RTEMS 5.2-rc1
fxp_cb_config Struct Reference
void * fill [2]
volatile u_int16_t cb_status
volatile u_int16_t cb_command
volatile u_int32_t link_addr
volatile u_int byte_count:6
volatile u_int volatile u_int rx_fifo_limit:2:4
volatile u_int volatile u_int tx_fifo_limit:3
volatile u_int volatile u_int volatile u_int8_t adaptive_ifs:1
volatile u_int mwi_enable:1
volatile u_int type_enable:1
volatile u_int read_align_en:1
volatile u_int end_wr_on_cl:1
volatile u_int volatile u_int rx_dma_bytecount:4:7
volatile u_int volatile u_int volatile u_int tx_dma_bytecount:1:7
volatile u_int volatile u_int volatile u_int dma_mbce:1
volatile u_int late_scb:1
volatile u_int direct_dma_dis:1
volatile u_int tno_int_or_tco_en:1
volatile u_int ci_int:1
volatile u_int ext_txcb_dis:1
volatile u_int ext_stats_dis:1
volatile u_int keep_overrun_rx:1
volatile u_int save_bf:1
volatile u_int disc_short_rx:1
volatile u_int underrun_retry:2
volatile u_int two_frames:1
volatile u_int dyn_tbd:1
volatile u_int mediatype:1
volatile u_int csma_dis:1
volatile u_int tcp_udp_cksum:1
volatile u_int vlan_tco:1
volatile u_int link_wake_en:1
volatile u_int arp_wake_en:1
volatile u_int mc_wake_en:1
volatile u_int:3
volatile nsai:1
volatile preamble_length:2
volatile loopback:2
volatile u_int linear_priority:3
volatile u_int volatile u_int linear_pri_mode:5:1
volatile u_int volatile u_int interfrm_spacing:4
volatile u_int promiscuous:1
volatile u_int bcast_disable:1
volatile u_int wait_after_win:1
volatile u_int ignore_ul:1
volatile u_int crc16_en:1
volatile u_int crscdt:1
volatile u_int fc_delay_lsb:8
volatile u_int fc_delay_msb:8
volatile u_int stripping:1
volatile u_int padding:1
volatile u_int rcv_crc_xfer:1
volatile u_int long_rx_en:1
volatile u_int pri_fc_thresh:3
volatile u_int volatile u_int ia_wake_en:1:1
volatile u_int volatile u_int magic_pkt_dis:1
volatile u_int volatile u_int tx_fc_dis:1
volatile u_int volatile u_int rx_fc_restop:1
volatile u_int volatile u_int rx_fc_restart:1
volatile u_int volatile u_int fc_filter:1
volatile u_int volatile u_int force_fdx:1
volatile u_int volatile u_int fdx_pin_en:1
volatile pri_fc_loc:1
volatile multi_ia:1
volatile volatile u_int:1:3
volatile volatile mc_all:1
