RTEMS 6.2
#define ADC_INJECTED_SOFTWARE_START   (LL_ADC_INJ_TRIG_SOFTWARE)
#define ADC_EXTERNALTRIGINJEC_T1_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM1_TRGO)
#define ADC_EXTERNALTRIGINJEC_T1_CC4   (LL_ADC_INJ_TRIG_EXT_TIM1_CH4)
#define ADC_EXTERNALTRIGINJEC_T2_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM2_TRGO)
#define ADC_EXTERNALTRIGINJEC_T2_CC1   (LL_ADC_INJ_TRIG_EXT_TIM2_CH1)
#define ADC_EXTERNALTRIGINJEC_T3_CC4   (LL_ADC_INJ_TRIG_EXT_TIM3_CH4)
#define ADC_EXTERNALTRIGINJEC_T4_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM4_TRGO)
#define ADC_EXTERNALTRIGINJEC_EXT_IT15   (LL_ADC_INJ_TRIG_EXT_EXTI_LINE15)
#define ADC_EXTERNALTRIGINJEC_T8_CC4   (LL_ADC_INJ_TRIG_EXT_TIM8_CH4)
#define ADC_EXTERNALTRIGINJEC_T1_TRGO2   (LL_ADC_INJ_TRIG_EXT_TIM1_TRGO2)
#define ADC_EXTERNALTRIGINJEC_T8_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM8_TRGO)
#define ADC_EXTERNALTRIGINJEC_T8_TRGO2   (LL_ADC_INJ_TRIG_EXT_TIM8_TRGO2)
#define ADC_EXTERNALTRIGINJEC_T3_CC3   (LL_ADC_INJ_TRIG_EXT_TIM3_CH3)
#define ADC_EXTERNALTRIGINJEC_T3_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM3_TRGO)
#define ADC_EXTERNALTRIGINJEC_T3_CC1   (LL_ADC_INJ_TRIG_EXT_TIM3_CH1)
#define ADC_EXTERNALTRIGINJEC_T6_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM6_TRGO)
#define ADC_EXTERNALTRIGINJEC_T15_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM15_TRGO)
#define ADC_EXTERNALTRIGINJEC_LPTIM1_OUT   (LL_ADC_INJ_TRIG_EXT_LPTIM1_OUT)
#define ADC_EXTERNALTRIGINJEC_LPTIM2_OUT   (LL_ADC_INJ_TRIG_EXT_LPTIM2_OUT)
#define ADC_EXTERNALTRIGINJEC_LPTIM3_OUT   (LL_ADC_INJ_TRIG_EXT_LPTIM3_OUT)
◆ ADC_EXTERNALTRIGINJEC_EXT_IT15
ADC group injected conversion trigger from external peripheral: external interrupt line 15. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_LPTIM1_OUT
ADC group injected conversion trigger from external peripheral: LPTIM1 OUT event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_LPTIM2_OUT
ADC group injected conversion trigger from external peripheral: LPTIM2 OUT event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_LPTIM3_OUT
ADC group injected conversion trigger from external peripheral: LPTIM3 OUT event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T15_TRGO
ADC group injected conversion trigger from external peripheral: TIM15 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T1_CC4
ADC group injected conversion trigger from external peripheral: TIM1 channel 4 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T1_TRGO
ADC group injected conversion trigger from external peripheral: TIM1 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T1_TRGO2
ADC group injected conversion trigger from external peripheral: TIM1 TRGO2 event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T2_CC1
ADC group injected conversion trigger from external peripheral: TIM2 channel 1 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T2_TRGO
ADC group injected conversion trigger from external peripheral: TIM2 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T3_CC1
ADC group injected conversion trigger from external peripheral: TIM3 channel 1 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T3_CC3
ADC group injected conversion trigger from external peripheral: TIM3 channel 3 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T3_CC4
ADC group injected conversion trigger from external peripheral: TIM3 channel 4 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T3_TRGO
ADC group injected conversion trigger from external peripheral: TIM3 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T4_TRGO
ADC group injected conversion trigger from external peripheral: TIM4 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T6_TRGO
ADC group injected conversion trigger from external peripheral: TIM6 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T8_CC4
ADC group injected conversion trigger from external peripheral: TIM8 channel 4 event (capture compare: input capture or output capture). Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T8_TRGO
ADC group injected conversion trigger from external peripheral: TIM8 TRGO event. Trigger edge set to rising edge (default setting).
◆ ADC_EXTERNALTRIGINJEC_T8_TRGO2
ADC group injected conversion trigger from external peripheral: TIM8 TRGO2 event. Trigger edge set to rising edge (default setting).
◆ ADC_INJECTED_SOFTWARE_START
Software triggers injected group conversion start
