RTEMS 6.2
raspberrypi.h File Reference
Register definitions. More...
#include <bspopts.h>
#include <stdint.h>
#include <bsp/utility.h>
Register Macros
#define BCM2835_REG(x)   (*(volatile uint32_t *)(x))
#define BCM2835_BIT(n)   (1 << (n))
Peripheral Base Register Address
#define RPI_PERIPHERAL_BASE   0x20000000
#define BASE_OFFSET   0X5E000000
#define RPI_PERIPHERAL_SIZE   0x01000000
Bus to Physical address translation
Macro.
#define BUS_TO_PHY(x)   ((x) - BASE_OFFSET)
Internal ARM Timer Registers
#define BCM2835_CLOCK_FREQ   250000000
#define BCM2835_TIMER_BASE   (RPI_PERIPHERAL_BASE + 0xB400)
#define BCM2835_TIMER_LOD   (BCM2835_TIMER_BASE + 0x00)
#define BCM2835_TIMER_VAL   (BCM2835_TIMER_BASE + 0x04)
#define BCM2835_TIMER_CTL   (BCM2835_TIMER_BASE + 0x08)
#define BCM2835_TIMER_CLI   (BCM2835_TIMER_BASE + 0x0C)
#define BCM2835_TIMER_RIS   (BCM2835_TIMER_BASE + 0x10)
#define BCM2835_TIMER_MIS   (BCM2835_TIMER_BASE + 0x14)
#define BCM2835_TIMER_RLD   (BCM2835_TIMER_BASE + 0x18)
#define BCM2835_TIMER_DIV   (BCM2835_TIMER_BASE + 0x1C)
#define BCM2835_TIMER_CNT   (BCM2835_TIMER_BASE + 0x20)
#define BCM2835_TIMER_PRESCALE   0xF9
Power Management and Watchdog Registers
#define BCM2835_PM_PASSWD_MAGIC   0x5a000000
#define BCM2835_PM_BASE   (RPI_PERIPHERAL_BASE + 0x100000)
#define BCM2835_PM_GNRIC   (BCM2835_PM_BASE + 0x00)
#define BCM2835_PM_GNRIC_POWUP   0x00000001
#define BCM2835_PM_GNRIC_POWOK   0x00000002
#define BCM2835_PM_GNRIC_ISPOW   0x00000004
#define BCM2835_PM_GNRIC_MEMREP   0x00000008
#define BCM2835_PM_GNRIC_MRDONE   0x00000010
#define BCM2835_PM_GNRIC_ISFUNC   0x00000020
#define BCM2835_PM_GNRIC_RSTN   0x00000fc0
#define BCM2835_PM_GNRIC_ENAB   0x00001000
#define BCM2835_PM_GNRIC_CFG   0x007f0000
#define BCM2835_PM_AUDIO   (BCM2835_PM_BASE + 0x04)
#define BCM2835_PM_AUDIO_APSM   0x000fffff
#define BCM2835_PM_AUDIO_CTRLEN   0x00100000
#define BCM2835_PM_AUDIO_RSTN   0x00200000
#define BCM2835_PM_STATUS   (BCM2835_PM_BASE + 0x18)
#define BCM2835_PM_RSTC   (BCM2835_PM_BASE + 0x1c)
#define BCM2835_PM_RSTC_DRCFG   0x00000003
#define BCM2835_PM_RSTC_WRCFG   0x00000030
#define BCM2835_PM_RSTC_WRCFG_FULL   0x00000020
#define BCM2835_PM_RSTC_SRCFG   0x00000300
#define BCM2835_PM_RSTC_QRCFG   0x00003000
#define BCM2835_PM_RSTC_FRCFG   0x00030000
#define BCM2835_PM_RSTC_HRCFG   0x00300000
#define BCM2835_PM_RSTS   (BCM2835_PM_BASE + 0x20)
#define BCM2835_PM_RSTS_HADDRQ   0x00000001
#define BCM2835_PM_RSTS_HADDRF   0x00000002
#define BCM2835_PM_RSTS_HADDRH   0x00000004
#define BCM2835_PM_RSTS_HADWRQ   0x00000010
#define BCM2835_PM_RSTS_HADWRF   0x00000020
#define BCM2835_PM_RSTS_HADWRH   0x00000040
#define BCM2835_PM_RSTS_HADSRQ   0x00000100
#define BCM2835_PM_RSTS_HADSRF   0x00000200
#define BCM2835_PM_RSTS_HADSRH   0x00000400
#define BCM2835_PM_RSTS_HADPOR   0x00001000
#define BCM2835_PM_WDOG   (BCM2835_PM_BASE + 0x24)
GPIO Registers
#define BCM2835_GPIO_REGS_BASE   (RPI_PERIPHERAL_BASE + 0x200000)
#define BCM2835_GPIO_GPFSEL1   (BCM2835_GPIO_REGS_BASE + 0x04)
#define BCM2835_GPIO_GPSET0   (BCM2835_GPIO_REGS_BASE + 0x1C)
#define BCM2835_GPIO_GPCLR0   (BCM2835_GPIO_REGS_BASE + 0x28)
#define BCM2835_GPIO_GPLEV0   (BCM2835_GPIO_REGS_BASE + 0x34)
#define BCM2835_GPIO_GPEDS0   (BCM2835_GPIO_REGS_BASE + 0x40)
#define BCM2835_GPIO_GPREN0   (BCM2835_GPIO_REGS_BASE + 0x4C)
#define BCM2835_GPIO_GPFEN0   (BCM2835_GPIO_REGS_BASE + 0x58)
#define BCM2835_GPIO_GPHEN0   (BCM2835_GPIO_REGS_BASE + 0x64)
#define BCM2835_GPIO_GPLEN0   (BCM2835_GPIO_REGS_BASE + 0x70)
#define BCM2835_GPIO_GPAREN0   (BCM2835_GPIO_REGS_BASE + 0x7C)
#define BCM2835_GPIO_GPAFEN0   (BCM2835_GPIO_REGS_BASE + 0x88)
#define BCM2835_GPIO_GPPUD   (BCM2835_GPIO_REGS_BASE + 0x94)
#define BCM2835_GPIO_GPPUDCLK0   (BCM2835_GPIO_REGS_BASE + 0x98)
AUX Registers
#define BCM2835_AUX_BASE   (RPI_PERIPHERAL_BASE + 0x215000)
#define AUX_ENABLES   (BCM2835_AUX_BASE + 0x04)
#define AUX_MU_IO_REG   (BCM2835_AUX_BASE + 0x40)
#define AUX_MU_IER_REG   (BCM2835_AUX_BASE + 0x44)
#define AUX_MU_IIR_REG   (BCM2835_AUX_BASE + 0x48)
#define AUX_MU_LCR_REG   (BCM2835_AUX_BASE + 0x4C)
#define AUX_MU_MCR_REG   (BCM2835_AUX_BASE + 0x50)
#define AUX_MU_LSR_REG   (BCM2835_AUX_BASE + 0x54)
#define AUX_MU_MSR_REG   (BCM2835_AUX_BASE + 0x58)
#define AUX_MU_SCRATCH   (BCM2835_AUX_BASE + 0x5C)
#define AUX_MU_CNTL_REG   (BCM2835_AUX_BASE + 0x60)
#define AUX_MU_STAT_REG   (BCM2835_AUX_BASE + 0x64)
#define AUX_MU_BAUD_REG   (BCM2835_AUX_BASE + 0x68)
I2C (BSC) Registers
#define BCM2835_I2C_BASE   (RPI_PERIPHERAL_BASE + 0x804000)
#define BCM2835_I2C_C   (BCM2835_I2C_BASE + 0x00)
#define BCM2835_I2C_S   (BCM2835_I2C_BASE + 0x04)
#define BCM2835_I2C_DLEN   (BCM2835_I2C_BASE + 0x08)
#define BCM2835_I2C_A   (BCM2835_I2C_BASE + 0x0C)
#define BCM2835_I2C_FIFO   (BCM2835_I2C_BASE + 0x10)
#define BCM2835_I2C_DIV   (BCM2835_I2C_BASE + 0x14)
#define BCM2835_I2C_DEL   (BCM2835_I2C_BASE + 0x18)
#define BCM2835_I2C_CLKT   (BCM2835_I2C_BASE + 0x1C)
SPI Registers
#define BCM2835_SPI_BASE   (RPI_PERIPHERAL_BASE + 0x204000)
#define BCM2835_SPI_CS   (BCM2835_SPI_BASE + 0x00)
#define BCM2835_SPI_FIFO   (BCM2835_SPI_BASE + 0x04)
#define BCM2835_SPI_CLK   (BCM2835_SPI_BASE + 0x08)
#define BCM2835_SPI_DLEN   (BCM2835_SPI_BASE + 0x0C)
#define BCM2835_SPI_LTOH   (BCM2835_SPI_BASE + 0x10)
#define BCM2835_SPI_DC   (BCM2835_SPI_BASE + 0x14)
I2C/SPI slave BSC Registers
#define BCM2835_I2C_SPI_BASE   (RPI_PERIPHERAL_BASE + 0x214000)
#define BCM2835_I2C_SPI_DR   (BCM2835_I2C_SPI_BASE + 0x00)
#define BCM2835_I2C_SPI_RSR   (BCM2835_I2C_SPI_BASE + 0x04)
#define BCM2835_I2C_SPI_SLV   (BCM2835_I2C_SPI_BASE + 0x08)
#define BCM2835_I2C_SPI_CR   (BCM2835_I2C_SPI_BASE + 0x0C)
#define BCM2835_I2C_SPI_FR   (BCM2835_I2C_SPI_BASE + 0x10)
#define BCM2835_I2C_SPI_IFLS   (BCM2835_I2C_SPI_BASE + 0x14)
#define BCM2835_I2C_SPI_IMSC   (BCM2835_I2C_SPI_BASE + 0x18)
#define BCM2835_I2C_SPI_RIS   (BCM2835_I2C_SPI_BASE + 0x1C)
#define BCM2835_I2C_SPI_MIS   (BCM2835_I2C_SPI_BASE + 0x20)
#define BCM2835_I2C_SPI_ICR   (BCM2835_I2C_SPI_BASE + 0x24)
#define BCM2835_I2C_SPI_DMACR   (BCM2835_I2C_SPI_BASE + 0x28)
#define BCM2835_I2C_SPI_TDR   (BCM2835_I2C_SPI_BASE + 0x2C)
#define BCM2835_I2C_SPI_GPUSTAT   (BCM2835_I2C_SPI_BASE + 0x30)
#define BCM2835_I2C_SPI_HCTRL   (BCM2835_I2C_SPI_BASE + 0x34)
IRQ Registers
#define BCM2835_BASE_INTC   (RPI_PERIPHERAL_BASE + 0xB200)
#define BCM2835_IRQ_BASIC   (BCM2835_BASE_INTC + 0x00)
#define BCM2835_IRQ_PENDING1   (BCM2835_BASE_INTC + 0x04)
#define BCM2835_IRQ_PENDING2   (BCM2835_BASE_INTC + 0x08)
#define BCM2835_IRQ_FIQ_CTRL   (BCM2835_BASE_INTC + 0x0C)
#define BCM2835_IRQ_ENABLE1   (BCM2835_BASE_INTC + 0x10)
#define BCM2835_IRQ_ENABLE2   (BCM2835_BASE_INTC + 0x14)
#define BCM2835_IRQ_ENABLE_BASIC   (BCM2835_BASE_INTC + 0x18)
#define BCM2835_IRQ_DISABLE1   (BCM2835_BASE_INTC + 0x1C)
#define BCM2835_IRQ_DISABLE2   (BCM2835_BASE_INTC + 0x20)
#define BCM2835_IRQ_DISABLE_BASIC   (BCM2835_BASE_INTC + 0x24)
GPU Timer Registers
#define BCM2835_GPU_TIMER_BASE   (RPI_PERIPHERAL_BASE + 0x3000)
#define BCM2835_GPU_TIMER_CS   (BCM2835_GPU_TIMER_BASE + 0x00)
#define BCM2835_GPU_TIMER_CS_M0   0x00000001
#define BCM2835_GPU_TIMER_CS_M1   0x00000002
#define BCM2835_GPU_TIMER_CS_M2   0x00000004
#define BCM2835_GPU_TIMER_CS_M3   0x00000008
#define BCM2835_GPU_TIMER_CLO   (BCM2835_GPU_TIMER_BASE + 0x04)
#define BCM2835_GPU_TIMER_CHI   (BCM2835_GPU_TIMER_BASE + 0x08)
#define BCM2835_GPU_TIMER_C0   (BCM2835_GPU_TIMER_BASE + 0x0C)
#define BCM2835_GPU_TIMER_C1   (BCM2835_GPU_TIMER_BASE + 0x10)
#define BCM2835_GPU_TIMER_C2   (BCM2835_GPU_TIMER_BASE + 0x14)
#define BCM2835_GPU_TIMER_C3   (BCM2835_GPU_TIMER_BASE + 0x18)
EMMC Registers
#define BCM2835_EMMC_BASE   (RPI_PERIPHERAL_BASE + 0x300000)
Mailbox Registers
#define BCM2835_MBOX_BASE   (RPI_PERIPHERAL_BASE+0xB880)
#define BCM2835_MBOX_PEEK   (BCM2835_MBOX_BASE+0x10)
#define BCM2835_MBOX_READ   (BCM2835_MBOX_BASE+0x00)
#define BCM2835_MBOX_WRITE   (BCM2835_MBOX_BASE+0x20)
#define BCM2835_MBOX_STATUS   (BCM2835_MBOX_BASE+0x18)
#define BCM2835_MBOX_SENDER   (BCM2835_MBOX_BASE+0x14)
#define BCM2835_MBOX_CONFIG   (BCM2835_MBOX_BASE+0x1C)
#define BCM2835_MBOX_FULL   0x80000000
#define BCM2835_MBOX_EMPTY   0x40000000
Mailbox Channels
#define BCM2835_MBOX_CHANNEL_PM   0
#define BCM2835_MBOX_CHANNEL_FB   1
#define BCM2835_MBOX_CHANNEL_VUART   2
#define BCM2835_MBOX_CHANNEL_VCHIQ   3
#define BCM2835_MBOX_CHANNEL_LED   4
#define BCM2835_MBOX_CHANNEL_BUTTON   5
#define BCM2835_MBOX_CHANNEL_TOUCHS   6
#define BCM2835_MBOX_CHANNEL_PROP_AVC   8
#define BCM2835_MBOX_CHANNEL_PROP_VCA   9
USB Registers
#define BCM2835_USB_BASE   (RPI_PERIPHERAL_BASE + 0x980000) /* DTC_OTG USB controller */
Raspberry Pi 2 CPU Cores Local Peripherals
#define BCM2836_CORE_LOCAL_PERIPH_BASE   0x40000000
#define BCM2836_CORE_LOCAL_PERIPH_SIZE   0x00040000
Raspberry Pi 2 Mailbox Register Defines
#define BCM2836_MAILBOX_0_WRITE_SET_BASE   0x40000080
#define BCM2836_MAILBOX_1_WRITE_SET_BASE   0x40000084
#define BCM2836_MAILBOX_2_WRITE_SET_BASE   0x40000088
#define BCM2836_MAILBOX_3_WRITE_SET_BASE   0x4000008C
#define BCM2836_MAILBOX_0_READ_CLEAR_BASE   0x400000C0
#define BCM2836_MAILBOX_1_READ_CLEAR_BASE   0x400000C4
#define BCM2836_MAILBOX_2_READ_CLEAR_BASE   0x400000C8
#define BCM2836_MAILBOX_3_READ_CLEAR_BASE   0x400000CC
Raspberry Pi 2 Core Timer
#define BCM2836_CORE_TIMER_CTRL   0x40000000
#define BCM2836_CORE_TIMER_CTRL_APB_CLK   0x00000100
#define BCM2836_CORE_TIMER_CTRL_INC_2   0x00000200
#define BCM2836_CORE_TIMER_PRESCALER   0x40000008
#define BCM2836_CORE_TIMER_LS32   0x4000001C
#define BCM2836_CORE_TIMER_MS32   0x40000020
Raspberry Pi 2 Local Timer
#define BCM2836_LOCAL_TIMER_CTRL   0x40000034
#define BCM2836_LOCAL_TIMER_CTRL_IRQ_FLAG   0x80000000
#define BCM2836_LOCAL_TIMER_CTRL_IRQ_EN   0x20000000
#define BCM2836_LOCAL_TIMER_CTRL_TIMER_EN   0x10000000
#define BCM2836_LOCAL_TIMER_RELOAD   0x0FFFFFFF
#define BCM2836_LOCAL_TIMER_IRQ_RELOAD   0x40000038
#define BCM2836_LOCAL_TIMER_IRQ_CLEAR   0x80000000
#define BCM2836_LOCAL_TIMER_RELOAD_NOW   0x40000000
#define BCM2836_LOCAL_TIMER_IRQ_ROUTING   0x40000024
#define BCM2836_LOCAL_TIMER_ROU_CORE0_IRQ   0x00
#define BCM2836_LOCAL_TIMER_ROU_CORE1_IRQ   0x01
#define BCM2836_LOCAL_TIMER_ROU_CORE2_IRQ   0x02
#define BCM2836_LOCAL_TIMER_ROU_CORE3_IRQ   0x03
#define BCM2836_LOCAL_TIMER_ROU_CORE0_FIQ   0x04
#define BCM2836_LOCAL_TIMER_ROU_CORE1_FIQ   0x05
#define BCM2836_LOCAL_TIMER_ROU_CORE2_FIQ   0x06
#define BCM2836_LOCAL_TIMER_ROU_CORE3_FIQ   0x07
Raspberry Pi 2 IRQ Routing
#define BCM2836_GPU_IRQ_ROUTING   0x4000000C
#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE0   0x00000000
#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE1   0x00000001
#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE2   0x00000002
#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE4   0x00000003
#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE0   0x00000000
#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE1   0x00000004
#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE2   0x00000008
#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE4   0x0000000C
Raspberry Pi 2 Interrupt Register Defines
#define BCM2836_CORE0_TIMER_IRQ_CTRL_BASE   0x40000040
#define BCM2836_CORE1_TIMER_IRQ_CTRL_BASE   0x40000044
#define BCM2836_CORE2_TIMER_IRQ_CTRL_BASE   0x40000048
#define BCM2836_CORE3_TIMER_IRQ_CTRL_BASE   0x4000004C
#define BCM2836_CORE_TIMER_IRQ_CTRL(cpuidx)    (BCM2836_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_IRQ   0x01
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_IRQ   0x02
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_IRQ   0x04
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_IRQ   0x08
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_FIQ   0x10
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_FIQ   0x20
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_FIQ   0x40
#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_FIQ   0x80
#define BCM2836_MAILBOX_IRQ_CTRL_BASE   0x40000050
#define BCM2836_MAILBOX_IRQ_CTRL(cpuidx)    (BCM2836_MAILBOX_IRQ_CTRL_BASE + 0x4 * (cpuidx))
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_IRQ   0x01
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_IRQ   0x02
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_IRQ   0x04
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_IRQ   0x08
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_FIQ   0x10
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_FIQ   0x20
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_FIQ   0x40
#define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_FIQ   0x80
#define BCM2836_IRQ_SOURCE_REG_BASE   0x40000060
#define BCM2836_IRQ_SOURCE_REG(cpuidx)    (BCM2836_IRQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
#define BCM2836_FIQ_SOURCE_REG_BASE   0x40000070
#define BCM2836_FIQ_SOURCE_REG(cpuidx)    (BCM2836_FIQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
#define BCM2836_IRQ_SOURCE_TIMER0   0x00000001
#define BCM2836_IRQ_SOURCE_TIMER1   0x00000002
#define BCM2836_IRQ_SOURCE_TIMER2   0x00000004
#define BCM2836_IRQ_SOURCE_TIMER3   0x00000008
#define BCM2836_IRQ_SOURCE_MBOX0   0x00000010
#define BCM2836_IRQ_SOURCE_MBOX1   0x00000020
#define BCM2836_IRQ_SOURCE_MBOX2   0x00000040
#define BCM2836_IRQ_SOURCE_MBOX3   0x00000080
#define BCM2836_IRQ_SOURCE_GPU   0x00000100
#define BCM2836_IRQ_SOURCE_PMU   0x00000200
#define BCM2836_IRQ_SOURCE_LOCAL_TIMER   0x00000800
◆ BCM2835_EMMC_BASE
NOTE: Since the SD controller follows the SDHCI standard, the rtems-libbsd tree already provides the remaining registers.
◆ BCM2835_GPU_TIMER_BASE
NOTE: The GPU uses Compare registers 0 and 2 for it's own RTOS. 1 and 3 are available for use in RTEMS.
