RTEMS 5.2-rc1
_rtems_rfs_inode_handle Struct Reference
#include <rtems-rfs-inode.h>
rtems_chain_node link
rtems_rfs_ino ino
rtems_rfs_inodenode
rtems_rfs_buffer_handle buffer
rtems_rfs_buffer_block block
int offset
int loads
RFS Inode Handle.
Field Documentation
◆ block
rtems_rfs_buffer_block _rtems_rfs_inode_handle::block
The block number that holds the inode.
◆ buffer
rtems_rfs_buffer_handle _rtems_rfs_inode_handle::buffer
The buffer that contains this inode.
◆ ino
rtems_rfs_ino _rtems_rfs_inode_handle::ino
The ino for this handle.
◆ link
rtems_chain_node _rtems_rfs_inode_handle::link
Handles can be linked as a list for easy processing.
◆ loads
int _rtems_rfs_inode_handle::loads
Number of load requests.
◆ node
rtems_rfs_inode* _rtems_rfs_inode_handle::node
The pointer to the inode.
◆ offset
int _rtems_rfs_inode_handle::offset
The offset into the block for the inode.
