RTEMS 5.2-rc1
User Extension Handler API. More...
#include <rtems/score/interr.h>Go to the source code of this file.
| struct | User_extensions_Table |
| User extension table. More... | |
Typedefs | |
| typedef void User_extensions_routine | RTEMS_DEPRECATED |
| typedef bool(* | User_extensions_thread_create_extension) (struct _Thread_Control *executing, struct _Thread_Control *created) |
| Task create extension. More... | |
| typedef void(* | User_extensions_thread_delete_extension) (struct _Thread_Control *executing, struct _Thread_Control *deleted) |
| Task delete extension. More... | |
| typedef void(* | User_extensions_thread_start_extension) (struct _Thread_Control *executing, struct _Thread_Control *started) |
| Task start extension. More... | |
| typedef void(* | User_extensions_thread_restart_extension) (struct _Thread_Control *executing, struct _Thread_Control *restarted) |
| Task restart extension. More... | |
| typedef void(* | User_extensions_thread_switch_extension) (struct _Thread_Control *executing, struct _Thread_Control *heir) |
| Task switch extension. More... | |
| typedef void(* | User_extensions_thread_begin_extension) (struct _Thread_Control *executing) |
| Task begin extension. More... | |
| typedef void(* | User_extensions_thread_exitted_extension) (struct _Thread_Control *executing) |
| Task exitted extension. More... | |
| typedef void(* | User_extensions_fatal_extension) (Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code) |
| Fatal error extension. More... | |
| typedef void(* | User_extensions_thread_terminate_extension) (struct _Thread_Control *terminated) |
| Task termination extension. More... | |
