RTEMS 5.2-rc1
#include <rtl-obj.h>
Data Fields | |
| rtems_chain_node | node |
| size_t | dependents |
| rtems_rtl_obj * | depends [] |
Object file dependents. This is a list of tables of pointers to the object modules the object file depends on. The table is a list of tables because unresolved externals can exist when an object file is loaded and resolved later when the dependent object file is loaded.
| size_t rtems_rtl_obj_depends::dependents |
The number of dependent object pointers.
| rtems_rtl_obj* rtems_rtl_obj_depends::depends[] |
Dependtent objects. More follow.
| rtems_chain_node rtems_rtl_obj_depends::node |
The node's link in the chain.
