RTEMS 6.1
LPSPI slave configuration structure. More...
#include <fsl_lpspi.h>
| uint32_t _lpspi_slave_config::bitsPerFrame |
Bits per frame, minimum 8, maximum 4096.
| lpspi_clock_phase_t _lpspi_slave_config::cpha |
Clock phase.
| lpspi_clock_polarity_t _lpspi_slave_config::cpol |
Clock polarity.
| lpspi_data_out_config_t _lpspi_slave_config::dataOutConfig |
Configures if the output data is tristated between accesses (LPSPI_PCS is negated).
| lpspi_shift_direction_t _lpspi_slave_config::direction |
MSB or LSB data shift direction.
| lpspi_pcs_polarity_config_t _lpspi_slave_config::pcsActiveHighOrLow |
Desired PCS active high or low
| lpspi_pin_config_t _lpspi_slave_config::pinCfg |
Configures which pins are used for input and output data during single bit transfers.
| lpspi_which_pcs_t _lpspi_slave_config::whichPcs |
Desired Peripheral Chip Select (pcs)
