RTEMS 6.2
#define COMP_OUTPUTPOL_NONINVERTED   ((uint32_t)0x00000000)
#define COMP_OUTPUTPOL_INVERTED   (COMP_CFGRx_POLARITY)
◆ COMP_OUTPUTPOL_INVERTED
COMP output level is inverted (comparator output is low when the input plus is at a higher voltage than the input minus)
◆ COMP_OUTPUTPOL_NONINVERTED
COMP output level is not inverted (comparator output is high when the input plus is at a higher voltage than the input minus)
