RTEMS 6.2
Data Structures | Functions | Variables
arm-pl011.h File Reference
ARM PL011 Support Package. More...
#include <rtems/termiostypes.h>
#include <dev/serial/arm-pl011-regs.h>
#include <bspopts.h>
struct  arm_pl011_uart
struct  arm_pl011_context
bool arm_pl011_probe (rtems_termios_device_context *base)
 Initialize pl011 registers.
void arm_pl011_write_polled (rtems_termios_device_context *base, char c)
 Write a char using polling mode.
int arm_pl011_read_polled (rtems_termios_device_context *base)
 Read a char using polling mode.
volatile arm_pl011_uartarm_pl011_get_regs (rtems_termios_device_context *base)
 Get register base address.
int arm_pl011_compute_baudrate_params (uint32_t *ibrd, uint32_t *fbrd, const uint32_t baudrate, const uint32_t clock, const unsigned short max_error)
 Compute baudrate params.
const rtems_termios_device_handler arm_pl011_fns
◆ arm_pl011_compute_baudrate_params()
int arm_pl011_compute_baudrate_params ( uint32_t *  ibrd,
uint32_t *  fbrd,
Parameters
ibrdThe integer part of the baud rate divisor value.
fbrdThe fractional part of the baud rate divisor value.
baudrateTermios device context.
clockThe UART reference clock frequency.
max_errorMaximum error.
Return values
0Success.
1The error is too large.
2ibrd is invalid.
◆ arm_pl011_get_regs()
volatile arm_pl011_uart * arm_pl011_get_regs ( rtems_termios_device_context base)
Parameters
baseTermios device context.
Return values
Registerbase address.
◆ arm_pl011_probe()
bool arm_pl011_probe ( rtems_termios_device_context base)
Parameters
Return values
trueSuccessfully initialized pl011 registers.
◆ arm_pl011_read_polled()
int arm_pl011_read_polled ( rtems_termios_device_context base)
Parameters
Return values
Characterread.
-1rxfifo is empty.
◆ arm_pl011_write_polled()
void arm_pl011_write_polled ( rtems_termios_device_context base,
char  c
Parameters
cCharacter to be written.
