RTEMS 6.2
Files | Data Structures | Functions
Tests a fatal error. More...
file  tr-fatal-sparc-leon3-clock-initialization.c
file  tr-fatal-sparc-leon3-clock-initialization.h
struct  BspSparcLeon3ValFatalClockInitialization_Context
 Test context for spec:/bsp/sparc/leon3/val/fatal-clock-initialization test case. More...
 RTEMS_SYSINIT_ITEM (OccupyClockInterrupt, RTEMS_SYSINIT_DEVICE_DRIVERS, RTEMS_SYSINIT_ORDER_FIRST)
void BspSparcLeon3ValFatalClockInitialization_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case.
This test case performs the following actions:
◆ BspSparcLeon3ValFatalClockInitialization_Run()
void BspSparcLeon3ValFatalClockInitialization_Run ( rtems_fatal_source  source,
Parameters
sourceis fatal source.
codeis fatal code.
