RTEMS 6.2
Tests a fatal error. More...
Files | |
| file | tr-fatal-sparc-leon3-cache-snooping-disabled-secondary.c |
| file | tr-fatal-sparc-leon3-cache-snooping-disabled-secondary.h |
| struct | BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context |
| Test context for spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-secondary test case. More... | |
| void | __real_bsp_start_on_secondary_processor (struct Per_CPU_Control *cpu_self) |
| void | __wrap_bsp_start_on_secondary_processor (struct Per_CPU_Control *cpu_self) |
| void | BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run | ( | rtems_fatal_source | source, |
| rtems_fatal_code | code | ||
| source | is fatal source. |
| code | is fatal code. |
