMAMUX1_CH0_EVT 0U |
| #define | HAL_DMAMUX1_SYNC_DMAMUX1_CH1_EVT 1U |
| #define | HAL_DMAMUX1_SYNC_DMAMUX1_CH2_EVT 2U |
| #define | HAL_DMAMUX1_SYNC_LPTIM1_OUT 3U |
| #define | HAL_DMAMUX1_SYNC_LPTIM2_OUT 4U |
| #define | HAL_DMAMUX1_SYNC_LPTIM3_OUT 5U |
| #define | HAL_DMAMUX1_SYNC_EXTI0 6U |
| #define | HAL_DMAMUX1_SYNC_TIM12_TRGO 7U |
| #define | HAL_DMAMUX2_SYNC_DMAMUX2_CH0_EVT 0U |
| #define | HAL_DMAMUX2_SYNC_DMAMUX2_CH1_EVT 1U |
| #define | HAL_DMAMUX2_SYNC_DMAMUX2_CH2_EVT 2U |
| #define | HAL_DMAMUX2_SYNC_DMAMUX2_CH3_EVT 3U |
| #define | HAL_DMAMUX2_SYNC_DMAMUX2_CH4_EVT 4U |
| #define | HAL_DMAMUX2_SYNC_DMAMUX2_CH5_EVT 5U |
| #define | HAL_DMAMUX2_SYNC_LPUART1_RX_WKUP 6U |
| #define | HAL_DMAMUX2_SYNC_LPUART1_TX_WKUP 7U |
| #define | HAL_DMAMUX2_SYNC_LPTIM2_OUT 8U |
| #define | HAL_DMAMUX2_SYNC_LPTIM3_OUT 9U |
| #define | HAL_DMAMUX2_SYNC_I2C4_WKUP 10U |
| #define | HAL_DMAMUX2_SYNC_SPI6_WKUP 11U |
| #define | HAL_DMAMUX2_SYNC_COMP1_OUT 12U |
| #define | HAL_DMAMUX2_SYNC_RTC_WKUP 13U |
| #define | HAL_DMAMUX2_SYNC_EXTI0 14U |
| #define | HAL_DMAMUX2_SYNC_EXTI2 15U |
| #define HAL_DMAMUX1_SYNC_DMAMUX1_CH0_EVT 0U |
DMAMUX1 synchronization Signal is DMAMUX1 Channel0 Event
| #define HAL_DMAMUX1_SYNC_DMAMUX1_CH1_EVT 1U |
DMAMUX1 synchronization Signal is DMAMUX1 Channel1 Event
| #define HAL_DMAMUX1_SYNC_DMAMUX1_CH2_EVT 2U |
DMAMUX1 synchronization Signal is DMAMUX1 Channel2 Event
| #define HAL_DMAMUX1_SYNC_EXTI0 6U |
DMAMUX1 synchronization Signal is EXTI0 IT
| #define HAL_DMAMUX1_SYNC_LPTIM1_OUT 3U |
DMAMUX1 synchronization Signal is LPTIM1 OUT
| #define HAL_DMAMUX1_SYNC_LPTIM2_OUT 4U |
DMAMUX1 synchronization Signal is LPTIM2 OUT
| #define HAL_DMAMUX1_SYNC_LPTIM3_OUT 5U |
DMAMUX1 synchronization Signal is LPTIM3 OUT
| #define HAL_DMAMUX1_SYNC_TIM12_TRGO 7U |
DMAMUX1 synchronization Signal is TIM12 TRGO
| #define HAL_DMAMUX2_SYNC_COMP1_OUT 12U |
DMAMUX2 synchronization Signal is Comparator 1 output
| #define HAL_DMAMUX2_SYNC_DMAMUX2_CH0_EVT 0U |
DMAMUX2 synchronization Signal is DMAMUX2 Channel0 Event
| #define HAL_DMAMUX2_SYNC_DMAMUX2_CH1_EVT 1U |
DMAMUX2 synchronization Signal is DMAMUX2 Channel1 Event
| #define HAL_DMAMUX2_SYNC_DMAMUX2_CH2_EVT 2U |
DMAMUX2 synchronization Signal is DMAMUX2 Channel2 Event
| #define HAL_DMAMUX2_SYNC_DMAMUX2_CH3_EVT 3U |
DMAMUX2 synchronization Signal is DMAMUX2 Channel3 Event
| #define HAL_DMAMUX2_SYNC_DMAMUX2_CH4_EVT 4U |
DMAMUX2 synchronization Signal is DMAMUX2 Channel4 Event
| #define HAL_DMAMUX2_SYNC_DMAMUX2_CH5_EVT 5U |
DMAMUX2 synchronization Signal is DMAMUX2 Channel5 Event
| #define HAL_DMAMUX2_SYNC_EXTI0 14U |
DMAMUX2 synchronization Signal is EXTI0 IT
| #define HAL_DMAMUX2_SYNC_EXTI2 15U |
DMAMUX2 synchronization Signal is EXTI2 IT
| #define HAL_DMAMUX2_SYNC_I2C4_WKUP 10U |
DMAMUX2 synchronization Signal is I2C4 Wakeup
| #define HAL_DMAMUX2_SYNC_LPTIM2_OUT 8U |
DMAMUX2 synchronization Signal is LPTIM2 output
| #define HAL_DMAMUX2_SYNC_LPTIM3_OUT 9U |
DMAMUX2 synchronization Signal is LPTIM3 output
| #define HAL_DMAMUX2_SYNC_LPUART1_RX_WKUP 6U |
DMAMUX2 synchronization Signal is LPUART1 RX Wakeup
| #define HAL_DMAMUX2_SYNC_LPUART1_TX_WKUP 7U |
DMAMUX2 synchronization Signal is LPUART1 TX Wakeup
| #define HAL_DMAMUX2_SYNC_RTC_WKUP 13U |
DMAMUX2 synchronization Signal is RTC Wakeup
| #define HAL_DMAMUX2_SYNC_SPI6_WKUP 11U |
DMAMUX2 synchronization Signal is SPI6 Wakeup
