RTEMS 6.2
Functions | Variables
apic.c File Reference
APIC implementation. More...
#include <acpi/acpi.h>
#include <apic.h>
#include <assert.h>
#include <bsp.h>
#include <pic.h>
#include <rtems/score/idt.h>
void apic_spurious_handler (void)
bool lapic_initialize (void)
 Initializes the Local APIC by hardware and software enabling it.
uint32_t lapic_timer_calc_ticks (uint64_t desired_freq_hz)
 Calculates the number of Local APIC timer ticks which can be used with lapic_timer_enable to set up a timer of given frequency.
void lapic_timer_enable (uint32_t reload_value)
 Enables the Local APIC timer.
volatile uint32_t * amd64_lapic_base
◆ lapic_initialize()
bool lapic_initialize ( void  )
Initializes the Local APIC by hardware and software enabling it, and sets up the amd64_lapic_base pointer that can be used as a 32-bit addressable array to access Local APIC registers.
Returns
true if successful.
◆ lapic_timer_calc_ticks()
uint32_t lapic_timer_calc_ticks ( uint64_t  desired_freq_hz)
Parameters
desired_freq_hzThe frequency in Hz.
Returns
The number of Local APIC timer ticks.
◆ lapic_timer_enable()
void lapic_timer_enable ( uint32_t  reload_value)
Parameters
reload_valueNumber of ticks per interrupt.
