RTEMS 6.1
SAI DMA transfer handle, users should not touch the content of the handle. More...
#include <fsl_sai_sdma.h>
Data Fields | |
| sdma_handle_t * | dmaHandle |
| uint8_t | bytesPerFrame |
| uint8_t | channel |
| uint8_t | channelNums |
| uint8_t | channelMask |
| uint8_t | fifoOffset |
| uint32_t | count |
| uint32_t | state |
| uint32_t | eventSource |
| sai_sdma_callback_t | callback |
| void * | userData |
| sdma_buffer_descriptor_t | bdPool [SAI_XFER_QUEUE_SIZE] |
| sai_transfer_t | saiQueue [SAI_XFER_QUEUE_SIZE] |
| size_t | transferSize [SAI_XFER_QUEUE_SIZE] |
| volatile uint8_t | queueUser |
| volatile uint8_t | queueDriver |
| sdma_buffer_descriptor_t _sai_sdma_handle::bdPool[SAI_XFER_QUEUE_SIZE] |
BD pool for SDMA transfer.
| uint8_t _sai_sdma_handle::bytesPerFrame |
Bytes in a frame
| sai_sdma_callback_t _sai_sdma_handle::callback |
Callback for users while transfer finish or error occurs
| uint8_t _sai_sdma_handle::channel |
start data channel
| uint8_t _sai_sdma_handle::channelMask |
enabled channel mask value, refernece _sai_channel_mask
| uint8_t _sai_sdma_handle::channelNums |
total transfer channel numbers, used for multififo
| uint32_t _sai_sdma_handle::count |
The transfer data count in a DMA request
| sdma_handle_t* _sai_sdma_handle::dmaHandle |
DMA handler for SAI send
| uint32_t _sai_sdma_handle::eventSource |
SAI event source number
| uint8_t _sai_sdma_handle::fifoOffset |
fifo address offset between multifo
| volatile uint8_t _sai_sdma_handle::queueDriver |
Index for driver to get the transfer data and size
| volatile uint8_t _sai_sdma_handle::queueUser |
Index for user to queue transfer.
| sai_transfer_t _sai_sdma_handle::saiQueue[SAI_XFER_QUEUE_SIZE] |
Transfer queue storing queued transfer.
| uint32_t _sai_sdma_handle::state |
Internal state for SAI SDMA transfer
| size_t _sai_sdma_handle::transferSize[SAI_XFER_QUEUE_SIZE] |
Data bytes need to transfer
| void* _sai_sdma_handle::userData |
User callback parameter
