RTEMS 5.2-rc1
| #define | TX4925_REG_BASE 0xFF1F0000 |
| #define | TX4925_CFG_CCFG 0xE000 /* Chip Configuration Register */ |
| #define | TX4925_CFG_REVID 0xE004 /* Chip Revision ID Register */ |
| #define | TX4925_CFG_PCFG 0xE008 /* Pin Configuration Register */ |
| #define | TX4925_CFG_TOEA 0xE00C /* TimeOut Error Access Address Register */ |
| #define | TX4925_CFG_PDNCTR 0xE010 /* Power Down Control Register */ |
| #define | TX4925_CFG_GARBP 0xE018 /* GBUS Arbiter Priority Register */ |
| #define | TX4925_CFG_TOCNT 0xE020 /* Timeout Count Register */ |
| #define | TX4925_CFG_DRQCTR 0xE024 /* DMA Request Control Register */ |
| #define | TX4925_CFG_CLKCTR 0xE028 /* Clock Control Register */ |
| #define | TX4925_CFG_GARBC 0xE02C /* GBUS Arbiter Control Register */ |
| #define | TX4925_CFG_RAMP 0xE030 /* Register Address Mapping Register */ |
| #define | SELCHI 0x00100000 |
| #define | SELTMR0 0x00000200 |
| #define | TX4925_TIMER0_BASE 0xF000 |
| #define | TX4925_TIMER1_BASE 0xF100 |
| #define | TX4925_TIMER2_BASE 0xF200 |
| #define | TX4925_TIMER_TCR 0x00 /* Timer Control Register */ |
| #define | TX4925_TIMER_TISR 0x04 /* Timer Interrupt Status Register */ |
| #define | TX4925_TIMER_CPRA 0x08 /* Compare Register A */ |
| #define | TX4925_TIMER_CPRB 0x0C /* Compare Register B */ |
| #define | TX4925_TIMER_ITMR 0x10 /* Interval Timer Mode Register */ |
| #define | TX4925_TIMER_CCDR 0x20 /* Divide Cycle Register */ |
| #define | TX4925_TIMER_PGMR 0x30 /* Pulse Generator Mode Register */ |
| #define | TX4925_TIMER_WTMR 0x40 /* Reserved Register */ |
| #define | TX4925_TIMER_TRR 0xF0 /* Timer Read Register */ |
| #define | TIMER_CLEAR_ENABLE_MASK 0x1 |
| #define | TIMER_INT_ENABLE_MASK 0x8000 |
| #define | FFI 0x1 |
| #define | TPIAE 0x4000 |
| #define | TPIBE 0x8000 |
| #define | TIIS 0x1 |
| #define | TPIAS 0x2 |
| #define | TPIBS 0x4 |
| #define | TWIS 0x8 |
| #define | TX4925_IRQCTL_DEN 0xF600 /* Interrupt Detection Enable Register */ |
| #define | TX4925_IRQCTL_DM0 0xF604 /* Interrupt Detection Mode Register 0 */ |
| #define | TX4925_IRQCTL_DM1 0xF608 /* Interrupt Detection Mode Register 1 */ |
| #define | TX4925_IRQCTL_LVL0 0xF610 /* Interrupt Level Register 0 */ |
| #define | TX4925_IRQCTL_LVL1 0xF614 /* Interrupt Level Register 1 */ |
| #define | TX4925_IRQCTL_LVL2 0xF618 /* Interrupt Level Register 2 */ |
| #define | TX4925_IRQCTL_LVL3 0xF61C /* Interrupt Level Register 3 */ |
| #define | TX4925_IRQCTL_LVL4 0xF620 /* Interrupt Level Register 4 */ |
| #define | TX4925_IRQCTL_LVL5 0xF624 /* Interrupt Level Register 5 */ |
| #define | TX4925_IRQCTL_LVL6 0xF628 /* Interrupt Level Register 6 */ |
| #define | TX4925_IRQCTL_LVL7 0xF62C /* Interrupt Level Register 7 */ |
| #define | TX4925_IRQCTL_MSK 0xF640 /* Interrupt Mask Register */ |
| #define | TX4925_IRQCTL_EDC 0xF660 /* Interrupt Edge Detection Clear Register */ |
| #define | TX4925_IRQCTL_PND 0xF680 /* Interrupt Pending Register */ |
| #define | TX4925_IRQCTL_CS 0xF6A0 /* Interrupt Current Status Register */ |
| #define | TX4925_IRQCTL_FLAG0 0xF510 /* Interrupt Request Flag Register 0 */ |
| #define | TX4925_IRQCTL_FLAG1 0xF514 /* Interrupt Request Flag Register 1 */ |
| #define | TX4925_IRQCTL_POL 0xF518 /* Interrupt Request Polarity Control Register */ |
| #define | TX4925_IRQCTL_RCNT 0xF51C /* Interrupt Request Control Register */ |
| #define | TX4925_IRQCTL_MASKINT 0xF520 /* Interrupt Request Internal Interrupt Mask Register */ |
| #define | TX4925_IRQCTL_MASKEXT 0xF524 /* Interrupt Request External Interrupt Mask Register */ |
| #define | TX4925_REG_READ(_base, _register) *((volatile uint32_t *)((_base) + (_register))) |
| #define | TX4925_REG_WRITE(_base, _register, _value) *((volatile uint32_t *)((_base) + (_register))) = (_value) |
MIPS Tx4925 specific information
