RTEMS 5.2-rc1
tx4925.h
1
7/*
8 * COPYRIGHT (c) 1989-2012.
9 * On-Line Applications Research Corporation (OAR).
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef __TX4925_h
17#define __TX4925_h
18
19#define TX4925_REG_BASE 0xFF1F0000
20
21
22/*
23 * Configuration Registers
24 */
25#define TX4925_CFG_CCFG 0xE000 /* Chip Configuration Register */
26#define TX4925_CFG_REVID 0xE004 /* Chip Revision ID Register */
27#define TX4925_CFG_PCFG 0xE008 /* Pin Configuration Register */
28#define TX4925_CFG_TOEA 0xE00C /* TimeOut Error Access Address Register */
29#define TX4925_CFG_PDNCTR 0xE010 /* Power Down Control Register */
30#define TX4925_CFG_GARBP 0xE018 /* GBUS Arbiter Priority Register */
31#define TX4925_CFG_TOCNT 0xE020 /* Timeout Count Register */
32#define TX4925_CFG_DRQCTR 0xE024 /* DMA Request Control Register */
33#define TX4925_CFG_CLKCTR 0xE028 /* Clock Control Register */
34#define TX4925_CFG_GARBC 0xE02C /* GBUS Arbiter Control Register */
35#define TX4925_CFG_RAMP 0xE030 /* Register Address Mapping Register */
36
37/* Pin Configuration register bits */
38#define SELCHI 0x00100000
39#define SELTMR0 0x00000200
40
41
42/*
43 * Timer Registers
44 */
45
46#define TX4925_TIMER0_BASE 0xF000
47#define TX4925_TIMER1_BASE 0xF100
48#define TX4925_TIMER2_BASE 0xF200
49
50#define TX4925_TIMER_TCR 0x00 /* Timer Control Register */
51#define TX4925_TIMER_TISR 0x04 /* Timer Interrupt Status Register */
52#define TX4925_TIMER_CPRA 0x08 /* Compare Register A */
53#define TX4925_TIMER_CPRB 0x0C /* Compare Register B */
54#define TX4925_TIMER_ITMR 0x10 /* Interval Timer Mode Register */
55#define TX4925_TIMER_CCDR 0x20 /* Divide Cycle Register */
56#define TX4925_TIMER_PGMR 0x30 /* Pulse Generator Mode Register */
57#define TX4925_TIMER_WTMR 0x40 /* Reserved Register */
58#define TX4925_TIMER_TRR 0xF0 /* Timer Read Register */
59
60/* ITMR register bits */
61#define TIMER_CLEAR_ENABLE_MASK 0x1
62#define TIMER_INT_ENABLE_MASK 0x8000
63
64/* PGMR register bits */
65#define FFI 0x1
66#define TPIAE 0x4000
67#define TPIBE 0x8000
68
69/* TISR register bits */
70#define TIIS 0x1
71#define TPIAS 0x2
72#define TPIBS 0x4
73#define TWIS 0x8
74
75
76/*
77 * Interrupt Controller Registers
78 */
79#define TX4925_IRQCTL_DEN 0xF600 /* Interrupt Detection Enable Register */
80#define TX4925_IRQCTL_DM0 0xF604 /* Interrupt Detection Mode Register 0 */
81#define TX4925_IRQCTL_DM1 0xF608 /* Interrupt Detection Mode Register 1 */
82#define TX4925_IRQCTL_LVL0 0xF610 /* Interrupt Level Register 0 */
83#define TX4925_IRQCTL_LVL1 0xF614 /* Interrupt Level Register 1 */
84#define TX4925_IRQCTL_LVL2 0xF618 /* Interrupt Level Register 2 */
85#define TX4925_IRQCTL_LVL3 0xF61C /* Interrupt Level Register 3 */
86#define TX4925_IRQCTL_LVL4 0xF620 /* Interrupt Level Register 4 */
87#define TX4925_IRQCTL_LVL5 0xF624 /* Interrupt Level Register 5 */
88#define TX4925_IRQCTL_LVL6 0xF628 /* Interrupt Level Register 6 */
89#define TX4925_IRQCTL_LVL7 0xF62C /* Interrupt Level Register 7 */
90#define TX4925_IRQCTL_MSK 0xF640 /* Interrupt Mask Register */
91#define TX4925_IRQCTL_EDC 0xF660 /* Interrupt Edge Detection Clear Register */
92#define TX4925_IRQCTL_PND 0xF680 /* Interrupt Pending Register */
93#define TX4925_IRQCTL_CS 0xF6A0 /* Interrupt Current Status Register */
94#define TX4925_IRQCTL_FLAG0 0xF510 /* Interrupt Request Flag Register 0 */
95#define TX4925_IRQCTL_FLAG1 0xF514 /* Interrupt Request Flag Register 1 */
96#define TX4925_IRQCTL_POL 0xF518 /* Interrupt Request Polarity Control Register */
97#define TX4925_IRQCTL_RCNT 0xF51C /* Interrupt Request Control Register */
98#define TX4925_IRQCTL_MASKINT 0xF520 /* Interrupt Request Internal Interrupt Mask Register */
99#define TX4925_IRQCTL_MASKEXT 0xF524 /* Interrupt Request External Interrupt Mask Register */
100
101#define TX4925_REG_READ( _base, _register ) \
102 *((volatile uint32_t *)((_base) + (_register)))
103
104#define TX4925_REG_WRITE( _base, _register, _value ) \
105 *((volatile uint32_t *)((_base) + (_register))) = (_value)
106
107#endif
