RTEMS 5.2-rc1
tc.h File Reference
#include "chip.h"
#include <stdint.h>
void TC_Configure (Tc *pTc, uint32_t dwChannel, uint32_t dwMode)
 Configures a Timer Counter Channel. More...
void TC_Start (Tc *pTc, uint32_t dwChannel)
 Reset and Start the TC Channel. More...
void TC_Stop (Tc *pTc, uint32_t dwChannel)
 Stop TC Channel. More...
uint32_t TC_FindMckDivisor (uint32_t dwFreq, uint32_t dwMCk, uint32_t *dwDiv, uint32_t *dwTcClks, uint32_t dwBoardMCK)
 Find best MCK divisor. More...
Purpose
Interface for configuring and using Timer Counter (TC) peripherals.
Usage
  1. Optionally, use TC_FindMckDivisor() to let the program find the best TCCLKS field value automatically.
  2. Configure a Timer Counter in the desired mode using TC_Configure().
  3. Start or stop the timer clock using TC_Start() and TC_Stop().
◆ TC_Configure()
void TC_Configure ( Tc pTc,
uint32_t  dwChannel,
uint32_t  dwMode
Configures a Timer Counter to operate in the given mode. Timer is stopped after configuration and must be restarted with TC_Start(). All the interrupts of the timer are also disabled.
Parameters
pTcPointer to a Tc instance.
channelChannel number.
modeOperating mode (TC_CMR value).
◆ TC_FindMckDivisor()
uint32_t TC_FindMckDivisor ( uint32_t  dwFreq,
uint32_t  dwMCk,
uint32_t *  dwDiv,
uint32_t *  dwTcClks,
uint32_t  dwBoardMCK
Finds the best MCK divisor given the timer frequency and MCK. The result is guaranteed to satisfy the following equation:
(MCK / (DIV * 65536)) <= freq <= (MCK / DIV)
with DIV being the highest possible value.
Parameters
dwFreqDesired timer frequency.
dwMCkMaster clock frequency.
dwDivDivisor value.
dwTcClksTCCLKS field value for divisor.
dwBoardMCKBoard clock frequency.
Returns
1 if a proper divisor has been found, otherwise 0.
◆ TC_Start()
void TC_Start ( Tc pTc,
uint32_t  dwChannel
Enables the timer clock and performs a software reset to start the counting.
Parameters
dwChannelChannel number.
◆ TC_Stop()
void TC_Stop ( Tc pTc,
uint32_t  dwChannel
Stop TC Channel.
Disables the timer clock, stopping the counting.
Parameters
