RTEMS 5.2-rc1
struct {
   uint32_t   pad:24
   uint32_t   tid:8
id
struct {
   uint32_t   epn:22
   uint32_t   size:3
   uint32_t   v:1
   uint32_t   att:2
   uint32_t   pad:4
hi
struct {
   uint32_t   rpn:22
   uint32_t   perm:6
   uint32_t   wimg:4
lo
struct {
   uint32_t   pad:24
   uint32_t   tid:8
id
struct {
   uint32_t   epn:22
   uint32_t   v:1
   uint32_t   ts:1
   uint32_t   size:4
   uint32_t   tpar:4
w0
struct {
   uint32_t   rpn:22
   uint32_t   par1:2
   uint32_t   pad:4
   uint32_t   erpn:4
w1
struct {
   uint32_t   par2:2
   uint32_t   pad1:14
   uint32_t   att:4
   uint32_t   wimge:5
   uint32_t   pad2:1
   uint32_t   perm:6
w2
Field Documentation
◆ att
uint32_t bsp_tlb_entry_t::att
Valid
struct { ... } bsp_tlb_entry_t::lo
High word
◆ pad
uint32_t bsp_tlb_entry_t::pad
Little-endian, User-defined
For matching the TLB array parity
◆ pad1
uint32_t bsp_tlb_entry_t::pad1
Parity for TLB word 2
◆ pad2
uint32_t bsp_tlb_entry_t::pad2
Write-Through/Caching Inhibited/Memory Coherent/Guarded/Endian
◆ par1
uint32_t bsp_tlb_entry_t::par1
The real (translated) page number.
◆ perm
uint32_t bsp_tlb_entry_t::perm
Real page number
◆ size
uint32_t bsp_tlb_entry_t::size
Effective page number
Translation Address Space
◆ tpar
uint32_t bsp_tlb_entry_t::tpar
Page size
◆ ts
uint32_t bsp_tlb_entry_t::ts
Valid
◆ v
uint32_t bsp_tlb_entry_t::v
Page size
◆ wimg
uint32_t bsp_tlb_entry_t::wimg
Execute enable, Write-enable, Zone select
◆ wimge
uint32_t bsp_tlb_entry_t::wimge
User-defined attributes
The documentation for this struct was generated from the following files:
