RTEMS 5.2-rc1
rtems_capture_from Struct Reference
Task id and mask for the from trigger. More...
#include <capture.h>
rtems_name name
rtems_id id
uint32_t trigger
A from capture is a task id and a mask for the type of from trigger we are interested in. The mask uses the same bit maps as the flags field in the control structure. There will only be a from type trigger if the flags in the control structure has the specific *_BY bit set.
