RTEMS 6.2
Macros | Functions
interrupt.c File Reference
#include <rtems/libio.h>
#include <bsp.h>
#include <libcpu/cecRegs.h>
#include <libcpu/sicRegs.h>
#include <bsp/interrupt.h>
#define SIC_IAR_COUNT_SET0   4
#define SIC_IAR_BASE_ADDRESS_0   0xFFC00150
void bfin_interrupt_init (void)
rtems_status_code bfin_interrupt_register (bfin_isr_t *isr)
rtems_status_code bfin_interrupt_unregister (bfin_isr_t *isr)
void bfin_interrupt_enable (bfin_isr_t *isr, bool enable)
void bfin_interrupt_enable_all (int source, bool enable)
void bfin_interrupt_enable_global (int source, bool enable)
Target: TLL6527v1-0 Compiler:
COPYRIGHT (c) 2010 by ECE Northeastern University.
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license
Author
Rohan Kangralkar, ECE, Northeastern University (kangr.nosp@m.alka.nosp@m.r.r@h.nosp@m.usky.nosp@m..neu..nosp@m.edu)
LastChange:
◆ bfin_interrupt_init()
void bfin_interrupt_init ( void  )
Initializes the interrupt module
The bf52x has 8 IAR registers but they do not have a constant pitch.
◆ bfin_interrupt_register()
rtems_status_code bfin_interrupt_register ( bfin_isr_t isr)
This routine registers a new ISR. It will write a new entry to the IVT table
Parameters
isrcontains a callback function and source
Returns
rtems status code
◆ bfin_interrupt_unregister()
rtems_status_code bfin_interrupt_unregister ( bfin_isr_t isr)
This function unregisters a registered interrupt handler.
Parameters
isr
