RTEMS 6.2
Linked list help functions used by driver manager. More...
| struct | drvmgr_list |
| #define | LIST_INITIALIZER(type, field) {NULL, NULL, offsetof(type, field)} |
| #define | LIST_HEAD(list, type) ((type *)(list)->head) |
| #define | LIST_TAIL(list, type) ((type *)(list)->tail) |
| #define | LIST_FIELD(list, entry) (*(void **)((char *)(entry) + (list)->ofs)) |
| #define | LIST_NEXT(list, entry, type) ((type *)(LIST_FIELD(list, entry))) |
| #define | LIST_FOR_EACH(list, entry, type) |
| void | drvmgr_list_init (struct drvmgr_list *list, int offset) |
| void | drvmgr_list_empty (struct drvmgr_list *list) |
| void | drvmgr_list_add_head (struct drvmgr_list *list, void *entry) |
| void | drvmgr_list_add_tail (struct drvmgr_list *list, void *entry) |
| void | drvmgr_list_remove_head (struct drvmgr_list *list) |
| void | drvmgr_list_remove (struct drvmgr_list *list, void *entry) |
| #define LIST_FOR_EACH | ( | list, | |
| entry, | |||
| type | |||
| void drvmgr_list_add_head | ( | struct drvmgr_list * | list, |
| void * | entry | ||
Add entry to front of list
| void drvmgr_list_add_tail | ( | struct drvmgr_list * | list, |
| void * | entry | ||
Add entry to end of list
| void drvmgr_list_empty | ( | struct drvmgr_list * | list | ) |
Clear list
| void drvmgr_list_init | ( | struct drvmgr_list * | list, |
| int | offset | ||
Initialize a list during runtime
| list | The list to initialize |
| offset | The number of bytes into the entry structure the next pointer is found |
| void drvmgr_list_remove | ( | struct drvmgr_list * | list, |
| void * | entry | ||
Remove entry from anywhere in list
| void drvmgr_list_remove_head | ( | struct drvmgr_list * | list | ) |
Remove entry from front of list
