RTEMS 6.2
Functions | Variables
Private implementation for Asynchronous I/O. More...
#include <pthread.h>
#include <unistd.h>
#include <time.h>
#include <signal.h>
#include <rtems/posix/aio_misc.h>
#include <limits.h>
int rtems_aio_init (void)
 Initialize the request queue for AIO Operations.
rtems_aio_requestinit_write_req (struct aiocb *aiocbp)
 initializes a read rtems_aio_request
rtems_aio_requestinit_read_req (struct aiocb *aiocbp)
 initializes a write rtems_aio_request
void rtems_aio_completed_list_op (listcb *listcbp)
 updates listcb after op completion
rtems_aio_request_chainrtems_aio_search_fd (rtems_chain_control *chain, int fildes, int create)
 Search for and create a chain of requests for a given file descriptor.
void rtems_aio_remove_fd (rtems_aio_request_chain *r_chain)
 Removes all the requests in a FD chain.
int rtems_aio_remove_req (rtems_chain_control *chain, struct aiocb *aiocbp)
 Remove request from given chain.
int rtems_aio_enqueue (rtems_aio_request *req)
 Enqueue requests, and creates threads to process them.
int rtems_aio_check_sigevent (struct sigevent *sigp)
 Checks the validity of a sigevent struct.
rtems_aio_queue aio_request_queue
This file contains the implementation of private methods used for the processing of Asynchronous I/O requests.
◆ init_read_req()
rtems_aio_request * init_read_req ( struct aiocb *  aiocbp)
Parameters
aiocbpointer to the aiocb describing the request
Return values
NULLthe aiocb passed was invalid, errno indicates the error:
Returns
rtems_aio_request* a pointer to the newly created request.
◆ init_write_req()
rtems_aio_request * init_write_req ( struct aiocb *  aiocbp)
Parameters
Return values
Returns
◆ rtems_aio_check_sigevent()
int rtems_aio_check_sigevent ( struct sigevent *  sigp)
Checks if the pointer passed as parameter points to a valid sigevent struct.
Parameters
sigpIs a pointer to the sigevent struct to check.
Return values
0The struct is not valid.
1The struct is valid.
◆ rtems_aio_completed_list_op()
void rtems_aio_completed_list_op ( listcb listcbp)
Parameters
listcbp
◆ rtems_aio_enqueue()
int rtems_aio_enqueue ( rtems_aio_request req)
Parameters
[in,out]reqA pointer to the request.
Return values
0if the request was added to the queue, errno otherwise.
◆ rtems_aio_init()
int rtems_aio_init ( void  )
Return values
0The queue has bees succesfully initialized.
-1An error occured while initializing the queue.
◆ rtems_aio_remove_fd()
void rtems_aio_remove_fd ( rtems_aio_request_chain r_chain)
Parameters
[in,out]r_chainA pointer to a chain of requests for a given FD
◆ rtems_aio_remove_req()
int rtems_aio_remove_req ( rtems_chain_control chain,
Parameters
[in,out]chainA pointer to the FD chain that may contain the request
[in,out]aiocbpA pointer to the AIO control block of the request.
Return values
AIO_CANCELEDThe request was canceled.
AIO_NOTCANCELEDThe request was not canceled.
◆ rtems_aio_search_fd()
rtems_aio_request_chain * rtems_aio_search_fd ( rtems_chain_control chain,
int  fildes,
int  create
Parameters
[in,out]chainA pointer to a chain of FD chains.
[in]fildesThe file descriptor to search for.
[in]createIf create == 0, the function just searches for the given FD. If create == 1, the function creates a new chain if none is found.
Return values
NULLIf create == 0 and no chain is found for the given FD.
Returns
A pointer to the chain if a chain for the given FD exists.
A pointer to a newly created chain if create == 1 and no chain is found for the given FD.
