RTEMS 5.2-rc1
Partition_Control Struct Reference
#include <partdata.h>
Objects_Control Object
void * starting_address
uintptr_t length
size_t buffer_size
rtems_attribute attribute_set
uintptr_t number_of_used_blocks
Chain_Control Memory
The following defines the control block used to manage each partition.
Field Documentation
◆ attribute_set
rtems_attribute Partition_Control::attribute_set
This field is the attribute set provided at create time.
◆ buffer_size
size_t Partition_Control::buffer_size
This field is the size of each buffer in bytes
◆ length
uintptr_t Partition_Control::length
This field is the size of the Partition in bytes.
◆ Memory
Chain_Control Partition_Control::Memory
This field is the chain used to manage unallocated buffers.
◆ number_of_used_blocks
uintptr_t Partition_Control::number_of_used_blocks
This field is the of allocated buffers.
◆ Object
Objects_Control Partition_Control::Object
This field is the object management portion of a Partition instance.
◆ starting_address
void* Partition_Control::starting_address
This field is the lock of the Partition. This field is the physical starting address of the Partition.
