RTEMS 5.2-rc1
Macros | Functions
watchdogdrv.h File Reference
#define WATCHDOG_DRIVER_TABLE_ENTRY    { Watchdog_initialize, NULL, NULL, NULL, NULL, Watchdog_control }
rtems_device_driver Watchdog_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arguments)
 Watchdog Driver Initialization. More...
rtems_device_driver Watchdog_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arguments)
 Watchdog Driver IO Control. More...
This file describes the Watchdog Driver for all boards. A watchdog is a hardware device that will reset the board if not touched in a specific way at a regular interval. It is a simple, yet important, part of many embedded systems.
◆ WATCHDOG_DRIVER_TABLE_ENTRY
This macro defines the watchdog device driver entry points.
◆ Watchdog_control()
rtems_device_driver Watchdog_control ( rtems_device_major_number  major,
void *  arguments
This method implements the IO Control device driver entry point for the watchdog hardware device.
Parameters
[in]majoris the watchdog device major number
[in]minoris the watchdog device minor number
[in]argumentspoints to device driver arguments
◆ Watchdog_initialize()
rtems_device_driver Watchdog_initialize ( rtems_device_major_number  major,
void *  arguments
This method initializes the watchdog hardware device. The device should be initialized as DISABLED since BSP initialization may take longer than the timeout period for the watchdog.
Parameters
