RTEMS 5.2-rc1
if_fxpreg.h
1/*
2 * Copyright (c) 1995, David Greenman
3 * Copyright (c) 2001 Jonathan Lemon <jlemon@freebsd.org>
4 * All rights reserved.
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice unmodified, this list of conditions, and the following
11 * disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 *
16 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
17 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
20 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
21 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
22 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
23 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
24 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
25 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
26 * SUCH DAMAGE.
27 *
28 * $FreeBSD: src/sys/dev/fxp/if_fxpreg.h,v 1.23.2.4 2001/08/31 02:17:02 jlemon Exp $
29 */
30
31#define FXP_VENDORID_INTEL 0x8086
32
33#define FXP_PCI_MMBA 0x10
34#define FXP_PCI_IOBA 0x14
35
36/*
37 * Control/status registers.
38 */
39#define FXP_CSR_SCB_RUSCUS 0 /* scb_rus/scb_cus (1 byte) */
40#define FXP_CSR_SCB_STATACK 1 /* scb_statack (1 byte) */
41#define FXP_CSR_SCB_COMMAND 2 /* scb_command (1 byte) */
42#define FXP_CSR_SCB_INTRCNTL 3 /* scb_intrcntl (1 byte) */
43#define FXP_CSR_SCB_GENERAL 4 /* scb_general (4 bytes) */
44#define FXP_CSR_PORT 8 /* port (4 bytes) */
45#define FXP_CSR_FLASHCONTROL 12 /* flash control (2 bytes) */
46#define FXP_CSR_EEPROMCONTROL 14 /* eeprom control (2 bytes) */
47#define FXP_CSR_MDICONTROL 16 /* mdi control (4 bytes) */
48#define FXP_CSR_FLOWCONTROL 0x19 /* flow control (2 bytes) */
49#define FXP_CSR_GENCONTROL 0x1C /* general control (1 byte) */
50
51/*
52 * FOR REFERENCE ONLY, the old definition of FXP_CSR_SCB_RUSCUS:
53 *
54 * volatile u_int8_t :2,
55 * scb_rus:4,
56 * scb_cus:2;
57 */
58
59#define FXP_PORT_SOFTWARE_RESET 0
60#define FXP_PORT_SELFTEST 1
61#define FXP_PORT_SELECTIVE_RESET 2
62#define FXP_PORT_DUMP 3
63
64#define FXP_SCB_RUS_IDLE 0
65#define FXP_SCB_RUS_SUSPENDED 1
66#define FXP_SCB_RUS_NORESOURCES 2
67#define FXP_SCB_RUS_READY 4
68#define FXP_SCB_RUS_SUSP_NORBDS 9
69#define FXP_SCB_RUS_NORES_NORBDS 10
70#define FXP_SCB_RUS_READY_NORBDS 12
71
72#define FXP_SCB_CUS_IDLE 0
73#define FXP_SCB_CUS_SUSPENDED 1
74#define FXP_SCB_CUS_ACTIVE 2
75
76#define FXP_SCB_INTR_DISABLE 0x01 /* Disable all interrupts */
77#define FXP_SCB_INTR_SWI 0x02 /* Generate SWI */
78#define FXP_SCB_INTMASK_FCP 0x04
79#define FXP_SCB_INTMASK_ER 0x08
80#define FXP_SCB_INTMASK_RNR 0x10
81#define FXP_SCB_INTMASK_CNA 0x20
82#define FXP_SCB_INTMASK_FR 0x40
83#define FXP_SCB_INTMASK_CXTNO 0x80
84
85#define FXP_SCB_STATACK_FCP 0x01 /* Flow Control Pause */
86#define FXP_SCB_STATACK_ER 0x02 /* Early Receive */
87#define FXP_SCB_STATACK_SWI 0x04
88#define FXP_SCB_STATACK_MDI 0x08
89#define FXP_SCB_STATACK_RNR 0x10
90#define FXP_SCB_STATACK_CNA 0x20
91#define FXP_SCB_STATACK_FR 0x40
92#define FXP_SCB_STATACK_CXTNO 0x80
93
94#define FXP_SCB_COMMAND_CU_NOP 0x00
95#define FXP_SCB_COMMAND_CU_START 0x10
96#define FXP_SCB_COMMAND_CU_RESUME 0x20
97#define FXP_SCB_COMMAND_CU_DUMP_ADR 0x40
98#define FXP_SCB_COMMAND_CU_DUMP 0x50
99#define FXP_SCB_COMMAND_CU_BASE 0x60
100#define FXP_SCB_COMMAND_CU_DUMPRESET 0x70
101
102#define FXP_SCB_COMMAND_RU_NOP 0
103#define FXP_SCB_COMMAND_RU_START 1
104#define FXP_SCB_COMMAND_RU_RESUME 2
105#define FXP_SCB_COMMAND_RU_ABORT 4
106#define FXP_SCB_COMMAND_RU_LOADHDS 5
107#define FXP_SCB_COMMAND_RU_BASE 6
108#define FXP_SCB_COMMAND_RU_RBDRESUME 7
109
110/*
111 * Command block definitions
112 */
114 void *fill[2];
115 volatile u_int16_t cb_status;
116 volatile u_int16_t cb_command;
117 volatile u_int32_t link_addr;
118};
120 void *fill[2];
121 volatile u_int16_t cb_status;
122 volatile u_int16_t cb_command;
123 volatile u_int32_t link_addr;
124 volatile u_int8_t macaddr[6];
125};
126/* I hate bit-fields :-( */
128 void *fill[2];
129 volatile u_int16_t cb_status;
130 volatile u_int16_t cb_command;
131 volatile u_int32_t link_addr;
132 volatile u_int byte_count:6,
133 :2;
134 volatile u_int rx_fifo_limit:4,
135 tx_fifo_limit:3,
136 :1;
137 volatile u_int8_t adaptive_ifs;
138 volatile u_int mwi_enable:1, /* 8,9 */
139 type_enable:1, /* 8,9 */
140 read_align_en:1, /* 8,9 */
141 end_wr_on_cl:1, /* 8,9 */
142 :4;
143 volatile u_int rx_dma_bytecount:7,
144 :1;
145 volatile u_int tx_dma_bytecount:7,
146 dma_mbce:1;
147 volatile u_int late_scb:1, /* 7 */
148 direct_dma_dis:1, /* 8,9 */
149 tno_int_or_tco_en:1, /* 7,9 */
150 ci_int:1,
151 ext_txcb_dis:1, /* 8,9 */
152 ext_stats_dis:1, /* 8,9 */
153 keep_overrun_rx:1,
154 save_bf:1;
155 volatile u_int disc_short_rx:1,
156 underrun_retry:2,
157 :3,
158 two_frames:1, /* 8,9 */
159 dyn_tbd:1; /* 8,9 */
160 volatile u_int mediatype:1, /* 7 */
161 :6,
162 csma_dis:1; /* 8,9 */
163 volatile u_int tcp_udp_cksum:1, /* 9 */
164 :3,
165 vlan_tco:1, /* 8,9 */
166 link_wake_en:1, /* 8,9 */
167 arp_wake_en:1, /* 8 */
168 mc_wake_en:1; /* 8 */
169 volatile u_int :3,
170 nsai:1,
171 preamble_length:2,
172 loopback:2;
173 volatile u_int linear_priority:3, /* 7 */
174 :5;
175 volatile u_int linear_pri_mode:1, /* 7 */
176 :3,
177 interfrm_spacing:4;
178 volatile u_int :8;
179 volatile u_int :8;
180 volatile u_int promiscuous:1,
181 bcast_disable:1,
182 wait_after_win:1, /* 8,9 */
183 :1,
184 ignore_ul:1, /* 8,9 */
185 crc16_en:1, /* 9 */
186 :1,
187 crscdt:1;
188 volatile u_int fc_delay_lsb:8; /* 8,9 */
189 volatile u_int fc_delay_msb:8; /* 8,9 */
190 volatile u_int stripping:1,
191 padding:1,
192 rcv_crc_xfer:1,
193 long_rx_en:1, /* 8,9 */
194 pri_fc_thresh:3, /* 8,9 */
195 :1;
196 volatile u_int ia_wake_en:1, /* 8 */
197 magic_pkt_dis:1, /* 8,9,!9ER */
198 tx_fc_dis:1, /* 8,9 */
199 rx_fc_restop:1, /* 8,9 */
200 rx_fc_restart:1, /* 8,9 */
201 fc_filter:1, /* 8,9 */
202 force_fdx:1,
203 fdx_pin_en:1;
204 volatile u_int :5,
205 pri_fc_loc:1, /* 8,9 */
206 multi_ia:1,
207 :1;
208 volatile u_int :3,
209 mc_all:1,
210 :4;
211};
212
213#define MAXMCADDR 80
215 struct fxp_cb_tx *next;
216 struct mbuf *mb_head;
217 volatile u_int16_t cb_status;
218 volatile u_int16_t cb_command;
219 volatile u_int32_t link_addr;
220 volatile u_int16_t mc_cnt;
221 volatile u_int8_t mc_addr[MAXMCADDR][6];
222};
223
224/*
225 * Number of DMA segments in a TxCB. Note that this is carefully
226 * chosen to make the total struct size an even power of two. It's
227 * critical that no TxCB be split across a page boundry since
228 * no attempt is made to allocate physically contiguous memory.
229 *
230 */
231#ifdef __alpha__ /* XXX - should be conditional on pointer size */
232#define FXP_NTXSEG 28
233#else
234#define FXP_NTXSEG 29
235#endif
236
237struct fxp_tbd {
238 volatile u_int32_t tb_addr;
239 volatile u_int32_t tb_size;
240};
241struct fxp_cb_tx {
242 struct fxp_cb_tx *next;
243 struct mbuf *mb_head;
244 volatile u_int16_t cb_status;
245 volatile u_int16_t cb_command;
246 volatile u_int32_t link_addr;
247 volatile u_int32_t tbd_array_addr;
248 volatile u_int16_t byte_count;
249 volatile u_int8_t tx_threshold;
250 volatile u_int8_t tbd_number;
251 /*
252 * The following structure isn't actually part of the TxCB,
253 * unless the extended TxCB feature is being used. In this
254 * case, the first two elements of the structure below are
255 * fetched along with the TxCB.
256 */
257 volatile struct fxp_tbd tbd[FXP_NTXSEG];
258};
259
260/*
261 * Control Block (CB) definitions
262 */
263
264/* status */
265#define FXP_CB_STATUS_OK 0x2000
266#define FXP_CB_STATUS_C 0x8000
267/* commands */
268#define FXP_CB_COMMAND_NOP 0x0
269#define FXP_CB_COMMAND_IAS 0x1
270#define FXP_CB_COMMAND_CONFIG 0x2
271#define FXP_CB_COMMAND_MCAS 0x3
272#define FXP_CB_COMMAND_XMIT 0x4
273#define FXP_CB_COMMAND_RESRV 0x5
274#define FXP_CB_COMMAND_DUMP 0x6
275#define FXP_CB_COMMAND_DIAG 0x7
276/* command flags */
277#define FXP_CB_COMMAND_SF 0x0008 /* simple/flexible mode */
278#define FXP_CB_COMMAND_I 0x2000 /* generate interrupt on completion */
279#define FXP_CB_COMMAND_S 0x4000 /* suspend on completion */
280#define FXP_CB_COMMAND_EL 0x8000 /* end of list */
281
282/*
283 * RFA definitions
284 */
285
286struct fxp_rfa {
287 volatile u_int16_t rfa_status;
288 volatile u_int16_t rfa_control;
289 volatile u_int8_t link_addr[4];
290 volatile u_int8_t rbd_addr[4];
291 volatile u_int16_t actual_size;
292 volatile u_int16_t size;
293};
294#define FXP_RFA_STATUS_RCOL 0x0001 /* receive collision */
295#define FXP_RFA_STATUS_IAMATCH 0x0002 /* 0 = matches station address */
296#define FXP_RFA_STATUS_S4 0x0010 /* receive error from PHY */
297#define FXP_RFA_STATUS_TL 0x0020 /* type/length */
298#define FXP_RFA_STATUS_FTS 0x0080 /* frame too short */
299#define FXP_RFA_STATUS_OVERRUN 0x0100 /* DMA overrun */
300#define FXP_RFA_STATUS_RNR 0x0200 /* no resources */
301#define FXP_RFA_STATUS_ALIGN 0x0400 /* alignment error */
302#define FXP_RFA_STATUS_CRC 0x0800 /* CRC error */
303#define FXP_RFA_STATUS_OK 0x2000 /* packet received okay */
304#define FXP_RFA_STATUS_C 0x8000 /* packet reception complete */
305#define FXP_RFA_CONTROL_SF 0x08 /* simple/flexible memory mode */
306#define FXP_RFA_CONTROL_H 0x10 /* header RFD */
307#define FXP_RFA_CONTROL_S 0x4000 /* suspend after reception */
308#define FXP_RFA_CONTROL_EL 0x8000 /* end of list */
309
310/*
311 * Statistics dump area definitions
312 */
313struct fxp_stats {
314 volatile u_int32_t tx_good;
315 volatile u_int32_t tx_maxcols;
316 volatile u_int32_t tx_latecols;
317 volatile u_int32_t tx_underruns;
318 volatile u_int32_t tx_lostcrs;
319 volatile u_int32_t tx_deffered;
320 volatile u_int32_t tx_single_collisions;
321 volatile u_int32_t tx_multiple_collisions;
322 volatile u_int32_t tx_total_collisions;
323 volatile u_int32_t rx_good;
324 volatile u_int32_t rx_crc_errors;
325 volatile u_int32_t rx_alignment_errors;
326 volatile u_int32_t rx_rnr_errors;
327 volatile u_int32_t rx_overrun_errors;
328 volatile u_int32_t rx_cdt_errors;
329 volatile u_int32_t rx_shortframes;
330 volatile u_int32_t completion_status;
331};
332#define FXP_STATS_DUMP_COMPLETE 0xa005
333#define FXP_STATS_DR_COMPLETE 0xa007
334
335/*
336 * Serial EEPROM control register bits
337 */
338#define FXP_EEPROM_EESK 0x01 /* shift clock */
339#define FXP_EEPROM_EECS 0x02 /* chip select */
340#define FXP_EEPROM_EEDI 0x04 /* data in */
341#define FXP_EEPROM_EEDO 0x08 /* data out */
342
343/*
344 * Serial EEPROM opcodes, including start bit
345 */
346#define FXP_EEPROM_OPC_ERASE 0x4
347#define FXP_EEPROM_OPC_WRITE 0x5
348#define FXP_EEPROM_OPC_READ 0x6
349
350/*
351 * Management Data Interface opcodes
352 */
353#define FXP_MDI_WRITE 0x1
354#define FXP_MDI_READ 0x2
355
356/*
357 * PHY device types
358 */
359#define FXP_PHY_DEVICE_MASK 0x3f00
360#define FXP_PHY_SERIAL_ONLY 0x8000
361#define FXP_PHY_NONE 0
362#define FXP_PHY_82553A 1
363#define FXP_PHY_82553C 2
364#define FXP_PHY_82503 3
365#define FXP_PHY_DP83840 4
366#define FXP_PHY_80C240 5
367#define FXP_PHY_80C24 6
368#define FXP_PHY_82555 7
369#define FXP_PHY_DP83840A 10
370#define FXP_PHY_82555B 11
Definition: if_fxpreg.h:127
Definition: if_fxpreg.h:119
Definition: if_fxpreg.h:214
Definition: if_fxpreg.h:113
Definition: if_fxpreg.h:241
Definition: if_fxpreg.h:286
Definition: if_fxpreg.h:313
Definition: if_fxpreg.h:237
